For some reason, Maple does not use \frac{}{} for things like 1/2 that can occur in an expression
expr:=1/2;
latex(expr);
            1/2
This make the generated code not good looking. For example using this in Maple:
latex(diff(y(x), x)+y(x)*cos(x)-(1/2)*sin(2*x) = 0);
produces this latex when proccessed:
When the latex is put inside a display in the document.  This is terrible. Is there a way to tell Latex to use \frac{}{} for fractions?
Hi:
i will sole the below non-linear equtions in maple,how?(all initial conditons are zero)
EQ1 := -9.034666667*10^5*Pi^2*q3(t)*q1(t)+3044.230933*Pi*q1(t)*q5(t)+3044.230933*Pi*q1(t)*q4(t)+2.541000000*10^5*q1(t)^3*Pi^4+2.171794873*10^5*q1(t)*Pi^2-2.171794873*10^5*q2(t)*Pi+4.372778665*(diff(q1(t), t, t)) = 0
EQ2 := 54294.87180*q2(t)-54294.87180*q1(t)*Pi-.8371635069*q4(t)*Pi+.8371635069*q5(t)*Pi+1.093194666*q2(t)*Pi^2+0.7054749580e-5*(diff(q2(t), t, t)) = 0
EQ3 := 9.034666667*10^5*q1(t)^2*Pi^2+6.776000000*10^5*Pi^2*q3(t)-2283.173200*q5(t)*Pi-2283.173200*q4(t)*Pi = 0
EQ4 := -1.123134385*10^8*q1(t)*(diff(q1(t), t))+636.6197724-5191.348750*q4(t)-2.035463170*10^7*(diff(q5(t), t))-2.035463170*10^7*(diff(q4(t), t))-5191.348750*q5(t) = 0
EQ5 := .7002817496-29887.90348*q4(t)+29887.90348*q5(t)-135.8992605*(diff(q2(t), t))-7463.364956*(diff(q4(t), t))+7463.364956*(diff(q5(t), t)) = 0
We are using your maple service and required your help in solving below problem '
1. Create a question type Maple Numeric with correct answer 27
2. If user gives 27d and 27e and on evaluate with your service getting response as true.
Please find the attached screens for more information. Also see request and response for numeric value 10 and if you see response even 10d is evaluating as true. This is wrong, please review and advice.
mapleScript :: before substitution
expr1:="<math><cn>${#answer}</cn></math>"; expr2:="<math><cn>${#correctAnswer}</cn></math>"; expr3:="<math><cn>${#tolrence}</cn></math>";expr1 := StringTools[SubstituteAll](expr1, ",", "");expr1 := StringTools[RegSubs]("<apply>< *([a-zA-Z]+)[ /]*>" = "<apply><ci>\1</ci>", expr1);expr1 := StringTools[RegSubs]("<apply><ci>(plus|minus|divide|times|power)</ci>" = "<apply><\\1/>", expr1);expr1 := StringTools[RegSubs]("<apply><ci> *([a-zA-Z]+) *</ci>" = "<apply><ci>x_\\1</ci>", expr1);expr1 := StringTools[RegSubs]("<c[ni]> *([0-9]+\\.[0-9]+) *</c[ni]>" = "<apply><ci>convert</ci><cn>\\1</cn><ci>rational</ci><ci>exact</ci></apply>", expr1);expr2 := StringTools[SubstituteAll](expr2, ",", "");expr2 := StringTools[RegSubs]("<apply>< *([a-zA-Z]+)[ /]*>" = "<apply><ci>\\1</ci>", expr2);expr2 := StringTools[RegSubs]("<apply><ci>(plus|minus|divide|times|power)</ci>" = "<apply><\\1/>", expr2);expr2 := StringTools[RegSubs]("<apply><ci> *([a-zA-Z]+) *</ci>" = "<apply><ci>x_\\1</ci>", expr2);expr2 := StringTools[RegSubs]("<c[ni]> *([0-9]+\\.[0-9]+) *</c[ni]>" = "<apply><ci>convert</ci><cn>\\1</cn><ci>rational</ci><ci>exact</ci></apply>", expr2);expr1 := MathML[ImportContent](expr1);expr2 := MathML[ImportContent](expr2);expr := combine(expr1-expr2, [radical,power,trig,ln,power,radical], symbolic);expr3:=MathML[ImportContent](expr3);result := evalb(abs(simplify(expr, symbolic))<=expr3);result := evalb(result = true);if not result then result := evalb(abs(simplify(expr, assume = real))<=expr3) end if;result := evalb(result = true);
mapleScript :: (user input) 10d
expr1:="<math><cn>10d</cn></math>"; expr2:="<math><cn>10</cn></math>"; expr3:="<math><cn>0</cn></math>";expr1 := StringTools[SubstituteAll](expr1, ",", "");expr1 := StringTools[RegSubs]("<apply>< *([a-zA-Z]+)[ /]*>" = "<apply><ci>\1</ci>", expr1);expr1 := StringTools[RegSubs]("<apply><ci>(plus|minus|divide|times|power)</ci>" = "<apply><\\1/>", expr1);expr1 := StringTools[RegSubs]("<apply><ci> *([a-zA-Z]+) *</ci>" = "<apply><ci>x_\\1</ci>", expr1);expr1 := StringTools[RegSubs]("<c[ni]> *([0-9]+\\.[0-9]+) *</c[ni]>" = "<apply><ci>convert</ci><cn>\\1</cn><ci>rational</ci><ci>exact</ci></apply>", expr1);expr2 := StringTools[SubstituteAll](expr2, ",", "");expr2 := StringTools[RegSubs]("<apply>< *([a-zA-Z]+)[ /]*>" = "<apply><ci>\\1</ci>", expr2);expr2 := StringTools[RegSubs]("<apply><ci>(plus|minus|divide|times|power)</ci>" = "<apply><\\1/>", expr2);expr2 := StringTools[RegSubs]("<apply><ci> *([a-zA-Z]+) *</ci>" = "<apply><ci>x_\\1</ci>", expr2);expr2 := StringTools[RegSubs]("<c[ni]> *([0-9]+\\.[0-9]+) *</c[ni]>" = "<apply><ci>convert</ci><cn>\\1</cn><ci>rational</ci><ci>exact</ci></apply>", expr2);expr1 := MathML[ImportContent](expr1);expr2 := MathML[ImportContent](expr2);expr := combine(expr1-expr2, [radical,power,trig,ln,power,radical], symbolic);expr3:=MathML[ImportContent](expr3);result := evalb(abs(simplify(expr, symbolic))<=expr3);result := evalb(result = true);if not result then result := evalb(abs(simplify(expr, assume = real))<=expr3) end if;result := evalb(result = true);
evalResult ::
expr1 := "<math><cn>10d</cn></math>" expr2 := "<math><cn>10</cn></math>" expr3 := "<math><cn>0</cn></math>" expr1 := "<math><cn>10d</cn></math>" expr1 := "<math><cn>10d</cn></math>" expr1 := "<math><cn>10d</cn></math>" expr1 := "<math><cn>10d</cn></math>" expr1 := "<math><cn>10d</cn></math>" expr2 := "<math><cn>10</cn></math>" expr2 := "<math><cn>10</cn></math>" expr2 := "<math><cn>10</cn></math>" expr2 := "<math><cn>10</cn></math>" expr2 := "<math><cn>10</cn></math>" expr1 := 10. expr2 := 10 expr := 0. expr3 := 0 result := true result := true result := true
expr1:="<math><cn>10</cn></math>"; expr2:="<math><cn>10</cn></math>"; expr3:="<math><cn>0</cn></math>";expr1 := StringTools[SubstituteAll](expr1, ",", "");expr1 := StringTools[RegSubs]("<apply>< *([a-zA-Z]+)[ /]*>" = "<apply><ci>\1</ci>", expr1);expr1 := StringTools[RegSubs]("<apply><ci>(plus|minus|divide|times|power)</ci>" = "<apply><\\1/>", expr1);expr1 := StringTools[RegSubs]("<apply><ci> *([a-zA-Z]+) *</ci>" = "<apply><ci>x_\\1</ci>", expr1);expr1 := StringTools[RegSubs]("<c[ni]> *([0-9]+\\.[0-9]+) *</c[ni]>" = "<apply><ci>convert</ci><cn>\\1</cn><ci>rational</ci><ci>exact</ci></apply>", expr1);expr2 := StringTools[SubstituteAll](expr2, ",", "");expr2 := StringTools[RegSubs]("<apply>< *([a-zA-Z]+)[ /]*>" = "<apply><ci>\\1</ci>", expr2);expr2 := StringTools[RegSubs]("<apply><ci>(plus|minus|divide|times|power)</ci>" = "<apply><\\1/>", expr2);expr2 := StringTools[RegSubs]("<apply><ci> *([a-zA-Z]+) *</ci>" = "<apply><ci>x_\\1</ci>", expr2);expr2 := StringTools[RegSubs]("<c[ni]> *([0-9]+\\.[0-9]+) *</c[ni]>" = "<apply><ci>convert</ci><cn>\\1</cn><ci>rational</ci><ci>exact</ci></apply>", expr2);expr1 := MathML[ImportContent](expr1);expr2 := MathML[ImportContent](expr2);expr := combine(expr1-expr2, [radical,power,trig,ln,power,radical], symbolic);expr3:=MathML[ImportContent](expr3);result := evalb(abs(simplify(expr, symbolic))<=expr3);result := evalb(result = true);if not result then result := evalb(abs(simplify(expr, assume = real))<=expr3) end if;result := evalb(result = true);
evalResult ::
expr1 := "<math><cn>10</cn></math>" expr2 := "<math><cn>10</cn></math>" expr3 := "<math><cn>0</cn></math>" expr1 := "<math><cn>10</cn></math>" expr1 := "<math><cn>10</cn></math>" expr1 := "<math><cn>10</cn></math>" expr1 := "<math><cn>10</cn></math>" expr1 := "<math><cn>10</cn></math>" expr2 := "<math><cn>10</cn></math>" expr2 := "<math><cn>10</cn></math>" expr2 := "<math><cn>10</cn></math>" expr2 := "<math><cn>10</cn></math>" expr2 := "<math><cn>10</cn></math>" expr1 := 10 expr2 := 10 expr := 0 expr3 := 0 result := true result := true result := true
When I try to export my data from a spreadsheet to Excel, instead of numbers I get a long text containing numbers. For example instead of having just "11625.7677908435" I get "Typesetting:-mprintslash([11625.7677908435], [HFloat(11625.767790843516)])".
How can I change the decimal to be displayed in the whole spreadsheet. The default decimals to be displayed is 4 in my version. How can I change it to another value? Also I don't want to click on "properties" each time I execute my worksheet. I want it to be automatically display  the number of digits I want.
I am connected to the linux version of Maple (xmaple) via putty and Xing (for GUI).
While the "big" code is running, I sometimes I got these messages,
But Maple (xmaple GUI) keeps running. It looks like it does not have an effect.
Should I be concerned?
How can I solve this problem on Maple?
Can anyone help me please ... I wrote another post before but I can not solve the problem.
lambda is an experimental parameter. I have this initial condition n(x,0)=0.4, c(x,0)=0.
Thanks to everyone
I want to get numerical solution of the Eqs.ode(see the folowlling ode and ibc)in Maple.However,when i run the following procedure,it prompts an error "Error, (in dsolve/numeric/bvp) cannot determine a suitable initial profile, please specify an approximate initial solution". How to solve the issue? Please help me.
n := 1.4; phi := 1; beta := .6931; psi := 1
> restart;
> n := 1.4; phi := 1; beta := .6931; psi := 1;
> s := proc (x) options operator, arrow; evalf(1+(phi*exp(beta*psi)*h(x))^n) end proc;
> Y := proc (x) options operator, arrow; evalf(f-(1/2-(1/2)/n)*ln(s(x))+2*ln(1-(1-s(x))^(-1+1/n))) end proc;
> ode := diff(h(x), `$`(x, 2))+(diff(Y(x), x))*(diff(h(x), x)+1) = 0;
> ibc := h(0) = 0, ((D(h))(10)+1)*s(10)^(-(1-1/n)*(1/2))*(1-(1-1/s(10))^(1-1/n))^2 = 0;
> p := dsolve({ibc, ode}, numeric);
I want to print the intersection of thie two circle but it shows
Error, (in plots:-display) expecting plot structure but received: `intersect`(CURVES([[1.000000000, 0.], [.9973715671, 0.4177774453e-1], [.9895277204, 0.8289662909e-1], [.9765921620, .1227081842], [.9587688933, .1605845580], [.9363389981, .1959284174], [.9096562091, .2281823686], [.8791413299, .2568377476], [.8452755984, .2814426418], [.8085930973, .3016090174], [.7696723313, .3170188388], [.7291271048, .3274290836], [.6875968398, .3326755761], [.6457364935, .3326755761], [.6042062285, .3274290835], [.5636610020, .3170188387], [.5247402363, .3016090175], [.4880577352, .2814426419], [.4541920036, .2568377477], [.4236771240, .2281823683], [.39...
How can i do for this problem to solve
At the moment, I am using
>writeto("Result1.txt");
> printf(StringTools[FormatTime]("%c\n"));
Thu Jul 31 14:28:08 2014
# lots of things here
>writeto(terminal);
To write a time and date stamp into my result1.txt file.
I understand that I can't write : into file names, but is there a way to writeto file using a more informative file name with date and time, such as,
Result_Thu Jul 31 14-28-08 2014.txt
Is that something can be easily formatted?
casper
Hi Maple friends.
Is there a Maple function to determine the intersection of two curves? For simple curves where the intersection is clear, I can plot them and use probeinfo to get the approximate intersection values.
But for more complex curves, where the scales are large, or the intersection point is not clear, it is difficult.
ie. intersection of y=x-3 and y=x^2-2*x-1
or intersection of y=x+1 and y=(x+1)/(x-1)
Say sometimes, I need to copy and paste results from Maple output, either in 1D or 2D or self formatted (see this).
Sometimes, it works fine, with just a single ">" sign, like this
> v1:=[
eta[p2] = 0.260 ,
eta[p3] = 0.113 ,
eta[p4] = -0.013 ,
eta[p5] = 0.215 ,
eta[p6] = -0.189 ,
eta[phi2] = 0.020 ,
.......ect
But sometimes, it looks like this:
> v1:=[
> eta[p2] = 0.260 ,
> eta[p3] = 0.113 ,
> eta[p4] = -0.013 ,
> eta[p5] = 0.215 ,
> eta[p6] = -0.189 ,
> eta[phi2] = 0.020 ,
> .......ect
Below is a screenshot from what I get when I copy the above synatex into Maple :
Personally, when I type in multiple synatex, I tend to use shift+enter, to avoid the use of many ">"s.
It does not have any effect in practice, but is there a way to improve this? I dont like seeing many many ">"s.
Is it possible to determine using maple both the exponents x and y, if only the value of n is known in the formula 3^x/2^y=n?
Sorry. I forgot to add that n is more than 1 and less than 2. For example 1.002 090 314 041, 1. 977 205 095 and the like.
Lets take 3^359/2^569 = 1.001 066 461 508 586.  Suppose we do not know the exponents 359 and 569.  Is it possible somehow deduce them from n = 1.001 066 461 508 586?
Hi Maple friends.
expand( (a+b)^2 );
a^2+2*a*b+b^2
expand( (a+b)^3 );
a^3+3*a^2*b+3*a*b^2+b^3
expand( (a+4)^4 )
a^4+16*a^3+96*a^2+256*a+256 (???)
Pascal's triangle shows that 'expand( (a+4)^4 )' should have resulted in a^4+4*a^3*b+6*a^2*b^2+4*a*b^3+b^4
Where are the b variables in Maple's solution?
hi , how can i solve this ?
4180*10^3*(diff(T(x, y), x))-60.5*(diff(T(x, y), y, y)) = 0
whith this boundary conditions
diff(T(x, 0), y) = 100, diff(T(x, 0.25e-4), y) = 1000
thanks.
First 1430 1431 1432 1433 1434 1435 1436 Last Page 1432 of 2463
