In the attached file, I want to transform (1) into (3) and back again (3) into (1). Attempts using CompleteSquare and expand in combination with other commands have failed. I would appreciate any advice.
dio1.mw
I am looking for a command that extracts sqrt(2) from
sqrt(4 + (-2*x - 2)*y)
The expression above is a subexpression of a larger expression generated by Maple (an integral).
In this situation manual workarounds are impractical and errorprone.
Ideally Maple should return
sqrt(2)*sqrt(2 - (x + 1)*y)
I tried simplify, factor, collect and so on...
In case that there is nothing (which I doubt):
Why is Maple not having simple commands that do extraction (and absortion/inclusion) of factors?
(extract and absorb are names not used so far that would be easy to remember.)
Update - example of an expression:
expr := Int(sqrt(-2*alpha^2*x - 2*alpha^2 + 4)/(sqrt(-alpha^2 + 1)*(-alpha^2*x - alpha^2 + 2)), alpha = 0 .. z) = EllipticF(z, sqrt(2*x + 2)/2)
I noticed today only 2 cases where calling simplify, with no options, made things worst.
Just trying to understand why.
Here is one example. Solved an ode. when calling odetest on this solution, it gives zero. But if the solution is simplified first, then odetest no longer gives zero. And it is actually hard to find a trick to make it become zero so far.
But the question is: Is this to be expected sometimes? I use simplify sporadically, but like to get smaller  expression at one point. But now I am not sure if I should even do that.
Could this be a problem in simplify itself somehow?
Here is an example.
ode:=diff(y(x), x) = y(x)*(-1 - x^(2/(ln(x) + 1))*exp(2*ln(x)^2/(ln(x) + 1))*x^2 - x^(2/(ln(x) + 1))*exp(2*ln(x)^2/(ln(x) + 1))*x^2*ln(x) + x^(2/(ln(x) + 1))*exp(2*ln(x)^2/(ln(x) + 1))*x^2*y(x) + 2*x^(2/(ln(x) + 1))*exp(2*ln(x)^2/(ln(x) + 1))*x^2*y(x)*ln(x) + x^(2/(ln(x) + 1))*exp(2*ln(x)^2/(ln(x) + 1))*x^2*y(x)*ln(x)^2)/((ln(x) + 1)*x);
diff(y(x), x) = y(x)*(-1-x^(2/(ln(x)+1))*exp(2*ln(x)^2/(ln(x)+1))*x^2-x^(2/(ln(x)+1))*exp(2*ln(x)^2/(ln(x)+1))*x^2*ln(x)+x^(2/(ln(x)+1))*exp(2*ln(x)^2/(ln(x)+1))*x^2*y(x)+2*x^(2/(ln(x)+1))*exp(2*ln(x)^2/(ln(x)+1))*x^2*y(x)*ln(x)+x^(2/(ln(x)+1))*exp(2*ln(x)^2/(ln(x)+1))*x^2*y(x)*ln(x)^2)/((ln(x)+1)*x)
sol_1:=dsolve(ode);
y(x) = exp(-(1/4)*x^4)/(x^(-2*ln(x)/(ln(x)+1))*exp(-(1/4)*(x^4*ln(x)+x^4+4*ln(ln(x)+1)*ln(x)-8*ln(x)^2+4*ln(ln(x)+1))/(ln(x)+1))*ln(x)^2+2*x^(-2*ln(x)/(ln(x)+1))*exp(-(1/4)*(x^4*ln(x)+x^4+4*ln(ln(x)+1)*ln(x)-8*ln(x)^2+4*ln(ln(x)+1))/(ln(x)+1))*ln(x)+x^(-2*ln(x)/(ln(x)+1))*exp(-(1/4)*(x^4*ln(x)+x^4+4*ln(ln(x)+1)*ln(x)-8*ln(x)^2+4*ln(ln(x)+1))/(ln(x)+1))+ln(x)*c__1+c__1)
odetest(sol_1,ode)
sol_2:=simplify(sol_1);
y(x) = 1/((ln(x)+1)*(exp((1/4)*x^4)*c__1+1))
odetest(sol_2,ode);
c__1*x^(ln(x)/(ln(x)+1)+3/(ln(x)+1))*exp(2*ln(x)^2/(ln(x)+1)+(1/4)*x^4)/((ln(x)+1)*(exp((1/4)*x^4)*c__1+1)^2)-c__1*x^3*exp((1/4)*x^4)/((ln(x)+1)*(exp((1/4)*x^4)*c__1+1)^2)
Download why_simplify_changes_things_at_dec_27_2025.mw
Notice how much simpler the solution becomes after calling simplify. I'd like to use that. But for some reason, odetest now fails to verify the simpler version. Which tells me simplify did something which made the solution not valid.
Here is second example, where calling simplify in betwen did not give zero as expected.
f := sqrt(1 + sin(x)^2);
F := int(f, x):
df := diff(F, x):
simplify(df - f);
(1+sin(x)^2)^(1/2)
F := int(f, x):
F := simplify(F):
df := diff(F, x):
simplify(df - f);
(1+sin(x)^2)^(1/2)
-csgn(1, cos(x))*sin(x)*EllipticE(sin(x), I)
Download why_simplify_changes_things_at_dec_27_2025_V2.mw
Just trying to understand why this happens and if this is something that could happen sometimes? May be one should avoid calling simplify in middle of computation and let the user decide if they want to simplify the final result or not?
I do not remember now if this came up before or not. But this has been a problem in Maple for years.
when doing infolevel[dsolve]:=5 and call dsolve(), some of the display on the screen is missing commas and multiplication sign and who know what else. Since it is all replace by space.
This happens only to part of the display. Here is an example (must use restart each time to see the full display)
ode:=diff(y(x),x) = (-y(x)^2+4*a*x)^2/y(x);
infolevel[dsolve]:=5;
dsolve(ode);
Here is the output. Using worksheet, V 2025.2 on windows 10 (I am only showing part of the output which has the problem)
Looking at the line where is says "-> Calling odsolve ". Notice the rest. diff(diff(y(x) x) x)  should be diff(diff(y(x),x),x)  and the end of the line has diff(y(x) x)) y(x)  . So one can guess this should be  diff(y(x),x))*y(x) or it could be diff(y(x),x))/y(x) or may be something else.
THis cause a problem when trying to copy it and use it to try it.
Is there something one can do  in settings to fix this part of the display? so nothing is replace by space?
Maple 2025.2 on windows 10
I also tried this in document mode instead of worksheet. Same result.
Update
Found where this comes from. From `odsolve/2` proc, line 21.
THis is how to see it.
ode:=diff(y(x),x)=x*y(x)+1/y(x)+y(x)^3;
stopat(`odsolve/2`);
dsolve(ode)
Now the debugger will come up. Then do in the debugger:
stopat 21
Click continue, you will now stop at this line
In the worksheet it now shows as
So something in
 `ODEtools/userinfo`(2,dsolve,`-> Calling odsolve with the ODE`,A);
Is not right. Also the last y(x) was meant to be second item in A which is expression sequence. But in worksheet it all display on one line with no commas between.,
So better formating in ODEtools/useinfo is needed here. For some reason, commas are all replaced by spaces.
Can Maple find the primitive elements of a cyclic group?
Is it possible to obtain integral of sqrt(1+sin(x)^2) in Maple as known result of elliptic integral of the second kind  E(x,-1) ?
Maple 2025 gives
integrand:=sqrt(1+sin(x)^2);
anti:=int(integrand,x);
anti:=simplify(anti);
Not able to differentiate back:
diff(anti,x);
simplify(%)
Google says:
And the above is also what Mathematica gives
Is it possible to obtain E(x,-1) also in Maple for this integral?
Maple 2025.2
Not able to make an example, since it depends of code flow and not able to reproduce it in small code. I spend hrs trying to make one. It depends on how memory is arranged and this problem shows only when running my large program.
But I can show screen shots from a debugging session showing clearly the problem, and the solution I found.
Maple was giving this result, when calling simplify to simplify a matrix:
Notice what happend. There was a matrix [3/2,-1,-3/2,0],[0,0,0,0],[-2,2,2,0]] before that was simplfied.
Next iteration called simplify on modified version of the matrix, which is  [3/2,-1,-3/2,0],[0,0,0,0],[0,2/3,0,0]].  (called e in the above).
But simplify returned as result the old copy. Which is completely wrong.
It simplified  [3/2,-1,-3/2,0],[0,0,0,0],[0,2/3,0,0]]  to  [3/2,-1,-3/2,0],[0,0,0,0],[-2,2,2,0]]  !
Now see what happes when calling forget(simplify)
You see, now it simplfies it correctly. (there is actually nothing to simplify, so it returned back same matrix as expected, and no copy it had in memory).
So now I went over all my code, and everywhere it calls simplify, added
     forget(simplify)
right after each call.
Problem fixed.
May be someone can shed a light on why this happens. Any information needed will try to provide. I can reproduce this each time but using the debugger.
ode:=diff(y(x),x) = 3*(y(x)*x)^(1/2);
IC:=y(0)=2;
sol:=dsolve([ode,IC])
This is a report of a Maple_2015's bug, apparently fixed in more recent versions, but which may have persisted for a few versions beyond 2015.
I don't think it's necessary to fill out an RCS form.
All started with an error in my code which was balanced by a maple 2015 bug. So I didn't see any error until I sent my code to @C_R  who uses a newer Maple version.
More precisely, in my Maple 2015 code I defined a NxN matrix B, a vector A of length N, that I mistakenly defined as a vector column, and finally computed the quantity R = A . B . A+.
Of course Maple should have fire an error.
The bug is that Maple 2015 doesn't fire an error if A is a float vector and B a float matrix.
kernelopts(version)
A := Vector(2, symbol=a):
B := Matrix(2$2, symbol=b):
R := A.B.A^+
Error, (in LinearAlgebra:-Multiply) cannot multiply a column Vector and a Matrix
A := Vector(2, i -> i):
B := Matrix(2$2, (i, j) -> i+j):
R := A.B.A^+
A := evalf(Vector(2, i -> i)):
B := evalf(Matrix(2$2, (i, j) -> i+j)):
R := A.B.A^+
30.
R := A^+.B.A
30.
Download Maple_2015_Bug.mw
I am trying to build an animated activity to introduce the concept of a definite integral.
My goal is to animate the graph simultaneously with a three-column table displaying the values of the upper Riemann sum, the lower Riemann sum, and the definite integral.
Any ideas or suggestions on how to implement this?
Many thanks in advance.
Riemann_Anim_table.mw
This is a good example of how Maple result looks different depending on what calls to Maple were made before.
I can't upload worksheet so have to show code and screen shot. Compare the screen shot below. Maple 2025.2. Same exact input., In first example the polynomial terms display in different order compared to the second example, even though the same exact input is used.
Clearly the first example is because Maple remembered this polynomial in its remember table somewhere before due to earlier call, and did not want to make new copy since it is same polynomial?
But I do want to make new polynomial. The old copy/order this polynomial in Maple internal tables is getting in the way.
But do not know how to tell Maple to clear its cache so I get same display as in the second example. I know both answers is the same. But the issue is why it displays different.
How could I get same output from first example as in the second one? What do I need to clear? I tried forget(Student:-Precalculus:-CompleteSquare) but this had no effect. ALso tried forget(all); also forget(all,forgetpermanent = true,reinitialize=true); also forget(Student:-Precalculus:-CompleteSquare,subfunctions=true);
code
eq := x^2 + y^2 + z^2 - 2*x + 8*y - 6*z - 30 = 0:
eq:=Student:-Precalculus:-CompleteSquare(eq):
e1:=convert(indets(%,`^`),list):
e2:=zip((a,b)->a=b,e1,[X,Y,Z]):
e3:=sort(eval(eq,e2));
e4:=map(X->rhs(X)=lhs(X),e2);
eval(e3,e4);
e3 := X + Y + Z - 56 = 0;
e4 := [X = (x - 1)^2, Y = (y + 4)^2, Z = (z - 3)^2];
eval(e3,e4);
[moderator: duplicate of this earlier question]
i found the same as author found but is not give me zero when i replace in my pdes can anyone see the problem?
test.mw
When clicking on a pink error message I get this
Can someone explain what is going on? Quite unusual for me all this.
I do not have a server to white list. What can I do about it?
Is that Sucuri thing safe?
Is there a way to disable / turn of ai in Maple Learn. The question is relevant because it is not allowed for our students to use AI during their exams.
Regards and happy holiday
What is the current status of SupportTools? Is this something that still brings fixes in Maple before official release?
I am asking because there have not been an update to ST since June 23, 2025. Almost 6 months ago.
Should one still check for current version of SupportTools, is it still being updated or not? If not, then what does SupportTools package actualy do or contain if it is no longer needed/used?
This is all fussy for me, and some clarification for users will be good to better understand the role of this package.
First 17 18 19 20 21 22 23 Last Page 19 of 2462
