Greetings
I am left wondering why evalf as well as right clicking and selecting approximate both are in error.
Try 1/2*sqrt(109) and find a solution with 5 digits (english isnt my first language so the wording may not be correct).
If you calculate it as 1/2*sqrt(109.0) you correctly get 5.2202
However, if you use evalf(1/2*sqrt(109)) or 1/2*sqrt(109) then right click and approximate with 5 digits you incorrectly get 5.2200.
I assume this is because both incorrectly round to 5 digits on sqrt(109) before dividing by 2 - a common mistake for very inexperienced students but surely not something I would expect from Maple.
Please explain and better yet fix. Thanks.
i'm going to solve the two eq. and plot the answer point
i try to do two group but the first succeed the second get some wrong
the first i named 1 ,and second named 2 as below
the 1 plot the correct point that i want
Although the 2 solve eq too but it didn't plot the point on(-0.36,0.29),
the code of this two is same ,
anyone can help me?
1.mw
2.mw
Hello.
I am trying to extract all the coefficients of a linear equation by calling coeffs function.
eq := 1.2*a[2]+1.3*a[3]+1.1*a[1]+1.0
vars := [seq(a[i], i = 1 .. 3)]
[a[1], a[2], a[3]]
coeffs(eq, vars)
1.0, 1.2, 1.3, 1.1
I expected I receive the coefficients in the same order as in vars variable, but I was wrong. How to extract coefficients in the order I need?
Download test.mw
in Kurzweil und Stellmacher "Theorie der endlichen Gruppen" page 97, Exercice 3 I have read
Is G nilpotent then G is cyclic.
I have found that if G is nilpotent it must not be cyclic.
Can anybody tell me whether I am right or not?
Best Regards
Kurt Ewald
Is there a way to open a classic worksheet in macintosh, even running windows through a virtual machine?
Hi there
I'm working with maple 13 (2d input) and I would like to hide the input in a worksheet, as follows:
view > show/hide contents > (unchecking) input
however i want to insert comments as text that will remain in my worksheet. Using '#' doesn't help, coz they get hidden too.
Couldn't sort out how to do this, any tips?
cheers
cilrcle.mw
i want to plot a circle which is centered at(0,0),and the radius is the length of Point2 and origin
but it shows some error,how could i do to solve this
cilrcle.mw
i want to plot a circle with that centered at (0,0),and the radius is the length of Point2 and orgin
but it shows the error
color.mw
how can i do if i  want to change the color of point1 which is rotated from point2
i want to make point2 red , and point1 is black , but the point1 is still  red
anyone can help me? thx
Hello People in mapleprimes,
I want to know how to factor the denominator of the first term in the right hand side, using commands not clickable math.
And, I know applyop can be used in this case, but I want to know is other ways than using applyop.
-tau*alpha*sigma*omega*(tau-omega^(-sigma))/(s*L*(1-gamma-tau^2+tau^2*gamma))
-(sigma*alpha)/s*(1-tau*omega^sigma)/(omega^(sigma-1)*(1-gamma)*L*(1/tau-tau));
taro
Hello all,
When I try to do this example, in the multibody analysis, http://www.maplesoft.com/products/maplesim/ModelGallery/detail.aspx?id=137
Thats already written :
but when I enter theses formulas(mModel & MB), that write instead of the example:
"Analyzing system..."
"Performing constraint analysis..."
"The system has 2 degree(s) of freedom. It is modeled using 2
generalized coordinate(s) coupled by 0 algebraic constraint(s\
And I have no result if i do vPosCons := MB:-GetPosCons(); . What am I doing wrong?
t := exp(2*(I*Pi*(1/11)))
u := t^10*a[10]+t^9*a[9]+t^8*a[8]+t^7*a[7]+t^6*a[6]+t^5*a[5]+t^4*a[4]+t^3*a[3]+t^2*a[2]+t*a[1]+a[0]
How can get maple to simplify expressions like u^3+u^2-1 so that the exponents are between 2*(I*Pi*(1/11)) and 1.
Essentially it keeps outputting things like exp(2*(I*Pi*(1/11)))^12 and not simplifying it as it is a root of unity
for example i want to save the Square root of 2 to 1000000 decimal place to an ascii text file ...
i used the writeto command after evalf[100](sqrt(2)) for but it contains line breaks and \ character in output !
but i only need the pure continues 1000000 digits !
please guide me on this simple request ?
Hi Maple friends.
If I have a table of values, how can Maple provide the function?
For example:
x=10,15,20,25,30,35,40
y=2.01,4.87,6.50,9.875,14.00,18.90,24.40
How can Maple find out the y function with respect to x?
I'm trying to make a piecewise function that will have period 12. That is, it repeats every 12 units across the x-axis.
I managed to do one cycle successfully with
plot(piecewise(0<=t and t<2, 4,2<=t and t<12,0), t=0..13);
But I'm not sure how to do it periodically. I thought about using modular arithmetic in the conditions and setting up something like
H(t)=piecewise(0<=modp1(f(t),12) and modp1(f(t),12)<2, 4,2<=modp1(f(t),12) and modp1(f(t),12)<12,0);
but this clearly doesn't work.
Some direction or advice would be appreciated. Thanks!
First 1422 1423 1424 1425 1426 1427 1428 Last Page 1424 of 2460
