Hi there,
I'd like to solve 7th order implicit simultaneous equation such as below, so I tried to do it by solve command.
However the calculation wasn't over although three hours passed.
eq1 := f1(a,b,c,d,e,f,g) = 0;
eq2 := f2(a,b,c,d,e,f,g) = 0;
eq7 := f7(a,b,c,d,e,f,g) = 0;
Just for your information, the eq1 and eq6 are written as follows specifically.
eq1 := -a-b-c-d-e-f-g+0.501857 = 0
eq6 := a*b*c*d*e*f+a*b*c*d*e*g+a*b*c*d*f*g+a*b*c*e*f*g+a*b*d*e*f*g+a*c*d*e*f*g+b*c*d*e*f*g+a*b*c*d*e+a*b*c*d*f+a*b*c*d*g+a*b*c*e*f+a*b*c*e*g+a*b*c*f*g+a*b*d*e*f+a*b*d*e*g+a*b*d*f*g+a*b*e*f*g+a*c*d*e*f+a*c*d*e*g+a*c*d*f*g+a*c*e*f*g+a*d*e*f*g+b*c*d*e*f+b*c*d*e*g+b*c*d*f*g+b*c*e*f*g+b*d*e*f*g+c*d*e*f*g-0.5281141885e-3+1.01894577*10^(-12)*I = 0
And the program code I used is:
solve([eq1,eq2,eq3,eq4,eq5,eq6,eq7],[a,b,c,d,e,f,g]);
Here is the specification of my computer.
OS: Windows 7 Enterprise 64bit
CPU: Intel Core i7-3520M 2.90 GHz
Memory: 4.00 GB
How can I handle this problem? Is the specification not enough to solve the equation? Do I need to leave my computer more and more time?
Any help would be appriciated.
the following program dont work
a := 1;
b := 2;
c := 3;
d := 4;
eq1 := a*x[1]-b*x[2] = 0;
eq2 := c*x[2]-d*x[1] = 3;
dd := fsolve({eq1, eq2}, {x[1], x[2]});
evalf(sin(dd[1]));
wouldyo please help me?
This may be just my lack of maple syntax, however I cannot seem to find a way to add upper indicies in tensors (without first converting them to some other object, array, matrix etc)
In the physics package an example is just the metric tensor.
I am trying to do something like this:
with(Physics);
add(g_[~mu,2], mu=1..2)
Is there an easy way of summing upper indicies? Obviously lower indicies work, because the add/sum command recognizes the variable to iterate.
Thanks in advance,
Age
 1) find  the direction in which f(x,y) increases most rapidly at the point P(1,2), and find the maximum rate of increase
of f at P.
Interpret 1) using the graph of f.
Let f(x,y) = 2+x^2 +1/4*(y^2)
Download Problem_#7_Instructor_#4.mw
First, thanks for taking the time to read this post. I'm trying to solve a system of equations, that consist of some complicated arguments. I've tried simplifying it a number of ways, and I've even tried using fsolve({...},{...}), but it will not yield any results. It only gives the response "Warning, solutions may have been lost". The link to the worksheet is posted above. I'm new to this program and forum, so I was not sure whether to upload the link or the contents (I can send the other if necessary.). Your help is much appreciated.
Stephen
Having solution of an inequations system, is there a way/function/algorithm to find a particular numeric solution (as simplex[minimize] can do) ?
ex:
Q := {1 < x - y, x + y < 1};
R := solve(Q);
      { x < 1 - y, y < 0, y + 1 < x }
manually it's easy to find some numeric solutions:
      y = -1, x = 1
      y = -2, x = 0
but I need an automatic way.
Thank you for your help
s.py
I need to build a multibody model in MapleSim 6.4 in which with few global parameters I can describe all the other parameters. In other words the final user will enter this few parameters, that are coordinates of specific points, and then the model will calculate all the relative distances on the base of those coordinates.
The problem is that if I apply trigonometric function and square root (like in the screenshot) the model is not calculating any value. Is it possible to make those calculculations?
this is the model (don't worry about the nonsense plots, it's because it's not ultimated):
DWS.msim
a+c^2
5*a+b^5
2*a+b^2*c+3*c
assume system of polynomials are above, how to test whether inverse exist
and find inverse of them
Hi all
I want to produce following c_nm's(which are differentiation based formula) . assume that N and M are known and f(t) is arbitrary. also n=1,2,...,N and m=0,1,..,M-1
how can we do this?
regards
Mahmood   Dadkhah
Ph.D Candidate
This Maple 13 so maybe things have been fixed. Here are four points whose convex hull consists of three points. Sometimes the result comes out correct, more often it does not. With numbers this small it shouldn't be an issue of roundoff. But changing digits changes the result!
Hi all
kx,ky is the wavenumber, how can I get the 4 cases of piecewise function according to kx=0,kx≠0 and ky=0,ky≠0. Thanks
J := `assuming`([4*(int(int(JJ*exp(-I*(kx*x+ky*y))*sin(2*l*pi*x/a)*sin(2*k*pi*y/b), x = 0 .. a, AllSolutions), y = 0 .. b, AllSolutions))/(a*b)], [k::posint, l::posint, a > 0, b > 0, JJ > 0])
Let a planar polygon P without selfintersections be given through the plottools:-polygon command.
How to find its triangulation as a set of triangles (The indication of common sides is desired too.) in an optimal way with Maple? This is used in the finite element method.
Triangulation
So this is the errorcode I get and my code is
> r := (x1, y1, x2, y2) options operator, arrow; (sqrt((x2-x1)^2+(y2-y1)^2))^2
> hreg := (A, C, x) options operator, arrow; A*x+C
> hpconf := (Q, x1, y1, x2, y2) options operator, arrow; Q*(1/4)*ln(2.25*b*K*t/(S*r(x1, y1, x2, y2)))/(3.14*K*b)
> he1 := (x, y, C) options operator, arrow; hreg(A1, C, x)+hpconf(Q1, x, y, xp1, yp1)+hpconf(Q2, x, y, xp2, yp2)+hpconf(Q3, x, y, xp3, yp3)+hpconf(Q4, x, y, xp4, yp4)
> C1 := solve(he1(-75, 0, C) = 20, C);
> plot3d(he1(x, y, C1), x = -75 .. 75, y = -75 .. 75, style = surfacecontour, axes = box);
I have defined all the constants, and squareboxes shouldn't be needed for the plot, right?
properties of operations on sets?
Example:
is((A minus B) intersect (A minus C) = A minus (B union C)) assuming A::set, B::set, C::set;
        FAIL
I currently have:
plot3d(78.9*x+49.1*y+15.7*(1-x-y), x = 0 .. 1, y = 0 .. 1)
I have ratios x, y and z and the ratio of z is implicit from the ratios of x and y (z=1-x-y), therefore whenever x+y>1 the surface is meaningless as it gives z as a negative ratio.
I want the surface to be plotted only for x+y<1, so something like:
plot3d(78.9*x+49.1*y+15.7*(1-x-y), x = 0 .. 1, y = 0 .. 1, x+y<1)
But I can't find a suitable command.
Thanks in advance,
Tom.
First 1398 1399 1400 1401 1402 1403 1404 Last Page 1400 of 2463
