I am stuck with the following problem:
convert(cos(alpha), exp); works fine for me.
Once I have the trigonometric functions in a matrix, it does not work any more:
In the latter line, A keeps the trigonometric functions. Why is this the case? Is there any way to force maple to keep the complex exponentials instead of trigonometric functions?
I am using LinearAlgebra and VectorCalculus.
Best Regards
Wassja
how to calculate the RicciTensor for system of 3 polynomials equations in 3 variables
i find examples using differential expression, how to do for system of polynomial equations
Riemannian metric of constant sectional curvature
expect to test whether metric of constant sectional curvature g(t) = 1 when t tends to infinity or finite T
with(DifferentialGeometry):
with(Tensor):
DGSetup([x,y,z],M);
C1 := Connection();
R1 := CurvatureTensor(C1);
Ric1 := RicciTensor(R1);
sys := Diff(g(t), t) = -2*Ric1;
According to kernelopts(version), I am using Maple 16.02, X86 64 LINUX, Nov 18 2012, Build ID 7888210 , having just updated
Maple 16.
I have a Maple worksheet with some graphs of 10^5 data points. When I export the worksheet to a pdf for inclusion in a LaTeX document (with pdfpages package, this recognizes page breaks), the file is around 100 Mb, much larger than I would like.
It seems that the file is large as a figure in the pdf is not just an image, the pdf seems to contain all of the information necessary to plot each data point individually.
Is there some way to encourage Maple 16 to treat figures as bitmaps (or something similarly much smaller than the original figures) upon exporting a worksheet to a pdf? I'll be happy for any suggestions.
NOTES:
1. This question was originally for Maple 16.00. Updating to 16.02a has not solved the problem.
2. I am suspicious that there is some bug in how Maple 16 exports figures made with "plot" to a pdf file.
When I try various methods of compressing the pdf that I've seen on the web, such as with pdftk 1.44, or ghostscript 8.70 or 9.07,  or pdf2ps followed by ps2pdf ,
error messages are returned. For example using pdftk:
pdftk input.pdf output.pdf
gives
"Done. Input errors, so no output created"
Ok guys, so i have a bunch of datapoints in 3d (x,y,z)
I'm trying to calculate an equation using maple that will express z as a function of x and y.
I've been browesing around for like 2 hours now with no hope. Help?
Is there any command in maple that can show us an assigned varibale how much bytes occupied on memory ?
a:=["just a string", 3.14 , 123 , x/y]
d:=array( 1 .. 2, 1 .. 2, [( 1, 1 ) = ("just a string"), ( 1, 2 ) = (3.14), ( 2, 1 ) = (123), ( 2, 2 ) = (x/y)  ] )
c:=a x^2 + b x + c
b := Matrix(2, 2, {(1, 1) = "just a string", (1, 2) = 3.14, (2, 1) = 123, (2, 2) = x/y})
It should be great for benchmarking !
how to add another line in this template of formula
use the expression template
how to add another line like
thank you in advance for your help
Der Group,
after updating to OS X Yosemite the License data of Maple 18 are invalid. What can I do?
Yours
Berthold
Hi Maple friends.
If I have y=-x^2+9 and y=x+3, how can I find the area that is bounded by the functions?
Easy enough to calculate by hand, but I need to use Maple to check my answers. Most preferably I'd like to use the Maple context menu to get the result, but any solution will be appreciated.
Can anyone tell me where I can find tutorial explaining how to solve laplace transform? I need a tutorial that explains starting with simple resolution to advanced resolution.
Hi all;
I have following program for plotting numerous function using hybrid functions.
if g1(t) is arbitrary function and g2(t) is its approximate by hybrid functions, I want to have a table of g1(t)-g2(t) for different value of t. but the result is without numeric values. what part is wrong????
best wishes
OHB.mws
Mahmood   Dadkhah
Ph.D Candidate
Hi Everyone,
I have an expression that contains a second order derivative: EXPR:=ay''(x) + bz'(x) + cf'(x)+... The variable y  obeys an ordinary differential equation, y''(x) = f(y,x). I would like to replace the second order deriavtive in my expression with f(y,x). So far I have tried applyrule([y''(x)=f(y,x)],EXPR), subs(y''(x)=f(y,x),EXPR) and algsubs(y''(x)=f(y,x),EXPR) and nothing seems to work. Any helpful suggestions?
How to calculate the Amplitude of two combined sinusoidal of different frequency and phase of a general equation as:
A sin(\omega_1 t)+B sin(\omega_2 t+\theta)
I need to know if the Software Maple solve, step-by-step series of Fourier and Laplace transforms? The Maple command has to solve step by step series of Fourier and Laplace transforms? or commands show only the direct solution?
I have a set "EQ" containing N linear equations in N unknowns. The only symbolic variables in each "EQ[i]" are the unknowns. I want to write a procedure that derives the matrices "A" and "b" where A.x=b is the same linear system stored in "EQ". In other words, I want to write the linear system in the matrix form.
Can anyone guide me through writting such a procedure?
As an example do it with the system written in the following file.
Note: This procedure will be used for large linear systems (e.g. 2000 Equations, 2000 Unknowns) so it will be important that the procedure uses the least operations required.
LinearSystem.mw
I have a large system of linear algebraic equations that I want to solve (2005 Unknowns, 2005 Equations). I was wondering that what are the proper commands to use in maple for solving the system as fast as possible. Take a look at the files in the download link if you want to see the system of linear algebraic equations.
http://pc.cd/h79
Please provide me any suggesitons that you may think will be helpful like using other sofwares that are good in doing this work such as MATLAB or something else.
Thanks in Advance
First 1399 1400 1401 1402 1403 1404 1405 Last Page 1401 of 2463
