How can I change the decimal to be displayed in the whole spreadsheet. The default decimals to be displayed is 4 in my version. How can I change it to another value? Also I don't want to click on "properties" each time I execute my worksheet. I want it to be automatically display  the number of digits I want.
I am connected to the linux version of Maple (xmaple) via putty and Xing (for GUI).
While the "big" code is running, I sometimes I got these messages,
But Maple (xmaple GUI) keeps running. It looks like it does not have an effect.
Should I be concerned?
How can I solve this problem on Maple?
Can anyone help me please ... I wrote another post before but I can not solve the problem.
lambda is an experimental parameter. I have this initial condition n(x,0)=0.4, c(x,0)=0.
Thanks to everyone
I want to get numerical solution of the Eqs.ode(see the folowlling ode and ibc)in Maple.However,when i run the following procedure,it prompts an error "Error, (in dsolve/numeric/bvp) cannot determine a suitable initial profile, please specify an approximate initial solution". How to solve the issue? Please help me.
n := 1.4; phi := 1; beta := .6931; psi := 1
> restart;
> n := 1.4; phi := 1; beta := .6931; psi := 1;
> s := proc (x) options operator, arrow; evalf(1+(phi*exp(beta*psi)*h(x))^n) end proc;
> Y := proc (x) options operator, arrow; evalf(f-(1/2-(1/2)/n)*ln(s(x))+2*ln(1-(1-s(x))^(-1+1/n))) end proc;
> ode := diff(h(x), `$`(x, 2))+(diff(Y(x), x))*(diff(h(x), x)+1) = 0;
> ibc := h(0) = 0, ((D(h))(10)+1)*s(10)^(-(1-1/n)*(1/2))*(1-(1-1/s(10))^(1-1/n))^2 = 0;
> p := dsolve({ibc, ode}, numeric);
I want to print the intersection of thie two circle but it shows
Error, (in plots:-display) expecting plot structure but received: `intersect`(CURVES([[1.000000000, 0.], [.9973715671, 0.4177774453e-1], [.9895277204, 0.8289662909e-1], [.9765921620, .1227081842], [.9587688933, .1605845580], [.9363389981, .1959284174], [.9096562091, .2281823686], [.8791413299, .2568377476], [.8452755984, .2814426418], [.8085930973, .3016090174], [.7696723313, .3170188388], [.7291271048, .3274290836], [.6875968398, .3326755761], [.6457364935, .3326755761], [.6042062285, .3274290835], [.5636610020, .3170188387], [.5247402363, .3016090175], [.4880577352, .2814426419], [.4541920036, .2568377477], [.4236771240, .2281823683], [.39...
How can i do for this problem to solve
At the moment, I am using
>writeto("Result1.txt");
> printf(StringTools[FormatTime]("%c\n"));
Thu Jul 31 14:28:08 2014
# lots of things here
>writeto(terminal);
To write a time and date stamp into my result1.txt file.
I understand that I can't write : into file names, but is there a way to writeto file using a more informative file name with date and time, such as,
Result_Thu Jul 31 14-28-08 2014.txt
Is that something can be easily formatted?
casper
Hi Maple friends.
Is there a Maple function to determine the intersection of two curves? For simple curves where the intersection is clear, I can plot them and use probeinfo to get the approximate intersection values.
But for more complex curves, where the scales are large, or the intersection point is not clear, it is difficult.
ie. intersection of y=x-3 and y=x^2-2*x-1
or intersection of y=x+1 and y=(x+1)/(x-1)
Say sometimes, I need to copy and paste results from Maple output, either in 1D or 2D or self formatted (see this).
Sometimes, it works fine, with just a single ">" sign, like this
> v1:=[
eta[p2] = 0.260 ,
eta[p3] = 0.113 ,
eta[p4] = -0.013 ,
eta[p5] = 0.215 ,
eta[p6] = -0.189 ,
eta[phi2] = 0.020 ,
.......ect
But sometimes, it looks like this:
> v1:=[
> eta[p2] = 0.260 ,
> eta[p3] = 0.113 ,
> eta[p4] = -0.013 ,
> eta[p5] = 0.215 ,
> eta[p6] = -0.189 ,
> eta[phi2] = 0.020 ,
> .......ect
Below is a screenshot from what I get when I copy the above synatex into Maple :
Personally, when I type in multiple synatex, I tend to use shift+enter, to avoid the use of many ">"s.
It does not have any effect in practice, but is there a way to improve this? I dont like seeing many many ">"s.
Is it possible to determine using maple both the exponents x and y, if only the value of n is known in the formula 3^x/2^y=n?
Sorry. I forgot to add that n is more than 1 and less than 2. For example 1.002 090 314 041, 1. 977 205 095 and the like.
Lets take 3^359/2^569 = 1.001 066 461 508 586.  Suppose we do not know the exponents 359 and 569.  Is it possible somehow deduce them from n = 1.001 066 461 508 586?
Hi Maple friends.
expand( (a+b)^2 );
a^2+2*a*b+b^2
expand( (a+b)^3 );
a^3+3*a^2*b+3*a*b^2+b^3
expand( (a+4)^4 )
a^4+16*a^3+96*a^2+256*a+256 (???)
Pascal's triangle shows that 'expand( (a+4)^4 )' should have resulted in a^4+4*a^3*b+6*a^2*b^2+4*a*b^3+b^4
Where are the b variables in Maple's solution?
hi , how can i solve this ?
4180*10^3*(diff(T(x, y), x))-60.5*(diff(T(x, y), y, y)) = 0
whith this boundary conditions
diff(T(x, 0), y) = 100, diff(T(x, 0.25e-4), y) = 1000
thanks.
a:=0.0000000000000000000000213123123;
evalf[3](a);
I think the above is the same as if I were to change the precision tab, to display 3 decimals.
Is there a way to ask Maple to display it as  (printf(  "%3.3f",a);)
0.000
But I want this as a standard Maple ouput.
and I am not just working with a single scalar, I need something that works for a Vector, Matrix, and perhaps, in general.
casper
v1:=[
eta[p2] = 0.260 ,
eta[p3] = 0.113 ,
eta[p4] = -0.013 ,
eta[p5] = 0.215 ,
eta[p6] = -0.189 ,
eta[phi2] = 0.020 ,
eta[phi3] = 0.063 ,
eta[phi4] = -0.014 ,
eta[phi5] = -0.414 ,
eta[phi6] = 0.067 ,
mu[p] = 0.466 ,
mu[phi] = -0.169 ,
tau[p3] = -0.000 ,
tau[p4] = 0.000 ,
w[1] = 0.023 ,
w[2] = -0.447 ,
w[3] = -0.110 ,
w[4] = 0.035 ,
w[5] = 0.445
for i to numelems(v1) do
    printf("%a = %3.3f , \n",lhs(v1[i]),rhs(v1[i]));
This runs and returns:
eta[p2] = 0.260 ,
eta[p3] = 0.113 ,
eta[p4] = -0.013 ,
eta[p5] = 0.215 ,
eta[p6] = -0.189 ,
eta[phi2] = 0.020 ,
eta[phi3] = 0.063 ,
eta[phi6] = 0.067 ,
mu[p] = 0.466 ,
mu[phi] = -0.169 ,
tau[p3] = 0.000 ,
tau[p4] = 0.000 ,
w[1] = 0.023 ,
w[2] = -0.447 ,
w[3] = -0.110 ,
w[4] = 0.035 ,
w[5] = 0.445 ,
Is there a way to align the qual signs? also to align the decials like this:
eta[p2]   =  0.260 ,
eta[p3]   =  0.113 ,
eta[p4]   = -0.013 ,
eta[p5]   =  0.215 ,
eta[p6]   = -0.189 ,
eta[phi2] =  0.020 ,
eta[phi3] =  0.063 ,
eta[phi6] =  0.067 ,
mu[p]     =  0.466 ,
mu[phi]   = -0.169 ,
tau[p3]   =   0.000 ,
tau[p4]   =   0.000 ,
w[1]       =   0.023 ,
w[2]       = -0.447 ,
w[3]       = -0.110 ,
w[4]       =  0.035 ,
w[5]       =  0.445 ,
For the negative numbers, I prefer to have 1 space of indentation.
casper
hi fellas
i have questions which maybe very common but i can't handle it right now
there are 9 matrices. each one of them is a 3*3 matrix, not to say all the matrices' elements are in symbolic form.
all i want is to form a matrix made out of the 9 matrices i mentioned above in **maple**; i mean something like "cell" in MatlabI'll be appreciated for your help
l := 16; m := .75; EIy := 0.2e5; EIz := 0.400e7; GJ := 0.1e5; mj := .1; Pz := 5000;
16
.75
0.2e5
0.400e7
0.1e5
.1
5000
eq1 := m*(diff(diff(w(x, t), t), t))+diff(diff(EIy*(diff(diff(w(x, t), x), x))+(EIz-EIy)*(diff(diff(w(x, t), x), x))*(theta(x)+phi(x, t))^2, x), x)-Pz = 0;
.75*(diff(diff(w(x, t), t), t))+0.2e5*(diff(diff(diff(diff(w(x, t), x), x), x), x))+0.398e7*(diff(diff(diff(diff(w(x, t), x), x), x), x))*(theta(x)+phi(x, t))^2+0.1592e8*(diff(diff(diff(w(x, t), x), x), x))*(theta(x)+phi(x, t))*(diff(theta(x), x)+diff(phi(x, t), x))+0.796e7*(diff(diff(w(x, t), x), x))*(diff(theta(x), x)+diff(phi(x, t), x))^2+0.796e7*(diff(diff(w(x, t), x), x))*(theta(x)+phi(x, t))*(diff(diff(theta(x), x), x)+diff(diff(phi(x, t), x), x))-5000 = 0
w := unapply(q[1](t)*cosh(1.8751*x/l),x, t);
proc (x, t) options operator, arrow; q[1](t)*cosh(.1171937500*x) end proc
theta := proc (x) options operator, arrow; 0 end proc;
#theta(x);eq1;
phi := unapply(q[4](t)*sin(1.5708*x/l),x, t);
proc (x, t) options operator, arrow; q[4](t)*sin(0.9817500000e-1*x) end proc
eq2:=unapply(lhs(eq1),x,t);
proc (x, t) options operator, arrow; .75*(diff(diff(q[1](t), t), t))*cosh(.1171937500*x)+3.772661154*q[1](t)*cosh(.1171937500*x)-302.9569534*q[1](t)*cosh(.1171937500*x)*q[4](t)^2*sin(0.9817500000e-1*x)^2+2515.691179*q[1](t)*sinh(.1171937500*x)*q[4](t)^2*sin(0.9817500000e-1*x)*cos(0.9817500000e-1*x)+1053.716523*q[1](t)*cosh(.1171937500*x)*q[4](t)^2*cos(0.9817500000e-1*x)^2-5000 end proc
f[1] := int(expand(eq2(x,t)*cosh(1.8751*x/l)), x = 0 .. l);
int(.75*(diff(diff(q[1](t), t), t))*cosh(.1171937500*x)^2+3.772661154*q[1](t)*cosh(.1171937500*x)^2-302.9569534*q[1](t)*cosh(.1171937500*x)^2*q[4](t)^2*sin(0.9817500000e-1*x)^2+2515.691179*cosh(.1171937500*x)*q[1](t)*sinh(.1171937500*x)*q[4](t)^2*sin(0.9817500000e-1*x)*cos(0.9817500000e-1*x)+1053.716523*q[1](t)*cosh(.1171937500*x)^2*q[4](t)^2*cos(0.9817500000e-1*x)^2-5000*cosh(.1171937500*x), x = 0 .. 16)
Download 1.mw
First 1427 1428 1429 1430 1431 1432 1433 Last Page 1429 of 2460
