I keep getting an error about the while. It is calling it an invalid if statement.  It may relate to semi colons, but I cannot find any errors myself. Please help.
InterpolIDW2:=proc(n,rwin,mink,p,R,IR)
local ix,iy,i,j,i0,i1,j0,j1,k;
local count,wgt,top,bot,hp;
print(`n=`,n,`rwin=`,rwin,`mink=`,mink,`p=`,p);
hp:=p/2;
for iy from 1 to n do
for ix from 1 to n do
if (IR(ix,iy)=0) then
i0:=max(1,ix-rwin);  i1:=min(n,ix+rwin);
j0:=max(1,iy-rwin);  j1:=min(n,iy+rwin);
k:=add(add(IR(i,j),i=i0..i1),j=j0..j1)
while (k<mink )do
if(i0>1) then
i0:= i0-1;
k:= k+ add(IR(i0,j),j=j0..j1)
if(i0<1) then
i0:=i0+1;
if(j0>1) then
  j0:=j0-1;
  k:= k+ add(IR(i,j0),i=i0..i1)
 if(j0<1) then
 j0:= j0+1;
top:=0;  bot:=0;
for j from j0 to j1 do
for i from i0 to i1 do
if (IR(i,j)<>0) then
wgt:=1/evalf[14](((ix-i)^(2)+(iy-j)^(2))^(hp));
top:=top+wgt*R(i,j);
bot:=bot+wgt;
R(ix,iy):=top/bot;
I'm trying to solve a series of equations and then graph them. I'm trying to solve for the variables involved:
values := solve({eq1, eq2, eq3, eq4, eq5, eq6, eq7, eq8, eq9,
eq10, eq11, eq12, eq13, eq14, eq15, eq16}, {a, b, b, c, d, e, f,
g, h, i, j, k, l, m, n, o, p});
. . . but it gives me this:
Warning, solving for expressions other than names or functions is not recommended.
values :=
int(int(y, 0 <= y, x^2+y^2+z^2 <= 1));
Error, (in int) integration range or variable must be specified in the second argument, got 0 <= y
int(int(y, y = 0, x^2+y^2+z^2 = 1));
Error, (in int) integration range or variable must be specified in the second argument, got y = 0
Am trying to create a gif file of  a cantilevered door opening with the aid of a coil spring.  The program is given below in text format.  At the end is a for/do loop which gives a series of pictures of the side view of the door opening.  I'd like to animate these and be able to create a gif file. The use of animate seems to require a function F(x,t) of two variables - one being time. My calculations do not involve time.  Any help gratefully received.
> with(plots): with(plottools):
> #Problems:
> #gif file???  Use of animate
> printlevel:=0:
> #h=doorheight;  h1=dist from floor to pivot point; base=dist of cantilever #connection to end of garage door
> h:=206:h1:=115:
> doorheight:=h:
> base:=24:
> #Spring data
> sbase:=0.4*base:  #sbase is height of base of spring connection point
> #Lower & upper proportions of spring length as ratio of spring length
> propn1:=0.2: propn2:=0.95:  #propn2 > propn1
> #alpha is inclination angle of coils in the spring
> alpha:=Pi/6:
> #nc is Number of Coils in Spring
> nc:=24:   #92 in my actual spring
> #Garage door (closed position lightly shown)
> gdupright:=line([0,0],[0,h], linestyle=2, color=grey):
> #cr is Cantilever Radius
> cr:=h1-base:
> #Counter-balance extension length is cr_ext
> cr_ext:=12:  # 62
> doorwidth:=0.05*h:
> guidewidth:=doorwidth*1.015:
> #macro(skyblue = COLOR(RGB, 0.1960, 0.6000, 0.8000));
> macro(palegreen=COLOR(RGB, .5607, .7372, .5607)):
> #g1 (top) & g2 are guides for door support
> #g_ext is guide extension proportion of guides above the door
> g_ext:=0:
> g1:=line([-doorwidth/2,doorheight*(1+g_ext)+guidewidth],[doorheight*(1+g_ext),doorheight*(1+g_ext)+guidewidth], color=palegreen):
> g2:=line([-doorwidth/2,doorheight*(1+g_ext)],[doorheight*(1+g_ext),doorheight*(1+g_ext)], color=palegreen):
> garagefloor:=line([-h*.65,0],[doorheight,0], color=black):
> rooflevel:=line([-h*.65,(1.05+g_ext)*h+guidewidth],[doorheight,(1.05+g_ext)*h+guidewidth], linestyle=2,color=grey):
> #Pivot point - pivpoint
> pivp_x:=0.019*h:   #doorwidth:
> #printf("pivp_x= %8.2f doorwidth= %7.1f\n",pivp_x,doorwidth):
> pivpoint:=circle([pivp_x,h1],doorwidth/2, color=red): #doorwidth/2 for radius - #use cr to check
> #mpp is mid point of rotation
> mpp := point([pivp_x,h1], color=black):
> #connect_point[j]:=circle([pivp_x+cr_ext*sin(theta),h1+cr_ext*sin(theta)],doorwidth/2, color=red):
> lastj:=4:    #Number of angle diplays -1 (for 0)
> #printf("Rotation Angle of cantilever (degrees) & distance along the guide arm (cm)  hc   kc"):
> for j from 0 to lastj do
> theta:=j*Pi/lastj:
> # hc was changed from cr*sin(theta)
> hc:=pivp_x-cr*sin(theta):kc:=h1-cr*cos(theta):
> x:=pivp_x-cr*sin(theta)+sqrt((h-base)^2-(h-kc)^2):
> #printf("%8.2f %7.1f    %5.2f   %5.2f\n",theta*180/Pi,x,hc,kc);
> if j=lastj then phi:=Pi/2:
>  else
> phi:=arctan((cr*sin(theta)+x-pivp_x)/(cr*(1+cos(theta))));
> end if:
> #Sides of door, starting at NW corner & going anti-clockwise
> door1 := line([x-doorwidth*cos(phi),h+doorwidth*sin(phi)],[x,h] , color=black):
> door2 := line([x,h],[x-h*sin(phi),h-h*cos(phi)] , color=black):
> door3 := line([x-h*sin(phi),h-h*cos(phi)],[x-h*sin(phi)-doorwidth*cos(phi),h-h*cos(phi)+doorwidth*sin(phi)], color=black):
> door4 := line([x-h*sin(phi)-doorwidth*cos(phi),h-h*cos(phi)+doorwidth*sin(phi)],[x-doorwidth*cos(phi),h+doorwidth*sin(phi)], color=black):
> #Counter balance arm
> cba:=line([x-(h-base)*sin(phi),h-(h-base)*cos(phi)],[pivp_x+cr_ext*sin(theta),h1+cr_ext*cos(theta)],color=blue):
> #Spring calcs # ???
> spring:=line([pivp_x,sbase],[pivp_x+cr_ext*sin(theta),h1+cr_ext*cos(theta)], linestyle=2, color=grey):
> #Turnbuckle
> tbuck1:=line([pivp_x,sbase],[pivp_x+cr_ext*propn1*sin(theta),sbase+propn1*(h1-sbase+cr_ext*cos(theta))], color=black):
> #for tbuck2 see below - it requires angle chi
> chi:=arctan(cr_ext*sin(theta)/(h1-sbase+cr_ext*cos(theta))):
> tbuck2:=arc([pivp_x,sbase],doorwidth/6,Pi/2-chi..3*Pi/2+.2, color=blue):
> #sl is spring length (l is the letter L lower case)
> sl:=sqrt(cr_ext^2+(h1-sbase)*((h1-sbase)+2*cr_ext*cos(theta))):
> for i from 0 to nc do
> x1[i]:=pivp_x+(propn1+(propn2-propn1)*i/nc)*sl*sin(chi):
> y1[i]:=sbase+(propn1+(propn2-propn1)*i/nc)*sl*cos(chi):
> connect_point:=circle([pivp_x+cr_ext*sin(theta),h1+cr_ext*cos(theta)],doorwidth/4, color=blue):
> printlevel:=1:
> #printf("x[%g] = %8.2f  y[%g] = %8.2f theta = %8.2f chi = %8.2f\n", i,x[i],i,y[i],theta*180/Pi,chi*180/Pi);
> #####---PRINT STATEMENT  (NB 2 #)
> #printf("i=%g x = %4.2f  y = %5.2f theta = %6.3f chi = %7.3f  Sp len=%5.3f\n",
> #i, x1[i],y1[i],theta*180/Pi,chi*180/Pi,sl);
> s_coil[i]:=line([x1[i]-doorwidth/2,y1[i]-doorwidth/2*tan(alpha-chi)], [x1[i]+doorwidth/2,y1[i]+doorwidth/2*tan(alpha-chi)], color=blue):
> end do:
> #Coords of end of spring (& counter-balance arm) are #[pivp_x+cr_ext*sin(theta),h1+cr_ext*cos(theta)]
> #Line from top of spring to kicker bolt
> #connectline[j]:=line([pivp_x+cr_ext*sin(theta),h1+cr_ext*cos(theta)], #[x1[nc]+doorwidth/2,y1[nc]+doorwidth/2*tan(alpha-chi)], color=green):
> printlevel:=-1:
> frame[j]:=plots[display](door1,door2,door3,door4,garagefloor,rooflevel,g1,g2,gdupright,pivpoint,cba,mpp,connect_point,seq(s_coil[i],i=0..nc), tbuck1,tbuck2, scaling=constrained, axes=none):
> end do;
> printlevel:=1:
> frame[j];
> end do;
> animate( frame[j],j=0..lastj,t=1..2,frames=50);
A major-league pitcher releases a ball at a point 6 feet above the ground and 58 feet from home plate at a speed of 100 mi/hr ,
If gravity had no effect, the ball would travel along a line and cross home plate 4 feet off the ground. Find the drop D caused by gravity.
NB: in this problem the angle alpha is the angle between the horizontal and the direction of the released ball. Since the ball is dropping, alpha will be negative.
Hi every body:
i have a second order ode and will convert to two ode of first order with maple,how do this work???
eq := diff(y(x), x, x)+2*y(x)+y(x)^2 = 0
taylor(1/(1+z^2), z = 1, 4)
The result is
1/2-(1/2)*z-1+(1/4)*(z-1)^2+O((z-1)^4)
but in fact the result is
1/2-(1/2)*(z-1)+(1/4)*(z-1)^2+O((z-1)^4)
my Maple is Maple 16,How to solve this problem?
Hi there,
is it possible to have the legend of a pointplot accepting arguments?
Say I have an array of 3 values (e.g. p:=[1.5,2,2.5]) representing a given parameter for a function. When representing this function by means of a plot, I would like the legend (legend="Parameter " + value in array; legend=["Parameter", "Parameter", "Parameter") to accept the contents of the array, without entering the values manually:
Parameter 1.5
Parameter 2
Parameter 2.5
How can this be achieved?
jon
When I plot an expresion I would the graphics be framed. What I am getting, instead, is the curve and the axis, whith no frame at all. How can I force Maple to make the graphic surrounded by a frame?
Archimedes supposedlly, was asked to determine whether a crown made for the king consisted of pure gold. According to
legend, he solved this problem by weighing the crown first in air and then in water. Suppose the scale read 7.84 N when the
crown was in the air and 6.84 N when it was in water.
What should Archimedes have told the king ?
Hi! I have a matlab worksheet that i need to convert it to Maplesoft. Is it possible?
Hikmat
Take a look at below. I was expecting maple to give me "g'(1)"! :)
hi.i am a problem with following dsolve.please help me....thanks alot
dsys3 := {10*f2(x)+12*(diff(f1(x), x))+14*f3(x) = 0, 2*(diff(f1(x), x, x))+4*(diff(f2(x), x))+6*(diff(f3(x), x)) = 0, 16*(diff(f3(x), x, x, x, x))+19*(diff(f3(x), x, x))+22*(diff(f1(x), x))+25*f2(x)+27*f3(x)+29*f3(x)+31+32 = 0, f1(0) = 0, f1(1) = 0, f2(0) = 0, f2(1) = 0, f3(0) = 0, f3(1) = 0, ((D@@1)(f1))(0) = 0, ((D@@1)(f1))(1) = 0, ((D@@1)(f2))(0) = 0, ((D@@1)(f2))(1) = 0, ((D@@1)(f3))(0) = 0, ((D@@1)(f3))(1) = 0}; dsol5 := dsolve(dsys3, 'maxmesh' = 500, numeric, range = 0 .. 1, abserr = .1, output = listprocedure); fy3 := eval(f3(x), dsol5); fy2 := eval(f2(x), dsol5); fy1 := eval(f1(x), dsol5)ERROR.mw
ADIABATIC FREE EXPANSION
Suppose an ideal gas expands to four times its initial volume. From experience for this process, the initial and final
temperature are the same.
  1. Using a macroscopic approach, calculate the entropy change for the gas
  2. Using statistical considerations, calculate the change in entropy for the gas and show that it agrees with the answer
    you obtained in part 1.
What is the probability that the total of two dice will be greater than 9, given that the first die is a 5?
First 1394 1395 1396 1397 1398 1399 1400 Last Page 1396 of 2463
