Anyone knows how to define a ring of polynomials with variables x_1,...,x_n such that x_i*x_j = -x_j*x_i if i \neq j?
I tried using the Physics package and AntiCommutator but the problem is that in that case the variables anticommute with themselves so I have x_i^2=0.
If there is no direct way to this, I guess I could define a procedure that would look at the monomials of a polynomial and order them in lexicographic order and each time it switches two variables with different index it would multiply the monomial by -1.
I also don't know how to do that since I don't know how to look at a specific term in a monomial. For example, if my monomial is x_ix_jx_k, is there a way to find the first two variables and then switch them if LexOrder(variable1,variable2)= LexOrder(x_i,x_j)= false, i.e. if i>j?
M-A
Hi there,
I used the following plot command in maple13.
implicitplot(abs(x)+abs(y)=2, x=-2..2, y=-2..2, scaling=constrained)
But the output(square) is not complete at vertices.In fact at the vertex the graph is like a trapezoid.
Any help will be appreciated.
Yegan
hi
i have solved my equation as folllow :
pde:= diff(T(x, y), x)-1.555*10^(-7)*(diff(T(x, y), y, y))/ ...........
sol := pdsolve(pde, {T(0, y) = 0, (D[2](T))(x, 0) = 1325.754092, (D[2](T))(x, 0.25e-4) = 1970434.783}, numeric)
I wana know that maple has used which of numeric method to solve my equation ?
1.ForwardTime1Space[forward/backward]
2.CenteredTime1Space[forward/backward]
3.BackwardTime1Space[forward/backward]
4.ForwardTimeCenteredSpace or Euler
5.CenteredTimeCenteredSpace or CrankNicholson
6.BackwardTimeCenteredSpace or BackwardEuler
7.Box
8.LaxFriedrichs
or ... ?
Tahnks.
For different reasons I need to ocasionally export a number of Maple worksheet in a folder to pdf files. Is there a way to automate this? I would want that the worksheet is opened, output removed, then executed and eventually exported to pdf. It can take quite a while to do this manually for about 50 worksheets.
Dear people in Maple primes,
Please tell me why algsubs would not work well in the following case.
algsubs(-eta*M[n]/(gamma*(eta*M[n]+gamma))-1/(eta*M[n]+gamma) = factor(-eta*M[n]/(gamma*(eta*M[n]+gamma))-1/(eta*M[n]+gamma)), (-eta*M[n]/(gamma*(eta*M[n]+gamma))-1/(eta*M[n]+gamma))*p[i]+(int(p[i], i = 0 .. M[n]))*eta/(gamma*(eta*M[n]+gamma))+alpha/(eta*M[n]+gamma));
Following error message appeared when the above code is executed:
Error, (in algsubs) cannot compute degree of pattern in eta
Best wishes.
taro
HI, dear all. When I tried to use the plot option 'adaptive' to make my plot more smooth and realistic, I encountered the following erro. I cannot understand why. From the help guide, I learn that adaptive can be assigned n or true or false, but errors appeared.  Thanks for your help.
> implicitplot(-x^3+3*x+a = 0, a = -3 .. 3, x = -4.0 .. 4.0, view = [-3 .. 3, -4 .. 4], adaptive = 2, resolution = 1000, numpoints = 2000);
Error, (in plot/options2d) unexpected option: adaptive = 2
> help("adaptive");
I encountered with a problem in understanding of structured types. I test following structured types:
the result is
I cannot understand two last results as I expected to receive trues. Could you explain me the result?
UPD
A code appropriate for copy/pase along with short problem solution is presented below
`type/A1`:={integer, rational};
`type/A2`:=integer or rational; #  it matchs the expressions that literally contain `or` (see @Carl Love's
answer below)
`type/A3`:=OR(integer, rational); # `Or` should be used rather then `OR` (see @acer's
answer below)
x:=5;
type(x, A1);
type(x, A2);
type(x, A3);
> restart;
> with(plots);
> Eq1 := diff(f(eta), eta, eta, eta)+f(eta)*(diff(f(eta), eta, eta))-2*(diff(f(eta), eta))^2-M^2*(diff(f(eta), eta)) = 0;
/ d / d / d \\\ / d / d \\
|----- |----- |----- f(eta)||| + f(eta) |----- |----- f(eta)||
\ deta \ deta \ deta /// \ deta \ deta //
/ d \ 2 / d \
- 2 |----- f(eta)| - M |----- f(eta)| = 0
\ deta / \ deta /
> Eq2 := 1+(4/3)*R*(diff(theta(eta), eta, eta))+Pr*(f(eta)*(diff(theta(eta), eta))-(diff(f(eta), eta))*theta(eta)) = 0;
4 / d / d \\
1 + - R |----- |----- theta(eta)||
3 \ deta \ deta //
/ / d \ / d \ \
+ Pr |f(eta) |----- theta(eta)| - |----- f(eta)| theta(eta)| = 0
\ \ deta / \ deta / /
> bcs1 := f(0) = S, (D(f))(0) = 1+L*G, (D(D(f)))(0) = .1, f(6) = 0;
f(0) = S, D(f)(0) = 1 + L G, @@(D, 2)(f)(0) = 0.1, f(6) = 0
> fixedparameter := [S = .1, M = .1];
[S = 0.1, M = 0.1]
> Eq3 := eval(Eq1, fixedparameter);
/ d \ / d \
- 2 |----- f(eta)| - 0.01 |----- f(eta)| = 0
\ deta / \ deta /
> fixedparameter := [R = .1, Pr = .7];
[R = 0.1, Pr = 0.7]
> Eq4 := eval(Eq2, fixedparameter);
/ d / d \\ / d \
1 + 0.1333333333 |----- |----- theta(eta)|| + 0.7 f(eta) |----- theta(eta)|
\ deta \ deta // \ deta /
/ d \
- 0.7 |----- f(eta)| theta(eta) = 0
\ deta /
> bcs2 := theta(0) = 1+T*B, (D(theta))(6) = B, theta(6) = 0;
theta(0) = 1 + T B, D(theta)(6) = B, theta(6) = 0
> T := .1; B := .1;
0.1
0.1
> L := [0., .1, .2, .3];
[0., 0.1, 0.2, 0.3]
> for k to 4 do R := dsolve(eval({Eq3, Eq4, bcs1, bcs2}, L = L[k]), [f(eta), theta(eta)], numeric, output = listprocedure); Y || k := rhs(R[2]); YL || k := rhs(R[3]) end do;
Error, (in dsolve/numeric/bvp/convertsys) too many boundary conditions: expected 6, got 7
> plot([YL || (1 .. 4)], 0 .. 6, 1 .. -.2, labels = [eta, diff(f(eta), eta)]);
Dear all;
I need your help to get all the solution of this nonlinear  system  with four parameters: r1, r2, q1, q2  assumed to be positives. Let the system:
the first equation is: r1*x*(1-x/q1)=x*y/(1+x)
the second equation: r2*y*(exp(-y)-q2)=-x*y/(1+x)
How can get the positive solution ( x, y) of the previous system.
Thank you for your help.
Dear Exppert,
I used the following command to plot the volume of revolutionin Maple13, but with the message "unable to invert function w.r.t. the vertical axis."
with(Student[Calculus1]):
VolumeOfRevolution(sqrt(1-(x-4)^2), -sqrt(1-(x-4)^2), x=3..5, axis=vertical, scaling=constrained, output=plot).
Meanwhile, this command can plot each function individually, which is a semi-torus.
Yegan
I'm trying make Maple write the actual result, when i differenting an expression: x[s] := x(t)+sin(theta(t))*a.
when i differentiate with respect to t, i get:
> diff(x[s], t);
/ d \ / d \
|--- ()(t)| + cos(theta(t)) |--- theta(t)| a
\ dt / \ dt /
Maple, writes the expression as a table, but i need to see the normal function? Why does it do that? And how can i make it show the expression as a normal function?
When i derive the two parts serperately i get the normal result, but as soon as i add them together, i get the table rasult again?
Is there an easy trick for this one?
-Nicolai
Hello.
I am trying to extract the terms that are a product of a commutative part and an operator part from the input expression. That is I am trying to extract a terms like a*A.B where A and B are quantum pperators.
I am trying to do it by creating corresponding structured type:
with(Physics);
Physics[Setup](op = {A, B}, quiet);
`type/ProdComOp` := `&*`(commutative, specfunc(anything, Physics:-`*`));
z0 := u*A.B-A+k*B+B.A.B+g;
z1 := z0+v*A.B.A;
S1 := indets(z1, ProdComOp);
and all it is Ok. The result is
But if
z2 := z0-v*A.B.A;
S2 := indets(z2, ProdComOp);
then
however I expected to receive the same as S1.
How to handle the sign of the commutative part? Thank you.
  I would like to readdata from a file
              -6
2 0.38 10 + 0. I
  I use
f:=readdata(`d:\\test.dat`,2);
for i from 1 to 20 do
print(i,f[i]);
  The problem is, seems maple get -6, instead of 10^-6, since the .txt file puts -6 in a row.
My question is, how to get the right data 0.38*10^-6 correctly?
P.S. I used cmaple  inputfile >  outputfile.txt to get the .txt file. Should I use writedata?
  I have a file "d:\\test.txt", the content is
       1, 2.0000 + 0. I
then I use
f:=readdata(`d:\\test.txt`,2);
for i from 1 to 1 do
print(i,f[i]);
it gives me
[[1.]]
1, [1.]
If I remove the comma in the file, I could obtain 2. I do not want to do it manually that remove all commas by hand. Is there any way to skip the commas in readdata?
Consider the function
The above definition may result in four cases depening on r and x.
Can Maple calculate automatically all possible cases and the corresponding Maxima, Minima and Values at intervals limits?
First 1381 1382 1383 1384 1385 1386 1387 Last Page 1383 of 2463
