When I plot someting in Maple17, it appears in a small square window that's horizontally centered.  I want to be able to create plots that appear larger.  There's plently of space on the screen for plots to be much larger.
Yes, I know I can grab the corner of a plot and drag it to make it bigger.  That's not what I want (that takes time, and it's tricky to maintain the aspect ratio).  I want the plot to appear large when I execute the plotting command.
I've searched for answers both on Google and mapleprimes, and come up empty.
If I have the following system of first order diff eq's:
x'(t)=2x(t)+3y(t)
y(t)=-3x(t)-2y(t)
then can I consider the coefficient matrix A=<<2,-3>,<3,-2>> and compute the eigenvalues of A and infer as follows:
if the eigenvalues are of the same sign- eq point is a node
if they are of opposite signs- eq point is a saddle
if they are pure imaginary- eq point is a center
if they are complex conjugates- eq. point is a spiral
I've been given these conditions but my text says for a linear system of the form x'=Ax, the eigenvalues of A can be used to identify the nature of the eq. point. I am confused as to whether this applies to the given system as well; I have obtained 5 different trajectories and drawn the phase diagram for the system
I have the following :
with(powseries):
difeq:=diff(y(x),x,x)+x*y=0;
icval:=y(0)=1,D(y)(0)=0;
pow_soln:=powsolve({difeq,icval});
tpsform(pow_soln,x,30);
pow_soln(_k);
for which the  transformed power series
is : 1 -(1/6)y*(x^3)
and pow_soln(_k) returns 0. What does this mean?
What is the best way to solve for the simple equation X^2+y^2=1[m]^2 symbolically for either x or y? I actually have a huge list of equations and want to solve the group but my problem boils down to the issue here where I get two possible solutions though using the assumption one is clearly negative and the assumption used should exclude negative results (see attempt below). Also solve doesn't seem to work with units either...  any ideas? Can I give the variables units in a meaningful way?
with(RealDomain);
f := x^2+y^2 = 1;
                            x^2+y^2 = 1
assume(y > 0)
a := y > 0
y1 = solve(f, y, useassumptions = true)
                          y1 = (sqrt(-x^2+1), -sqrt(-x^2+1))
y2 = solve({a, f}, y)
                          y2 = ({y = sqrt(-x^2+1)}, {y = -sqrt(-x^2+1)})
Why is y = -sqrt(-x^2+1) a solution?
Also, how do I use units when trying to solve
f := x^2+y^2 = Unit('m')^2;
assume(x > 0);
assume(y > 0);
d = solve(f, y, useassumptions = true);
Error, (in Units:-Standard:-+) the units `m^2` and `1` have incompatible dimensions
THANKS!
My assignment is to plot 3 graphs when u0=65.70 and 95 and I thought I did my code properly but now I am getting weird errors
a0:=80;
a1:=-5;
b1:=-5*(3)^0.5;
w:=Pi/12;
k:=0.2;
u0:=65;
t=0:0.001:100;
c0=u0-a0-(k^2*a1-k*w*b1)/(k^2+w^2);
c1=(k^2*a1-k*w*b1)/(k^2+w^2);
d1=(k*w*a1+k^2*b1)/(k^2+w^2);
u=a0+c0*exp(-k*t)+c1*cos(w*t)+d1*sin(w*t);
plot(t,u,'r');
I am getting an error here that says Error, (in plot) unexpected options: [65., r] and I don't know how to fix this
legend('u(0)=65');
hold on;
u0=70;
plot(t,u,'-');
I am also getting an error with the '-' portion of my plot "Error, invalid uneval"
legend('u(0)=70');
hold on;
u0=95;
plot(t,u,'g');
I am getting an error yet again with my plot and this time it is "Warning, expecting only range variable u in expression t to be plotted but found name t"
legend('u(0)=90');
I am new to maple, having recently made the switch from mathCAD, and I am having problems getting the basics to do what I think they ought to be doing.
I am trying to get maple to go step by step through a derivation of a formula. In one line I define a variable
U4 := expression
In the next line I will call the same variable and take the derivative of it. Sometimes it works and sometimes it evaluates to zero when it should not. I can't seem to pin down a pattern of when it does and does not work. I will change something that is not working, and then change it back, and it will work. Am i assigning my variables inconsistently?
I took a screencapture of the worksheet in question. Thanks in advance for the help.
Screen shot
****** My question *****
for k from 0 to n do    # n is any integer.
func := f(x):             # func is any funciton of x.
D := diff(func, x$k);   # The maple don't allow to uses k but I want to diff k-th order in each k-loop.
end do;                    # How to diff func for k-th times in each k-loop.
Hello guys,
I am stuck with the following code. I cannot get a solution. Mapple doesn't even run. Please help, I am in urgent need on help!!!
Compared to Maple on Windows, how do ppl like Maple on Macs ?
Any comments ??
Thanks, cheers !
I'm trying to solve a system of four pdes and I know that the Newton method won't converge.
Are there other numerical methods that I can use?
Any help would be greatly appreciated!
Eve
I'm an industrial engineering student who's running into problems with solving a simple system of non-linear equations.
Why do I get this error when issuing the solve command? I'm pretty sure I'm only passing two lists into the function?
Thanks a lot in advance,
Joshua
Is there any way to remove the empty space that comes under images when printing the project, while using document mode?
Nicolai
Please fix the MapleCloud service. Is no longer working. E uploaded jobs and are not shown. Fix it please.
I have a matrix A for which the basis of the left null space using NullSpace() is the empty set {}  while the column space is {e1,e2,e3}. By definition, we need every vector in col space . every vector in basis of left null space =0 but how would I show that in this case? Can I determine another basis for the left null space?
Hi everyone! I need to weight a serie of values which x1 range go from 280 to 4000 by the factors provided by another serie of values, which x2 values go from 206.6 to 12400. In the graphs, the red curve is a listplot of the serie which y1 values I want to weight by the y2 values of the listplot of the serie in black. I want the resulting serie in the x1 range, but with the y3 values equal to y2*y1. How can I do that since the series have different intervals?
Serie in red=S and serie in black=t
S:=
...[417., .96392], [418., .92392], [419., .96354], [420., .88467], [421., 1.0067], [422., .99499], [423., .96531], [424., .96182], [425., .99312], [426., .96667], [427., .9355], [428., .94625], [429., .87766], [430., .70134], [431., .63779], [432., 1.0628], [433., .9905], [434., .91653], [435., 1.007], [436., 1.1061], [437., 1.1306], [438., .99368], [439., .95753], [440., 1.0993], [441., 1.0859], [442., 1.164], [443., 1.1823], [444., 1.1537], [445., 1.1992], [446., 1.0766], [447., 1.2257], [448., 1.2422], [449., 1.2409], [450., 1.2881], [451., 1.3376], [452., 1.2822], [453., 1.1854], [454., 1.273], [455., 1.2655], [456., 1.3088], [457., 1.3213], [458., 1.2946], [459., 1.2859], [460., 1.2791], [461., 1.3255], [462., 1.3392], [463., 1.3452], [464., 1.3055], [465., 1.2905], [466., 1.319], [467., 1.2616], [468., 1.3178], [469., 1.3247], [470., 1.2749], [471., 1.2975], [472., 1.3661], [473., 1.3144], [474., 1.3304], [475., 1.3755], [476., 1.3299], [477., 1.3392], [478., 1.3839], [479., 1.3586], [480., 1.3825], [481., 1.3836], [482., 1.3899], [483., 1.3742], [484., 1.3492], [485., 1.3457], [486., 1.0918], [487., 1.2235], [488., 1.3252], [489., 1.2492], [490., 1.3968], [491., 1.3435], [492., 1.2818], [493., 1.3719], [494., 1.3402], [495., 1.4238], [496., 1.3548], [497., 1.3788], [498., 1.3421], [499., 1.3429], [500., 1.3391], [501., 1.299], [502., 1.2991], [503., 1.3597], [504., 1.2682], [505., 1.3598], [506., 1.4153], [507., 1.3548], [508., 1.321], [509., 1.385], [510., 1.3497], [511., 1.3753], [512., 1.4125], [513., 1.3277], [514., 1.3003], [515., 1.3385], [516., 1.3514], [517., 1.1017], [518., 1.2605], [519., 1.2222], [520., 1.3349], [521., 1.3452], [522., 1.376], [523., 1.2976], [524., 1.3962], [525., 1.3859], [526., 1.3479], [527., 1.1795], [528., 1.3508], [529., 1.4142], [530., 1.3598], [531., 1.4348], [532., 1.4094], [533., 1.259], [534., 1.3491], [535., 1.3701], [536., 1.4292], [537., 1.3229], [538., 1.3896], [539., 1.3558], [540., 1.3096], [541., 1.2595], [542., 1.3714], [543., 1.3493], [544., 1.3971], [545., 1.3657], [546., 1.3536], [547., 1.3717], [548., 1.3331], [549., 1.3752], [550., 1.3648], [551., 1.3639], [552., 1.3923], [553., 1.3533], [554., 1.3802], [555., 1.3883], [556., 1.3651], [557., 1.3321], [558., 1.3613], [559., 1.2885], [560., 1.3118], [561., 1.3885], [562., 1.3225], [563., 1.3731], [564., 1.3466], [565., 1.3555], [566., 1.2823], [567., 1.3673], [568., 1.3554], [569., 1.3228], [570., 1.324], [571., 1.281], [572., 1.3534], [573., 1.3595], [574., 1.3527], [575., 1.3225], [576., 1.3118]...
t:=
[[206.6000, 0.9110470095e-3], [210.1000, 0.8504840202e-3], [213.8000, 0.8153191021e-3], [217.5000, 0.7517070516e-3], [221.4000, 0.7035057451e-3], [225.4000, 0.6694785180e-3], [229.6000, 0.6318423899e-3], [233.9000, 0.5994622965e-3], [238.4000, 0.5764355678e-3], [243.1000, 0.5331430203e-3], [248.0000, 0.4950946716e-3], [253.0000, 0.4422658739e-3], [258.3000, 0.4023846661e-3], [263.8000, 0.3732428357e-3], [269.5000, 0.3444825682e-3], [275.5000, 0.3307336604e-3], [281.8000, 0.3570645679e-3], [288.3000, 0.4052774535e-3], [295.2000, 0.4741877081e-3], [302.4000, 0.5345931300e-3], [310.0000, 0.6002211844e-3], [317.9000, 0.7217256785e-3], [326.3000, 0.9176207886e-3], [335.1000, 0.1271492339e-2], [344.4000, 0.1679935813e-2], [354.2000, 0.1976514731e-2], [364.7000, 0.2169413297e-2], [375.7000, 0.2420056977e-2], [387.5000, 0.2698356864e-2], [399.9000, 0.3092320191e-2], [413.3000, 0.3891714441e-2], [427.5000, 0.4875961623e-2], [442.8000, 0.6098167657e-2], [459.2000, 0.8645631738e-2], [476.9000, 0.1639763449e-1], [495.9000, 0.1611551307e-1], [516.6000, 0.1102654621e-1], [539.1000, 0.5287562153e-2], [563.6000, 0.3253578980e-2], [590.4000, 0.2176718340e-2], [619.9000, 0.1510939515e-2], [652.5000, 0.1117755662e-2], [688.8000, 0.8568924681e-3], [729.3000, 0.6693019750e-3], [774.9000, 0.5484788449e-3], [826.6000, 0.4632457834e-3], [885.6000, 0.3982461677e-3], [953.7000, 0.3505755460e-3], [1033.000, 0.3130972421e-3], [1127.000, 0.2814970511e-3], [1240.000, 0.2609345123e-3], [1305.000, 0.2500612658e-3], [1378.000, 0.2397447628e-3], [1459.000, 0.2312899569e-3], [1550.000, 0.2268792462e-3], [1653.000, 0.2197119097e-3], [1771.000, 0.2106962051e-3], [1907.000, 0.2046935228e-3], [2066.000, 0.2003490235e-3], [2254.000, 0.1974613611e-3], [2480.000, 0.1948841680e-3], [2755.000, 0.1957355188e-3], [3100.000, 0.1937027704e-3], [3542.000, 0.1867538618e-3], [4133.000, 0.1849393481e-3], [4959.000, 0.1835339010e-3], [6199.000, 0.1838769393e-3], [8266.000, 0.1869179329e-3], [12400.00, 0.1990760933e-3]]
First 1340 1341 1342 1343 1344 1345 1346 Last Page 1342 of 2459
