I would like to open a modelica model with MapleSIM. When I do "import modelica", I received the error message : "import failed : no library found".
I believed the modelica library was already installed on maplesim but may be not. Do I need to install modelica library ? and if yes, how ?
More generally speaking, how can I do to open a modelica model on maplesim?
Thank you for your help.
We deploy Maple to our users using Microsoft App-V; We have been using App-V 4  to successfully deploy Maple for some time. When I package Maple 18 for App-V 5 deployment, when a user launches Maple there is an error "too many levels of recursion".
After clicking OK to clear the error, choosing any of the options on the start screen, e.g. signal processing, simply launches a help screen with the message "no matches found" instead of launching a new worksheet.
App-V is our standard method of deploying applications, and has always worked OK in the past. Do you have any recommendations for packaging Maple 18 via App-V?
Good day,
What scheme does midrich method is using in solving BVP?
Hi, I would like to know if there is a command on Maple 18 that can show all the decompositions of a given symbolic tensor.
  Excuse me, I have a following expression
x^2+x+2;
  I want to replace all x as x+1
x:=x+1 does not work.
Is there any simple solution?
Thank you very much in advance
hi,
   here are  equations like this
 sol := [abs(r)^2+abs(t)^2 = 1, r*conjugate(t)+t*conjugate(r), abs(r) = abs(t)]
when i solve this equations using command solve,the result  is none. and i used r=x+I*y,t=u+I*v in the equations,
sol:=[u^2+v^2+x^2+y^2 = 1, 2*u*x+2*v*y, sqrt(x^2+y^2) = sqrt(u^2+v^2)]
i still can't get a result.why,can you help me.
thanks.
Hi there
I am stuck with the expression
> e := (3+2*sinh(x)^2)/(sinh(x)^2*tanh(x));
                               3 + 2 sinh(x)
                              sinh(x)  tanh(x)
its simplified way, which i cannot find, is
> f := 3*coth(x)^3-coth(x);
                            3 coth(x)  - coth(x)
> simplify(e-f);
I would appreciate immensely if someone could give me some pointers on how to solve it.
best regards
nvc
Hi:
I will a write program in maple for plot the function f(x),while asked value n from user at first,then plot function f(x) for each value of n and finally all plots show in one figure only for different value of n,how to do it?
f(x)=1+2*(1+x)^n,x=0..5
Dear Maple Users,
I'm beginner in Maple.
I have this system of Pde:
with lambda experimental parameter and n,c,v dependent variables. I write this on Maple but I read on internet that the solution "float(undefined)" is an error.
I will insert this initial condition: c(x,0)=0,n(x,0)=0.4
Thanks everybody
Hallo,
how can I  construct a Permutationgroup with given GroupOrder and Degree.
for instance: GroupOrder 12 and Degree 5, I found by accident
G:=<(1,2,3),(1,5,2)>
Best Regards
Kurt Ewald
Hi:
how i can plot the function in terms of different values of n in a figure:
f(x)=1+2*(1+x)^n
n=1,2,3,4
x-axis->x
y-axis->f(x)
The toggle button in the embedded components has a default image which points up and down. Is there any way to rotate this image so that it points left and right?  I though I might actually just rotate the default image gif(?) directly, but the properties window does not give the location of the gif(?) used for this image. I also can't locate the image file simply looking at the Maple program folder. Otherwise, I have to go find or create an image of my own.
Good Afternoon Everyone,
Would anybody be kind to help me with the interpolation of two variables in a table to obtain a value for f18.1 (Stiffness) and f18.2 (Damping) given SR_ratio and Lamda_ratio.
Moses
with(CurveFitting)
with(ExcelTools):
Slenderness Ratio (Variable 1):
SR__ratio := 84.01
Ratio of modulus of elasticity of Pile vs shear modulus of soil (Variable 2):
`&lambda;__ratio` := 229.58
Slenderness ratio of pile from stiffness of pile table:
SR__stiff := [10.8696, 21.7391, 32.6087, 43.4783, 46.7391, 54.3478, 65.2174, 76.0870, 86.9565, 100.0]
Ratio of Young's Modulus of Pile to Shear modulus of soil:
EG__ratio := [250.0, 500.0, 1000.0, 2500.0, 5000.0, 10000.0]
Vertical stiffness coefficient for floating pile as per Novak (1983) f18.1.250:
`f__18.1.250` := [0.332e-1, 0.509e-1, 0.571e-1, 0.582e-1, 0.582e-1, 0.582e-1, 0.582e-1, 0.582e-1, 0.582e-1, 0.582e-1]
Vertical stiffness coefficient for floating pile as per Novak (1983) f18.1.500:
`f__18.1.500` := [0.187e-1, 0.301e-1, 0.364e-1, 0.405e-1, 0.416e-1, 0.416e-1, 0.416e-1, 0.416e-1, 0.416e-1, 0.416e-1]
Vertical stiffness coefficient for floating pile as per Novak (1983) f18.1.1000:
`f__18.1.1000` := [0.104e-1, 0.166e-1, 0.218e-1, 0.26e-1, 0.27e-1, 0.281e-1, 0.291e-1, 0.301e-1, 0.301e-1, 0.301e-1]
Vertical stiffness coefficient for floating pile as per Novak (1983) f18.1.2500:
`f__18.1.2500` := [0.52e-2, 0.83e-2, 0.104e-1, 0.125e-1, 0.135e-1, 0.145e-1, 0.166e-1, 0.177e-1, 0.187e-1, 0.197e-1]
Vertical stiffness coefficient for floating pile as per Novak (1983) f18.1.10000:
`f__18.1.10000` := [0.21e-2, 0.31e-2, 0.42e-2, 0.42e-2, 0.52e-2, 0.52e-2, 0.62e-2, 0.62e-2, 0.73e-2, 0.83e-2]
Slenderness ratio of pile from damping of pile table:
SR__damp := [10.8696, 16.3043, 21.7391, 27.1739, 32.6087, 38.0435, 43.4783, 48.913, 54.3478, 59.7826, 65.2174, 70.6522, 76.0870, 81.5217, 86.9565, 92.3913, 100.0]
Vertical damping coefficient for floating pile as per Novak (1983) f18.2.250:
`f__18.2.250` := [.1032, .1137, .1126, .1095, .1053, .1021, 0.989e-1, 0.979e-1, 0.979e-1, 0.979e-1, 0.979e-1, 0.979e-1, 0.979e-1, 0.979e-1, 0.979e-1, 0.989e-1, 0.989e-1]
Vertical damping coefficient for floating pile as per Novak (1983) f18.2.500:
`f__18.2.500` := [0.558e-1, 0.695e-1, 0.811e-1, 0.832e-1, 0.811e-1, 0.789e-1, 0.758e-1, 0.737e-1, 0.726e-1, 0.716e-1, 0.705e-1, 0.695e-1, 0.695e-1, 0.695e-1, 0.695e-1, 0.705e-1, 0.705e-1]
 Vertical damping coefficient for floating pile as per Novak (1983) f18.2.1000:
`f__18.2.1000` := [0.295e-1, 0.421e-1, 0.495e-1, 0.537e-1, 0.568e-1, 0.589e-1, 0.579e-1, 0.568e-1, 0.558e-1, 0.537e-1, 0.526e-1, 0.516e-1, 0.516e-1, 0.505e-1, 0.505e-1, 0.505e-1, 0.495e-1]
 Vertical damping coefficient for floating pile as per Novak (1983) f18.2.2500:
`f__18.2.2500` := [0.126e-1, 0.179e-1, 0.232e-1, 0.263e-1, 0.305e-1, 0.326e-1, 0.347e-1, 0.368e-1, 0.379e-1, 0.379e-1, 0.379e-1, 0.379e-1, 0.379e-1, 0.368e-1, 0.358e-1, 0.358e-1, 0.337e-1]
   Vertical damping coefficient for floating pile as per Novak (1983) f18.2.10000:
`f__18.2.10000` := [0.32e-2, 0.53e-2, 0.74e-2, 0.84e-2, 0.105e-1, 0.116e-1, 0.137e-1, 0.147e-1, 0.147e-1, 0.168e-1, 0.168e-1, 0.179e-1, 0.189e-1, 0.189e-1, 0.200e-1, 0.211e-1, 0.211e-1]
`f__18.1` := ArrayInterpolation(SR__ratio, `&lambda;__ratio`, SR__stiff, EG__ratio, `f__18.1.250`)
`f__18.2__ _` := ArrayInterpolation(SR__ratio, `&lambda;__ratio`, SR__damp, EG__ratio, `f__18.2.250`)
Download Dynamic_Table.mwDynamic_Table.mw
Moses
Hi:
how i can plot the function f(x) in term of 1/x in maple?for example i have the function f(x)=x^2 and x=0..1,now i plot f(x) in term of 1/x.
First 1428 1429 1430 1431 1432 1433 1434 Last Page 1430 of 2460
