in Matlab and Mathematica it is possible to put the labels in contour plot, directly on the lines (with nice positioning).
This makes it much much easier to see the level of each contour line since the values are on the lines,  without having to jump to the legend and guess the color and try to visually match colors with the plot.
For example, in Matlab
clear; close all;
x = 0:0.05:20;
y = 0:0.05:15;
[x,y] = meshgrid(x,y);
z = (11-x-y).^2 + (1+x+10*y-x.*y).^2;
[C,h] =contour(x,y,z,10);
clabel(C,h)
gives
In Maple
f:=(11 - x - y)^2 + (1 + x + 10*y - x*y)^2:
plots:-contourplot(f, x=0..20, y=0..15,
         legend=true,
         contours=10,
         'axes'='boxed',
         legendstyle=[location=right],
         colorscheme="DivergeRainbow");
Is there a way to tell Maple to put contour labels on the "middle" of the level lines (contour lines) similar to what Matlab does?
I see no such option in https://www.maplesoft.com/support/help/maple/view.aspx?path=plots/contourplot
I think I remeber doing this before but not sure and it is not in my cheat sheet.
Given an expression, I wanted to find all names in it. Which can be done using indets(f,name);
But then how to check if any of the names found are not in the Maple initial known names given in https://www.maplesoft.com/support/help/Maple/view.aspx?path=initialconstants
For example,
f:=x^2 - y^2+Pi;
indets(f,name);
Gives {Pi, x, y}  how does one then check if this list does not have any known name in it?
In this case Pi. I do not want to check explicitly for each name listed on the web page above.
Are these initial known names  grouped in some specific maple type that can be used to check against?
Or is there a command in Maple to return a list of all these initially known names? If so this list can be used to check against.
Asked google AI and it did not know.
Maple 2025.2
What does Error, (in dsolve/numeric/bvp) bad index into Matrix mean?
Also, I'm trying to run it, it is slow, any suggestions?
with(Student[VectorCalculus]);
with(DynamicSystems);
with(DEtools);
with(PDEtools, ReducedForm, declare, diff_table, dsubs);
NULL;
 #Digits:= trunc(evalhf(Digits)); #generally a very efficient setting
# Here we solve a 1D problem in 3 regions. In each region, we have concentration and potential (c,phi) distributions,
# We first solve the unperturbed steady-state problem and then the linearized perturbation problem (which rely on the steady state).
# Each region is defined in x = 0..1, and the regions are connected by interface conditions that
# connect (c1(1),phi1(1)) to (c2(0),phi2(0)) and (c2(1),phi2(1)) to (c3(0),phi3(0))
Q:=10;   omega:=100;     J0:= 0.01;   # parameters
                            Q := 10
                          omega := 100
                           J0 := 0.01
# The unperturbed steady-state
c1:=1-J0/2*x:
c3:=1-J0/2*(x-1):
c12:= eval(c1,x=1);
c32 := eval(c3,x=0);
S1:=sqrt(Q^2+4*c12^2):
S3:=sqrt(Q^2+4*c32^2):
c21:=eval((S1-Q)/2);
c23:=eval((S3-Q)/2);
I0:=fsolve(Q*i0/2/J0*ln((J0*S1-Q*i0)/(J0*S3-Q*i0))=(J0-S1+S3)/2,i0);
V:=(I0/J0+1)*ln(c32/c12)+ln((c21+Q)/(c23+Q))+(J0+2*c23-2*c21)/Q; # the potential drop across the system
c2:=solve(y-c21+Q*I0/2/J0*ln((Q*I0-Q*J0-2*J0*y)/(Q*I0-Q*J0-2*J0*c21))=-J0/2*x,y):
phi1:=I0/J0*ln(c1)+V:
phi3:=I0/J0*ln(c3):
dphi1:=diff(phi1,x);
dphi3:=diff(phi3,x);
phi21:=I0/J0*ln(c12)+V-0.5*ln((c21+Q)/c21);
phi2:=(2*c21-2*c2+Q*phi21-J0*x)/Q:
dphi2:=diff(phi2,x);
dphi12 := eval(dphi1, x=1);
dphi21 := eval(dphi2, x=0);
dphi23 := eval(dphi2, x=1);
dphi32 := eval(dphi3, x=0);
INT1 := int(1/(2*c1), x = 0 .. 1);
INT2 := int(1/(2*c2 + Q), x = 0 .. 1);
INT3 := int(1/(2*c3), x = 0 .. 1);
INT := INT1 + INT2 + INT3;
                      c12 := 0.9950000000
                       c32 := 1.005000000
                      c21 := 0.09804129000
                      c23 := 0.1000024500
                      I0 := 0.01419804328
                       V := 0.02539628566
                              0.007099021640
                dphi1 := - --------------------
                           1 - 0.005000000000 x
                              0.007099021640
           dphi3 := - ------------------------------
                      1.005000000 - 0.005000000000 x
                     phi21 := -2.299074561
dphi2 := (0.001000000000 LambertW(-0.2818670588 exp(-0.2818670588
   - 0.0007043224058 x)))/(1
   + LambertW(-0.2818670588 exp(-0.2818670588 - 0.0007043224058 x)
  )) - 0.001000000000
                   dphi12 := -0.007134695118
                   dphi21 := -0.001392499832
                   dphi23 := -0.001391964358
                   dphi32 := -0.007063703124
                      INT1 := 0.5012541824
                     INT2 := 0.09805801917
                      INT3 := 0.4987541511
                       INT := 1.098066353
sys1 := {
-omega*C11(x)+diff(diff(C12(x), x), x)=0,
omega*C12(x)+diff(diff(C11(x), x), x) = 0,
-omega*C21(x)+diff(diff(C22(x), x)+(c2*sigma2-C22(x)*dphi2*Q)/(2*c2+Q), x) =0,
 omega*C22(x)+diff(diff(C21(x), x)+(c2*sigma1-C21(x)*dphi2*Q)/(2*c2+Q), x) = 0,
-omega*C31(x)+diff(diff(C32(x), x), x)=0,
omega*C32(x)+diff(diff(C31(x), x), x) = 0
sys2 := {
diff(FA1(x), x) = C11(x)*dphi1/c1,
diff(FA2(x), x) = C21(x)*dphi2/(c2+Q/2),
diff(FA3(x), x) = C31(x)*dphi3/c3,
diff(FB1(x), x) = C12(x)*dphi1/c1,
diff(FB2(x), x) = C22(x)*dphi2/(c2+Q/2),
diff(FB3(x), x) = C32(x)*dphi3/c3
Bc := {
C11(0) = 0, C12(0) = 0,  C31(1) = 0, C32(1) = 0,
FA1(0) = 0, FB1(0) = 0,  FA3(1) = 0, FB3(1) = 0,
2*C11(1)/c12 = C21(0)/(c21+Q)+C21(0)/c21,
2*C12(1)/c12 = C22(0)/(c21+Q)+C22(0)/c21,
C21(1)/(c23+Q)+C21(1)/c23 = 2*C31(0)/c32,
C22(1)/(c23+Q)+C22(1)/c23 = 2*C32(0)/c32,
D(C11)(1)+dphi12*C11(1)-sigma1/2-c12*D(FA1)(1) = D(C21)(0)+dphi21*C21(0)-(c21+Q)*sigma1/(2*c21+Q)-(c21+Q)*D(FA2)(0),
D(C12)(1)+dphi12*C12(1)-sigma2/2-c12*D(FB1)(1) = D(C22)(0)+dphi21*C22(0)-(c21+Q)*sigma2/(2*c21+Q)-(c21+Q)*D(FB2)(0),
D(C11)(1)-dphi12*C11(1)+sigma1/2+c12*D(FA1)(1) = D(C21)(0)-dphi21*C21(0)+c21*sigma1/(2*c21+Q)+c21*D(FA2)(0),
D(C12)(1)-dphi12*C12(1)+sigma2/2+c12*D(FB1)(1) = D(C22)(0)-dphi21*C22(0)+c21*sigma2/(2*c21+Q)+c21*D(FB2)(0),
D(C31)(0)+dphi32*C31(0)-sigma1/2-c32*D(FA3)(0) = D(C21)(1)+dphi23*C21(1)-(c23+Q)*sigma1/(2*c23+Q)-(c23+Q)*D(FA2)(1),
D(C32)(0)+dphi32*C32(0)-sigma2/2-c32*D(FB3)(0) = D(C22)(1)+dphi23*C22(1)-(c23+Q)*sigma2/(2*c23+Q)-(c23+Q)*D(FB2)(1),
D(C31)(0)-dphi32*C31(0)+sigma1/2+c32*D(FA3)(0) = D(C21)(1)-dphi23*C21(1)+c23*sigma1/(2*c23+Q)+c23*D(FA2)(1),
D(C32)(0)-dphi32*C32(0)+sigma2/2+c32*D(FB3)(0) = D(C22)(1)-dphi23*C22(1)+c23*sigma2/(2*c23+Q)+c23*D(FB2)(1)
all_sys := sys1 union sys2 union Bc:
sol1 := dsolve(all_sys, initmesh = 100, maxmesh = 15000, numeric, method = bvp[midrich], output = listprocedure):
#(all_sys, numeric, method = bvp[midrich]);
 I would like to bulild a Gaussian Mixture Model in Maple using the most straightforward apprach:
Apperantly something goes wrong, PDF in (5) is a product not a sum and variance is quadratic in w (6) not linear as it should be.
How to correct this?
Helllo folkx :)
What is wrong in my functions f and g ?
I don't catch the point.
JM--
    Standard Worksheet Interface, Maple 2025.2, Windows 11,
     November 11 2025 Build ID 1971053
with(RandomTools):
Generate(float(range = 2.532000 .. 7.723000, digits = 4));
                             2.537
f := x -> Generate(float(range = 0 .. 100)):
f(30);
                            94.3141
f(0.200000);
                            23.9622
randomize();
                         2413841372727
f(30);
                            86.2657
plot(f(x), x = 1 .. 100.000000);
plots[listplot](sort([seq(Generate(float(range = 0.032100 .. 162.000000, digits = 3)), i = 1 .. 20)]));
plots[listplot](sort([seq(Generate(float(range = 0.032100 .. 162.000000, digits = 3, method = uniform)), i = 1 .. 20)]));
g := ((x -> Generate(float(range = 0 .. x))) assuming (x*float and 0 < x)):
plot(g(x), x = 1 .. 50);
Error, (in RandomTools:-Generate) invalid input: unknown expects value for keyword parameter range to be of type numeric .. numeric, but received 0 .. x
Is the following behavior expected? using  t=0 .. 3*Pi  vs.  t=0 .. round(3*Pi) give different plots.  Why? Should not the plot be the same?
ps. do not know if I asked this before or not. I can't remember. Search in Mapleprimes is not easy.
ode := diff(y(t), t$2) + y(t)=0;
DEtools:-DEplot(ode, y(t), t=0 .. 3*Pi, y=-1 .. 1,[[y(0)=1,D(y)(0)=0]],linecolor=blue);
diff(diff(y(t), t), t)+y(t) = 0
DEtools:-DEplot(ode, y(t), t=0 .. round(3*Pi), y=-1 .. 1,[[y(0)=1,D(y)(0)=0]],linecolor=blue);
Download deplot_with_round_jan_17_2026.mw
I am looking for ways to clear remember tables in a Maple session to ensure that a Maple command/procedure is executed as if it were being called for the first time. I currently use
map(forget, [anames()])
but I am not sure if that statement clears all existing remeber tables (i.e. including system remember tables)?
Are there other ways to do this? Restart is not an option since it clears almost everything.
Edit: This question is not about disabling remember tables.
I'm looking for the general solution to the attached differential equation. Maple doesn't provide it. What am I doing wrong?
ode5 := diff(y(x), x) = (8*y(x)*b-32*b^2*x/y(x)-64*b^2*x^2*y(x))/(3*y(x)^2+8*b*x-16*b^2*x^2/y(x)^2)
simplify(ode5)
diff(y(x), x) = ((64*b^2*x^2-8*b)*y(x)^3+32*b^2*x*y(x))/(-3*y(x)^4-8*b*x*y(x)^2+16*b^2*x^2)
dsolve(ode5, y(x))
NULLNULL
Download testdgl5.mw
I am using the following (dummy) code. I would appreciate any help generating a plot with multiple functions and a legend. I am getting an error message stating that the parameter "v" is unknown. I believe the issue is due to the complexity of the functions (fun1 and fun2) that use the "piecewise" command in my code.
fun1 := piecewise(cond1, a(x,v), cond2, b(x,v))
fun2 := piecewise(cond1, c(x,v), cond2, d(x,v))
myPlotFunction := proc(v)
local p1, p2:
p1 := plot(fun1, x=0..1, color = [blue], linestyle = [solid], thickness = [3], legend = ["H"]):
p2 := plot(fun2, x=0..1, color = [red], linestyle = [dash], thickness = [3], legend = ["L"]):
plots:-display({p1, p2}, title="Multiple plots");
Explore(myPlotFunction(v), parameter={v=0..1});
Omkar
WHen plotting f(x) and g(x) on same plot, and putting legend at bottom (default), the legends show horizontally. i.e. f(x) then g(x) on same line.
I'd like the legend to be stacked vertically, just like when the legend on the right or left, But keep it at bottom. But want to do all this in code. Not using any UI context tools or mouse.
Here is an example
f:=x->x^3-x^2+1;
g:=x->6-2*x-x^2;
the_legend:=[typeset("f(x) = ",f(x)),typeset("g(x) = ",g(x))]:
plots[setoptions](font=[TIMES,16], labelfont=[TIMES,18]):
the_title:="Plot of f(x) and g(x)":
plot([f(x),g(x)],x=-5..5,
     'gridlines',
     'color'=['red','blue'],
     'legend'=the_legend,
     'legendstyle'=['location'='bottom'],
     'axes'='normal',
     'title'=the_title,
     'scaling'='unconstrained');
proc (x) options operator, arrow; x^3-x^2+1 end proc
proc (x) options operator, arrow; 6-2*x-x^2 end proc
#I want the above legend to be stacked vertically like the
#following one, but keep it at bottom
     'gridlines',
     'legendstyle'=['location'='right'],
     'axes'='normal',
     'title'=the_title,
Download legend_question.mw
I was wondering which theorem the following result is based on, and what the name of the sequence used is.
restart; with(LinearAlgebra)
K := proc (i::integer, j::integer) local M; M := Matrix(5, 5); M[i, i] := 1; M[j, j] := 1; return M end proc
F := proc (r, c, g, h) options operator, arrow; Adjoint(A.K(r, c).B.K(g, h).C) end proc
d1 := 3; d2 := 5; A := Matrix(d1, d2, symbol = a); B := Matrix(d2, d2, symbol = b); C := Matrix(d2, d1, symbol = c)
d1 := 3
d2 := 5
Matrix(3, 5, {(1, 1) = a[1, 1], (1, 2) = a[1, 2], (1, 3) = a[1, 3], (1, 4) = a[1, 4], (1, 5) = a[1, 5], (2, 1) = a[2, 1], (2, 2) = a[2, 2], (2, 3) = a[2, 3], (2, 4) = a[2, 4], (2, 5) = a[2, 5], (3, 1) = a[3, 1], (3, 2) = a[3, 2], (3, 3) = a[3, 3], (3, 4) = a[3, 4], (3, 5) = a[3, 5]})
Matrix(5, 5, {(1, 1) = b[1, 1], (1, 2) = b[1, 2], (1, 3) = b[1, 3], (1, 4) = b[1, 4], (1, 5) = b[1, 5], (2, 1) = b[2, 1], (2, 2) = b[2, 2], (2, 3) = b[2, 3], (2, 4) = b[2, 4], (2, 5) = b[2, 5], (3, 1) = b[3, 1], (3, 2) = b[3, 2], (3, 3) = b[3, 3], (3, 4) = b[3, 4], (3, 5) = b[3, 5], (4, 1) = b[4, 1], (4, 2) = b[4, 2], (4, 3) = b[4, 3], (4, 4) = b[4, 4], (4, 5) = b[4, 5], (5, 1) = b[5, 1], (5, 2) = b[5, 2], (5, 3) = b[5, 3], (5, 4) = b[5, 4], (5, 5) = b[5, 5]})
Matrix(%id = 36893489807004764868)
simplify(Adjoint(A.B.C)-add([F(1, 2, 1, 2), F(1, 2, 1, 3), F(1, 2, 1, 4), F(1, 2, 1, 5), F(1, 2, 2, 3), F(1, 2, 2, 4), F(1, 2, 2, 5), F(1, 2, 3, 4), F(1, 2, 3, 5), F(1, 2, 4, 5), F(1, 3, 1, 2), F(1, 3, 1, 3), F(1, 3, 1, 4), F(1, 3, 1, 5), F(1, 3, 2, 3), F(1, 3, 2, 4), F(1, 3, 2, 5), F(1, 3, 3, 4), F(1, 3, 3, 5), F(1, 3, 4, 5), F(1, 4, 1, 2), F(1, 4, 1, 3), F(1, 4, 1, 4), F(1, 4, 1, 5), F(1, 4, 2, 3), F(1, 4, 2, 4), F(1, 4, 2, 5), F(1, 4, 3, 4), F(1, 4, 3, 5), F(1, 4, 4, 5), F(1, 5, 1, 2), F(1, 5, 1, 3), F(1, 5, 1, 4), F(1, 5, 1, 5), F(1, 5, 2, 3), F(1, 5, 2, 4), F(1, 5, 2, 5), F(1, 5, 3, 4), F(1, 5, 3, 5), F(1, 5, 4, 5), F(2, 3, 1, 2), F(2, 3, 1, 3), F(2, 3, 1, 4), F(2, 3, 1, 5), F(2, 3, 2, 3), F(2, 3, 2, 4), F(2, 3, 2, 5), F(2, 3, 3, 4), F(2, 3, 3, 5), F(2, 3, 4, 5), F(2, 4, 1, 2), F(2, 4, 1, 3), F(2, 4, 1, 4), F(2, 4, 1, 5), F(2, 4, 2, 3), F(2, 4, 2, 4), F(2, 4, 2, 5), F(2, 4, 3, 4), F(2, 4, 3, 5), F(2, 4, 4, 5), F(2, 5, 1, 2), F(2, 5, 1, 3), F(2, 5, 1, 4), F(2, 5, 1, 5), F(2, 5, 2, 3), F(2, 5, 2, 4), F(2, 5, 2, 5), F(2, 5, 3, 4), F(2, 5, 3, 5), F(2, 5, 4, 5), F(3, 4, 1, 2), F(3, 4, 1, 3), F(3, 4, 1, 4), F(3, 4, 1, 5), F(3, 4, 2, 3), F(3, 4, 2, 4), F(3, 4, 2, 5), F(3, 4, 3, 4), F(3, 4, 3, 5), F(3, 4, 4, 5), F(3, 5, 1, 2), F(3, 5, 1, 3), F(3, 5, 1, 4), F(3, 5, 1, 5), F(3, 5, 2, 3), F(3, 5, 2, 4), F(3, 5, 2, 5), F(3, 5, 3, 4), F(3, 5, 3, 5), F(3, 5, 4, 5), F(4, 5, 1, 2), F(4, 5, 1, 3), F(4, 5, 1, 4), F(4, 5, 1, 5), F(4, 5, 2, 3), F(4, 5, 2, 4), F(4, 5, 2, 5), F(4, 5, 3, 4), F(4, 5, 3, 5), F(4, 5, 4, 5)]))
Matrix(%id = 36893489807027993164)
nops([F(1, 2, 1, 2), F(1, 2, 1, 3), F(1, 2, 1, 4), F(1, 2, 1, 5), F(1, 2, 2, 3), F(1, 2, 2, 4), F(1, 2, 2, 5), F(1, 2, 3, 4), F(1, 2, 3, 5), F(1, 2, 4, 5), F(1, 3, 1, 2), F(1, 3, 1, 3), F(1, 3, 1, 4), F(1, 3, 1, 5), F(1, 3, 2, 3), F(1, 3, 2, 4), F(1, 3, 2, 5), F(1, 3, 3, 4), F(1, 3, 3, 5), F(1, 3, 4, 5), F(1, 4, 1, 2), F(1, 4, 1, 3), F(1, 4, 1, 4), F(1, 4, 1, 5), F(1, 4, 2, 3), F(1, 4, 2, 4), F(1, 4, 2, 5), F(1, 4, 3, 4), F(1, 4, 3, 5), F(1, 4, 4, 5), F(1, 5, 1, 2), F(1, 5, 1, 3), F(1, 5, 1, 4), F(1, 5, 1, 5), F(1, 5, 2, 3), F(1, 5, 2, 4), F(1, 5, 2, 5), F(1, 5, 3, 4), F(1, 5, 3, 5), F(1, 5, 4, 5), F(2, 3, 1, 2), F(2, 3, 1, 3), F(2, 3, 1, 4), F(2, 3, 1, 5), F(2, 3, 2, 3), F(2, 3, 2, 4), F(2, 3, 2, 5), F(2, 3, 3, 4), F(2, 3, 3, 5), F(2, 3, 4, 5), F(2, 4, 1, 2), F(2, 4, 1, 3), F(2, 4, 1, 4), F(2, 4, 1, 5), F(2, 4, 2, 3), F(2, 4, 2, 4), F(2, 4, 2, 5), F(2, 4, 3, 4), F(2, 4, 3, 5), F(2, 4, 4, 5), F(2, 5, 1, 2), F(2, 5, 1, 3), F(2, 5, 1, 4), F(2, 5, 1, 5), F(2, 5, 2, 3), F(2, 5, 2, 4), F(2, 5, 2, 5), F(2, 5, 3, 4), F(2, 5, 3, 5), F(2, 5, 4, 5), F(3, 4, 1, 2), F(3, 4, 1, 3), F(3, 4, 1, 4), F(3, 4, 1, 5), F(3, 4, 2, 3), F(3, 4, 2, 4), F(3, 4, 2, 5), F(3, 4, 3, 4), F(3, 4, 3, 5), F(3, 4, 4, 5), F(3, 5, 1, 2), F(3, 5, 1, 3), F(3, 5, 1, 4), F(3, 5, 1, 5), F(3, 5, 2, 3), F(3, 5, 2, 4), F(3, 5, 2, 5), F(3, 5, 3, 4), F(3, 5, 3, 5), F(3, 5, 4, 5), F(4, 5, 1, 2), F(4, 5, 1, 3), F(4, 5, 1, 4), F(4, 5, 1, 5), F(4, 5, 2, 3), F(4, 5, 2, 4), F(4, 5, 2, 5), F(4, 5, 3, 4), F(4, 5, 3, 5), F(4, 5, 4, 5)])
100
Download Adjoint353.mw
Is this account worth keeping? I only made it to try to download Maple. I am having technical problems downloading the app using a code, and was hoping that having a MapleSoft account would stop the firewall from blocking me somehow?... not my best idea, I will admit.
So is this account worth keeping? I can't delete it for some reason anyway
Just want to know if it will help me in any way with using Maple
Given equation such as 1/A=x/A, at school we are allowed to write this as 1=x by canceling A on both side.
But in Maple, even if I tell it that A is not zero, it still refuses to simplify it and cancel A from both sides.
What could be the reson for this?
eq:= 1/A = x/A;
simplify(eq) assuming A<>0
Using Mathematica it does it:
I am not looking for workaround, I know how to force this if needed, one way could be
numer(normal((lhs-rhs)(eq)))=0
gives 1 - x = 0
My question is why Maple's simplify does not simplify it automatically? Even using simplify with size option did not. Is it just weakness in simplify or is there a subtle mathematical reason behind it which I am missing?
Maple 2025.2
Hi, I want to write a function to parse an expression into coefficients and exponents as follows:
I found a similar function (factors), but it fails in the second case.
First 14 15 16 17 18 19 20 Last Page 16 of 2462
