i am solving 3 ODE with boundary condition.. with boundary condition
b.mw
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/b.mw .
Download b.mw
then i got this error
i dont know where i need to change.. could you help me..
Dear Friends,
My present problem is to calculate the coefficients
of ODES based on the experiment data. In order to simulate the actual experiment, a set of  is given with . Then the experiment data (yexp) can be calculated. Finally, the least-squares method (lsq) is used to calculate the coefficient values. Now the NLPSolve function can be used. However, the globalsolve cant run.
If it is convenient for you, wish you can solve it.
Code:
cdm_ode := diff(y1(t), t) = c0*(y6(t)*(1-y3(t))/(s0*(1-y4(t)*(1-y5(t)))))^n/(1-y2(t)), diff(y2(t), t) = ks*y2(t)^(1/3)*(1-y2(t)), diff(y3(t), t) = h1*(1-y3(t)/h2)*c0*(y6(t)*(1-y3(t))/(s0*(1-y4(t)*(1-y5(t)))))^n/(sigma*(1-y2(t))), diff(y4(t), t) = (1/3)*kp*(1-y4(t))^4, diff(y5(t), t) = A*B*y1(t)^(B-1)*c0*(y6(t)*(1-y3(t))/(s0*(1-y4(t)*(1-y5(t)))))^n/(1-y2(t)), diff(y6(t), t) = y6(t)*c0*(y6(t)*(1-y3(t))/(s0*(1-y4(t)*(1-y5(t)))))^n/(1-y2(t));
tol_t := 3600;
sol := dsolve([cdm_ode, y1(0) = 0, y2(0) = 0, y3(0) = 0, y4(0) = 0, y5(0) = 0, y6(0) = 175], numeric, range = 0 .. tol_t, output = listprocedure, parameters = [c0, n, sigma, s0, ks, h1, h2, kp, A, B]);
sol(parameters = [5.7*10^(-6), 10.186, 175, 200, 5*10^(-8), 10000, .269, 1.5*10^(-7), 1.5, 2]);
t := [seq(i^2, i = 0 .. 50, 1)];
y1data := subs(sol, y1(t));
y1exp := [seq(y1data(t[i]), i = 1 .. 51)];
err := proc (c0, n, s0, ks, h1, h2, kp, A, B) local y1cal, y1val, lsq; sol(parameters = [c0, n, 175, s0, ks, h1, h2, kp, A, B]); y1cal := subs(sol, y1(t)); y1val := [seq(y1cal(t[i]), i = 1 .. 51)]; lsq := add((y1val[i]-y1exp[i])^2, i = 1 .. 51); lsq end proc;
with(Optimization);
val := NLPSolve(err, 10^(-8) .. 10^(-4), 2 .. 20, 150 .. 250, 10^(-2) .. 1, 100 .. 20000, 10^(-5) .. .4, 10^(-5) .. 1, .5 .. 2, 1 .. 10);
GlobalSolve(err, 10^(-10) .. 10^(-4), 2 .. 20, 150 .. 250, 0 .. 1, 100 .. 15000, 0 .. .5, 0 .. 1, .5 .. 2, 1 .. 5);
Error, (in GlobalOptimization:-GlobalSolve) `InertForms` does not evaluate to a module
This question is directed at Maplesoft employees. I am not sure if this is the best place to ask this question, but I don't know where else to ask.
I use my desktop machine at home and my tablet at university, so would like to have Maple installed on both machines. Currenly I have Maple installed on the tablet. The tablet is for portability, but at home, Maple is easier to use on the desktop due to the bigger screen and keyboard.
I can't afford to pay for 2 licenses, and I am not sure that many students can. Can Maplesoft change the licensing model to include a second license for $50? I bought Maple 18 for $132, and would be happy to pay $50 for a second license. This way, Maplesoft can make more money, and the student can use Maple in better ways.
EDIT: I also bought the Mathematics Survival Kit, mainly because it featured prominantly in the Maple webstore, and integrates with Maple. Information about the MSK were sparse, and so I was really buying blind, based solely on my good image of Maple. I found the MSK to be terrible, and because of it's association with Maple, tarnished Maple's image for me.
I recommend Maple to people, but I also warn them about buying add-ons, based on my experience with the MSK, which is truly terrible.
Hi. I need to test if a variable is a dot-product of "anything"-s (usually it is quantum operators).
I try the following
with(Physics);
Physics:-Setup(mathematicalnotation = true);
Physics:-Setup(anticommutativeprefix = psi);
ap1 := Physics:-Creation(psi, 1, notation = explicit);
am1 := Physics:-Annihilation(psi, 1, notation = explicit);
ap2 := Physics:-Creation(psi, 2, notation = explicit);
am2 := Physics:-Annihilation(psi, 2, notation = explicit);
z1 := ap1.am1.ap2:
type(z1, ('`.`')(anything));
and get
whereas
z2 := a*b*c;
type(z2, (':-`*`')(anything));
returns
I studied ?type,structured and other sources but didn't find any answer.
 the price demand function p(x)=50-x  with $120 fixed cost and $30 variable cost per unit.
is the answerx=$5.67?
I am a Masters of Chemistry student at Leeds University and my project involes producing undirected graphs that look like 2D shapes to represent models of molecules for other student users e.g. if there are 6 atoms it will draw a hexagon shape with each vertices as an atom. It is meant to know what graph to draw by asking them questions in maplet pop-up style windows. To do this I have to ask questions in the pop-up windows like "How many atoms in your molecule?" with a drop down box numbering 2-25 as the possibilities.
The problem I am having is getting Maple to relate the answers to these questions on the maplets to the shape (undirected graph) I want it to draw. It displays the answer in the worksheet as for example; ["12"] but I don't know how to ask maple to recognise this number as meaning anything for making the graph.
Is there anyone who knows about using maplets that could have a chat with me about this?
Thanks! From Megan
#DeHoog f4(t)
F4 := proc (F::procedure, Tol, M, t) local T, gamma1, Fc, e, q, d, A, B, i, r, m, n, h2M, R2M, A2M, B2M, a, z; T := evalf(2*t); gamma1 := evalf((-1)*.5*ln(Tol)/T); Fc := Array(0 .. 2*M); e := Array(0 .. 2*M, 0 .. 2*M); q := Array(0 .. 2*M, 0 .. 2*M); d := Array(0 .. 2*M); A := Array(-1 .. 2*M); B := Array(-1 .. 2*M); Fc[0] := evalf(.5*F(gamma1)); for i to 2*M do a := gamma1+I*i*Pi/T; Fc[i] := evalf(F(a), 25) end do; for i from 0 to 2*M do e[0, i] := 0 end do; for i from 0 to 2*M-1 do q[1, i] := evalf(Fc[i+1]/Fc[i]) end do; for r to M do for i from 2*M-2*r+1 by -1 to 0 do if 1 < r then q[r, i] := evalf(q[r-1, i+1]*e[r-1, i+1]/e[r-1, i]) end if; if i < 2*M-2*r+1 then e[r, i] := evalf(q[r, i+1]-q[r, i]+e[r-1, i+1]) end if end do end do; d[0] := Fc[0]; for m to M do d[2*m-1] := -q[m, 0]; d[2*m] := -e[m, 0] end do; z := evalf(exp(I*Pi*t/T)); A[-1] := 0; B[-1] := 1; A[0] := d[0]; B[0] := 1; for n to 2*M do A[n] := A[n-1]+d[n]*z*A[n-2]; B[n] := B[n-1]+d[n]*z*B[n-2] end do; h2M := evalf(.5+((1/2)*d[2*M-1]-(1/2)*d[2*M])*z); R2M := evalf(-h2M-h2M*sqrt(1+d[2*M]*z/h2M^2)); A2M := A[2*M-1]+R2M*A[2*M-2]; B2M := B[2*M-1]+R2M*B[2*M-2]; evalf(exp(gamma1*t)*Re(A2M/B2M)/T) end proc;
F4(proc (p) options operator, arrow; int(12*Dirac(a)*BesselJ(0, 2*a)/(a*p), a = 0 .. .100) end proc, 0.1e-4, 4, 10);
Float(undefined)
Download dehoog.mw
How is it possible to numerically integrate the function containing Diract delta function.
The following code for example is failed to answer and makes computer memory full.
Has anyone made use of the GeM module?  found here http://math.usask.ca/~shevyakov/gem/
ode := (-6 + 3*x - 3*x^2 + 2*x^3)*y(x) + x*(6 - 3*x + x^3)*diff(y(x),x) + x^2*(-3 + 3*x - 3*x^2 + x^3)*diff(y(x),x$2)= 0;
ic := y(0)= 0, D(y)(0)= 1:
sol:=dsolve({ode, ic},y(x));
Gives
What is _C2  that shows up there? Since this is second order and I give 2 initial conditions, I did not expect to see any _C in solution.  How should I handle this solution now? (say to evaluate it, etc...) with this unknown _C2 in there?
Maple 18.1 on windows.
Hello everyone!
Does anyone have an idea about the keyboard shortcut for right-clicking with a mouse? Strangely enough the standard context-menu key won't work in maple. Neither does shift+F10. I tried remapping this function to other keyboard keys but without any success so far...
Couldn't find anything about it in the manuals, maple help, google, etc.. It's such a frequent action, I just can't believe there is not a quicker alternative to grabbing the mouse, pointing it to what you are editing and right-clicking...
Many thanks in advance!!! :)
I have a fairly old laptop, a Toshiba S10 Tecra, windows 7 64 bit and 4 Gb RAM.  It has an NVidia Quadro NVS 150m video card inside and according to NVidia CUDA capable of a compute level to 1.1 which is ok for float[4] but not float[8].  Inititiating the computecabability in maple does indeed bring a score level of 1.1.
Doing any LinearAlgebra matrix calculations with CUDA enabled is maybe 5x's slower than with it disabled.  I run into BLAS errors and screen blankouts at matrix values of 2000.  The video driver is the latest from Toshiba (2010) but not NVidia (2014) I suppose there would be an increased performace with newer drivers but if I'm going to run into the same issue of slower calculations with CUDA enabled there's no point in even testing the newer drivers on an otherwise fine running machine.
Since it is a low end video card is CUDA even worthwhile, will I even notice a speed up with updated drivers?
First 1389 1390 1391 1392 1393 1394 1395 Last Page 1391 of 2463
