I'm currently evaluating MapleFlow and the transition from MathCad sheets to this software.
I was looking at temperature conversions and this seems to be wrong:
I was expecting 0°C after the conversion. Has someone an explanation for this?
Thanks for your help.
Hello Ladies and Genlemen,
What is the command to display a list of *all* the packages in Maple ?
How do you insert an output for exemple (2.1.1) in a worksheet?
CTRL+K is inactive for me...it just adds a CRLF.
Thank you very much and kind regards,
Jean-Michel
I was searching release notes for some old Maple versions. I found so many broken links on Maple web pages. The first page is https://www.maplesoft.com/products/maple/history/
Scrolling down, and starting from Maple 2016 (about half way down the page), all links to the "product press release" are broken. This is the link to the right of each product.  All these links on the right, from 2016 to the end of the page are broken,
Clicking on any of these, sends the user to new broken web page, called https://www.maplesoft.com/company/publications/  titled "Maplesoft media coverage".
This page does not even work. Clicking on "Jump to year" does not open. Clicking in "first page" does nothing. Tried Edge browser on windows 10, also the page does nothing.
Then I clicked on Maplesoft Media Releases link at top, and now it works.
But jumping to any year before  2016, all the links that show on those pages are broken. Try and see,
For example. jumping to 2015, and clicking on release called "
November 25, 2015"
Gives
This applies to each press release for each year from 2015 to 1997.
Hundreds of links are broken.
There is software which checks broken links, and it is free for windows, called Xenu's Link Sleuth. May be someone at Maplesoft can use it to find all broken links at Maplesoft web site and fix them?
It is not acceptable in this day and age to have a Major software company with a web site full of broken links.
Do not know if this known or reported or not. Just in case. Here is an example where odetest gives internal error when adding integer to assuming.
Maple 2025.2. Firewall will not let me upload now. Here is code
sol:=y(x) = -4/9*I*(x+1)^(1/4)*(x-1)^(1/4)*2^(1/2)*x^2+4/9*(x+1)^(1/4)*(x-1)^(1/4)*2^(1/2)*x^2+4/9*I*(x+1)^(1/4)*(x-1)^(1/4)*2^(1/2)+1/9*x^4-4/9*(x+1)^(1/4)*(x-1)^(1/4)*2^(1/2)-16/9*I*(x+1)^(1/2)*(x-1)^(1/2)-2/9*x^2+1/9;
ode:=(-x^2+1)*diff(y(x),x)+x*y(x) = x*(-x^2+1)*y(x)^(1/2);
IC:=y(0) = 1;
odetest(sol,[ode,IC]) assuming integer,positive;
Screen shot
There used to be specific web pages, that lists specific update to Maple DE solver.
Only ones I can find are from version 8 to 16. Here are the links below. They start by saying this
https://www.maplesoft.com/support/help/Maple/view.aspx?path=updates/Maple8/de
https://www.maplesoft.com/support/help/Maple/view.aspx?path=updates/Maple9/de
https://www.maplesoft.com/support/help/Maple/view.aspx?path=updates/Maple10/de
https://www.maplesoft.com/support/help/Maple/view.aspx?path=updates/Maple11/de
https://www.maplesoft.com/support/help/Maple/view.aspx?path=updates/Maple12/de
https://www.maplesoft.com/support/help/Maple/view.aspx?path=updates/Maple13/de
https://www.maplesoft.com/support/help/Maple/view.aspx?path=updates/Maple14/de
https://www.maplesoft.com/support/help/Maple/view.aspx?path=updates/Maple15/de
https://www.maplesoft.com/support/help/Maple/view.aspx?path=updates/Maple16/de
But these do not works for anything after Maple 16 and before 8. i.e. changing the number in the link to 17 or 18 and so on, gives no page found error.
All my search leads to no result.
Are such help pages still present for updates to DE solvers in Maple for versions after Maple 16? WHat link to use to access them?
When I look at web pages under "what is new" it also does not have specific section just for DE solver like those pages had. For example   https://www.maplesoft.com/support/help/maple/view.aspx?path=updates%2Fv2025  does not have specific section just for DE solvers.
 i wait 30 minute to  see the result of this function it will zero or not but is not give me outcome, is so importan for me which to see this function is my answer, how i can see the result, can  anyone give me the way
T-pde.mw
I have the following data
Dados:=[-9.43, -4.42, -4.04, -2.88, -1.90, -1.81, -1.20, -1.16, -1.03, -.14, 1.27, 1.72, 1.97, 1.98, 2.24, 3.24, 3.64, 3.8, 5.1, 5.52]
and using command
Histogram(Dados, binbounds = [-10, -7, -4, -1, 2, 5, 8], frequencyscale = absolute)
I can create a frequency histogram for the classes [-10,-7[, [-7,-4[, [-4,-1[, [-1,2[, [2,5[, [5,8[. However, how I can create a cumulative histogram with corresponding polygon employing this same information? With thanks.
The system below obviously has the unique solution  t=3*Pi/2 , but Maple doesn't return any solution. I wonder if this bug persists in recent versions of Maple?
solve({cos(t)=0,sin(t)=-1,t>=0,t<=2*Pi}, t);
   #  NULL
I wanted to trick odetest and see what it does. I gave it solution to ode with IC. The solution was in form of implicit solution.
odetest verified it.
Then I solved for y(x) from the implicit solution and passed each now explicit solution to odetest, now it does not verify either one. (two explicit solutions resulted)
I would have thought that odetest to not verify the implicit solution as well. Is this a bug or an expected behavior when using implicit?
Does this mean, to be safe, one should try to solve for y(x) explicitly before using odetest? But sometimes this can be expensive or not possible nor practical to do as implicit solution can be complicated to solve for y(x).
Maple 2025.2 on windows 10.
Firewall now suddently will not let me upload a worksheet again for some reason. Firewall did not have a problem yesterday, but today it complained.
So here code and screen shot
ode:=2*y(x) + 2*x*y(x)^2 + (2*x + 2*x^2*y(x))*diff(y(x), x) = 0;
IC:=y(0) = 1;
maple_sol:=dsolve([ode,IC]);
#                         maple_sol := ()
my_sol_1:=x*y(x)*(2+y(x)*x)=0;
odetest(my_sol_1,[ode,IC])
#                             [0, 0]
PDEtools:-Solve(my_sol_1,y(x));
map(X->odetest(X,[ode,IC]),[%])
#   [[0, 1], [0, undefined]]
So I want to create gamma matrices like this one:
and the four Pauli matrices. So how can I create this one if I have defined the identity matrix (2X2) and the zero matrix(2X2).
 I have tried this:
with(LinearAlgebra);
ga_zero := matrix(4, 4, [ZeroMatrix(2), IdentityMatrix(2), -IdentityMatrix(2), ZeroMatrix(2)]);
Which, of course, did not work. I knew it from the start. But I am wondering how to do it.
Thank you in advance for your help
Mario
I downloaded the Maple free trial but could not find the Migration Assistant. What to do?
In my Maple program, the voltage output of the system is computed as a time-domain response under different time intervals. The response curve has already been successfully obtained and plotted.
However, I would like to further extract and plot the envelope of this response. I initially attempted to determine the envelope by identifying the extrema of the signal, i.e., by solving the condition that the time derivative of the response equals zero. Unfortunately, this approach consistently leads to error messages, and I am not sure whether the issue is related to symbolic differentiation, numerical noise, or the implementation itself.
Could anyone please advise on:
  1. The correct way to extract an envelope curve from a time-domain signal in Maple?
  2. Whether there are alternative or more robust methods (e.g., based on numerical post-processing, signal processing techniques, or built-in Maple tools) to obtain the envelope, especially for numerically computed responses?
Any suggestions or example commands would be greatly appreciated.
numsolve-1229.mw
In the attached file, I want to transform (1) into (3) and back again (3) into (1). Attempts using CompleteSquare and expand in combination with other commands have failed. I would appreciate any advice.
dio1.mw
I am looking for a command that extracts sqrt(2) from
sqrt(4 + (-2*x - 2)*y)
The expression above is a subexpression of a larger expression generated by Maple (an integral).
In this situation manual workarounds are impractical and errorprone.
Ideally Maple should return
sqrt(2)*sqrt(2 - (x + 1)*y)
I tried simplify, factor, collect and so on...
In case that there is nothing (which I doubt):
Why is Maple not having simple commands that do extraction (and absortion/inclusion) of factors?
(extract and absorb are names not used so far that would be easy to remember.)
Update - example of an expression:
expr := Int(sqrt(-2*alpha^2*x - 2*alpha^2 + 4)/(sqrt(-alpha^2 + 1)*(-alpha^2*x - alpha^2 + 2)), alpha = 0 .. z) = EllipticF(z, sqrt(2*x + 2)/2)
I noticed today only 2 cases where calling simplify, with no options, made things worst.
Just trying to understand why.
Here is one example. Solved an ode. when calling odetest on this solution, it gives zero. But if the solution is simplified first, then odetest no longer gives zero. And it is actually hard to find a trick to make it become zero so far.
But the question is: Is this to be expected sometimes? I use simplify sporadically, but like to get smaller  expression at one point. But now I am not sure if I should even do that.
Could this be a problem in simplify itself somehow?
Here is an example.
ode:=diff(y(x), x) = y(x)*(-1 - x^(2/(ln(x) + 1))*exp(2*ln(x)^2/(ln(x) + 1))*x^2 - x^(2/(ln(x) + 1))*exp(2*ln(x)^2/(ln(x) + 1))*x^2*ln(x) + x^(2/(ln(x) + 1))*exp(2*ln(x)^2/(ln(x) + 1))*x^2*y(x) + 2*x^(2/(ln(x) + 1))*exp(2*ln(x)^2/(ln(x) + 1))*x^2*y(x)*ln(x) + x^(2/(ln(x) + 1))*exp(2*ln(x)^2/(ln(x) + 1))*x^2*y(x)*ln(x)^2)/((ln(x) + 1)*x);
diff(y(x), x) = y(x)*(-1-x^(2/(ln(x)+1))*exp(2*ln(x)^2/(ln(x)+1))*x^2-x^(2/(ln(x)+1))*exp(2*ln(x)^2/(ln(x)+1))*x^2*ln(x)+x^(2/(ln(x)+1))*exp(2*ln(x)^2/(ln(x)+1))*x^2*y(x)+2*x^(2/(ln(x)+1))*exp(2*ln(x)^2/(ln(x)+1))*x^2*y(x)*ln(x)+x^(2/(ln(x)+1))*exp(2*ln(x)^2/(ln(x)+1))*x^2*y(x)*ln(x)^2)/((ln(x)+1)*x)
sol_1:=dsolve(ode);
y(x) = exp(-(1/4)*x^4)/(x^(-2*ln(x)/(ln(x)+1))*exp(-(1/4)*(x^4*ln(x)+x^4+4*ln(ln(x)+1)*ln(x)-8*ln(x)^2+4*ln(ln(x)+1))/(ln(x)+1))*ln(x)^2+2*x^(-2*ln(x)/(ln(x)+1))*exp(-(1/4)*(x^4*ln(x)+x^4+4*ln(ln(x)+1)*ln(x)-8*ln(x)^2+4*ln(ln(x)+1))/(ln(x)+1))*ln(x)+x^(-2*ln(x)/(ln(x)+1))*exp(-(1/4)*(x^4*ln(x)+x^4+4*ln(ln(x)+1)*ln(x)-8*ln(x)^2+4*ln(ln(x)+1))/(ln(x)+1))+ln(x)*c__1+c__1)
odetest(sol_1,ode)
sol_2:=simplify(sol_1);
y(x) = 1/((ln(x)+1)*(exp((1/4)*x^4)*c__1+1))
odetest(sol_2,ode);
c__1*x^(ln(x)/(ln(x)+1)+3/(ln(x)+1))*exp(2*ln(x)^2/(ln(x)+1)+(1/4)*x^4)/((ln(x)+1)*(exp((1/4)*x^4)*c__1+1)^2)-c__1*x^3*exp((1/4)*x^4)/((ln(x)+1)*(exp((1/4)*x^4)*c__1+1)^2)
Download why_simplify_changes_things_at_dec_27_2025.mw
Notice how much simpler the solution becomes after calling simplify. I'd like to use that. But for some reason, odetest now fails to verify the simpler version. Which tells me simplify did something which made the solution not valid.
Here is second example, where calling simplify in betwen did not give zero as expected.
f := sqrt(1 + sin(x)^2);
F := int(f, x):
df := diff(F, x):
simplify(df - f);
(1+sin(x)^2)^(1/2)
F := int(f, x):
F := simplify(F):
df := diff(F, x):
simplify(df - f);
(1+sin(x)^2)^(1/2)
-csgn(1, cos(x))*sin(x)*EllipticE(sin(x), I)
Download why_simplify_changes_things_at_dec_27_2025_V2.mw
Just trying to understand why this happens and if this is something that could happen sometimes? May be one should avoid calling simplify in middle of computation and let the user decide if they want to simplify the final result or not?
First 16 17 18 19 20 21 22 Last Page 18 of 2462
