I need your help to create a band matrix of n block,   and each block of the matrix is given by:
A=[[1,2,3];[2,1,3]; [3,2,1]]:
Thanks for your help
I'm trying to find the partial sum of the function. Now I need to plot the first couple partial sums onto 1 graph.
I'm not really sure how to input the plot function. I was able to graph it by inputting each partial sum function but I would prefer an easier solution.
Hi every body:
i will earn the cofficients of q(T),q(T)^2 and (diff(q(T), T, T)) with commonds maple,how?
eq := 324.6463527*(diff(q(T), T, T))+4.012505275*10^11*q(T)+3.589858529*10^12*q(T)^2 = 0;
Hey guys,
I have a problem with this code:
d := Array(1 .. 15);
for i to s1 do
for c2 to 15 do
if `mod`(c2+(J+H)*(`mod`(1/(H+1), A[i])), A[i]) = 0 then d[c2] := d[c2]+l(A[i]) else d[c2] := d[c2]end if
end do
d;
The problem is that my code stops running when I encounter that `mod`(1/(H+1), A[i]) doesn`t have an modular inverse. What I would like to have is that the loop just continues and does nothing when my array when it encounters an error.
Hope you can help me!
I am quite new on Maple and Maplesim. A co-worker and I are evaluating a demo version (Maple 18 with Maplesim 7) for a possible purchase in 2015. For the project my collegue and I are working on, we need to detect when a signal becomes zero in order to switch between two options. We were trying to do this using the "Change" or "Boolean Change" components (the difference between those two is not really clear to us). Correct me if I am wrong, but those components should detect when a boolean signal has a change in value (both rising or decreasing) and in that case the output should become TRUE, while otherwise is FALSE.
The problem is that the component work if a "Terminate" is connected, but the output is always FALSE in any other case.
At the bottom we are attaching a file with two very easy examples.
In the first one the input of the "Boolean Change" component is a "Boolean Pulse". We compared also the output of the "Change", "Rising Edge", and "Edge with Initial Value" components. We were expecting istantaneous pulse with frequency equal to that of the boolean pulse, or its half for the Edge block. On the contrary the output of all the components stays zero (thus FALSE) for the whole simulation.
The second example use the output of a "Greater Threshold" component to enter the "Boolean Change", whose output is used to trigger a "Switch", whose output is in turn used as an input for the "Greater Threshold" component. The expected result is to have the "Switch" output to alternate the two inputs, instead it keeps the second one (thus the input for the switch is always FALSE).
The feature we need is more similar to this second output, but we don't understand what we are doing wrong or if there is another way to do it.
Thank you in advance
Irene
test_change.msim
The limit of
G := N -> sum(1/N*numtheory[sigma](k)/k,k=1..N )
as N -> infinity should be Pi^2/6. However
eval( G(N), N=infinity );
returns 0.
Can anyone explain this puzzling behaviour?
Looking at  http://www.maplesoft.com/support/help/maple/view.aspx?path=ImageTools
http://www.maplesoft.com/support/help/maple/view.aspx?path=ImageTools%2fFormats
it seems to only support jpeg,tiff,bmp.
This seems like something from 1980's days. Is there another package to load other image formats? Such as png for example, and to export as png?
I'd like to import png file, rescale it in Maple (make thumbnail image) and export it again.
I am using 18.1 on windows 7
As stated, contourplot3d is not displaying contours. Even in the Maple Help examples the contours are not displayed in the help screen.
In this example:
contourplot3d(-5*x/(x^2+y^2+1), x = -3 .. 3, y = -3 .. 3, filledregions = true);
which is directly from Maple Help, the surface is plotted (with boxed axes), but no contours appear.
When I try
contourplot3d(-5*x/(x^2+y^2+1), x = -3 .. 3, y = -3 .. 3);
the plot shows nothing except boxed axes.
I've also tried
plot3d(-5*x/(x^2+y^2+1), x = -3 .. 3, y = -3 .. 3, contours=6);
and the surface shows but without countours. Furthermore, the Maple scripts that worked previously in earlier versions (showing contours via plot3d) now do not show contours in Maple 18. This occurs on both Win 7 and Win 8 laptops.
Hello everybody
I am working on the bending of FGM plate, and I just used maple for the calculation functions of my problem of the bending of FGM plates.
Can any from the members of mapleprimes one help me to write Navier's equation include below for the bending of the plate because I am new in using Maple 18
alfa=m*pi/a, beta=n*pi/b with m=1,3,5..100 and n=1,3,5...100
Thank's for all
Bending
Hi gang!
Upon upgrading to a stable mac OSX Yosemite, I've been experiencing a noticeably slower Maple 18. The Maple machine itself is quick during calculus operations, though the interface bugs me after the upgrade.
It seems as if the program constantly has to load any open palettes. So for an example, if I run with the 'expression' and 'calculus'-palettes open - which I do constantly - it seems as if Maple has to load every single icon, piece by piece. This loading occurs randomly, but often it happens several times every minute. The loading causes a 3-4 sec lag, which is incredibly annoying. Closing the paletts does not affect this random loading. I run with the recent Java-upgrade specifically for Yosemite.
Before upgrading, I ran Maple 18 on 10.9 Mavericks and everything worked ran like a dream. The program was incredebly fast and responsive. Furthermore, I run Maple on a late 2014 fully specced MBP, so hardware shouldn't be an issue either.
My Maple is installed with an authorized academic license.
Anyone able to give some inputs to what might seem to cause the issue here?
Thanks a bunch! :-)
Best regards,
Claus Iversen
Denmark
Aslam-u-Alikum, want to write the following in Maple please help
psi[1]:=psi[1,0];
psi[2]:=psi[1,1];
psi[3]:=psi[1,2];
psi[4]:=psi[1,3];
psi[5]:=psi[2,0];
psi[6]:=psi[2,1];
psi[7]:=psi[2,2];
psi[8]:=psi[2,3];
PhD (Scholar)
Department of Mathematics
[x+p*y, x+y, y+z] would like to filter with indets([x+y,y+z])
so that that the list remove polynomials which contain variable p
with(plots)
inequal((2*c-1)/(3*c-1),c=0..1.5,Alpha=0..1)
with(plots)
inequal((2*c-1)/(3*c-1),c=0..1,Alpha=0..1)
Why are the results of the two orders above so different???
A bug in the function of inequal???
First 1388 1389 1390 1391 1392 1393 1394 Last Page 1390 of 2463
