Hi;
Could anyone help me to convert the following codes into Mpale?
while n>= 1
    for i=1:n
        S(i)=resultant(F(i), F(i+1), Plex(i));
    end
    F(i)=S(i);
    n=n-1;
end
Hello! I have written a code to solve 1D heat equation with Neumann B.C. using explicit method. But there is a problem with plot. I don't understant, what's wrong. Help me, please. I will be very grateful. The code is attached here.
pr3.mw
11.pdf
I am writing a program in C that uses the open maple library. It is not the first time that I use it but now I am facing a strange problem that involves the simplify command: suppose a,x,y are symbols that are not previously used in maple, the following lines
1)  EvalMapleStatement(kv, "simplify((a*x^2-y^2)/(x^2*y^2-1));");
2)  EvalMapleStatement(kv, "simplify((2*x^2-y^2)/(x^2*y^2-1));");
only differ by the fact that the parameter a is replaced by 2 in the second line. But they return the following output:
1) (a*x^2-y^2)/(x^2*y^2-1)
that is correct, nothing to simplify..
2) Error, (in gcd/LinZip) input must be polynomials over the integers
I must be doing something wrong but I am getting nowhere...
Thanks...
P.S. This is the complete listing
#include <stdio.h>
#include <stdlib.h>
#include "maplec.h"
static void M_DECL textCallBack( void *data, int tag, char *output )
    printf("%s\n",output);
int main( int argc, char *argv[] )
    char err[2048];  /* command input and error string buffers */
    MKernelVector kv;  /* Maple kernel handle */
    MCallBackVectorDesc cb = {  textCallBack,
                                0,   /* errorCallBack not used */
                                0,   /* statusCallBack not used */
                                0,   /* readLineCallBack not used */
                                0,   /* redirectCallBack not used */
                                0,   /* streamCallBack not used */
                                0,   /* queryInterrupt not used */
                                0    /* callBackCallBack not used */
    ALGEB r, l;  /* Maple data-structures */
        char *myargv[]={"maple"};
        int myargc=1;
    if( (kv=StartMaple(myargc,myargv,&cb,NULL,NULL,err)) == NULL ) {
        printf("Fatal error, %s\n",err);
        return( 1 );
    StopMaple(kv);
    return( 0 );
compiled with
gcc prova.c -I /Library/Frameworks/Maple.framework/Versions/Current/extern/include/ -L /Library/Frameworks/Maple.framework/Versions/Current/bin.APPLE_UNIVERSAL_OSX/ -l maplec
Hello i want to solve the differentiel equation but i have these problem i don't understund  why !?
restart:with(plots):
mb:=765 : mp:=587 :Ib:=76.3*10^3 :Ip:=7.3*10^3 :l:=0.92 :d:=10:F:=0.042:omega:=0.56 :
eq1:=(mb+mp)*diff(x(t),t$2)+mp*l*cos(alpha(t))*diff(alpha(t),t$2)+mp*[l*[diff(alpha(t),t)]^2*sin(alpha(t))]-F*sin(omega*t)=0;
1352*(diff(diff(x(t), t), t))+540.04*cos(alpha(t))*(diff(diff(alpha(t), t), t))+[540.04*[diff(alpha(t), t)]^2*sin(alpha(t))]-0.42e-1*sin(.56*t) = 0
eq2:=-mp*l*sin(alpha(t))*diff(alpha(t),t$2)+mp*[l*[diff(alpha(t),t)]^2*cos(alpha(t))]-9.81*(mp+mb)-F*sin(omega*t)=0;
-540.04*sin(alpha(t))*(diff(diff(alpha(t), t), t))+[540.04*[diff(alpha(t), t)]^2*cos(alpha(t))]-13263.12-0.42e-1*sin(.56*t) = 0
eq3:=mp*[d+l*cos(alpha(t))]*diff(x(t),t$2)+[Ip+mp*l^2+mp*d*l*cos(alpha(t))]*diff(alpha(t),t$2)-mp*sin(alpha(t))*[-l*d*alpha(t)^2]+mp*[l*9.81*sin(alpha(t))]=0;
587*[10+.92*cos(alpha(t))]*(diff(diff(x(t), t), t))+[7796.8368+5400.40*cos(alpha(t))]*(diff(diff(alpha(t), t), t))-587*sin(alpha(t))*[-9.20*alpha(t)^2]+[5297.7924*sin(alpha(t))] = 0
eq4:=mp*l*cos(alpha(t))*diff(x(t),t$2)+(Ip+mp*l^2)*diff(alpha(t),t$2)-mp*9.81*l*sin(alpha(t))=0;
540.04*cos(alpha(t))*(diff(diff(x(t), t), t))+7796.8368*(diff(diff(alpha(t), t), t))-5297.7924*sin(alpha(t)) = 0
CI:= x(0)=0,alpha(0)=0,D(x)(0)=0,D(alpha)(0)=0;
x(0) = 0, alpha(0) = 0, (D(x))(0) = 0, (D(alpha))(0) = 0
sys := eq1, eq2, eq3, eq4:
solution:=dsolve([sys,CI],numeric);
Error, (in DEtools/convertsys) unable to convert to an explicit first-order system
thanks for your help
Download tangage.mw
Is it possible to numerically calculate  the integral
int((-12*y^2+1)*ln(abs(Zeta(x+I*y)))/(4*y^2+1)^3, [y = 0 .. infinity, x = 1/2 .. infinity])
in Maple?
The code
int((-12*y^2+1)*ln(abs(Zeta(x+I*y)))/(4*y^2+1)^3, [y = 0 .. infinity, x = 1/2 .. infinity],numeric,epsilon=0.1)
has been executed on my comp  without any output since this morning.
Hello everybody, i need to graphic a couple of functions just like this one:
 http://temasmatematicos.uniandes.edu.co/Casquetes_cilindricos/Pags/Anim_1.htm
i have been watching this:
 http://www.maplesoft.com/teachingconcepts/detail.aspx?cid=12 VISUALIZATION --> Animation 2
i've tried with (plots) (plottools) animate, etc. but i can't figure out how to do it.
It would be very helpful if someone explain me how to do this.
Thank you all!
I have setup two groups in MapleCloud, to be used for distribution of materials (a readonly group) and as a drop for students to deposit their exercise sheets (an opaque group). It is my understanding that e.g. students have to request joining a group and I get to approve them.
How does one join a group managed by someone else? If I try from another account I cannot see the groups I just created, so I cannot request joining them. I seem also to not be able to just approve someone (by their email e.g.) without that person having requested to join first.
USPAS2014
Is there a way of ploting y=x^x for when x<0 and y is a noncomplex solution?
i have a corei7 laptop and i want maple to use all of my cpu cores in paraller,what should i do exactly ? in there anyway to use them without using grid computing toolbox ? or how to manage it with grid computing toolbox? i want maple use all of my cpu power during computation, tnx for help
another interesting bug in mapleprimes, when i created new tage , i face this error :
Only users with at least 250 reputation can create new tags, please remove or replace these tags: computing !
i have 305 but i could not do it ! :| .
hello , i have a metric that i know its ricci scalar (R=2m^2-2w^2), but maple obtains zero. i dont know where is my problem.
metric.mw
Best regards
I have some questions about Mobius Project:
  1. What is the license of the worksheets posted on Mobius Project's website?
    I can not find any information about the license of the materials submitted to the Mobius Project.
    Is my worksheets are protected by intellectual property laws and copyrighted by me?
    Or it is freely available for any use for everyone?
  2. What are the terms of use of Mobius Project and its service? I can not find it anywhere.
  3. What is the copyright for http://mobius.maplesoft.com/?
    I do not see any copyright in the footer of the site or elsewhere.
    So, no copyrights mean the materials/resources on this website can be freely copied/used by anyone?
I thought I could plot this by the graph below but I got an error...WHY is that?
with pointplot3d and 14,000 points when I enter symbol=point I get an empty plot.
Only when I set symbolsize=1 (a point) do I get points appearing in the graph.  Bug?
I came across an image/photo and thought, It will be fun to try it in maple.
Except plotting a few triangles and circles, I couldn't make it.
Here is the image.
Have a look please.
Cheers!
Bonjour,
Comment calculer, sous maple, le crochet de Poisson des deux fonctions suivantes :
f:=(x,y,u,v)->x*u+y*v;
g:=(x,y,u,v)->x*y^2+v^3;
Merci d'avance,
Gérard.
First 1456 1457 1458 1459 1460 1461 1462 Last Page 1458 of 2463
