Whenever i open Maple 18, some symbols are missing including the arrows. I use Maple 18 to do math assingments, and the arrows are useful. It seems like a lot of other content is missing in Maple 18 as well. Below is a picture of the missing symbols, or there should be one. Any help on how i get the arrows back, would be amazing.
Symbols missing
Hi, i'm trying to make a function to create 2 polygons with the same number of sides, the same center but different radius. These 2 polygons have to be on the same draw. I tried by doing this function but its not working..
 If anyone could help me it would be great and sorry for my bad english i'm from France.
Hallo
Use DrawSubgroupLattice for G:=Symm(4) then
A:=DerivedSeries(G);
Drawing this Series there are red marked 30,29,21,1.
But why not 8 or 9 or 10 which are between 21 and 1?
Best regards
Kurt Ewald
Hi:
i solved nonlinear ode in terms of t (y(t)) with dsolve command,how i will evaluate value function(y(t)) in points t=0..1 with delta t=0.01 and results(t and y(t)) inside a excel file?
eq := diff(y(t), t, t)-y(t)^2 = 1
res := dsolve({eq, y(0) = 0, (D(y))(0) = 0}, {y(t)}, numeric)
Hello! How can I find extremes of numeric solution of ODE system obtained using "dsolve"? Can I use something like "extrema" function?
If I use a decimal like 0.569840290998053 into a fraction?
I notice that when I tried to factor the polynomial
x^3+x^2+2*x+1 I did not get the rational roots of the polynomial, then I tried using synthetic division to solve for the roots but I could not find a root. So I believe that the roots of the polynomial equation are complex numbers...
How could I use synthetic division to find the rational roots of this integral so that I could do a Partial Fraction Decomposition for the integral...
Here is my code & the error mesage.  What's wrong?
with(Statistics);
X := Vector*([0, 5, 10, 15, 20, 25, 30], datatype = float);
Y := Vector*([38.8, 53.8, 82.4, 107.6, 130.7, 152.4, 173.2], datatype = float);
NonlinearFit(av^2+bv+c, X, Y, v);
Error, (in Statistics:-NonlinearFit) invalid input: PostProcessData expects its 1st argument, x, to be of type {array, list, rtable}, but received w
Hello everybody,
I want to find all of roots of the complex variables functions in two ways.
(1) find the value which can make the function equals 0
(2) find the real value and imaginary value which make real part and imaginary part of function equal 0
(I know answers of these two case is not equal completely.)
The function is a non-linear function, including sin, cos and Bessel function, such as:
And, I used Analytic and fsolve to do case (1) and (2), but failure. The follow result is how I tried to find the real value answer:
It seems that both of two commands can only find some of roots.
How to find all of roots of these cases? The related .mw file is attached.
Cannot_find_all_of_roots.mw
Thanks a lot.
I am trying to take out the intersection between two bases from one of the original basis. I have two matrices (A and B) and want to find the intesection between the range (or column space) of A and the null space of B. The range of A is
X1:=ColumnSpace(A)
For some reason, the column space is not presented as a list, but with square brakes, so I convert this into a list of vectors:
X2:=SumBasis([X1[1],X1[2]])    %If I use the command Basis, it returns again square brakets, not sure why...
The null space of B
X3:=NullSpace(B)
X4:=IntersectionBasis([X2,X3])
X5:= X2\cap X4 % I am using latex code for the intersection symbol...
The result is the empty set! Evidently, X2 and X3 are differnt bases.
Any help would be really welcome! Many thanks!
Joaquin
How do I interpolate using polar coordinates?  I have a series with non-uniform spacing, that I want to map onto a uniform space polar grid.
Any assistance would be appreciated.
let A be a matrix=
[  7        7      9    -17
   6        6      1    -2
 -12    -12    -27    1
   7       7      17   -15 ]
What is the reduced row echelon form of A?
What is the rank of A?
A consistent system of linear equations in 14 unknowns is reduced to row echelon form. There are then 10 non-zero rows (i.e. 10 pivots). How many parameters (free variables) will occur in the solution?
I failed to solve the ODE system shown as follows, where y1(x) and y2(x) are functions of x, ranging from -L/2 to L/2. All the other parameters are constants (A,B,C,F,G). The analytic or numeric solution of y1(x) and y2(x) are wanted.Really appreciate for you experts' help and time!!!
dsys:={diff(y1(x),x$2)-A*x^2*y1=B*diff(y2(x),x$3),diff(y2(x),x$2)-C*diff(y1(x),x)=F*x^2+G}
boundary conditions:y1(0)=0, diff(y2(L/2),x$2)=0, D(y2)(0)=0, y2(L/2)=0
RandomCompositions:= module()
local
Compositions, Rand,
local
Compositions, Rand,
ModuleApply:= proc(n::posint, k::posint)
local C;
Compositions:= [seq(C-~1, C= combinat:-composition(n+k, k))];
Rand:= rand(1..nops(Compositions));
()-> Compositions[Rand()]
end module:
R:= RandomCompositions(8,6):
seq(R(),i=1..10);
[0, 0, 2, 6, 0, 0], [1, 0, 0, 3, 4, 0], [0, 3, 3, 2, 0, 0],[1, 2, 4, 0, 1, 0], [0, 4, 0, 1, 3, 0],
[2, 0, 1, 4, 1, 0],[2, 0, 1, 1, 3, 1], [1, 0, 4, 2, 1, 0], [1, 3, 0, 2, 0, 2],[2, 0, 3, 2, 1, 0]
with(Statistics):
Tally(R());
[0 = 1, 1 = 4, 4 = 1]
I want to count the 0 to 8 respectively summation,and divide by i.
 But the  seq command  R() isn't conform  with Tally command R() .
First 1421 1422 1423 1424 1425 1426 1427 Last Page 1423 of 2460
