Hi, I've written some matrix computation in maple 18 . I wanna open this file in maple 16 ? how is it possible ? any help is appreciated in advance.
Hello, all.
I would like to plot a weighted graph.
Edge weights are floating point numbers (for example, 1,0; 2,0, 3,0, ...).
I tried:
>M := MATRIX([[0., 2.0, 1.0], [2.0, 0., 3.0], [1.0, 3.0, 0.]]);
> with(GraphTheory):
> G := Graph(undirected,weighted,M);
But it doesn't work.
Of course, I can take the edge weight and multiply it by 10 or 100.
May be somebody could provide a more simple solution.
I have the following condition with two unknowns: t1 and t3:
-N*exp(Q1*alpha*eta*t1/(N*w))*exp(-(((N*w-z)*t1^2+((-N*w+z)*t3+2*Q1)*t1+(1/2)*t3*(t3*(N*w-z)-2*Q1))*alpha-2*N*w*C[max]*(t1-(1/2)*t3))*eta/(N*w))*S1*upsilon*w+N*exp(Q1*alpha*eta*t1/(N*w))*exp(-(((N*w-z)*t1^2+((-N*w+z)*t1+2*Q1)*t1+(1/2)*t1*((N*w-z)*t1-2*Q1))*alpha-2*N*w*C[max]*(t1-(1/2)*t1))*eta/(w*N))*S1*upsilon*w+K1^2*exp((1/2)*t1^2*alpha*eta*z/(N*w))*exp(-(1/2)*t1^2*alpha*eta)*exp(t1*eta*C[max])*alpha*eta*t1*z-K1^2*exp((1/2)*t1^2*alpha*eta*z/(N*w))*exp(-(1/2)*t1^2*alpha*eta)*exp(t1*eta*C[max])*alpha*eta*t3*z+K1*exp((1/2)*t1^2*alpha*eta*z/(N*w))*exp(-(1/2)*t1^2*alpha*eta)*exp(t1*eta*C[max])*S1*alpha*eta*t1*z-K1*exp((1/2)*t1^2*alpha*eta*z/(N*w))*exp(-(1/2)*t1^2*alpha*eta)*exp(t1*eta*C[max])*S1*alpha*eta*t3*z = 0
I know that this condition holds when t1=t3. Does there exist an additional solution for t1 and t3 which satisfies this condition?
Dmitry
error in( dsolve/numeric/bvp) unable to achieve the requested accuracy of 0.1e-5 with maximum 128 point mesh (was able to get 0.22e-4), consider increasing `maxmesh` or using larger `abserr`
The above is the error message displayed by maple 17. How do I correct this.
Adeniyi Michael
M:=Array([[a+2*b,b],[x1+y1,z1+z2]]);
pars:=indets(M);
npars:=numelems(pars);
myRand:=RandomTools[Generate](float(range=-3..3),makeproc=true):
set1:={seq(pars[i]=myRand(),i=1..npars)};
numM:=subs(set1,M);
LinearAlgebra:-Rank(numM);
is there a way to make sure that the random values generated from myRand(), subs into M, to make sure that each cell of M is between 0 and 1?
Basically, what I need is being able to simulate some values, subject to each cell of M is between 0 and 1, and find the rank of M. I want to do that efficiently 20 times (or more possibly). Those values that make the cells out of 0 and 1 do not count as 1 of the 20 simulations.
casper
Mytest:=module()
    option package;
    export
        mymain
    # local a,b,c;
    uses LinearAlgebra;
    interface(rtablesize=infinity);
    mymain:=proc(n::integer)
        local ans;
        ans:=Vector(n);
        return ans;
end module;
Here is a short piece of code to create a Maple package. It runs fine. Is that possible to hide the code from print() ?
with(Mytest);
print(mymain); # which displays the source code
Could I hide some of the code? Say I want to use the function mymain() for debugging purpose, but I dont want to make it local to the package. Instead I keep it in "export", but I dont want users to see its code.
Is it possible in Maple 15 to solve an equation with a parameter for a given set of parameters? How can this be passed to the solve function, should I use some kind of list?  After obtaining the solution how can I assign the solutions to variables such as x1 for the first value of the parameter, x2 for the second value of the parameters and so on. Furthermore, is this possible with the fsolve command?
Hello I am a Maple 15 user and I am using the command fsolve to solve for the intersection of two curves over a specified interval in x, namely from 0 to the lim defined in the Maple document. The specified interval contains asymptotes and when I specify the full interval only one of the three solutions is returned even if I can see that there are three distinct solutions by looking at the plot of RHS and LHS. Should I use another technique to find the solution or is my implementation of fsolve command wrong?
with(ListTools):
n1 := 1:
n2 := 1.50:
n3 := 1.40:
lambda := 1.3:
k0 := 2*Pi/lambda:
d := 3:
x0 := k0*d:
arg1 := sqrt(x0^2*(n2^2-n1^2)):
arg2 := sqrt(x0^2*(n2^2-n3^2)):
lim := FindMinimalElement([arg1, arg2]):
sqr1 := sqrt(x0^2*(n2^2-n1^2)-x^2):
sqr2 := sqrt(x0^2*(n2^2-n3^2)-x^2):
LHS := tan(x):
RHS := (sqr1+sqr2)/(x*(1-sqr1*sqr2/x^2)):
plot([LHS, RHS], x = 0 .. lim, y = -6 .. 6)
fsolve(RHS = LHS, x = (1/2)*Pi .. 3*Pi*(1/2))
2.634254816
fsolve(RHS = LHS, x = 3*Pi*(1/2) .. 9*Pi*(1/4))
5.222527128
fsolve(RHS = LHS, x = 9*Pi*(1/4) .. lim)
7.598486053
Download HW4Q2.mw
Hey guys,
i'd like to create a custom component for maplesim. I opened the template in maple18 and defined the following equations:
eq := [p(t) = p__0+rho*g*h(t), Q(t) = A*(diff(h(t), t)), L(t) = 100*h(t)/h(0)]
These equations describes a tank with a liquid in it. Now I tried to define a function L(t) (above) that gives the level of the tank in percentage. Therefore I need the initial height value at t=0. The function defined above (h(0)) does not work, cause maple tells me that the function does not exist.
Any hint how to get an initial value or a value at t=0? Or maybe another way to solve my problem?
Hopefully I described right. :-)
Best regards
Christian
I'm pretty new to Maple and I can't figure out how to input angles in degrees and radians in Maple 16 and in Maple Calculator.
E.g. How could I type 58 degrees, 28 minutes, 18 seconds?
puckie62
How can I compute KroneckerProduct of two matrices in maple 18 ? Any help is appreciated in advance.
Hey guys.
Basically I want to tranverse the syntax tree, replace an indexed expression based on some rule, then return the modified expression. Here is what I am trying to do. Psuedo code below --
applyRule(expr)
   if isSymbol(expr) then
       return expr;
   elif isIndexed(expr) and ruleSatisfied then
       return modified_expr;
      # Apply operator on the sub-expressions
      # This is the part im having trouble with
      return op(0,expr)(op(map(applyRule, [op(expr)])));
   end if:
The line marked with the comment above works MOST of the time, but it'll fail for indexed objects (A[i,j] becomes A(i,j)). The unapply function looked promising, but that also has some corner cases (e.g. if I try to deconstruct the expression A = B*C it will fail)
Kind regards,
woggy
I'm trying to resolve a differential equation system and plot it. But when I use the "odeplot" command, just appear the words in blue and there's no graphic. Does anyone know whats happening?
Dear all;
Thank you very much is you can make the computation using maple.
I have this system:
x'(t)=x*y-x^2*y+y^3;
y'(t)=y^2+x^3-x*y^2;
I would like to make to change the system in another system using polar coordinate: like x=r*cos(theta) and y=r*sin(theta), and then derive a simple system: r'=F(r, theta) and theta'=G(r, theta), where here F and G are two unknowns functions.
Many thinks if someone can help me using a Maple code.
Hello everyone.
I have lots of lengthy equations in Maple that I don't want to waste time for rewritting them. I am looking for a clean and tidy way to export these equations from Maple and import them into a LaTeX or Word document.
As an example do it with the equation in the following file.
Example.mw
Many many thanks.
First 1392 1393 1394 1395 1396 1397 1398 Last Page 1394 of 2463
