ode:=diff(y(x), x, x)-y(x)*(a^2*x^(2*n)-1);
dsolve(ode,y(x));
gives
     DESol({diff(_Y(x), x, x)+(-a^2*x^(2*n)+1)*_Y(x)}, {_Y(x)})
as answer. I read the help on DESol, but what does the above actually mean? Where is the solution of the ode? It just returned the ode back to me. Can I consider that Maple did not solve this ode in this case?
from help
"DESol is a data structure to represent the solution of a differential equation. It is to dsolve as RootOf is to solve."
From 1 to 1000, how many time we use "5"?
print_result.mw
How could I convert HFloat type number to a number?
My ultimate aim is to print the ouput in a "nicer" wa, like this
printf("Minimum value is: 2.440\n");
printf("x=2.257\n");
printf("y=0.000\n");
and possibly can be written to a file (using writeto).
I have been using Mapleprimes for many years. I have asked a lot of questions as well as helped, commented on some posts.
But I always found it a bit difficult to dig up my old posts. So I can have a look what I have asked.
In the "account" page, I can find "Subscriptions",
In the "www.mapleprimes.com/recent/" page, I can find "Your Contributions".
But is there some where, I can dig up ALL my posts (those I have "asked") only?
casper
Say I run a procedure, it could take about 3 minutes to run, or maybe hours, or longer.
Is it possible to trigger a sound, like "ding", after it's finished?
I may like to read something while the program is running, but I want to see the results immediately.
It would be nice to have such function.
Also, for procedures that runs for a "long" time, could I get 10 (or 15) minutes sound notice?
casper
I wonder if there is a way to achieve this, say I have 4 Maple worksheets,
sheet1.mw
sheet2.mw
sheet3.mw
sheet4.mw
all of them can run seperately. Each of them runs on lots of data, and takes a big chuck of time. I hope to run them one by one. After each file is completed, save (Export) as PDF file, and move on to the next one.
On my own PC, I use Maple X64 windows version. I have never used the command line, but I suppose that will be done in this version, instead of the GUI version?
On the school server, it's Maple X64 linux version. So it's also has the maple command line version as well as the xmaple version.
casper
seq1:=seq(i,i=1..5);
seq2:=seq(i,i=2..6);
dseq:=seq2-seq1;
seq2:=seq(i,i=1..5);
dseq:=seq2-seq1;
seq1:=[seq(i,i=1..5)];
seq2:=[seq(i,i=1..5)];
dseq:=seq2-seq1;
Is that possible to get the differences between two sequences directly? (instead of using a list)
I don't quit understand why the second method would collapse the 0s into just a single value. It's not a set.
casper
Suppose i am trying to do a sequential if command as follows:
seq(`if`(a[i] < b[i], c[i], d[i]), i = 1 .. 10);
now this doesnot evaluate the i's in c[i] and d[i].
please help me with complete evaluation of this statement.
I'd like to try the new Maple IDE
http://www.maplesoft.com/products/toolboxes/IDE/index.aspx
Maple IDE - Integrated Development Environment
Is there a way to obtain a trial version even for a week just to try it out? I do not want to spend all this money then find out it does not work well.
any one here uses this and can recommend it or comment on how well it works? For example, can one run Maple code directly from it and have the code execute in Maple, or must one load the file manually from the editor into Maple to run it each time they make any changes to the code?
I want to sum over several variables at once.
For example, something like
add(add(add(f(k1,k2,k3),k1=range1),k2=range2),k3=range3);
sums over 3 variables. But this can only be done if I know the number of variables in advance. I want to write a code that will sum over m variables, with m being supplied on demand.
Maple can do this for integrals. If I write
int(f(seq(k[i],i=1..m)),[seq(k[i]=range[i],i=1..m)]);
the integral is computed over m variables, for any m.
How can something like this be implemented for summation?
So suppose in one maple worksheet, I run:
>assume(w, real); y:=2*w;
>save y, "test.m";
And then I open another, and run
>read "test.m";
>subs(w=1,y);
The substitution won't work, while it works if I don't make any assumptions about the variable w.  However, in the piece of code I'm actually running (this snippet is just to illustrate the problem), I need to make the assumption that w is real for solving a system of equations (otherwise maple seems to run out of memory).  Is there a way to save my result y in such a way so that I can make substitutions for w later?
As am trying to solve this integration:
A(c,n,m):=evalf(int(1/(y)*exp(-c*y^(2)),y=n..m))
B(c,n,m):=evalf(int(exp(-c*y^(2)),y=n..m))
C(c,n,m):=evalf(int(y*exp(-c*y^(2)),y=n..m))
d(c,n,m):=evalf(int(y^(2)*exp(-c*y^(2)),y=n..m))
E(c,n,m):=evalf(int(y^(3)*exp(-c*y^(2)),y=n..m))
F0 := exp(beta*s1)*exp(gamma0^2*exp(beta*s1)/(2*gamma1))*A((1/2)*gamma1*exp(beta*s1), gamma0/gamma1,gamma0/gamma1+tau1)/gamma1+exp(beta*s2)*exp(gamma0^2*exp(beta*s2)/(2*gamma1))*A((1/2)*gamma1*exp(beta*s2), gamma0/gamma1+a, gamma0/gamma1+tau2-tau1+a)/gamma1+exp(beta*s3)*exp(gamma0^2*exp(beta*s3)/(2*gamma1))*A((1/2)*gamma1*exp(beta*s3), gamma0/gamma1+b, gamma0/gamma1+c-tau2+b)/gamma1
F1 := exp(beta*s1)*exp(gamma0^2*exp(beta*s1)/(2*gamma1))*(gamma0^2*A((1/2)*gamma1*exp(beta*s1), gamma0/gamma1, gamma0/gamma1+tau1)/gamma1^2-2*gamma0*B((1/2)*gamma1*exp(beta*s1), gamma0/gamma1, gamma0/gamma1+tau1)/gamma1+C((1/2)*gamma1*exp(beta*s1), gamma0/gamma1, gamma0/gamma1+tau1))/gamma1+exp(beta*s2)*exp(gamma0^2*exp(beta*s2)/(2*gamma1))*(gamma0^2*A((1/2)*gamma1*exp(beta*s2), gamma0/gamma1+a, gamma0/gamma1+tau2-tau1+a)/gamma1^2-2*gamma0*B((1/2)*gamma1*exp(beta*s2), gamma0/gamma1+a, gamma0/gamma1+tau2-tau1+a)/gamma1+C((1/2)*gamma1*exp(beta*s2), gamma0/gamma1+a, gamma0/gamma1+tau2-tau1+a))/gamma1+exp(beta*s3)*exp(gamma0^2*exp(beta*s3)/(2*gamma1))*(gamma0^2*A((1/2)*gamma1*exp(beta*s3), gamma0/gamma1+b, gamma0/gamma1+c-tau2+b)/gamma1^2-2*gamma0*B((1/2)*gamma1*exp(beta*s3), gamma0/gamma1+b, gamma0/gamma1+c-tau2+b)/gamma1+C((1/2)*gamma1*exp(beta*s3), gamma0/gamma1+b, gamma0/gamma1+c-tau2+b))/gamma1
F01 := exp(beta*s1)*exp(gamma0^2*exp(beta*s1)/(2*gamma1))*(B((1/2)*gamma1*exp(beta*s1), gamma0/gamma1, gamma0/gamma1+tau1)-gamma0*A((1/2)*gamma1*exp(beta*s1), gamma0/gamma1, gamma0/gamma1+tau1)/gamma1)/gamma1+exp(beta*s2)*exp(gamma0^2*exp(beta*s2)/(2*gamma1))*(B((1/2)*gamma1*exp(beta*s2), gamma0/gamma1+a, gamma0/gamma1+tau2-tau1+a)-gamma0*A((1/2)*gamma1*exp(beta*s2), gamma0/gamma1+a, gamma0/gamma1+tau2-tau1+a)/gamma1)/gamma1+exp(beta*s3)*exp(gamma0^2*exp(beta*s3)/(2*gamma1))*(B((1/2)*gamma1*exp(beta*s3), gamma0/gamma1+b, gamma0/gamma1+c-tau2+b)-gamma0*A((1/2)*gamma1*exp(beta*s3), gamma0/gamma1+b, gamma0/gamma1+c-tau2+b)/gamma1)/gamma1
`F&beta;` := int((s1^2*(gamma0*t+(1/2)*gamma1*t^2)*exp(beta*s1)*(gamma1*t+gamma0)*exp(beta*s1))*exp(-(gamma0*t+(1/2)*gamma1*t^2)*exp(beta*s1)), t = 0 .. tau1)+int((s2^2*(gamma0*(a+t-tau1)+(1/2)*gamma1*(a+t-tau1)^2)*exp(beta*s2)*(gamma0+gamma1*(a+t-tau1))*exp(beta*s2))*exp(-(gamma0*(a+t-tau1)+(1/2)*gamma1*(a+t-tau1)^2)*exp(beta*s2)), t = tau1 .. tau2)+int((s3^2*(gamma0*(b+t-tau2)+(1/2)*gamma1*(b+t-tau2)^2)*exp(beta*s3)*(gamma0+gamma1*(b+t-tau2))*exp(beta*s3))*exp(-(gamma0*(b+t-tau2)+(1/2)*gamma1*(b+t-tau2)^2)*exp(beta*s3)), t = tau2 .. c)+int((s3^2*(gamma0*(b+t-tau2)+(1/2)*gamma1*(b+t-tau2)^2)*exp(beta*s3)*(gamma0+gamma1*(b+t-tau2))*exp(beta*s3))*exp(-(gamma0*(b+t-tau2)+(1/2)*gamma1*(b+t-tau2)^2)*exp(beta*s3)), t = c .. infinity)
I need to have tau2 as varibles to get there optimal values ..
Minimize(1/((F0*F1-F01^2)*n^3*`F&beta;`), tau2 = 237..273})
But this error keeps coming :
Error, (in Optimization:-NLPSolve) integration range or variable must be specified in the second argument, got HFloat(1.0) = 121.0828419 .. HFloat(193.0828419)
Please Help ..
Every time I type
`&Delta;&epsilon;`(T, z)
it becomes
T Delta&epsilon; z
Is there any way to tell maple to stay what it is as I've typed, just like other function express f(x), etc
Hi all
I have a mathematical problem and I asked it in various sites but the answers till yet are not correct.
Assume that we have:
T[m]:=t->t^m:
b[n,m]:=unapply(piecewise(t>=(n-1)*tj/N and t<n*tj/N, T[m](N*t-(n-1)*tj), 0), t):
where n,N,tj are known constants. furthermore assume that we want to comute the following integral:
for following approximations:
I have written the following code but it seems to be incorrect:
V1:=Vector([seq(seq(b[n,m](t),m=0..1),n=1..3)]);
V:=evalf(V1.Transpose(V1));
the original program is :
taaylor.mws
I will be so grateful if any one can help me to solve it by maple
Mahmood   Dadkhah
Ph.D Candidate
First 1431 1432 1433 1434 1435 1436 1437 Last Page 1433 of 2460
