http://en.wikipedia.org/wiki/Hypersurface
http://people.cs.uchicago.edu/~niyogi/papersps/surfacesampling.pdf
hypersurface is a homogenous polynomial
f(x,y) = 0
i do not understand how sampling hypersurface can generate this kind of polynomial
Have a good day;
Anyone know the correct command to plot functions (For Exact Solution). Here I have attached the file:
Exact.mw
For your information, I need to plot the different values of R in the same graph. The values of R are
R=0, 0.1, 0.2 and 0.3.
Thank you very much in advance.
May God bless you :)
i am solving a system of pde with boundar conditons then i got this error...
Error, (in pdsolve/numeric/plot) unable to compute solution for tau>HFloat(0.0):
Thank.
jeffrey_fluid.mw
Pr := .71;
.71
PDE := {(diff(theta(eta, tau), eta, eta))/Pr+f(eta, tau)*(diff(theta(eta, tau), eta))-theta(eta, tau)*(diff(f(eta, tau), eta))-a*(diff(theta(eta, tau), tau)) = 0, diff(f(eta, tau), eta, eta, eta)+f(eta, tau)*(diff(f(eta, tau), eta, eta))-(diff(f(eta, tau), eta))^2-a*(diff(f(eta, tau), eta, tau))-K*(a*(diff(f(eta, tau), eta, eta, eta, tau))+2*(diff(f(eta, tau), eta))*(diff(f(eta, tau), eta, eta, eta))-(diff(f(eta, tau), eta, eta))^2-f(eta, tau)*(diff(f(eta, tau), eta, eta, eta, eta)))+lambda*(1+epsilon*cos(Pi*tau))*theta(eta, tau) = 0};
{1.408450704*(diff(diff(theta(eta, tau), eta), eta))+f(eta, tau)*(diff(theta(eta, tau), eta))-theta(eta, tau)*(diff(f(eta, tau), eta))-(diff(theta(eta, tau), tau)) = 0, diff(diff(diff(f(eta, tau), eta), eta), eta)+f(eta, tau)*(diff(diff(f(eta, tau), eta), eta))-(diff(f(eta, tau), eta))^2-(diff(diff(f(eta, tau), eta), tau))-K*(diff(diff(diff(diff(f(eta, tau), eta), eta), eta), tau)+2*(diff(f(eta, tau), eta))*(diff(diff(diff(f(eta, tau), eta), eta), eta))-(diff(diff(f(eta, tau), eta), eta))^2-f(eta, tau)*(diff(diff(diff(diff(f(eta, tau), eta), eta), eta), eta)))+(1+cos(Pi*tau))*theta(eta, tau) = 0}
IBC := {f(0, tau) = 0, f(10, tau) = 0, f(eta, 0) = 0, theta(0, tau) = 1, theta(10, tau) = 0, theta(eta, 0) = 0, (D[1](f))(0, tau) = 1, (D[1](f))(10, tau) = 0};
L := [1]
[1]
for i to 1 do K := L[i]; pds := pdsolve(PDE, IBC, numeric, spacestep = 1/100); p[i] := plots[display]([seq(pds:-plot(f, tau = 1, eta = 0 .. 1, legend = L[i]), j = 5)]) end do
Newton iteration is not converging
display({p[1]})
Error, (in plots:-display) expecting plot structures but received: {p[1]}
Download jeffrey_fluid.mw
I am having issues when defining functions in a loop. First, I define the first two functions as follows (here, r(x) is a function already assigned).
f_0 := x -> r(x):
f_1 := x -> r(x)*f_0(r(x)):
Then, I define successive functions in a for loop as follows.
for i from 2 to 10 do
   f_i := x -> r(x)*f_[i - 1](r(x));
end do
The loop defines the function f_2 but compiles erroneously for f_3 which, and I do admit, relies on f_2. Does someone have an idea of how to fix this issue? Any help will be greatly appreciated. Thanks.
Aslam-u-Alikum. Hope you will be fine all.  I want to plot the follwing vector in the plan z=0 at time t=0 and A=1
v := `<,>`(VectorCalculus[`-`](VectorCalculus[`*`](VectorCalculus[`*`](VectorCalculus[`*`](A, y), 1/VectorCalculus[`+`](x^2, y^2)), exp(VectorCalculus[`-`](VectorCalculus[`*`](k, t))))), VectorCalculus[`*`](VectorCalculus[`*`](VectorCalculus[`*`](A, x), 1/VectorCalculus[`+`](x^2, y^2)), exp(VectorCalculus[`-`](VectorCalculus[`*`](k, t)))), VectorCalculus[`*`](B, t))
I am waiting for your positive answer.
I am trying to alter the Virtual Solar system Maple worksheet of Yi Xie in the way that I added several objects to the eight planets and Pluto (e.g. Hale-Bopp, Sedna, 2012 VP113 etc.) and would like to adjust the array such that when zooming out and the obrit and labels overlap so that it's unreadable anymore (orbits and labels) that I can switch on and off (respectively display/not display) specific parts, e.g. the inner solar system. In the original file a single array was created from 1..18 (including 9 orbital entries and 9 label entries). What I did is to create arrays for each part of the Solar system, e.g. Inner for the planets+Pluto 1..18, an array for Hale-Bopp with an orbital entry and a label entry, so [1,2], and an array with 6 entries for 3 additional objects like Sedna, Planet X and 2012 VP113. As well as the sun, which only has a single entry as there are no orbital elements necessary and one just makes a 3dplot (I did not label it, so just one entry). All arrays are converted into lists in the end and displayed. Here is the code:
> with(linalg);
> with(plots);
> with(plottools);
> P1 := matrix([[cos(omega[j]), -sin(omega[j]), 0], [sin(omega[j]), cos(omega[j]), 0], [0, 0, 1]]); P2 := matrix([[1, 0, 0], [0, cos(i[j]), -sin(i[j])], [0, sin(i[j]), cos(i[j])]]); P3 := matrix([[cos(Omega[j]), -sin(Omega[j]), 0], [sin(Omega[j]), cos(Omega[j]), 0], [0, 0, 1]]);
> A:=matrix([[a[j]*(cos(E[j])-e[j])],[a[j]*sqrt(1-e[j]^2)*sin(E[j])],[0]]);
> R:=multiply(P3,P2,P1);
> B:=multiply(R,A);
> a := [.38709893, .72333199, 1.00000011, 1.52366231, 5.20336301, 9.53707032, 19.19126393, 30.06896348, 39.48168677, 1/0.5454e-2, 268.2509283, 532.7838156, 300];
> e := [.20563069, 0.677323e-2, 0.1671022e-1, 0.9341233e-1, 0.4839266e-1, 0.5415060e-1, 0.4716771e-1, 0.858587e-2, .24880766, .994920, .7005635, .8570973, .1];
> i := [7.00487, 3.39471, 0.5e-4, 1.85061, 1.30530, 2.48446, .76986, 1.76917, 17.14175, 89.5328, 24.01830, 11.92859, 10];
> Omega := [48.33167, 76.68069, -11.26064, 49.57854, 100.55615, 113.71504, 74.22988, 131.72169, 110.30347, 282.1476, 90.88303, 144.53190, 45];
> omega := [77.45645, 131.53298, 102.94719, 336.04084, 14.75385, 92.43194, 170.96424, 44.97135, 224.06676, 130.8038, 293.03200, 311.18311, 150];
> i := map(x→ convert(x, units, deg, rad) end proc, i);
> Omega := map(x→ convert(x, units, deg, rad) end proc, Omega);
> omega := map(x→ convert(x, units, deg, rad) end proc, omega);
> for j to 13 do omega[j] := arcsin(sin(omega[j]-Omega[j])/sin(arccos(sin(i[j])*cos(omega[j]-Omega[j])))) end do;
> x := array(1 .. 13);
> y := array(1 .. 13);
> z := array(1 .. 13);
> for j to 13 do x[j] := B[1, 1]; y[j] := B[2, 1]; z[j] := B[3, 1] end do;
> Sun := array([1]);
> Inner := array(1 .. 18); for j to 9 do Colors := [black, green, blue, red, black, yellow, green, violet, brown, aquamarine, black, black, red]; Linestyle := [solid, solid, solid, solid, solid, solid, solid, solid, solid, longdash, solid, solid, longdash]; Inner[j] := spacecurve([subs(E[j] = E, x[j]), subs(E[j] = E, y[j]), subs(E[j] = E, z[j])], E = 0 .. 2*Pi, color = Colors[j], linestyle = Linestyle[j]) end do;
> Comet := array([1, 2]); if j = 10 then Colors := [aquamarine]; Linestyle := [longdash]; Comet[1] := spacecurve([subs(E[j] = E, x[j]), subs(E[j] = E, y[j]), subs(E[j] = E, z[j])], E = 0 .. 2*Pi, color = Colors[j], linestyle = Linestyle[j]) end if;
> Oort := array(1 .. 6); for j from 11 to 13 do Colors := [black, black, red]; Linestyle := [solid, solid, longdash]; Inner[j] := spacecurve([subs(E[j] = E, x[j]), subs(E[j] = E, y[j]), subs(E[j] = E, z[j])], E = 0 .. 2*Pi, color = Colors[j], linestyle = Linestyle[j]) end do;
> Sun[1] := plot3d(0.1e-1, 0 .. 2*Pi, 0 .. Pi, style = PATCHNOGRID, coords = spherical, color = red);
> Inner[10] := textplot3d([subs(E[1] = 0, x[1]), subs(E[1] = 0, y[1]), subs(E[1] = 0, z[1]), "Mercury"]); Inner[11] := textplot3d([subs(E[2] = 0, x[2]), subs(E[2] = 0, y[2]), subs(E[2] = 0, z[2]), "Venus"]); Inner[12] := textplot3d([subs(E[3] = 0, x[3]), subs(E[3] = 0, y[3]), subs(E[3] = 0, z[3]), "Earth"]); Inner[13] := textplot3d([subs(E[4] = 0, x[4]), subs(E[4] = 0, y[4]), subs(E[4] = 0, z[4]), "Mars"]); Inner[14] := textplot3d([subs(E[5] = 0, x[5]), subs(E[5] = 0, y[5]), subs(E[5] = 0, z[5]), "Jupiter"]); Inner[15] := textplot3d([subs(E[6] = 0, x[6]), subs(E[6] = 0, y[6]), subs(E[6] = 0, z[6]), "Saturn"]); Inner[16] := textplot3d([subs(E[7] = 0, x[7]), subs(E[7] = 0, y[7]), subs(E[7] = 0, z[7]), "Uranus"]); Inner[17] := textplot3d([subs(E[8] = 0, x[8]), subs(E[8] = 0, y[8]), subs(E[8] = 0, z[8]), "Neptune"]); Inner[18] := textplot3d([subs(E[9] = 0, x[9]), subs(E[9] = 0, y[9]), subs(E[9] = 0, z[9]), "Pluto"]); Comet[2] := textplot3d([subs(E[10] = 0, x[10]), subs(E[10] = 0, y[10]), subs(E[10] = 0, z[10]), Hale-Bopp]); Oort[4] := textplot3d([subs(E[11] = 0, x[11]), subs(E[11] = 0, y[11]), subs(E[11] = 0, z[11]), "2012 VP113"]); Oort[5] := textplot3d([subs(E[12] = 0, x[12]), subs(E[12] = 0, y[12]), subs(E[12] = 0, z[12]), "Sedna"]); Oort[6] := textplot3d([subs(E[13] = 0, x[13]), subs(E[13] = 0, y[13]), subs(E[13] = 0, z[13]), "Planet X ?", color = red]);
> Sun1 := convert(Sun, 'list');
> Inner1 := convert(Inner, 'list');
> Comet1 := convert(Comet, 'list');
> Oort1 := convert(Oort, 'list');
> display(Sun1, Inner1, Comet1, Oort1, scaling = CONSTRAINED);
The first error message appears after the if-condition. Can you tell me where I am making a mistake? Beware: when copy paste the code from Maple to Word and from Word in here the colons at the end of lines have changed into semi-colons. Hope this is no problem in executing the code despite the lines being in the same ">..." e.g. where the labels are defined.
Good day everyone, could you please help use Gauss Elimination method for these system of equations. See the worksheet here F1.mw
Can we output a mixed number instead of  an improper fraction in Maple programmatically. For example
                 instead  of
I am solving 6 ODE equations with boundary conditions using Runge kutta Felbergh 45 (Maple 12). then, i got this problem.. any suggestion??
Thank you :)
ISPC3.mw
restart; with(plots); M := 3; k = .2; blt := 6; r := 2; l := .1; Pr := 6.8; Ec := 2; N := .5; rho := .5; Tv := .5; Tt := .5; c := 1; cm := .1; cp := .1
Eq1 := diff(f(eta), eta, eta, eta)+f(eta)*(diff(f(eta), eta, eta))-(diff(f(eta), eta))^2-M*(diff(f(eta), eta))+B*H(eta)*(F(eta)-(diff(f(eta), eta))) = 0;
diff(diff(diff(f(eta), eta), eta), eta)+f(eta)*(diff(diff(f(eta), eta), eta))-(diff(f(eta), eta))^2-3*(diff(f(eta), eta))+B*H(eta)*(F(eta)-(diff(f(eta), eta))) = 0
Eq2 := G(eta)*(diff(F(eta), eta))+F(eta)^2+B*(F(eta)-(diff(f(eta), eta))) = 0;
Eq3 := G(eta)*(diff(G(eta), eta))+B*(f(eta)+G(eta)) = 0;
Eq4 := G(eta)*(diff(H(eta), eta))+H(eta)*(diff(G(eta), eta))+F(eta)*H(eta) = 0;
Eq5 := diff(theta(eta), eta, eta)+Pr*(f(eta)*(diff(theta(eta), eta))-2*(diff(f(eta), eta))*theta(eta))+N*Pr*(theta1(eta)-theta(eta))/(rho*c*Tt)+N*Pr*Ec*(F(eta)-(diff(f(eta), eta)))^2/(rho*Tv) = 0;
diff(diff(theta(eta), eta), eta)+6.8*f(eta)*(diff(theta(eta), eta))-13.6*(diff(f(eta), eta))*theta(eta)+13.60000000*theta1(eta)-13.60000000*theta(eta)+27.20000000*(F(eta)-(diff(f(eta), eta)))^2 = 0
Eq6 := 2*F(eta)*theta1(eta)+G(eta)*(diff(theta1(eta), eta))+cp*(theta1(eta)-theta(eta))/(c*cm*Tt) = 0;
2*F(eta)*theta1(eta)+G(eta)*(diff(theta1(eta), eta))+2.000000000*theta1(eta)-2.000000000*theta(eta) = 0
bcs1 := f(0) = r, (D(f))(0) = -1, (D(f))(blt) = 0, F(blt) = 0, G(blt) = -f(blt), H(blt) = k, theta(0) = 1, theta(blt) = 0, theta1(blt) = 0;
f(0) = 2, (D(f))(0) = -1, (D(f))(6) = 0, F(6) = 0, G(6) = -f(6), H(6) = k, theta(0) = 1, theta(6) = 0, theta1(6) = 0
L := [0.1e-2];
[0.1e-2]
for k to 1 do R := dsolve(eval({Eq1, Eq2, Eq3, Eq4, Eq5, Eq6, bcs1}, B = L[k]), [f(eta), F(eta), G(eta), H(eta), theta(eta), theta1(eta)], numeric, output = listprocedure); Y || k := rhs(R[2]); YP || k := rhs(R[3]); YR || k := rhs(R[4]); YQ || k := rhs(R[5]) end do
R
R
print([(YP || (1 .. 1))(0)]);
[YP1(0)]
P1 := plot([YP || (1 .. 1)], 0 .. 14, labels = [eta, (D(f))(eta)]):
plots:-display([P1]);
Download ISPC3.mw
restart; with(linalg); with(stats); with(plots); with(Statistics); with(LinearAlgebra);
s := 1/(273.16+50); s1 := 1/(273.16+145); s3 := 1/(273.16+250); s2 := 1/(273.16+197.5); gamma0 := 0.1e-3; gamma1 := .5; gamma2 := 0.15e-2; beta := -3800;
c := 300; n := 200; tau1 := 99; tau2 := 120;
Delta := solve(1-exp(-(gam0*tau1+(1/2)*gam1*tau1^2)*exp(beta*s1)) = 1-exp(-(gam0*a+(1/2)*gam1*a^2)*exp(beta*s2)), a);
a := Delta[1];
Theta := solve(1-exp(-(gam0*(a+tau2-tau1)+(1/2)*gam1*(a+tau2-tau1)^2)*exp(beta*s2)) = 1-exp(-(gam0*b+(1/2)*gam1*b^2)*exp(beta*s3)), b);
b := Theta[1];
n1 := n*(int((gam1*t+gam0)*exp(beta*s1)*exp(-(gam0*t+(1/2)*gam1*t^2)*exp(beta*s1)), t = 0 .. tau1));
200. - 200. exp(-0.01119474511 gam0 - 0.5541398828 gam1)
n2 := (n-n1)*(int((gam1*t+gam0)*exp(beta*s2)*exp(-(gam0*t+(1/2)*gam1*t^2)*exp(beta*s2)), t = a .. a+tau2-tau1));
g1 := -n1(gam0, gam1)*(int((1/(gam1*t+gam0)-t*exp(beta*s1))*(gamma2*t^2+gamma1*t+gamma0)*exp(beta*s1)*exp(-(gamma0*t+(1/2)*gamma1*t^2+(1/3)*gamma2*t^3)*exp(beta*s1)), t = 0 .. tau1))-evalf(n2(gam0, gam1)*(int((1/(gam0+gam1*(a+t-tau1))-(a+t-tau1)*exp(beta*s2))*(gamma0+gamma1*(a+t-tau1)+gamma2*(a+t-tau1)^2)*exp(beta*s2)*exp(-(gamma0*(a+t-tau1)+(1/2)*gamma1*(a+t-tau1)^2+(1/3)*gamma2*(a+t-tau1)^3)*exp(beta*s2)), t = tau1 .. tau2)))
g2 := -n1*(int((t/(gam1*t+gam0)-(1/2)*t^2*exp(beta*s1))*(gamma2*t^2+gamma1*t+gamma0)*exp(beta*s1)*exp(-(gamma0*t+(1/2)*gamma1*t^2+(1/3)*gamma2*t^3)*exp(beta*s1)), t = 0 .. tau1))-evalf(n2*(int(((a+t-tau1)/(gam0+gam1*(a+t-tau1))-(1/2)*(a+t-tau1)^2*exp(beta*s2))*(gamma0+gamma1*(a+t-tau1)+gamma2*(a+t-tau1)^2)*exp(beta*s2)*exp(-(gamma0*(a+t-tau1)+(1/2)*gamma1*(a+t-tau1)^2+(1/3)*gamma2*(a+t-tau1)^3)*exp(beta*s2)), t = tau1 .. tau2)))
solve({g1 = 0, g2 = 0}, {gam0, gam1})
I want to find the answer of gam0 and gam1. It takes me 20 hours until now...and still evaluating...
Please Help ..
I can't directly copy Maple code into messages but have to insert into Word first, apply some changes that for better readability and copy it from there via Word-paste. Is there a direct way?
how do minor generate 2*2 matrix from 5*5 matrix or n*n matrix which n >= 3
first case is the symmetric or nonsymmetric ladder matrix which fill full upper right and lower left corner
{0,1,1,1,1}
{1,0,1,1,1}
{1,0,0,0,1}
{1,1,1,0,0}
{1,1,1,1,0}
second case is overlap two different first case , one is 1 and another is 0 which is for display partial fill the upper right corner and lower right corner
{0,1,0,0,0}
{1,0,1,1,0}
{1,0,0,0,1}
{0,1,1,0,0}
{0,0,0,1,0}
I am trying separation of variables in Maple. I get an equation that has the form
And now I want to tell Maple to assign the terms with 1/R in them to one variable, say eq21, and the term with 1/Z to second variable, say eq22 The idea is that I can later more easily work with each separate ode.
I do not know to separate those apart. I could offcourse copy and paste by hand, but I want to automate this.
I tried match() and patmatch() but I am not seeing the way. Here is the code:
T:=  (r,z)-> Z(z)*R(r);
eq1:= diff(T(r,z),r$2)+1/r*diff(T(r,z),r)+diff(T(r,z),z$2);
eq2:=expand(eq1/(Z(z)*R(r)));
#need now way to break the above into 2 different variables.
ps. I know I can do this:
eq3:=collect(eq2,1/R(r));
eq21:=op(1,eq3);
eq22:=op(2,eq3);
But this for me is not the right way to do it. I think there should be more algebraic way.
First 1362 1363 1364 1365 1366 1367 1368 Last Page 1364 of 2463
