Dear Maple users
I have a question which is maybe easily solved, but I cannot seem to find the solution myself. A vector X of coefficients has been computed earlier in the Maple document and I want these coefficients placed in front of some written symbols in order to make Maple display the final result in a nice way. I made an attempt with the Vector command as shown in the image, but I cannot make the indices start at -2. In addition I want some written math placed in front of the expression. In fact I want it displayed like shown on the image marked with a red rectangle. I did write this manually, but want Maple to do it automatically when given the coefficients vector calculated earlier. I hope someone can help me here!
(It is about finite difference methods, by the way)
Erik
How to numerically solve the problem
with Maple? Such type problems arise in elasticity theory (for example, see https://zbmath.org/?q=an:01366371).
Edit. Typo in the code:sin(y(x)) instead of sin(x).
How I can get a list of all label refernces of a worksheet. In fact I want to write a small code which would produce the LaTex output (written to a text file) for my indicated labels. thanx
I've got the following double integral over a region A:
e^(1/x*y)/(y^2)*(x+1)^2 where A={(x,y):1/2<=x*y<=2,1<=x<=3}
to evaluate this:
I've tried :
int6:=int(int(e^(1/x*y)/((y^2)*(x+1)^2),x=1..3),y=(1/2)..(2/3));
since the largest lower bound and smallest upper bound for y based on 1/2<=xy<=2 are 1/2 and 2/3 respectively.
This statement however, only evaluates the inner integral; is my approach correct?
I've got a function y(x) that is initially defined as x^3+y^3=1 and need to plot it, and find y',y''.
At present, I've used implicitplot(x^3+y^3=1,x=0..5,y=0..5) to plot it, but that doesnt seem to work. Also, to find y'
I've used the statement
implicitdiff(g(x,y),y(x),x) where g:=(x,y)->x^3+y^3=1 but this gives me an error that my input is invalid; y(x) is expected to be of the form {(name, set(name), set(function(name))}.
I don't quite understand..
I would like to know how to verify
y=x e5x cos(2x)
is a solution to the differential equation
y(4) -20 y”’+158 y”-580y’+841y=0
Dear All
I have a question:
How can I computet the laplace inverse of a function that is below!
My version of Maple is 13:
It should be noted that r>0, \rho>0.5, y\in R.
> restart;
> with(MTM);
print(??); # input placeholder
> ilaplace(r^(rho-.5)*abs(y)^(rho-1)*exp(-r*y)/GAMMA(rho-.5), s);
I need to plot the maximum of x^2 and sqrt(|x|) together on one graph. I've currently defined a procedure f that uses an if-else construct for the given function. However, when I use plot(f,-3..3); I get the following error:
"Warning, unable to evaluate the function to numeric values in the region; see the plotting command's help page to ensure the calling sequence is correct"
How do I resolve this error?
Hye, anyone know what is the float means?
and why maple cant gives the answer while the others software can?(for my problem)
hope anyone can help me because I really need this for my comparison study.
Here I have attached the file :.comparison_try1.mw
thank you in advance :)
Hello people in Mapleprimes,
I wish you to teach me about this.
From a matrix, I want to make a string.
pt3 := Matrix(4, 2, [1, 3, 4, 5, 6, 8, 5, 10]);
string1 := cat(
  "(", convert(pt3[1, 1], string), ",", convert(pt3[1, 2], string), ",", ")",
  "(", convert(pt3[2, 1], string), ",", convert(pt3[2, 2], string), ",", ")",
  "(", convert(pt3[3, 1], string), ",", convert(pt3[3, 2], string), ",", ")",
  "(", convert(pt3[4, 1], string), ",", convert(pt3[4, 2], string), ")"
The above code makes
string1 := "(1,3,)==(4,5,)==(6,8,)==(5,10)"
What I want to know is how to write a code of programming without writing each row of the above code.
Actually, though I wrote 4 row matrix above, the number of rows of matrix I want to deal with might be more than 100.
Best wishes.
taro
I am new to Maple. I am working though the manual and in chapter two I tried to get the derivative of ln(x^2+1). I am getting something completely different that the actual derivative. I tried a simple derivatie (the derivative of 2x and get 0). I do not know what I am doing wrong. Any help will be appreciated.
How can I link the axes in two or more separate plots so that when I zoom in one, the others are also zoomed. Also when I want to link the 'x' or the 'y' axis only.
Dear mapleprimes users,
I have a problem with the LeastSquaresPlot(A0,[p, sec ]) function, for the vector A0, then it gives the error:
Error, (in Student:-LinearAlgebra:-LeastSquaresplot) all points must evaluate to numeric values.
I tried to convert the vector A0 to numeric values, but I didn`t succeed yet. I take A0 = vector(1..10,2) as an example, but still I get nothing.
Thanks for the help!
Yours
I've got the following equations :
x^3-4x=y, y^3-3y=x that I want to plot together over an appropriate range for x and y
I've tried plots[multiple]([eq1,x=-2..2,y=-2..2],[eq2,x=-2..2,y=-2..2])
but that doesn't seem to work. How can I rectify this error?
Following is the set of commands I performed.
> points := plots[implicitplot](t+sin(8*x^3*t)-x^3 = 0, t = -0.50e-1 .. 0.5e-1, x = -10/9 .. 10/9);
> ptslist := convert([1, 1], points, listlist);
In an output I need the data at the specified values of t. It will be great favor, if someone can help me out.
First 1355 1356 1357 1358 1359 1360 1361 Last Page 1357 of 2463
