Can anyone coax Maple to solve this reccurence relation? It seems harmless enough but Maple is struggng a bit with "hypergeomsols."
f := c -> (2*n-c)*f(c-1) - (c-1)*n*f(c-2);
f(0) := 1;
f(1) := 2*n-1;
Determine using determinants the range of values of a (if any) such that
f(x,y,z)=4x^2+y^2+2z^2+2axy-4xz+2yz
has a minimum at (0,0,0).
From the theory, I understand that if the matrix corresponding to the coefficients of the function is positive definite, the function has a local min at the point. But, how do I get the range of values of a such that f is a min? Is this equivalent to finding a such that det(A) > 0?
2.
Now modify the function to also involve a parameter b: g(x,y,z)=bx^2+2axy+by^2+4xz-2a^2yz+2bz^2. We determine conditions on a and b such that g has a minimum at (0,0,0).
By plotting each determinant (using implicitplot perhaps, we can identify the region in the (a,b) plane where g has a local minimum.
Which region corresponds to a local minimum?
Now determine region(s) in the (a,b) plane where g has a local maximum.
I don't understand this part at all..
I've got the following matrix :
A:=[<a,a-1,-b>|<a-1,a,-b>,<b,b,2a-1>] where <> are the column elements of A, a is  a real number defined on [0,1] and b^2=2a(1-a)
a) to show A is an orthogonal matrix, I understand that I need A.Transpose(A)=Identity(3*3) but is there a way in which I can let a take a random real numbered value between 0 and 1? The rand() only returns an integer within a range. Directly multiplying A and Transpose(A) will return an expression in a, so what's the right approach?
b) from a) we can infer that A is a matrix that describes a rotation in e1,e2,e3 where these are the standard bases vectors in R3. How can I determine the rotation axis? The hint I've been given says I need to consider the Eigenvalues and eigen vectors but I don't quite understand how.
I have the function:   f(x,y) = 1/(sqrt(2*Pi)) * e-1/2(x^2+y^2)
I need to take the total derivative of this function in maple, but I don't know the syntax.
When plotting a continous function that looks something like a square wave, for example like this:
f:=x->piecewise(0<x<Pi,0,Pi<x<2*Pi,Pi);
a:=0: b:=2*Pi: p:=b-a:
fp:=f(x-floor( (x-a)/p)*p);
plot(fp,x=-6*Pi..6*Pi,discont=true);
Is there some way to show dashed vertical lines at the points of discontinuity?
So i got a procedure test, she is kind of numeric, i whant to optimaze test([.5, .5, .5], 1, 3, 100, 100, true, [x, 0, 0, 0, 0])=0 by x. But optinization substitutes x like a symbol, i tryed all methods but they all do the same.
f := proc (x) options operator, arrow; abs(test([.5, .5, .5], 1, 3, 100, 100, true, [x, 0, 0, 0, 0])-.4) end proc; Minimize(f(x));
Error, (in test) cannot determine if this expression is true or false: 0 < -43.0+100*x
Can i some how use optinization on such procedure?
file link  - >    primset.mw
A created an overly complicated worksheet thaI can no longer open.  It's about 17 Mb, has several interactive plots and equations in it.  Is there a way to force Maple to open a worksheet without executing it?
(Lesson learned:  split this up into separate worksheets next time.)
I wish to use closed Newton-Cotes with n=2, also known as Simpson's Rule to numerically integrate an improper integral.
If it matters the integrand is (cos(2x))/(x^1/3), integrating between x=0..1
I've tried a few different (but similar) code but to no avail. Here is some stuff I've tried:
1.
with(Student[NumericalAnalysis]):
with(Student[Calculus 1]):
Simp1 := ApproximateInt(cos(2*x)/x^(1/3), x = 0 .. 1, method = newtoncotes[2]);
This gives me an output message that says "Float(infinity)".
2.
Simp2 := int(exp(-x)/sqrt(1-x), x = 0 .. 1);
This doesn't have Simpson's rule as an option.
I think I'm on the right track with my first try, since I guess it wasn't tecnically an error message, but I'm not sure how to alter the code accordingly to get a numerical value instead. Thanks for any help.
I am trying to numerically double integrate x^2+sqrt(y), with the bounds y=0..x and x=1..1.5.
Then I tried the following code:
int(int(x^2+sqrt(y),method=trapezoid,y=0..x),method=trapezoid,x=1..1.5);
I know how to write the code if instead of a 'x' in my upper limit for my integral, I had a real number, but I'm not sure how to remedy to code in order make it work. Any help would be appreciated. Thanks!
with(ODETools):
eqn1 := ((diff(f4(r), r))*r-f4(r)*f1(r)+f4(r))/(f4(r)*r^2) = 0
eqn4 := f4(r)*(r*(diff(f1(r), r))+f1(r)^2-f1(r))/(f1(r)^2*r^2) = 2*m*Dirac(r)*f4(r)/r^2
dsolve({eqn1, eqn4})
[{-(2*Dirac(r)*(diff(f4(r), r))^2*m*r^2+4*Dirac(r)*(diff(f4(r), r))*f4(r)*m*r+2*Dirac(r)*f4(r)^2*m-f4(r)*(diff(diff(f4(r), r), r))*r^2-2*(diff(f4(r), r))*r*f4(r))/f4(r) = 0}, {f1(r) = ((diff(f4(r), r))*r+f4(r))/f4(r)}]
When I try to solve this system of ODE, Maple does not factor out f4(r) in eqn4.  How do I get Maple to solve eqn4? So that I can get the correct result for f1(r) below:
dsolve((r*(diff(f1(r), r))+f1(r)^2-f1(r))/(f1(r)^2*r^2) = 2*m*Dirac(r)/r^2)
f1(r) = -r/(2*m*Heaviside(r)-_C1-r)
Download dsolve_question.mw
I got the Real and Imaginary of an expression J1
assume(d,real):
Gamma:=0.04:tau:=10*Pi:j:=0:
J1:=(exp((1-I*d)*Gamma*tau)-1)/((1-I*d));
J1mod:=simplify((Re(J1))^2+(Im(J1))^2): (I works here this amont is real)
but when I change the expression  for J1 to be
J1:=((2*e^(-2^(-j-1)*(1-I*d))-e^(-2^(-j)*(1-I*d))-1)*exp((1-I*d)*Gamma*tau)-1)/((1-I*d)):
J1mod here is complex(I dont know why? it doesnt separate the real and the im )
Any comments will help
Hello everybody,
can somebody tell me how to use subscripts in textmode?
Thanks for your help!
Picard
OK, what am I doing wrong here?
This polynomial can be factored by almost anyone who knows algebra:
factor(x^2+y^2+2*xy);
but Maple refuses:
 x2  + y2  + 2 xy
but if I pose the question this way:
ans := expand((x+y)^2);
factor(ans);
(x + y)2
I get the expected result.  What is wrong with how I am using the factor?
If we have a piecewise continous 2*Pi-periodic function
h(t)=e^(2*t) when 0 < t < 2*Pi
How can we plot it? It should look something like this:
Periodic plot
I.e. I want to be able to just set an interval and then it automatically plots the function with the specified periodicity.
I am new to maple. I want to write the following codes in Maple in a file and execute it. I am writing the code in matlab. thanks
for i =1:1:5
for j=1:1:5
M(i,j)=i+j;
end
end
First 1341 1342 1343 1344 1345 1346 1347 Last Page 1343 of 2459
