I have two lists with differential monomials, like this: [y'y'', y''', (y'')^2].
List is rather big, i want to check if one such a list contains in other.
Seems to be that there is some internal procedure for this operation.
But I don't know what it is...
I have an ode in the form:
diff(u(x),x)-f(x)=u(x)^3+B(X)*u(x)+g(x)
how to extaract and name the different coefficients of the equation?
Hamada
Having a little trouble getting data from openstreetmap from export here
http://www.openstreetmap.org/export#map=17/43.4763/-80.5459
Dear friends:
If
n:=197
then
d:=convert(n,base,10) --> returns [7,9,1]
Is there a simple way for getting back n from d, i.e., 197 from [7,9,1] , not using a for loop?
Thanks and best regards
César Lozaada
Nm= p1. p2 ...pm + 1, for m more than or equals 1.
So N1 = p1 + 1 = 2 + 1 = 3, N2 = p1 p2 + 1 = 2  3 + 1 = 7, etc.
We prove that Nm is not divisible by any of p1, p2, . . . , pm, so that Nm is either a prime or it is divisible by a prime larger than pm.
(c) Use Maple to find out which of these numbers Nm, for m = 1, 2, . . . , 15, is actually prime.
Use Maple to compare pm with the smallest prime number that divides Nm, for m =1, 2, . . . , 15.
So I am brand new to using Maple and am trying to solve a system of ODE's. When I try and use dsolve however I reciever the error "function expected" and I am not sure why. The code I have is as follows
sys_ode := diff(A(t), t) = a*(A(t)+B(t))-b1*A(t)*(C(t)+D(t))-g1*A(t)*B(t), diff(B(t), t) = -b2*B(t)*(C(t)+D(t))+g1*A(t)*B(t), diff(C(t), t) = e*(b1*A(t)+b2*B(t))*C(t)-g2*b2*C(t)*B(t)-g3*C(t)*D(t), diff(D(t), t) = g2*b2*C(t)*D(t)-m*D(t)
dsolve([sys_ode])
I'm sure it is something simple, but I just can't seem to figure out where the issue is. Any help is much appreciated.
I'm trying to substitute one Differential equation into another differential equation.
eq1:=d*n(t)/dt = (rho(t)-beta)*n(t)/Lambda+lambda*C(t)+q
eq2:=diff(eq1, t)
resulting in -> eq2 := d*(diff(n(t), t))/dt = (diff(rho(t), t))*n(t)/Lambda+(rho(t)-beta)*(diff(n(t), t))/Lambda+lambda*(diff(C(t), t))
then I'm given that (diff(C(t), t)) is given by another equation:
eq3:=d*C(t)/dt = beta*n(t)/Lambda-lambda*C(t)
At this point I'm trying to substitute equation 3 into equation 2 for diff(C(t),t)
eq4 := subs(diff(C(t), t) = rhs(eq2), eq5)
however no matter what way's I try this I get an error:
Error, (in simpl/reloprod) invalid terms in product: (d*(diff(n(t), t))/dt = (diff(rho(t), t))*n(t)/Lambda+(rho(t)-beta)*(diff(n(t), t))/Lambda+lambda*(diff(C(t), t)))^-1
I then tried to map it but again i got an error specifically about the first parameter:
Error, invalid operator parameter name
eq5:=map((d/dt C(t))->beta/Lambda*n(t)-lambda*C(t),eq2)
I'm just wondering if what I am trying to do is even possible in Maple?
If anyone can help I would greatly appreciate it!
The system :
Hello ..
I need codes bifurcation and cobweb for logistic map by maple ..
can you help me ?
Thanks ...
I am trying to recreate journal work for validating using another computer program so I am trying to use maple to solve the ODE, based on further research I found using laplace might be the best but I am having some trouble.
eq8:=d*(n(t)+C(t))/drho = -rho(t)/(l*alpha*K_c)
given the initial conditions of:
ICs:= n(0) = n_0, rho(0) = rho_0, C(0) = (beta-rho_0)*n_0/(l*lambda)
therefore:
equation9 := dsolve({equation8, ICs}, {C(t), n(t)}, method = laplace)
Following this process I get the error:
Error, (in dsolve) invalid initial condition
According to the journal work the solution I am looking for is:
C(t)=-n(t)+(rho_0^2+rho(t)^2)/(2*l*alpha*K_c)+((Beta+l*lambda-rho_0)*n_0)/(l*lambda)
is there something that I'm doing wrong or missing?
Any help would be greatly Appreciated!
I want to simulate Inelastic collision
There has 2 ball which I can change  Quality and Radius.
one ball  move to another stirless ball with diferent angle
I need your help .. I solve a system and I get the error Warning, solutions may have been lost.
The maple code is attached.
testerror.mw
Thank you for your help.
hi everyone , i need your point of view in my question,any help would be appreciated in advance .
we have a discrete function named g(t) and a continous function f(t) in in convolution integral just like this :
int(f(t-x)*g(x),x=0..t) ;
we have just g(x) in some special points int the interval (0..t) , thus i need to convert this integral to a series.
how should i do this ? can anyone help or any idea ? i need at first a mathematical solution or idea about how to do this and then, how to do this in a software ?
tnx again.
I am trying to define some functions by recursion relations but I get this error:
Error, (in type/realcons) too many levels of recursion
Please see the attached file for details:
File.mw
Eq2 := diff(T(y), y, y)+(diff(sigma(y), y))*(diff(T(y), y))+(diff(T(y), y))^2+(exp(-y)
+exp(y))^2 = 0;
Eq3 := diff(sigma(y), y, y)+(diff(T(y), y, y))= 0;
bcs2:=T(h1)=0,T(h2)=1,sigma(h1)=0,sigma(h2)=1;
dsolve({Eq2,Eq3,bcs2});
This give me nothing. Please help me out.
First 1382 1383 1384 1385 1386 1387 1388 Last Page 1384 of 2463
