Hi:
i have data in a file excell(attach in below) and i will import them to maple and plot the figure,how do this work?
with regards...
data.xls
Hi Maple friends.
I am trying to differentiate these:
1. csc(x)/x
2. 3*x^2*cot(x)
From doing it by hand, I am getting:
1. -cosec(x)*(xcot(x) + 1)
2. 6x*cot(x) - 3x^2*cosec^2(x)
But Maple is giving the answer:
1. diff(csc(x)/x, x);
-csc(x)*cot(x)/x-csc(x)/x^2
2. diff(3*x^2*cot(x), x);
6*x*cot(x)+3*x^2*(-1-cot(x)^2)
My answers don't look like Maple's answers. Are they actually the same?
The problem is how to plot a linear transformation, for example,
(x,y)->(x-y/2,y)
As, I searched, I found out that the code "LinearTransformPlot" can do that but it defines to act for example on lines or a certain subspace. May I ask you to learn the solution. Should we have a subspace untill we can plot the transformation? Thanks
Hello people in mapleprimes,
I want to modify the next equation:
(**)  a:=sigma*omega*alpha = mu(H, H)*s*omega*gamma1*L+mu(F, H)*s*L-mu(F, H)*s*L*gamma1;
to be
(***)    sigma*omega*alpha = mu(H, H)*s*omega*gamma1*L+(1-gamma1)*mu(F, H)*s*L;
For that, first I defined b as
b:=sum(op(k,rhs(a)),k=2..3)=collect(sum(op(k,rhs(a)),k=2..3),{s,L,mu(F,H)});
, and substituted this to a with
subs(b,a);
But, what I could obtain was only the orignal equation (**) not (***).
Please tell me how to use subs to this problem to obtain (***)。
taro
P.S.
I know
(****)collect(lhs(a)=rhs(a),{s,L,mu(F,H)});
works well as for what I wrote (**) as above.
But, originally, it was a result from substituting various equations into an equation.
For it, (****) does not work well.
Whenever i open Maple 18, some symbols are missing including the arrows. I use Maple 18 to do math assingments, and the arrows are useful. It seems like a lot of other content is missing in Maple 18 as well. Below is a picture of the missing symbols, or there should be one. Any help on how i get the arrows back, would be amazing.
Symbols missing
Hi, i'm trying to make a function to create 2 polygons with the same number of sides, the same center but different radius. These 2 polygons have to be on the same draw. I tried by doing this function but its not working..
 If anyone could help me it would be great and sorry for my bad english i'm from France.
Hallo
Use DrawSubgroupLattice for G:=Symm(4) then
A:=DerivedSeries(G);
Drawing this Series there are red marked 30,29,21,1.
But why not 8 or 9 or 10 which are between 21 and 1?
Best regards
Kurt Ewald
Hi:
i solved nonlinear ode in terms of t (y(t)) with dsolve command,how i will evaluate value function(y(t)) in points t=0..1 with delta t=0.01 and results(t and y(t)) inside a excel file?
eq := diff(y(t), t, t)-y(t)^2 = 1
res := dsolve({eq, y(0) = 0, (D(y))(0) = 0}, {y(t)}, numeric)
Hello! How can I find extremes of numeric solution of ODE system obtained using "dsolve"? Can I use something like "extrema" function?
If I use a decimal like 0.569840290998053 into a fraction?
I notice that when I tried to factor the polynomial
x^3+x^2+2*x+1 I did not get the rational roots of the polynomial, then I tried using synthetic division to solve for the roots but I could not find a root. So I believe that the roots of the polynomial equation are complex numbers...
How could I use synthetic division to find the rational roots of this integral so that I could do a Partial Fraction Decomposition for the integral...
Here is my code & the error mesage.  What's wrong?
with(Statistics);
X := Vector*([0, 5, 10, 15, 20, 25, 30], datatype = float);
Y := Vector*([38.8, 53.8, 82.4, 107.6, 130.7, 152.4, 173.2], datatype = float);
NonlinearFit(av^2+bv+c, X, Y, v);
Error, (in Statistics:-NonlinearFit) invalid input: PostProcessData expects its 1st argument, x, to be of type {array, list, rtable}, but received w
Hello everybody,
I want to find all of roots of the complex variables functions in two ways.
(1) find the value which can make the function equals 0
(2) find the real value and imaginary value which make real part and imaginary part of function equal 0
(I know answers of these two case is not equal completely.)
The function is a non-linear function, including sin, cos and Bessel function, such as:
And, I used Analytic and fsolve to do case (1) and (2), but failure. The follow result is how I tried to find the real value answer:
It seems that both of two commands can only find some of roots.
How to find all of roots of these cases? The related .mw file is attached.
Cannot_find_all_of_roots.mw
Thanks a lot.
I am trying to take out the intersection between two bases from one of the original basis. I have two matrices (A and B) and want to find the intesection between the range (or column space) of A and the null space of B. The range of A is
X1:=ColumnSpace(A)
For some reason, the column space is not presented as a list, but with square brakes, so I convert this into a list of vectors:
X2:=SumBasis([X1[1],X1[2]])    %If I use the command Basis, it returns again square brakets, not sure why...
The null space of B
X3:=NullSpace(B)
X4:=IntersectionBasis([X2,X3])
X5:= X2\cap X4 % I am using latex code for the intersection symbol...
The result is the empty set! Evidently, X2 and X3 are differnt bases.
Any help would be really welcome! Many thanks!
Joaquin
How do I interpolate using polar coordinates?  I have a series with non-uniform spacing, that I want to map onto a uniform space polar grid.
Any assistance would be appreciated.
First 1424 1425 1426 1427 1428 1429 1430 Last Page 1426 of 2463
