I am new to the Maple Forum and have the following question.I am calculating some Gaussian error propagations and other equations and did this in this way:
[eval(diff(x(y,z),y),[y=...,z=...])2*(dy)2+eval(diff(x(y,z),z),[y=...,z=...])2*(dz)2]1/2
Now I am having several dozens of different y and z for which I have to calculate the above equation. How can I define these variables y and z only once at the beginning before all equations and press the button !!! that everything afterwards is just calculated with the defined variables? This way I would only have to change the variables once instead of several times in each term and for each equation.
Thank you very much. I appreciate your help!
L
Is it possible to evaluate a function at multiple points described by an array or something of that sort and have Maple return the evaluations as an array. I need approximations of a function at various values of its argument so it would be nice to do it with a single command.
How do I make "simplify" function to recognize complex exponentials. Maple created some exponentiol functions with a square root of negative expression in the denominator of the exponent. It refuses to simplify it. If I manually edit it, by taking negative sign under the root and adding immaginary number, the simplification works. How do I simplify it without manual edit?
The Eq 33 is manually edited line. Simplify function correctly uses cos function.
The Eq 34 is original expression. I tried to tell maple to assume real numbers hoping that it will wotk, but it did not.
I have question about how to write the expression to get the order in the sequence?
For exmple, if I have this sequence,
E:=[0,2,7,15,26,40]
I want to write a procedure that tells me the location of any input,x in the sequence E.
For example, if I choose x:=3, then the number 3 is actually between 2 and 7, so it will give me the answer C(x)=3 (because 7 is the third elemet).
I try to write the procedure but there always wrong! I do not know what expression should I write!
C:=proc(x)
local
for i from 1 to nops(E) do
if x<=E[i] then
c:=E[i]
fi;od;
end;
Please help!
hi
I need your help,it is very necessary.I want to write two dimensional arrays to a file ,and then I should be able to read it again.I appericiate your help.
How do i use d'Alembert formula to solve,plot and animate with Maple software
I seem to run into problems with (quantum) perturbation theory. In the following minimal working example, an energy denominator, as occuring in perturbation theory is not evaluated if I previously assume that the quantum number is a positive integer. It's supposed to return an error, as the energy denominator is 0.
restart; with(Physics)
a := Annihilation(N, 1, notation = explicit):
psi := Ket(N, m);
Physics:-Ket(N, m)
E := proc (g) options operator, arrow; (1/2)*g*(g-1)-mu*g end proc:
simplify(value(Typesetting:-delayDotProduct(Typesetting:-delayDotProduct(Dagger(psi), 1/(E(m)-H)), psi)))
-I/(Im(m)*(2*Re(m)-1-2*mu))
assume(`in`(m, nonnegint), m > 0);
-2*Physics:-Bracket(Physics:-Bra(N, m), 1/(-2*mu*Physics:-`*`(`a-`[N[1]], `a+`[N[1]])+2*mu*m-m^2+Physics:-`*`(Physics:-`^`(`a-`[N[1]], 2), Physics:-`^`(`a+`[N[1]], 2))-4*Physics:-`*`(`a-`[N[1]], `a+`[N[1]])+2*mu+m+2), Physics:-Ket(N, m))
Parse:-ConvertTo1D, "invalid input %1", `.`(Dagger(psi), 1/(E-H), psi)
2/(2*mu*m-m^2+2*E+m)
Download energy_denominator.mw
Best regards,
Sören
how to calculate the cobordism between two ideals
I was helping for a computing session today.
Maple 17 and 18 were not plotting the following:
spacecurve([x,cos(x), sin(x)], x = 0..10);
On some of the machines, with campus site license, windows 7, x64.
The plot came up with a "frame" only. And nothing was plotted.
We really can't figure out why?
Something to do with the settings(options)?
Had anyone had a similar experience?
casper
Find a series solution of the differental equation
y'=2*x*y
do graph have invariant for invariant of cayley graph
for example, how to convert below word relation into graph
a^2 = 1
a*b = b*a
my code can only do for one variable,
how to make divisible checking for multivariable cases with the ordering such as plex
IsDivisible(LP(h, t), LP(g[i], t), x)
it is not only x when multivariable
f:=LP(y^2*x,plex(x, y))[2];
g:=LP(y*x-y,plex(x, y))[2];
Remainder(f, g, gcd(f,g));
degree(Remainder(f, g, x),x);
degree(g, x);
remainder has error expect its 3rd argument x, to be of type or but received y*x
how to do if have ordering
do it need to check whether both f and g have variable x using indets and then apply remainder?
do it need to check each variable starting from the first variable in the ordering?
how about if f has variable x but g do not have variable x, or f do not have variable x and g have variable x
if so, i try to replace below code in the bottom code, it has error
Error, (in FindDivisble) cannot determine if this expression is true or false: 0 < Search(x, {x, y})
FindDivisble := proc(g, h, t)
with(ListTools):
result := 0;
for i from 1 to nops(g) do
mainvariable := 0;
for j from 1 to nops(t) do
mainvariable := op(j, t);
if mainvariable <> 0 then
if Search(mainvariable, indets(h)) > 0 and Search(mainvariable, indets(g[i])) > 0 then
if IsDivisible(LP(h,t), LP(g[i],t), mainvariable) = 0 then
return i;
result := 0;
end if:
end if:
end if:
return result;
with(Groebner):
LP := proc(f, t)
return LeadingTerm(f, t)/LeadingCoefficient(f, t);
IsDivisible := proc(f, g, x)
with(Algebraic):
if Remainder(f, g, x) = 0 or degree(Remainder(f, g, x),x) < degree(g, x) then
return 0;
return 1;
end if:
result := 0;
if IsDivisible(LP(h, t), LP(g[i], t), x) = 0 then
return i;
result := 0;
end if:
return result;
MD := proc(f, g, t)
r := 0;
u := Matrix(nops(g), 1);
for j from 1 to nops(g) do
u[j] := 0;
h := f;
while h <> 0 do
i := FindDivisble(g, h, t);
if i > 0 then
u[i] := u[i] + LeadingTerm(h, t)/LeadingTerm(f[i], t);
h := h - LeadingTerm(h, t)/LeadingTerm(f[i], t)*f[i];
r := r + LeadingTerm(h, t);
h := h - LeadingTerm(h, t);
end if:
f:=y^2*x;
f1 := y*x-y;
f2 := y^2-x;
MD(f,[f1,f2],plex(x, y));
So I'm trying to make a procedure to tell is a sequence is graphical or not.
seqgraph:= proc (L::list)
local k::integer, i::integer, n::integer, a::integer, S;
n := numelems(L);
S := convert(L, `+`);
a := 0;
if type(S, odd) then print("not graphical")
else for k to n do
if add(L[i], i = 1 .. k) <= k(k-1)+add(min(k, L[i]), i = k+1 .. n) then a := a+1
else a := a+2
if n = a then print(graphical)
else print("not graphical")
 I'm trying to say that if that equality (which is part of the erdos gallai theorem) holds for that value of k then we'll add one to a value (a). Thus, if a=n at the end then the ineuqality was true for each k and thus it would it should print "graphical" but every list I test it one prints 'not graphical'. Where is my mistake? I get an error saying it can't execute add?
From some scientific experiments, the following set of data is available
(1.0, 2.33),(2.0, 0.0626),(3.0, −2.16),(4.0, −2.45),(5.0, −0.357),(6.0, 2.21),(7.0, 2.75),(8.0, 0.636),(9.0, −2.45).
We need to use least squares method to fit the curve to the data
y = a + b cos(x) + c sin(x) + d cos(2x) + e sin(2x)
Show your solution procedure in Maple and get the best fit for the coefficients. Finally
plot the data and the y curve together on the same graph to visualize the fitting. For the
data, use blue circles while for the y curve, use red solid line style. Use the leastsquares
command we learned in LinearAlgebra package.
First 1401 1402 1403 1404 1405 1406 1407 Last Page 1403 of 2463
