t := exp(2*(I*Pi*(1/11)))
u := t^10*a[10]+t^9*a[9]+t^8*a[8]+t^7*a[7]+t^6*a[6]+t^5*a[5]+t^4*a[4]+t^3*a[3]+t^2*a[2]+t*a[1]+a[0]
How can get maple to simplify expressions like u^3+u^2-1 so that the exponents are between 2*(I*Pi*(1/11)) and 1.
Essentially it keeps outputting things like exp(2*(I*Pi*(1/11)))^12 and not simplifying it as it is a root of unity
for example i want to save the Square root of 2 to 1000000 decimal place to an ascii text file ...
i used the writeto command after evalf[100](sqrt(2)) for but it contains line breaks and \ character in output !
but i only need the pure continues 1000000 digits !
please guide me on this simple request ?
Hi Maple friends.
If I have a table of values, how can Maple provide the function?
For example:
x=10,15,20,25,30,35,40
y=2.01,4.87,6.50,9.875,14.00,18.90,24.40
How can Maple find out the y function with respect to x?
I'm trying to make a piecewise function that will have period 12. That is, it repeats every 12 units across the x-axis.
I managed to do one cycle successfully with
plot(piecewise(0<=t and t<2, 4,2<=t and t<12,0), t=0..13);
But I'm not sure how to do it periodically. I thought about using modular arithmetic in the conditions and setting up something like
H(t)=piecewise(0<=modp1(f(t),12) and modp1(f(t),12)<2, 4,2<=modp1(f(t),12) and modp1(f(t),12)<12,0);
but this clearly doesn't work.
Some direction or advice would be appreciated. Thanks!
Hi there
I'm taking my first steps with maple and my question is not exactly briliiant
Putting in a simple way, I'm trying to solve sth that looks like this
> li := a*[cos(7*x+8*x*y+9*y)*cos(-7*x-8*x*y-9*y)];
             a [cos(7 x + 8 x y + 9 y) cos(-7 x - 8 x y - 9 y)]
and i want to replace
with
getting (if i do it by hand)
> algsubs(7*x+8*x*y+9*y = 20*y, li);
                    a [cos(20 y) cos(-7 x - 8 x y - 9 y)]
my question, is there an elegant way to do it? sth that would look like this?
thank you for any tips
Hi i have trouble with this equation to solve with maple please help me
with boundary condition :
how i solve above equation with maple?( there is function to solve this equation in maple ?
email :
sattar.dogonchi@yahoo.com
D__s := 0.5e-1
f__s := 2.5*Unit('Hz')
f := 7.5*Unit('Hz')
D__1 := .8*D__s
D__2 := 0.87e-1
D__HH := `if`(f/Unit('Hz') < f__s/Unit('Hz'), D__1, D__2)
x__p := map(proc (z) options operator, arrow; z*Unit('ft') end proc, [-3.3, 0., 3.3, -3.3, 0., 3.3, -3.3, 0., 3.3])
y__p := map(proc (z) options operator, arrow; z*Unit('ft') end proc, [3.3, 3.3, 3.3, 0., 0., 0., -3.3, -3.3, -3.3])
n__pile := nops(x__p)
dex := proc (xpin, ypin, npilein) local i, j, fin, Sin; global x__p, y__p, n__pile; x__p := xpin; y__p := ypin; n__pile := npilein; for i to n__pile do for j to n__pile do fin := []; Sin[i, j] := sqrt((x__p[i]-x__p[j])^2+(y__p[i]-y__p[j])^2); fin := [op(fin), Sin[i, j]] end do end do end proc
Parse:-ConvertTo1D, "first argument to _Inert_ASSIGN must be assignable"
dex(x__p, y__p, n__pile)
`&xi;ex`(x__p, y__p, n__pile)
Download Test_modify.mw
Good Afternoon Community,
Would anybody please help me with the attached workshet. I have written a procedure with Maple to calculate the spacing between piles assumming any pile as a reference point, and also to calculate the angle between each pile from the same reference point, my procedure is not yielding any results. Please Help!
Moses
Hi There
I'm getting started with maple and facing a doubt about using subs, somehow it does not seem to work, this is my expression:
> restart;
> theta := omega*t-k*x;
                                omega t - k x
> phi[1] := -(1/2)*H*c*cosh(k*(z+h))*sin(theta)/sinh(k*h);
                   H c cosh(k (z + h)) sin(-omega t + k x)
                                 2 sinh(k h)
> diff(phi[1], t, t);
                H c cosh(k (z + h)) sin(-omega t + k x) omega
                                 2 sinh(k h)
> td := simplify(subs(z = 0, %));
                   H c cosh(k h) sin(-omega t + k x) omega
                                 2 sinh(k h)
> simplify(subs(cosh(k*h)/sinh(k*h) = 1/tanh(k*h), %));
                                 2 sinh(k h)
I cannot subs cosh/sinh = tanh. I would like to know why.
Any tips? Thank you
Hej,
when using Statistics:-Histogram i received the following strange result for the ordinate:
Statistics:-Histogram([0.587944711e-1, 0.587944836e-1, 0.589720582e-1]);
Download Histogram.mw
I want to find a point has coordinates are integer numbers and write the equation of tangent line to a given circle,  knowing that, the points of tangent has also integer coordinates. For example, the circle has centre M(-1,-5) and radius R=5. I tried
with(geometry):
point(M,-1,-5):
R:=5:
eqS:=Equation(circle(S,(a-HorizontalCoord(M))^2 + (b-VerticalCoord(M))^2 -R^2=0,[a,b],'centername'=T)):
L:=[]:
for a from -50 to 50  do
for b from -50 to 50  do
if  a <>HorizontalCoord(M) and b<>VerticalCoord(M) and eqS then
L:=[op(L), [a,b]] fi;
od: od:
nops(L);
eqS:=Equation(circle(S,(x-HorizontalCoord(M))^2 + (y-VerticalCoord(M))^2 -R^2=0,[x,y],'centername'=T));
k:=[seq](sort(Equation(TangentLine(P, S, point(A, pt[])), [x,y])), pt in L):
seq([L[i],k[i]],i=1..nops(L));
Next,
> with(combinat):
d:=choose(k,2):
for i from 1 to nops(d) do
seq([d[i],solve([op(1,d[i]),op(2,d[i])],[x,y])],i=1..nops(d));
If I want to the point of intersection of two lines which are not perpendicular line, for example
[[-3*x-4*y-48 = 0, 4*x+3*y-6 = 0], [[x = 24, y = -30]]]
How can I select?
Dear friends:
I have a long expression having a/some RootOf(something..) inside it.
Any way to get just that "something..", i.e., the argument of RootOf() from that expression?
Thank you very much.
César Lozada
Sorry if the question of the title wasn't very clear. I am not sure how to express it correctly.
But here is what I do for linux,
and I get
So when I submitted a lot of jobs, I can see the arguments that was passed to it. I can easily kill a process.
How do I do that in windows if anyone knows?
Here is a screenshot from windows task manager:
That does not give informative details, just like the 'top' command in linux.
How to make Decimal number in maple by default?
How to make radian to degrees? Think It is like this "degcos" but I cant see the correct result, because it is not showed in decimals
Why do I have to active all my varibles when I open the document after I have saved it?
Østerbro
Does anyone have JavaViewLib running on Maple 18?  Could you help me out?  I can't get it running and I really need a way to export some 3d plots to a web page where a colleague can view them (rotate and such).
Thanks, Chad.
I'm trying to do some fitting using NonlinearFit, for the coefficients I know in advance, that they have to fulfill a condition (a+b>c+1). I couldn't find a way to make Maple take this condition into consideration while fitting my data. I tried to use Parameterrange to make the difference a+b-c+1 positive, this works for linear conditions like mine but leads to computational difficulties and errors like "no improved point could be found".
Thanks in advance,
Sören
First 1426 1427 1428 1429 1430 1431 1432 Last Page 1428 of 2463
