I'm importing a STL geometry with plottools[importplot].
The result is a PLOT3D data structure. Applying "op" to the structure reveals that it is formed by POLYGONS structures.
How can I import the same STL geometry, and, instead of getting a POLYGONS structure, getting a POINTS structure?
I think it should be direct for Maple, because in the plot view configs one can select the style to be surface, contour and even point.
If the conversion has to be by hand, does someone know a not too painful method? For me it's being painful, as I'm trying a solution all the day.
I am numerically solving a nonlinear system of nine equations. How long can I expect it to take?
I have run it for 30 minutes and it has not solved yet.
Here is the system of equations:
0=Lambda-mu.*S-beta.*(H+C+C1+C2).*(S./N)-tau.*(T+C).*(S./N);
0=tau.*(T+C).*(S./N)-beta.*(H+C+C1+C2).*(T./N)-(mu+mu_T).*T;
0=beta.*(H+C+C1+C2).*(S./N)-tau.*(T+C).*(H./N)-(mu+mu_A).*H;
0=beta.*(H+C+C1+C2).*(T./N)+tau.*(T+C).*(H./N)-(mu+psi.*mu_A+mu_T+lambda_T).*C;
0=lambda_T.*C-(mu+mu_A+rho_1+eta_1).*C1;
0=rho_1.*C1-(mu+mu_A+rho_2+eta_2).*C2;
0=eta_1.*C1-(mu+rho_1+gamma).*CT1;
0=eta_2.*C2-(mu+rho_2+gamma.*(rho_1)./(rho_1+rho_2)).*CT2+(rho_1).*CT1;
0 = N - S - T - H - C - C1 - C2 - CT1 - CT2;
and I have numeric values for Lambda, beta, tau, mu, mu_T, mu_A, rho_1, rho_2, psi, gamma. The only parameters left are eta_1, eta_2.
How is vertical text created in a plot?  It would be similiar to using the labeldirection option set to "vertical", but my text in question will be an annotation within the field of the plot.  A more general question would be how to place rotated text within a plot.
Hi everyone.
I wrote simple program with several functions. I would like to obtain parallel computing of my functions. I can't understand how to use nodes.
My programm.
Simple_example.mw
When I input
cos(k*Pi) assuming k::odd
The result is -1
but
(-1)^k assuming k::odd
The result is (-1)^k
Why doesn't the second expression work?
AOA... How are you all. I need the answer of the following question.
input in Maple: expand(exp(a+b)+exp(c+b))
output:  exp(a)*exp(b)+exp(c)*exp(b)
input in Maple: expand(exp(2a+b)+exp(3c+b))
output:  (exp(a))^2*exp(b)+(exp(c))^3*exp(b)
but i need exp(2a)*exp(b)+exp(3c)*exp(b)
PhD (Scholar)
Department of Mathematics
Say for a complicated function f(x), there are 10 solutions. I want to check for any of the solutions, the matrix R is defined or not.
Is there a way to force execution like the following ones?
seq(1/i,i=0..3);
for i from 0 to 3 do
    1/i;
I think the problem is that, Maple stops immediately when it's undefined. But the following terms could be defined.
Or is there a way to put this check into "solve"? That's
> solve(f(x),x, "some way of making sure that the solution has to be defined for the matrix R" )
Is there a way to achieve this?
Hi guys.
I have variables that look like C[i,j,k,l], where i,j,k,l can range between 1..3 for example. Is there a simple way to create a pattern-based assumption for something like C[i,j,k,l] = C[j,i,k,l] for all i,j,k,l ?
Kind regards,
woggy
Maple returns the wrong answer to the following very simple double sum:
T:=(x,m)->sum( sum(binomial(m,k+p),k=1..m-p)*x^p,p=0..m-1);
Maple gives zero for all m>0.  However, the correct answer is a non-zero polynomial in x.
For example, with Maple:
T(x, 3);
The correct answer is  x^2+4*x+7.
It would be helpful if others can check this double sum in their version of Maple and report results.
Does Maple have any tool or package that computes the Fourier & Fourier-Bessel series expansions of a given funtion "f(x)" over a specified interval "[a,b]"?
what are the examples of calculating devices and packages?
I set a physical model for my reseach,
equ1 := x^4-5*x
equ2 := 1/x+x^2+3
x is a function of time t and it meets diff(x(t), t) = equi-equ2.
I want to plot the curve of x(t) varying with time
When I use the following command
DEplot({x(0) = 0, diff(x(t), t) = equi-equ2},x(t), t = 0 .. 20)   it shows: Error, (in DEtools/DEplot) called with too few arguments
Who can tell me what is wrong with my calculation? Thanks
Hi I am working on the following problem (See below the line) from the text A Introduction to the Mathematics of Biology (Ch 2 pgs.21-23). I am working in Maple 18 and the code for this problem is from Maple 11 I think. If you look at the last line of code, I ran into a snag. Can anyone help????? We are in a study Gourp and alll are stumped.
_______________________________________________________________________________________________________
Problem # 2 - Find a fit for the cumulative US AIDS data as a polynomial function. Alsoo find an exponential fit for the data. (assume the Data I have inputed is correct if you don't have the book).
AIDS := [97, 206, 406, 700, 1289, 1654, 2576, 3392, 4922, 6343, 8359, 9968, 12990, 14397, 16604, 17124, 19585, 19707, 21392, 20846, 23690, 24610, 26228, 22768];
CAC := [seq(sum(AIDS[j]/(1000.0), j = 1 .. i), i = 1 .. 24)];
[0.09700000000, 0.3030000000, 0.7090000000, 1.409000000,
2.698000000, 4.352000000, 6.928000000, 10.32000000,
15.24200000, 21.58500000, 29.94400000, 39.91200000,
52.90200000, 67.29900000, 83.90300000, 101.0270000,
120.6120000, 140.3190000, 161.7110000, 182.5570000,
206.2470000, 230.8570000, 257.0850000, 279.8530000]
Time := [seq(1981+(i-1)*(1/2), i = 1 .. 24)];
ln(CAC)=k*lnt+A
LnCAC := map(ln, CAC);
[-2.333044300, -1.194022473, -0.3438997525, 0.3428802329,
0.9925107578, 1.470635510, 1.935571171, 2.334083760,
2.724054775, 3.071998629, 3.399328971, 3.686677031,
3.968441145, 4.209145378, 4.429661370, 4.615387808,
4.792578782, 4.943918402, 5.085810791, 5.207062453,
5.329074480, 5.441798471, 5.549406770, 5.634264465]
LnTime := map(ln, [seq((i+1)/(2*(1/10)), i = 1 .. 24)]);
[ln(10), ln(15), ln(20), 2 ln(5), ln(30), ln(35), ln(40), ln(45),
ln(50), ln(55), ln(60), ln(65), ln(70), ln(75), ln(80), ln(85),
ln(90), ln(95), 2 ln(10), ln(105), ln(110), ln(115), ln(120),
3 ln(5)]
with(stats);
fit[leastsquare[[x, y], y = k*x+lnA]]([LnTime, LnCAC]);
y = 3.293411005 x - 10.12289000
k := op(1, op(1, rhs(%))); LnA := op(2, rhs(`%%`)); A := exp(LnA);
Error, invalid input: rhs received exp(LnA), which is not valid for its 1st argument, expr
exp(LnA)
So, I have the following problem. In my research, I am trying to prove that something is impossible. I do that by encoding it as a set of equations, and asking Maple to solve them, and if it finds that the system has no solutions, I got what I wanted. However, I really wanted to see Maple output this fact explictly, more or less like Mathematica (where I either get an error message, or I get "False" if I use the Reduce command). The reason for this is that I will embed this procedure in a loop that varies some of my starting assumptions, and I want Maple to output that the system has no solutions at each iteration. This is useful since each iteration takes more than half an hour to run, and there are dozens of them, so I want the program to provide me some intermediate feedback, rather than waiting for everything to finish to get an answer.
Is the question clear?
Thanks a lot for the help!
Solve, using 4000 miles for the radius of the earth.
A space shuttle is in circular orbit 150 miles above the surface of the earth. Approximate
  1. the speed
  2. the time required for one revolution.
First 1393 1394 1395 1396 1397 1398 1399 Last Page 1395 of 2463
