Dear Maple Experts,
i am new to maple and I am trying to write a maple algorithm in order to calculate the GCD of two functions.
I have defined the two functions and written the algorithm, but I get an error "Unable to Parse".
Here is my code:
restart; with(Algebraic); with(LinearAlgebra[Generic]); with(RegularChains); with(FastArithmeticTools); with(ChainTools); interface(rtablesize = 15);
f := (y^2-1)*((y+1)*x^4+(y^2-1)*x^3+(y^3-1)*x^2+(y^4-1)*x+y^5-1);
g := (y-1)*x^5+(y^2-1)*x^4+(y^3-1)*x^3+(y^4-1)*x^2+(y^5-1)*x+y^6-1;
SubRes:=proc(f,g,var): local  i,a, delta, beta, psi: if degree(f,var)<degree(g,var) then a[0]:=Algebraic:-PrimitivePart(g,var): a[1]:=Algebraic:-PrimitivePart(f,var): else a[0]=Algebraic:-PrimitivePart(f,var): a[1]:=Algebraic:-PrimitivePart(g,var): fi: delta[0]:=degree(a[0],var)-degree(a[1],var): beta[2]:=(-1)^((delta[0]+1)): psi[2]:=-1: i:=1: while a[i]<>0 do a[i+1]:=(prem(a[i-1], a[i], var))/(beta[i+1]): delta[i]:=degree(a[i],var)-degree(a[i+1], var): i:=i+1: psi[i+1]:=((-lcoeff(a[i-1],var))^((delta[i-2])))*((psi[i])^((1-delta[i-2]))): beta[i+1]:=-lcoeff(a[i-1],var)*(psi[i+1])^((delta[i-1])): od: print("Last Non-Zero Subresultant: ", sort(simplify(a[i-1])),y): return (Algebraic:-PrimitivePart(a[i-1],var)): end proc
and I get this error:
Error, unable to parse
Would you kindly help me to fix this issue?
Kind Regards,
Ash
I am trying to figure out how to find several parital sums of the Airy's Function on a common screen. I figured out how to do it for a the Bessel fucntion of order 1, but I am not given the series for Airy's . Can anyone help me with what I would plug in to maple for the Airy's function or how I would go about finding the parital sums it would be greatly apperciated.
Rob
Dear Community,
Does anybody know, if there is a limit for the maximum number of equations for MapleSim? I tried with a system of 4456 equations, and I got the error message "(in DSN/RunSimulation ) system is inconsistent" When I took away most of the components (subsystems) it worked. So I suppose there must be some limit for the number of equations.
Tx in advance,
Andras
Hello, everybody!
If it is convenient for you, I wish you can help me review the following program. Thank you very much in advance. I want to obtain the coefficient values of c0, n, s0, ks, h1, h2, kp, A, B for the ODE system.
cdm_ode := diff(y1(t), t) = c0*(y6(t)*(1-y3(t))/(s0*(1-y4(t)*(1-y5(t)))))^n/(1-y2(t)), diff(y2(t), t) = ks*y2(t)^(1/3)*(1-y2(t)), diff(y3(t), t) = h1*(1-y3(t)/h2)*c0*(y6(t)*(1-y3(t))/(s0*(1-y4(t)*(1-y5(t)))))^n/(sigma*(1-y2(t))), diff(y4(t), t) = (1/3)*kp*(1-y4(t))^4, diff(y5(t), t) = A*B*y1(t)^(B-1)*c0*(y6(t)*(1-y3(t))/(s0*(1-y4(t)*(1-y5(t)))))^n/(1-y2(t)), diff(y6(t), t) = y6(t)*c0*(y6(t)*(1-y3(t))/(s0*(1-y4(t)*(1-y5(t)))))^n/(1-y2(t));
tol_t := 3600;
sol := dsolve([cdm_ode, y1(0) = 0, y2(0) = 0, y3(0) = 0, y4(0) = 0, y5(0) = 0, y6(0) = 175], numeric, range = 0 .. tol_t, output = listprocedure, parameters = [c0, n, sigma, s0, ks, h1, h2, kp, A, B]);
err := proc (c0, n, s0, ks, h1, h2, kp, A, B) local st1, st2, sv1, sv2, sv; sol(parameters = [c0, n, 175, s0, ks, h1, h2, kp, A, B]); st1 := subs(sol, y1(t)); sv1 := [st1(1), st1(100), st1(210), st1(2500), st1(2800), st1(3000)]; sol(parameters = [5.7/10^6, 10.186, 175, 200, 1/20000000, 10000, .269, 1.5/10^7, 1.5, 2]); st2 := subs(sol, y1(t)); sv2 := [st2(1), st2(100), st2(210), st2(2500), st2(2800), st2(3000)]; sv := add((sv1[i]-sv2[i])^2, i = 1 .. 6); sv end proc;
with(GlobalOptimization);
GlobalSolve(err, c0 = 0 .. 1, n = 1 .. 20, s0 = 150 .. 250, ks = 0 .. 1, h1 = 100 .. 15000, h2 = 0 .. .5, kp = 0 .. 1, A = .5 .. 2, B = 1 .. 5);
Error, (in GlobalOptimization:-GlobalSolve) `InertForms` does not evaluate to a module
Is there a Maple-function that returns a number of transpositions needed to transform a list into a list with some particular order? Actually, I need just a parity of a number of transpositions. All elements of a list are different.
For example, one needs 4 (even) transpositions to transform a list [w,x,y,z] into a list [y,x,z,w]:
[w,x,y,z]->[w,y,x,z]->[y,w,x,z]->[y,x,w,z]->[y,x,z,w]
Please I need someone to help out with how to solve the below ODE numerically using finite difference method with the necessary maple code:
█( S〗_h〗^' (t)=Λ_h-αβ_m I_v S_h-μ_h S_h+πI_m,
〖I_m〗^' (t)=αβ_m I_v S_h-(σ_m+π+μ_h ) I_m
〖 S〗_v〗^' (t)=Λ_v-αβ_v I_m S_v-μ_v S_v
〖I_v〗^' (t)=αβ_v I_m S_v-μ_v I_v )
The initial conditions can be assumed. Suppose i want to include controls, how do I solve the problem and equally plot the graph.
ADENIYI MICHAEL
http://i.imgur.com/JGObjn5.png
I tried with and without evalf. Do I need to import something? or something like with Linear Algebra?
i am solving 3 ODE question with boundary condition. when i running the programm i got this error.. any one could help me please.. :)
restart; with(plots); k := .1; E := 1.0; Pr := 7.0; Ec := 1.0; p := 2.0; blt := 11.5
Eq1 := diff(f(eta), eta, eta, eta)+f(eta)*(diff(f(eta), eta, eta))+Gr*theta(eta)-k*(diff(f(eta), eta))+2*E*g(eta) = 0;
diff(diff(diff(f(eta), eta), eta), eta)+f(eta)*(diff(diff(f(eta), eta), eta))+Gr*theta(eta)-.1*(diff(f(eta), eta))+2.0*g(eta) = 0
Eq2 := diff(g(eta), eta, eta)+f(eta)*(diff(g(eta), eta))-k*g(eta)-2*E*(diff(f(eta), eta)) = 0;
diff(diff(g(eta), eta), eta)+f(eta)*(diff(g(eta), eta))-.1*g(eta)-2.0*(diff(f(eta), eta)) = 0
Eq3 := diff(theta(eta), eta, eta)+Pr*(diff(theta(eta), eta))*f(eta)+Pr*Ec*((diff(f(eta), eta, eta))^2+(diff(g(eta), eta))^2) = 0;
diff(diff(theta(eta), eta), eta)+7.0*(diff(theta(eta), eta))*f(eta)+7.00*(diff(diff(f(eta), eta), eta))^2+7.00*(diff(g(eta), eta))^2 = 0
bcs1 := f(0) = p, (D(f))(0) = 1, g(0) = 0, theta(0) = 1, theta(blt) = 0, (D(f))(blt) = 0, g(blt) = 0;
f(0) = 2.0, (D(f))(0) = 1, g(0) = 0, theta(0) = 1, theta(11.5) = 0, (D(f))(11.5) = 0, g(11.5) = 0
L := [10, 11, 12];
[10, 11, 12]
for k to 3 do R := dsolve(eval({Eq1, Eq2, Eq3, bcs1}, Gr = L[k]), [f(eta), g(eta), theta(eta)], numeric, output = listprocedure); Y || k := rhs(R[3]) end do
R
R
plot([Y || (1 .. 3)], 0 .. 10, labels = [eta, (D(f))(eta)]);
Warning, unable to evaluate the functions to numeric values in the region; see the plotting command's help page to ensure the calling sequence is correct
Download tyera(a).mw
I'm using maple to write text to an external text file. My code is
f := x-> arcsin(x);
file := "C:\\example.txt":
fopen(file,WRITE,TEXT):
fprintf(file,"%a",f(1)):
fclose(file):
The problem is that the output in my file example.txt reads "1/2*Pi" and I'd like it to be "1/2*pi". In other words, is it possible to have maple scan my file and replace the occurances of "Pi" with "pi"?
Is there a way to do the following on Maple:
I want Maple to use Jacobi's method to give an approximation of the solution to the following linear system, with a tolerance of 10^(-2) and with a maximum iteration count of 300.
The linear system is
x_1-2x_3=0.2
-0.5x_1+x_2-0.25x_3=-1.425
x_1-0.5x_2+x_3=2
I'd like to clean up my project a bit. In a chapter of a project I made lots of calculations and declared a many (30) variabeles (Table, Numeric, Formula, ..)
Is there a way to remove all variable's except specified one's? (If it is possible I don't want to use an external file to write it to and read it back after a restart)
Is there a way to do a "restart" and preserve only the one's (2) that I need for my next chapter?
Or if not, without a "restart" and remove all variables except specified one's?
Thanks for your help,
What’s the simplest way to solve an algebraic equation in the complex domain?
For example,
I*(a+3*b)+2*b+5*a = 3+2*I
where a and b are real numbers.
One of my post graduate students chose the theme "Discrete Wavelet analysis of medical signals with Maple" for her thesis. I test, is it possible to support such reearch be Maplesoft &  what may be the form of such support, if it is possible?
First 1390 1391 1392 1393 1394 1395 1396 Last Page 1392 of 2463
