Hello people in mapleprimes,
I want to draw a graph of a procedure.
filter:=x->if x<10 then 1-x/10 else 0 fi;
plot('filter(x)',x=0..20);
works well. But, I don't know why it is needed for filter(x) is wrapped with foward quotte ' .
I changed that quote to back quote ` but, in this case the result hadn't appeared.
And, without the foward quote ', error appears.
And, even if I wrapped x with ' as in plot('filter(x)','x' =0..20),
a graph appeared properly, though I cannot understand why wrapped x, 'x' is right.
Please teach me the logic of the above code.
Best wishes.
taro yamada
solve(a/(x+1)>1,x)
When I type this command and run it,It returns nothing but this warning
"Warning, solutions may have been lost"
How can I get the correct solution using Maple 18
AoA. How are you hope you will be fine. Sir the following matrix have been given
A := Matrix(2, 2, {(1, 1) = 1, (1, 2) = 2, (2, 1) = -1, (2, 2) = 2});
B := Matrix(2, 2, {(1, 1) = 1, (1, 2) = 0, (2, 1) = -2, (2, 2) = 3});
C := Matrix(2, 2, {(1, 1) = 0, (1, 2) = 0, (2, 1) = 0, (2, 2) = 0});
I want to write M by M matrix using the above matrices like this
P:=[[[A,B,B,...,B],[C,A,B,...,B],[C,C,A,...,B],[.,.,.,...,B],[C,C,C,...,A]]]
PhD (Scholar)
Department of Mathematics
AoA... I want to plot the following functions
f(x)=sin(x)
g(x)=sin(x)-x+x^2
h(x)=cos(x)-sin(x)
I(x)=exp(x)-x
J(x)=sin(x)+exp(x)
in one coordinate having the line style and legend like attached file.
1-s2.0-S0377042714003331-main.pdf
PhD (Scholar)
After I do
plot(cos);
Now I right-click on the plot, and from the menu change the "line" to "dashed" style, so the plot becomes like this:
Now I would like to obtain the Maple plot command that would have generated the above plot, so I can use the command later in my script.  I could not find a menu option to show the Maple command.
Maple 18.02 on windows 7
I want to get the result of multi-matrix multiply like followed below,
but error "final value in for loop must be numeric or character"
(*n is arbitrary and B[1],B[2],...,B[n] have been obtained*)
A:=LinearAlgebra:-IdentityMatrix(n);
#using the multiplication operation of matrix
for i from 1 to n do
   A:=LinearAlgebra:-Multiply(A,B[i]);
return A
help me
I have a loop with the do structure but there is an error in the loop .
how can I continue the loop by error or disregard it?
y(t) = _C1*exp(-1.*t)*sin(.57736*t)+_C2*exp(-1.*t)*cos(.57736*t)
The answer i got for a DE raised in mapleprime is given above.
What command do i write now to get a plot of the same?
Ramakrishnan V
Hey, how is can i see all the steps in maple? I would specially like to know it for differential equations.
For example we could use this one:
dl := 3*(diff(y(t), t, t))+6*(diff(y(t), t))+4*y(t) = 0
tmp:=Vector(
1+(-s[2]-s[4]+2*w[1]/(1+1/exp(mu[p]))^2+(2*(-w[1]+1))/(1+1/(exp(mu[p])*exp(eta[p2])))^2)*s[1]^3+(-s[2]+s[3])*s[1]^2-s[2]*s[1],
(s[2]+s[4]-2*w[1]/(1+1/exp(mu[p]))^2-(2*(-w[1]+1))/(1+1/(exp(mu[p])*exp(eta[p2])))^2)*s[1]^3
tmp := Vector(2, {(1) = 1+(-s[2]-s[4]+2*w[1]/(1+1/exp(mu[p]))^2+(-2*w[1]+2)/(1+1/(exp(mu[p])*exp(eta[p2])))^2)*s[1]^3+(-s[2]+s[3])*s[1]^2-s[2]*s[1], (2) = (s[2]+s[4]-2*w[1]/(1+1/exp(mu[p]))^2-(-2*w[1]+2)/(1+1/(exp(mu[p])*exp(eta[p2])))^2)*s[1]^3})
rule3:=w[1]/(1+1/exp(mu[p]))^2+(-w[1]+1)/(1+1/(exp(mu[p])*exp(eta[p2])))^2 = s[3];
applyrule(rule3,tmp[1]);
1+(-s[2]-s[4]+2*w[1]/(1+1/exp(mu[p]))^2+2*(-w[1]+1)/(1+1/(exp(mu[p])*exp(eta[p2])))^2)*s[1]^3+(-s[2]+s[3])*s[1]^2-s[2]*s[1]
Download problem.mw
This is part of a large simplifcation where lots of terms are being substituted. In two of those terms, it did not simplify as we would expect.
I think the main thing is trying to find a way to factor out the "2".
I could do this
>rule3:=2*rule3;
> rule3ne:=-(w[1]/(1+1/exp(mu[p]))^2+(-w[1]+1)/(1+1/(exp(mu[p])*exp(eta[p2])))^2) = -s[3];
> rule3ne:=2*rule3ne;
> applyrule(rule3ne,tmp[2]);
For this example, this works.
But I hope for a more generic approach.
casper
Hello, Im trying to do a jocobian
http://www.maplesoft.com/support/help/Maple/view.aspx?path=VectorCalculus/Jacobian
but when I try the example code
jacobian([rcos(t), rsin(t), r^2*t], [r, t])
i only get the output as
jacobian([rcos(t), rsin(t), RandomMatrix(4, 4*density = .75, outputoptions = [shape = tringular*lowe])^2*t], [RandomMatrix(4, 4*density = .75, outputoptions = [shape = tringular*lowe]), t])
I want the output as a matrix as in the example url.
a:=[1,2,3]:
b:=[1,2,3]:
evalb(a=b)    #The result is true
c:=Array([1,2,3]):
d:=Array([1,2,3]):
evalb(c=d)    #The result is false
This is Why?
I have the following system of non-linear equations and want to find their solutions experimenting with my parameters. I also want to restrict the solutions to be non-negative. I have done the following, but i am sure it exist a more efficient way. Can somone help on this?
eqns := [A = (gr_c+delta)*kh^(1-alpha)/sav_rate, theta = Rk*(Rh-Rk)/(gamma*((Rh-Rk)^2+sigma^2)), theta = 1*1+kh, Rk = 1+rk-delta, Rh = 1+rh-delta, rk = A*alpha*kh^(alpha-1), rh = A*(1-alpha)*kh^alpha, sigma = sigmay/theta, varrho = Rap^((eps-1)*eps/(1-gamma)), Rap = Rk^(1-gamma)+(1-gamma)*Rk^(-gamma)*theta*(Rh-Rk)-.5*Rk^(-gamma-1)*gamma*(1-gamma)*theta^2*((Rh-Rk)^2+sigma^2), R = Rk+theta*(Rh-Rk), beta = ((1+gr_c)/R)^(1/eps)/varrho];
[ (1 - alpha)
[ (gr_c + delta) kh
[A = ----------------------------,
[ sav_rate
Rk (Rh - Rk)
theta = ---------------------------, theta = 1 + kh,
/ 2 2\
gamma \(Rh - Rk) + sigma /
Rk = 1 + rk - delta, Rh = 1 + rh - delta,
(alpha - 1) alpha
rk = A alpha kh , rh = A (1 - alpha) kh ,
/(eps - 1) eps\
sigmay \ 1 - gamma /
sigma = ------, varrho = Rap , Rap =
theta
(1 - gamma) (-gamma)
Rk + (1 - gamma) Rk theta (Rh - Rk) - 0.5
(-gamma - 1) 2 / 2 2\
Rk gamma (1 - gamma) theta \(Rh - Rk) + sigma /,
/ 1 \]
\eps/]
/1 + gr_c\ ]
\ R / ]
R = Rk + theta (Rh - Rk), beta = ---------------]
varrho ]
vals := [alpha = .36, delta = 0.6e-1, sigmay = sqrt(0.313e-1), gamma = 3, eps = .5, gr_c = 0.2e-1, sav_rate = .23];
eval(eqns, vals);
[ 0.64 Rk (Rh - Rk)
[A = 0.3478260870 kh , theta = -----------------------,
[ / 2 2\
[ 3 \(Rh - Rk) + sigma /
0.36 A
theta = 1 + kh, Rk = 0.94 + rk, Rh = 0.94 + rh, rk = ------,
0.64
kh
0.36 0.1769180601
rh = 0.64 A kh , sigma = ------------,
theta
0.1250000000
varrho = Rap ,
1 2 theta (Rh - Rk)
Rap = --- - -----------------
2 3
Rk Rk
2 / 2 2\
3.0 theta \(Rh - Rk) + sigma /
+ --------------------------------, R = Rk + theta (Rh - Rk),
4
Rk
2.000000000]
/1\ ]
1.0404 |-| ]
\R/ ]
beta = ---------------------]
varrho ]
eqns := [A = .3478260870*kh^.64, theta = (1/3)*Rk*(Rh-Rk)/((Rh-Rk)^2+sigma^2), theta = 1+kh, Rk = .94+rk, Rh = .94+rh, rk = .36*A/kh^.64, rh = .64*A*kh^.36, sigma = .1769180601/theta, varrho = Rap^.1250000000, Rap = 1/Rk^2-2*theta*(Rh-Rk)/Rk^3+3.0*theta^2*((Rh-Rk)^2+sigma^2)/Rk^4, R = Rk+theta*(Rh-Rk), beta = 1.0404*(1/R)^2.000000000/varrho];
[ 0.64 Rk (Rh - Rk)
[ / 2 2\
0.36 A
0.64
kh
0.36 0.1769180601
theta
0.1250000000
varrho = Rap ,
1 2 theta (Rh - Rk)
2 3
Rk Rk
2 / 2 2\
4
Rk
2.000000000]
/1\ ]
1.0404 |-| ]
\R/ ]
varrho ]
solve(eqns, [Rk, Rh, varrho, Rap, beta, R, A, sigma, theta, rk, rh, kh]);
hello . i have a Partial differential equation i need some help with
This is how it goes
Hi everyone.
I always used simple command to plot graphs with parametric function:
> plot([seq([i, t, t=0..11-i], i=1..10)], thickness=3, color=blue);
And I always obtained this:
But yesterday I installed second update for Maple 18, and now I get only error:
"Error, (in plot) invalid input: ToInert expects 1 or 2 arguments, but received 0"
What command I should use now?
First 1386 1387 1388 1389 1390 1391 1392 Last Page 1388 of 2463
