odetest does not want to verify this maple solution against the IC.  Anyone could find why or a trick to get [0,0] from odetest?
Can not upload worksheet due to firewall at Mapleprime issue. Here the code and screen shot.
ode := diff(y(x),x) +cos(1/exp(2*x))*y(x) = sin(1/exp(x));
IC := a*D(y)(x0)+ c*y(x0) = b*y0;
maple_sol:=dsolve([ode,IC],y(x));
the_residue:=odetest(maple_sol,[ode,IC]);
#not zero, also simplify did not give zero
Hi everyone,
I'm trying to simplify
sqrt(sqrt(12)/(9 + sqrt(108)))
into
1-sqrt(3)/3
using Maple. Could someone please show me the Maple commands or step-by-step procedure that would do the simplification for me?
using regular expression in Maple is little annoying, because one has to escape \ in the regx string itself, which makes it more complicated compared to other languages. For example
StringTools:-RegMatch("^\[.*\]$","[A]")
gives false. But
StringTools:-RegMatch("^\\[.*\\]$","[A]")
gives true.
Other languages have special function to generate the regx itself, which does not require escaping the \ when writing the regx Which makes it easier to see the regx (escaping is done under the cover). like this
Since all places and web sites that show examples of regx., do not have to escape \ before using, it will be good if Maple adds such special new function to StringTools to generate regx like the above so users do not have to remember to escape \.
It is hard enough to use regx without having to also remember to escape things.
I could not find such a function in Maple. Does one exist?
Maple 2025.2
I use plot(sol,...) to plot solution of ode. I do not give x or y ranges and let Maple figure the best values. Then use the command
T:=rhs~(indets(p, identical("originalview")=anything))[];
To extract the x and y ranges used and then use these in the command DEtools:-DEplot(....)
The plot() command shows the solution plot fully (in this example below, the left and right sides).
But the  DEtools:-DEplot(....) only shows part of the solution on top of the slope field arrows.  Even though the same x and y ranges is used.
I found that if I increase the y range for the DEtools:-DEplot(....) by a little bit, now the full solution shows, which is same as plot command generated.
Since I am doing all this in code, without looking, I am first plotting the solution using plot() and then use the ranges generated for DEtools:-DEplot(....).
If I do not use the y range in DEtools:-DEplot(....) but only use the x range, sometimes it works and sometimes Maple gives warnings. (depending on the solution). So I am  back to using the ranges generated by plot() command to be safe.
Here is an example to show this problem
ode:=diff(y(x),x) = x*(x^2+9)^(1/2);
IC:=y(-4) = 0;
sol:=dsolve([ode,IC]);
p:=plot(rhs(sol),'axes'='boxed','labels'=[x,y(x)],'axis'=['gridlines'=['color'='lightblue']],'color' = 'red');
Now the x and y ranges used above is extraced
from_x := op(1,T[1]);
to_x   := op(2,T[1]);
from_y := op(1,T[2]);
to_y   := op(2,T[2]);
#gives
      T := [-9.94999999999999929 .. 9.94999999999999929,
        -32.6629164062620561 .. 332.469298224442980]
                 from_x := -9.94999999999999929
                  to_x := 9.94999999999999929
                 from_y := -32.6629164062620561
                  to_y := 332.469298224442980
These are used in the DEplot
DEtools:-DEplot(ode,[y(x)],x=from_x..to_x,y=from_y ..to_y ,[IC],
                'dirfield'=[15,15],
                'labels'=[x,y(x)],
                'axes' = 'boxed',
                'arrows'='smalltwo', #'curve',
                'color' = 'blue',#color of arrows
                'linecolor'='red'#color of solution
Notice how the solution (red line) is truncated.  It turns out in this case adding say 10% to the y range, it now shows the solution like this
DEtools:-DEplot(ode,[y(x)],x=from_x..to_x,y=from_y-(0.1*abs(from_y)) ..to_y ,[IC],
                'dirfield'=[15,15],
                'labels'=[x,y(x)],
                'axes' = 'boxed',
But I do not know if this trick will work for each example.
As I said, I can not give the y range to DEplot, then in this example, it will now show the full solution. But I have examples where this can cause warnings.
The question is, why giving same y range used by plot to DEplot cause the solution (red line) to truncate? Why one has to increase the y range to make it show the full solution?
Is there a better method that the above to make DEplot show full solution same as plot() does?
Maple 2025.2
ps. I just tried upload the worksheet and now it works! it looks like mapleprimes web site is fixed.
IC:=y(-4) = 0;
diff(y(x), x) = x*(x^2+9)^(1/2)
y(-4) = 0
y(x) = (1/3)*(x^2+9)^(3/2)-125/3
to_x   := op(2,T[1]);
to_y   := op(2,T[2]);
[-9.94999999999999929 .. 9.94999999999999929, -32.6629164062620561 .. 332.469298224442980]
9.94999999999999929
332.469298224442980
                'dirfield'=[15,15],
                'labels'=[x,y(x)],
                'axes' = 'boxed',
                'dirfield'=[15,15],
                'labels'=[x,y(x)],
                'axes' = 'boxed',
Download example_phase_plot.mw
How to explain this strange behavior?   odetest(sol,ode) does not give zero. But odetest(sol,[ode,IC]) gives [0,0]
Same solution and same ode. Why adding IC, now odetest says solution verifies the ode, but without adding IC, it does not give zero right away. I know I can simplify the result to zero. But the point is that it should have given zero right away, because that is what it did when adding IC.
Should it not have given zero in first case also?
Can't upload worksheet due to security. Here is code and screen shot
ode := diff(y(x),x) + cos(1/exp(2*x))*y(x) = sin(1/exp(x));
IC := a*D(y)(x0)+c*y(x0) = b*y0;
sol:=y(x) = ((-cos(exp(-2*x0))*a + c)*Int(sin(exp(-tau))*exp(-1/2*Ci(exp(-2*tau))), tau = 0 .. x0) + Int(sin(exp(-tau))*exp(-1/2*Ci(exp(-2*tau))), tau = 0 .. x)*(cos(exp(-2*x0))*a - c) + exp(-1/2*Ci(exp(-2*x0)))*(a*sin(exp(-x0)) - b*y0))*exp(1/2*Ci(exp(-2*x)))/(cos(exp(-2*x0))*a - c);
odetest(sol,ode);
#not zero
#now
odetest(sol,[ode,IC]);
#gives [0,0]
By symbolic regression I mean an algorithm that determines a model (fit function) that fits best to a data set.
Are there any commands, packages, libraries or MaplesPrime post that are helpful in this regrad?
Edit: For the data set below a symbolic regression could ideally algortihm return "simple" models (formulas)  that use a "minimal" number of terms.
data_set := [[0, 0.], [.1, -0.192545973e-2], [.2, -0.57548536e-2], [.3, -0.93691571e-2], [.4, -0.116497299e-1], [.5, -0.122768958e-1], [.6, -0.114535757e-1], [.7, -0.96377097e-2], [.8, -0.73398894e-2], [.9, -0.50026258e-2], [1.0, -0.29489933e-2], [1.1, -0.13773796e-2], [1.2, -0.3802267e-3], [1.3, 0.288809e-4], [1.4, -0.1112403e-3], [1.5, -0.7312233e-3], [1.6, -0.1747389e-2], [1.7, -0.3072868e-2], [1.8, -0.4624615e-2], [1.9, -0.6327418e-2], [2.0, -0.8115810e-2], [2.1, -0.9934627e-2], [2.2, -0.11738712e-1], [2.3, -0.13492153e-1], [2.4, -0.15167275e-1], [2.5, -0.16743558e-1], [2.6, -0.18206567e-1], [2.7, -0.19546942e-1], [2.8, -0.20759491e-1], [2.9, -0.21842382e-1], [3.0, -0.22796451e-1], [3.1, -0.23624612e-1], [3.2, -0.24331323e-1], [3.3, -0.24922213e-1], [3.4, -0.25403690e-1], [3.5, -0.25782692e-1], [3.6, -0.26066441e-1], [3.7, -0.26262258e-1], [3.8, -0.26377439e-1], [3.9, -0.26419110e-1], [4.0, -0.26394196e-1], [4.1, -0.26309316e-1], [4.2, -0.26170744e-1], [4.3, -0.25984403e-1], [4.4, -0.25755853e-1], [4.5, -0.25490243e-1], [4.6, -0.25192364e-1], [4.7, -0.24866612e-1], [4.8, -0.24517040e-1], [4.9, -0.24147342e-1], [5.0, -0.23760880e-1], [5.1, -0.23360701e-1], [5.2, -0.22949566e-1], [5.3, -0.22529948e-1], [5.4, -0.22104070e-1], [5.5, -0.21673916e-1], [5.6, -0.21241260e-1], [5.7, -0.20807663e-1], [5.8, -0.20374513e-1], [5.9, -0.19943032e-1], [6.0, -0.19514256e-1], [6.1, -0.19089134e-1], [6.2, -0.18668453e-1], [6.3, -0.18252883e-1], [6.4, -0.17843021e-1], [6.5, -0.17439353e-1], [6.6, -0.17042293e-1], [6.7, -0.16652162e-1], [6.8, -0.16269229e-1], [6.9, -0.15893717e-1], [7.0, -0.15525760e-1], [7.1, -0.15165506e-1], [7.2, -0.14812994e-1], [7.3, -0.14468255e-1], [7.4, -0.14131340e-1], [7.5, -0.13802188e-1], [7.6, -0.13480766e-1], [7.7, -0.13167023e-1], [7.8, -0.12860860e-1], [7.9, -0.12562203e-1], [8.0, -0.12270906e-1], [8.1, -0.11986869e-1], [8.2, -0.11709977e-1], [8.3, -0.11440094e-1], [8.4, -0.11177068e-1], [8.5, -0.10920752e-1], [8.6, -0.10671030e-1], [8.7, -0.10427731e-1], [8.8, -0.10190686e-1], [8.9, -0.9959797e-2], [9.0, -0.9734839e-2], [9.1, -0.9515736e-2], [9.2, -0.9302291e-2], [9.3, -0.9094362e-2], [9.4, -0.8891836e-2], [9.5, -0.8694538e-2], [9.6, -0.8502346e-2], [9.7, -0.8315094e-2], [9.8, -0.8132637e-2], [9.9, -0.7954917e-2], [10.0, -0.7781747e-2]]
plots:-pointplot([[0, 0.], [.1, -0.192545973e-2], [.2, -0.57548536e-2], [.3, -0.93691571e-2], [.4, -0.116497299e-1], [.5, -0.122768958e-1], [.6, -0.114535757e-1], [.7, -0.96377097e-2], [.8, -0.73398894e-2], [.9, -0.50026258e-2], [1.0, -0.29489933e-2], [1.1, -0.13773796e-2], [1.2, -0.3802267e-3], [1.3, 0.288809e-4], [1.4, -0.1112403e-3], [1.5, -0.7312233e-3], [1.6, -0.1747389e-2], [1.7, -0.3072868e-2], [1.8, -0.4624615e-2], [1.9, -0.6327418e-2], [2.0, -0.8115810e-2], [2.1, -0.9934627e-2], [2.2, -0.11738712e-1], [2.3, -0.13492153e-1], [2.4, -0.15167275e-1], [2.5, -0.16743558e-1], [2.6, -0.18206567e-1], [2.7, -0.19546942e-1], [2.8, -0.20759491e-1], [2.9, -0.21842382e-1], [3.0, -0.22796451e-1], [3.1, -0.23624612e-1], [3.2, -0.24331323e-1], [3.3, -0.24922213e-1], [3.4, -0.25403690e-1], [3.5, -0.25782692e-1], [3.6, -0.26066441e-1], [3.7, -0.26262258e-1], [3.8, -0.26377439e-1], [3.9, -0.26419110e-1], [4.0, -0.26394196e-1], [4.1, -0.26309316e-1], [4.2, -0.26170744e-1], [4.3, -0.25984403e-1], [4.4, -0.25755853e-1], [4.5, -0.25490243e-1], [4.6, -0.25192364e-1], [4.7, -0.24866612e-1], [4.8, -0.24517040e-1], [4.9, -0.24147342e-1], [5.0, -0.23760880e-1], [5.1, -0.23360701e-1], [5.2, -0.22949566e-1], [5.3, -0.22529948e-1], [5.4, -0.22104070e-1], [5.5, -0.21673916e-1], [5.6, -0.21241260e-1], [5.7, -0.20807663e-1], [5.8, -0.20374513e-1], [5.9, -0.19943032e-1], [6.0, -0.19514256e-1], [6.1, -0.19089134e-1], [6.2, -0.18668453e-1], [6.3, -0.18252883e-1], [6.4, -0.17843021e-1], [6.5, -0.17439353e-1], [6.6, -0.17042293e-1], [6.7, -0.16652162e-1], [6.8, -0.16269229e-1], [6.9, -0.15893717e-1], [7.0, -0.15525760e-1], [7.1, -0.15165506e-1], [7.2, -0.14812994e-1], [7.3, -0.14468255e-1], [7.4, -0.14131340e-1], [7.5, -0.13802188e-1], [7.6, -0.13480766e-1], [7.7, -0.13167023e-1], [7.8, -0.12860860e-1], [7.9, -0.12562203e-1], [8.0, -0.12270906e-1], [8.1, -0.11986869e-1], [8.2, -0.11709977e-1], [8.3, -0.11440094e-1], [8.4, -0.11177068e-1], [8.5, -0.10920752e-1], [8.6, -0.10671030e-1], [8.7, -0.10427731e-1], [8.8, -0.10190686e-1], [8.9, -0.9959797e-2], [9.0, -0.9734839e-2], [9.1, -0.9515736e-2], [9.2, -0.9302291e-2], [9.3, -0.9094362e-2], [9.4, -0.8891836e-2], [9.5, -0.8694538e-2], [9.6, -0.8502346e-2], [9.7, -0.8315094e-2], [9.8, -0.8132637e-2], [9.9, -0.7954917e-2], [10.0, -0.7781747e-2]])
CurveFitting:-Interactive(data_set)
Download regression_dataset.mw
I do not understand the following typesetting example from this helpage.
with(Typesetting)
interface(typesetting = extended)
Typeset(BesselJ(v, x))
BesselJ(v, x)
Same output without Typeset
BesselJ(v, x)
BesselJ(v, x)
Download Typeset.mw
Why the Typeset call when the output does not change. Is the helppage maybe broken? It says Examples but lists only one.
If MapleSoft read this: Some more typesetting examples would be helpfull.
I recently read something in another forum about solving a simple ordinary differential equation as an initial value problem (file attached). An unexpected solution behavior was interpreted there as a weakness of the software. However, upon closer inspection, the cause is different, and as a software novice, I cannot determine it myself.
Therefore, my question is:
Is there a way, using Maple, to check the Lipschitz condition in the neighborhood of the initial value before starting the solution of an explicit first-order system of differential equations as an initial value problem?
DGL_test.mw
i try to find the parameter in this equation but some issues show up which i am not sure i can fix that or not? there is any way for finding thus parameters?
test-F-p.mw
Could someone please check if these are new in Maple 2025.2? I am on windows 10.
eqs:=[_C1+_C2 = 0, _C1*exp(3^(1/2)*((cos(1/6*Pi*3^(1/2))-1)*(cos(1/6*Pi*3^(1/2))+1))^(1/2)/(cos(1/6*Pi*3^(1/2))-1)^(1/2)/(cos(1/6*Pi*3^(1/2))+1)^(1/2)*ln(cos(1/6*Pi*3^(1/2))+(cos(1/6*Pi*3^(1/2))^2-1)^(1/2)))+_C2*exp(-3^(1/2)*((cos(1/6*Pi*3^(1/2))-1)*(cos(1/6*Pi*3^(1/2))+1))^(1/2)/(cos(1/6*Pi*3^(1/2))-1)^(1/2)/(cos(1/6*Pi*3^(1/2))+1)^(1/2)*ln(cos(1/6*Pi*3^(1/2))+(cos(1/6*Pi*3^(1/2))^2-1)^(1/2))) = 4];
c:=[_C1, _C2];
solve(eqs,c);
#Error, (in convert/real_rat) too many levels of recursion
And
eqs:= [3^(1/4*3^(1/2))*exp(3/4*Pi)*_C1-1/3*exp(3/4*Pi)*3^(-1/4*3^(1/2)+1/2
)*_C2 = 1, _C1/(cos(1/3*Pi*3^(1/2))-1)^(1/4)/(cos(1/3*Pi*3^(1/2))+1)^(1/4)*exp(
3/4*Pi-1/2*Pi*3^(1/2))*(cos(1/3*Pi*3^(1/2))^2-1)^(1/4)*3^(1/4*3^(1/2))*((cos(1/
3*Pi*3^(1/2))^2-1)^(1/2)+cos(1/3*Pi*3^(1/2)))^(1/2*3^(1/2))-_C2*3^(-1/2-1/4*3^(
1/2))/(cos(1/3*Pi*3^(1/2))-1)^(1/4)/(cos(1/3*Pi*3^(1/2))+1)^(1/4)*(cos(1/3*Pi*3
^(1/2))^2-1)^(1/4)*exp(3/4*Pi-1/2*Pi*3^(1/2))*((cos(1/3*Pi*3^(1/2))^2-1)^(1/2)+
cos(1/3*Pi*3^(1/2)))^(-1/2*3^(1/2)) = 5*exp(-1/2*Pi*3^(1/2))]:
c:=[_C1, _C2];
solve(eqs,c)
And
eqs:=[3^(1/2*3^(1/2))*exp(1/2*Pi)*_C1-1/6*3^(-1/2*3^(1/2)+1/2)*exp(1/2*Pi
)*_C2 = 5, _C1/(cos(1/6*Pi*3^(1/2))-1)^(1/4)/(cos(1/6*Pi*3^(1/2))+1)^(1/4)*exp(
1/2*Pi-1/6*Pi*3^(1/2))*(cos(1/6*Pi*3^(1/2))^2-1)^(1/4)*3^(1/2*3^(1/2))*((cos(1/
6*Pi*3^(1/2))^2-1)^(1/2)+cos(1/6*Pi*3^(1/2)))^(3^(1/2))-1/6*_C2*3^(-1/2*3^(1/2)
+1/2)/(cos(1/6*Pi*3^(1/2))-1)^(1/4)/(cos(1/6*Pi*3^(1/2))+1)^(1/4)*exp(1/2*Pi-1/
6*Pi*3^(1/2))*(cos(1/6*Pi*3^(1/2))^2-1)^(1/4)*((cos(1/6*Pi*3^(1/2))^2-1)^(1/2)+
cos(1/6*Pi*3^(1/2)))^(-3^(1/2)) = 2*exp(-1/6*Pi*3^(1/2))]:
c:=[_C1, _C2];
solve(eqs,c)
Trace shows they are coming from Algebraic: best unknown/equation
Cannot upload worksheet due to security. Here is screen shot
Variation of (a) Skin friction ∂W/∂Z​, (b) Heat Transfer ∂θ/∂Z​, and (c) Mass Transfer ∂ϕ/∂Z​ for γ=10.0, Pr=7.0, ε=1.0, Nt=0.4, and Nb=0.2.
10.0   0.03301 1.90406 0.21772
20.0   0.01212 1.90403 0.20269
30.0   0.00727 1.90402 0.19325
40.0   0.00522 1.90400 0.18645
how to get this values by solving the PDE by using the pdsolve method
Variation of (a)W(b) θ and (c) ϕ for different value of γ when ε = 10.0, Nb = 0.4, ε = 10.0, Sc = 0.5 and Pr = 7.0.
consider X as 0.1
plume_work.mw
Could someone please check if this error happens in earlier versions of Maple? I have only Maple 2025.2 on Windows.
Unable to upload worksheet due to new security. Here is the code to run
integrand:=-3*(Pi-2*arcsin(tau))*(tau+1)^(1/2)*(tau+(tau^2-1)^(1/2))^(2*(tau^2-1)^(1/2)/(tau-1)^(1/2)/(tau+1)^(1/2))*(tau-1)^(1/2)*(-16/3*tau^2+Pi-2*arcsin(tau)+8/3)/(4*tau^2-4);
int(integrand,tau)
The error is
Update dec 12, 2025
Here is another int() error. In Maple 2025.2.  It comes from
RationalTrigOnly: case ratpoly*trig(arg)
Error, (in unknown) too many levels of recursion
I still can not upload worksheet. So here is the code followed by screen shot
integrand:=-(tau+(tau^2-1)^(1/2))^(1/2*(tau^2-1)^(1/2)/(tau-1)^(1/2)/(tau+1)^(1/2))*(64*tau^4+Pi^2-4*Pi*arcsin(tau)+4*arcsin(tau)^2-64*tau^2+8)*(tau-1)^(1/2)*(tau+1)^(1/2)/(16*tau^2-16);
int(integrand,tau);
TrigOnly: case of integrand containing trigs
I did not make new question as this seems to be same source of error but can not be sure now.
Second update DEC 12, 2025
Here is 3rd one. Seems also the same. comes from RationalTrigOnly: case ratpoly*trig(arg)
integrand:=-(tau + sqrt(tau^2 - 1))^(2*sqrt(tau^2 - 1)/(sqrt(tau - 1)*sqrt(tau + 1)))*(Pi - 2*arcsin(tau))*(12*tau^2 + Pi - 2*arcsin(tau) - 6)*sqrt(tau - 1)*sqrt(tau + 1)/(16*tau^2 - 16);
int(integrand,tau);
Why one is no longer able to upload worksheet here showing a problem? I found an internal error in int() but can't upload worksheet.
When I click on the green arrow and select my worksheet, I get this message
What is going on? I am on windows 10 and I tried 2 different browsers. So the problem is on the Mapleprimes site.
Can anyone else try to upload a worksheet to test to see if they get same problem?
Currently, when I have solution to an ode, say y(x)=sin(x)+_C1 and have some initial condition, then to solve for _C1,  I manually substitute the solution into the IC and replace each x by x0 and replace each derivative manually and so on.
This is because I could not find automatic way to do this. Using another software, it is possible to automate this by writing the solution using the  y -> Function[{x}, ...] syntax. But in Maple, I was not sure how to do the same.
Here is a simple made up example.
sol:= y(x) = sin(x)+_C1;
IC := a*D(y)(x0)+c*y(x0)= b*y0+exp((D@@2)(y)(x0));
The goal is to replace the solution (which is function y(x)) into the IC, and automatically replace all its derivatives and replace x by x0 then solve for _C1 from the equation that results.
Now I do this manually like this
eval(IC,[ y(x0)=eval(rhs(sol),x=x0),
          D(y)(x0)=eval(diff(rhs(sol),x),x=x0),
         (D@@2)(y)(x0)= eval(diff(rhs(sol),x$2),x=x0) ])
which gives
But this is too much work.
Using the other software, I can do the above much more easily like this
sol = y -> Function[{x}, Sin[x] + C[1]]
ic = a*y'[x0] + c*y[x0] == b*y0 + Exp[y''[x0]];
ic /. sol
I looked at algsubs, dchange, or making the solution as function instead, and so on but could not emulate the y -> Function[{x}, Sin[x] + C[1]] method in Maple.
What would be similar method in Maple to do the above automatically?  May be there is already builtin function in Maple?
I frequently receive this message after installing the most recent Maple update:
Can anyone help me with this? Thank you so much for your valuable support.
First 18 19 20 21 22 23 24 Last Page 20 of 2462
