I have created three random variables:  r, theta and phi.  That went as I expected.  I then did some math with these random variable.  I calculated the following:  sin(phi), sin(theta), cos(phi) and cos(theta).
When I viewed the PDFs of these above four, I get what I expected with the exception of sin(theta).  I got an error message telling me that I provided three arguments when Maple expected only two arguments.  I am confused as to why this happened.
I wonder if I broke any rules when I named these variables, but I don't know...any suggestions? My work is attached.
with(Statistics)
theta := RandomVariable(Uniform(0, 2*Pi))
_R
phi := arccos(-1+2*RandomVariable(Uniform(0, 1)))
arccos(-1+2*_R0)
r := RandomVariable(Uniform(0, 1))^(1/3)
_R1^(1/3)
SinPhi := sin(phi)
2*(-_R0^2+_R0)^(1/2)
PDF(SinPhi, t)
piecewise(t <= 0, 0, t < (1/2)*4^(1/2), t/(-t^2+1)^(1/2), (1/2)*4^(1/2) <= t, 0)
SinTheta := sin(theta)
sin(_R)
PDF(SinTheta, t)
Error, (in Statistics:-PDF) invalid input: type expects 2 arguments, but received 3
CosPhi := cos(phi)
-1+2*_R0
PDF(CosPhi, t)
(1/2)*piecewise((1/2)*t < -1/2, 0, (1/2)*t < 1/2, 1, 0)
CosTheta := cos(theta)
cos(_R)
PDF(CosTheta, t)
piecewise(t <= -1, 0, t < 1, 1/(Pi*(-t^2+1)^(1/2)), 1 <= t, 0)
Download Basics.mw
Could someone suggest a way to help dsolve be able to obtain this solution to this complicated first order ode? In V 2025.2 it is not able to solve it as is
ode:=-x*sqrt((1 - x)/(x + 1))*(x + 1)*arcsech(x)*diff(y(x), x)*exp(y(x)/arcsech(x) + exp(y(x)/arcsech(x))) - y(x)*exp(y(x)/arcsech(x) + exp(y(x)/arcsech(x))) + 2*x*sqrt((1 - x)/(x + 1))*(x + 1)*arcsech(x)^2 = 0;
-x*((1-x)/(x+1))^(1/2)*(x+1)*arcsech(x)*(diff(y(x), x))*exp(y(x)/arcsech(x)+exp(y(x)/arcsech(x)))-y(x)*exp(y(x)/arcsech(x)+exp(y(x)/arcsech(x)))+2*x*((1-x)/(x+1))^(1/2)*(x+1)*arcsech(x)^2 = 0
sol:=dsolve(ode);
expected_sol:=y(x)=arcsech(x)*ln(ln(2*x+_C1));
y(x) = arcsech(x)*ln(ln(2*x+_C1))
odetest(expected_sol,ode) assuming x>0
Download ode_solution_feb_6_2026.mw
Instead of
if not(type(expr,atomic))...
I would like to use something like that for better readabilty
if type(expr,composite)...
where "composite" is a placeholder for beeing not atomic.
Does anyone have any exoerience playing with this topic?
I have the functions dx(t), dt(t), and dz(t).  They are all the same function.  I constructed the dz(t) function as a piecewise function, then copied it to dx(t) and dy(t).  The area under the function curves sum to one as I would expect.
How can I convert these functions into a PDF form so that I can perform mathematical operations on the PDFs, such as add the PDFs to create another PDF?
SphereFinal.mw
Noticed something strange.  When I type
F:=x-> (x^4+3*x^3-3*x^2-2*x-24)/(x^4-4*x^3-13*x^2+62*x-56);
u:=x->piecewise(x=-4,limit(F(x),x=-4),true,F(x));
u(-4);
Gives Error, (in F) numeric exception: division by zero which means it did not hit the first condition x=-4
But when I write this
A:=limit(F(x),x=-4);
u:=x->piecewise(x=-4,A,true,F(x));
u(-4)
Now it gives expected result 15/47
To avoid defining many variables, like A above, I'd like to just write the  limit inside.
Is there a way to make Maple accept the limit inside piecewise as written above? i.e. have it evaluate to 15/47?
Help says "The piecewise function evaluates its arguments on an as-needed basis."
Not sure what this means.
I tried adding eval, as in
u:=x->piecewise(x=-4,eval(limit(F(x),x=-4)),true,F(x));
But this did nothing
Maple 2025.2
Should not the following two commands produce same solution?
f:=x->(x^2+3*x-4)*cos(x^2+3*x-5);
PDEtools:-Solve({f(x)=0,0<x,x<2},x);
solve({f(x)=0,0<x,x<2},x);
This is what the result looks like
Why Solve gives one solution and solve gives 2? Is this expected or a bug?
btw, the solution from solve is also not complete. There are 5 roots not 2.
Student:-Calculus1:-Roots(f(x),x=0..2);
Just for my understanding:
I have read ?procedure and noticed that the term variable is used as a synonym for the term name.
Otherwise Maple uses the term variable more in a mathematical sense and the term name to refer to an expression.
Is this to make the help page easier to read or to use jargon familiar from other programming languages?
This use of vocabulary must be intentional. However I do not fully understand this subtle difference.
I would like to express the decision variables Pn_W,w_W,Ce_W,i1_W,Pn_D,w_D,Ce_D...other variables...​ in a compact form. Since their analytical expressions are lengthy, I want to identify terms and define appropriate composite parameters to simplify their representation.
Q_shorten_1.mw
For example ,  Suppose the original expression is: q := ((Cn - a)^2 + (P - d - b)*x^2 + Cn - a - b)/y(Cn - a)^2
Lets say Cn - a =X , P - d - b =S
Then the expression can be rewritten as: q = (X^2 + S*x^2 + X - b)/yX^2
Hello everyone
Dear experienced and expert friends
As a beginner, I would like to ask if any of my friends can guide me.
The following commands are related to Mathematica:
plots = Table[n = sValues[[i]];
   ParametricPlot[{1 - 2/n - 1.5/n^2 + (1.33 - 2/n) \[Gamma] -
      0.0740741 (15 + 4*n) \[Gamma]^2,
     12/n^2 + (16 \[Gamma])/n + (80 \[Gamma]^2)/9}, {\[Gamma], 0,
     0.06}, PlotStyle -> colors[[i]],
    PlotRange -> {{-10, 10}, {-10, 10}}], {i, Length[sValues]}];
Show[plots, Frame -> True, FrameLabel -> {"\!\(\*
StyleBox[SubscriptBox[\"n\", \"s\"],\nFontSize->16,\n\
FontColor->GrayLevel[0]]\)", "\!\(\*
StyleBox[\"r\",\nFontSize->16,\nFontColor->GrayLevel[0]]\)"},
 GridLinesStyle -> Black, PlotRange -> {{0.94, 1}, {0, 0.06}},
 PlotLegends ->
  Placed[LineLegend[sValues, LegendLabel -> "s,w"], {0.5, 0.5}],
 ImageSize -> 400]
I want to rewrite this process in Maple for my own functions.
I would be grateful if it is possible or if these commands are rewritten in a complete and executable form in Maple for me so that I can understand the working pattern. Or at least an equivalent command that can do this in Maple is introduced
Thank you all
I have two random variables:  x and y.  I want to multiply them and get the resulting Probability Density Function, z.  If you look below, Example 1 works as expected.  When I try Example 2, however, I get disappointing results.
Clearly, Example 2 involves nonzero lower boundaries, which is messing me up.  Does anyone have any suggestions for Example 2?
Example 1
with(Statistics)
x := RandomVariable(Uniform(0, 1))
_R
y := RandomVariable(Uniform(0, 2))
_R0
z = PDF(x*y, t)
z = piecewise(t < 0, 0, t <= 2, (1/2)*ln(2)-(1/2)*ln(t), 2 < t, 0)
Example 2
x := RandomVariable(Uniform(1, 2))
_R1
y := RandomVariable(Uniform(2, 3))
_R2
z := PDF(x*y, t)
int(piecewise(_t < 1, 0, _t < 2, 1, 2 <= _t, 0)*piecewise(t/_t < 2, 0, t/_t < 3, 1, 0)/abs(_t), _t = -infinity .. infinity)
Download MultiplyPDFFunctions.mw
I am experimenting with Threads:-Task:-Continue in Maple 2020.2 and sometimes it returns different results depending on N, or, how fine the mesh is. I have modified procedures cont and task in a Maple example shown in a worksheet. I can compare the result from Threads with one I can obtain another way and which surely is correct. The result from Threads depends on N: sometimes it is correct, sometimes it is not. The wrong result is returned only when the Threads:-Task:-Continue loop is executed, of course.
Has anyone spotted that problem? Is there a way to trace what actually is being done in each leaf? Does this problem appear in later versions of Maple?
I would appreciate some feedback.
Thanks in advance,
Rafal Anlamowicz
rablamowicz@gmail.com
Hello there,
There are two ways that I know of to define functions in maple:
f(x) :=      (1)
f := x->     (2)
The issue that I'm noticing is that if I only use one method, everything works as I expect it to, but if I use both methods in the same document on a function with the same name eg. (doing f :=x->2x and then later in the document doing f(x) := 5x), (2) seems to completely overrule anything (1) says, even if (1) is used after.
Can anyone explain why this is?
First 12 13 14 15 16 17 18 Last Page 14 of 2462
