Group Theory,
Given a Group G and a normal Subgroup H.
I can get " map(Representative,RightCosets(H,G)) ".
Is ist possible to get the factor group  G/N ?
Best regards
Kurt Ewald
Hey,
I am trying to write a single procedure to find the root of any function using the Newton-Raphson method, given the initial approximation and the tolerance. If this fails to converge, the program must then use the Bisection method to find the root. Need some help please. The current procedure i have done is only coming out with the first Iteration
Thanks for the help!
hi dears. i cant solve this question by Analytical method such variational itteration method (VIM) or homotopy perturbation method (HPM), homotopy analysis method(HAM)
Hello;
Suppose we have a vector as follows:
Plex:=[u,v,w,x,y,z]
Could anyone help me to reproduce the following vectors via a "for" loop?
[ v, u, w, x, y, z]
 [ w, v, u, x, y, z]
 [ x, w, v, u, y, z]
 [ y, x, w, v, u, z]
I have a simple Matlab script which can do what I intend. So, my question is how can I implement this script in Maple?
Plex=[u,v,w,x,y,z]
for i=2:5
    Plex=[Plex(i) Plex];
    Plex(i+1)=[];
    disp(Plex)
end
Hello all,
I'm an engineering student working on bicycle shifting. After an dynamic study i encounter the equation:
E:=5.37*theta12(t)=C*(diff(theta12(t),[t$2])+diff(theta10(t),[t$2]))+247.2*[diff(theta10(t),[t$2])*(-6.53*cos(theta12(t))+8.51*sin(theta12(t)))+diff(theta10(t),t)*diff(theta12(t),t)*(6.53*sin(theta12(t))+8.51*cos(theta12(t)))]-247.2*diff(theta10(t),t)*(-diff(theta12(t),t)+diff(theta10(t),t))*(-6,53*sin(theta12(t))-8,51*cos(theta12(t)));
where C is a real constant
More exactly, i would need to find a formule for theta12 using the succesive derivatives of theta10.
I heard that i need to search a numerical solution but,up to now, don't succeed to solve it.
I'm open to all idea.
I have low vision, and the default fonts in Maple are too small for me to read.  I can enlarge the normal input and output using the View/Zoom Factor, and this works very well for me.  However, it seems to have no effect on the fonts in spreadsheets.
Can anyone tell my how to make the fonts in Maple spreadsheets larger?  I'm using Maple 18 on Windows 8.1. Thank you.
how to singularize existing function?
any group theory can describe the singularity function?
Hi, My goal is to compute the coefficient beta_i, so i will solve a system and get the coefficient beta_i. But my code return an error. Any help please. Many thinks
coef_approx:=proc(a,N,i,d)
local Fredholm,eq2,eq3,Vct_basis,fct,sys,eq4,M,w,b,M1,V,Vect_beta,h,x,phi,Kernel,lambda;
# Fredholm Integral equation
Fredholm:=phi(x)=f(x)+lambda*int(Kernel(x,y)*phi(y),y=-a..a);
# stepsize
h:=a/N;
# First Approximation of integral
eq2:=int(Kernel(x,y)*phi(y),y=-a..a)=sum(int(Kernel(x,y)*phi(y),y=n*h..(n+d)*h),n=-N..N-d);
#Approximate the integral (Method used)
eq3:=phi->int(Kernel(x,y)*phi(y),y=n*h..(n+d)*h)=add(beta[i]*phi((n+i-1)*h),i=1..d+1):
eq4:=int(Kernel(x,y)*phi(y),y=n*h..(n+d)*h)=add(alpha[i](n,m)*phi((n+i-1)*h),i=1..d+1);
# Fct used to compute the coeffcient beta[i]
Vct_basis:=[seq(x^i,i=0..d+1)]:
fct:=[seq(unapply(Vct_basis[i],x),i=1..d+2)];
# system of equation must be solved
sys:=[seq(eq3(fct[i]),i=1..d+1)]:
x:='x';
x:=m*h:
w := [seq(beta[i],i=1..d+1)];
M,b := GenerateMatrix(sys,w);
M1:=-M: V:=-b:
Vect_beta:=(M1)^(-1).V:
return Vect_beta;
Good day, please how can one solve these BVPs using FINITE DIFFERENCE METHOD in maple. Here is the problem FDM.mw
Hi;
Could anyone help me to convert the following codes into Mpale?
while n>= 1
    for i=1:n
        S(i)=resultant(F(i), F(i+1), Plex(i));
    end
    F(i)=S(i);
    n=n-1;
end
Hello! I have written a code to solve 1D heat equation with Neumann B.C. using explicit method. But there is a problem with plot. I don't understant, what's wrong. Help me, please. I will be very grateful. The code is attached here.
pr3.mw
11.pdf
I am writing a program in C that uses the open maple library. It is not the first time that I use it but now I am facing a strange problem that involves the simplify command: suppose a,x,y are symbols that are not previously used in maple, the following lines
1)  EvalMapleStatement(kv, "simplify((a*x^2-y^2)/(x^2*y^2-1));");
2)  EvalMapleStatement(kv, "simplify((2*x^2-y^2)/(x^2*y^2-1));");
only differ by the fact that the parameter a is replaced by 2 in the second line. But they return the following output:
1) (a*x^2-y^2)/(x^2*y^2-1)
that is correct, nothing to simplify..
2) Error, (in gcd/LinZip) input must be polynomials over the integers
I must be doing something wrong but I am getting nowhere...
Thanks...
P.S. This is the complete listing
#include <stdio.h>
#include <stdlib.h>
#include "maplec.h"
static void M_DECL textCallBack( void *data, int tag, char *output )
    printf("%s\n",output);
int main( int argc, char *argv[] )
    char err[2048];  /* command input and error string buffers */
    MKernelVector kv;  /* Maple kernel handle */
    MCallBackVectorDesc cb = {  textCallBack,
                                0,   /* errorCallBack not used */
                                0,   /* statusCallBack not used */
                                0,   /* readLineCallBack not used */
                                0,   /* redirectCallBack not used */
                                0,   /* streamCallBack not used */
                                0,   /* queryInterrupt not used */
                                0    /* callBackCallBack not used */
    ALGEB r, l;  /* Maple data-structures */
        char *myargv[]={"maple"};
        int myargc=1;
    if( (kv=StartMaple(myargc,myargv,&cb,NULL,NULL,err)) == NULL ) {
        printf("Fatal error, %s\n",err);
        return( 1 );
    StopMaple(kv);
    return( 0 );
compiled with
gcc prova.c -I /Library/Frameworks/Maple.framework/Versions/Current/extern/include/ -L /Library/Frameworks/Maple.framework/Versions/Current/bin.APPLE_UNIVERSAL_OSX/ -l maplec
Hello i want to solve the differentiel equation but i have these problem i don't understund  why !?
restart:with(plots):
mb:=765 : mp:=587 :Ib:=76.3*10^3 :Ip:=7.3*10^3 :l:=0.92 :d:=10:F:=0.042:omega:=0.56 :
eq1:=(mb+mp)*diff(x(t),t$2)+mp*l*cos(alpha(t))*diff(alpha(t),t$2)+mp*[l*[diff(alpha(t),t)]^2*sin(alpha(t))]-F*sin(omega*t)=0;
1352*(diff(diff(x(t), t), t))+540.04*cos(alpha(t))*(diff(diff(alpha(t), t), t))+[540.04*[diff(alpha(t), t)]^2*sin(alpha(t))]-0.42e-1*sin(.56*t) = 0
eq2:=-mp*l*sin(alpha(t))*diff(alpha(t),t$2)+mp*[l*[diff(alpha(t),t)]^2*cos(alpha(t))]-9.81*(mp+mb)-F*sin(omega*t)=0;
-540.04*sin(alpha(t))*(diff(diff(alpha(t), t), t))+[540.04*[diff(alpha(t), t)]^2*cos(alpha(t))]-13263.12-0.42e-1*sin(.56*t) = 0
eq3:=mp*[d+l*cos(alpha(t))]*diff(x(t),t$2)+[Ip+mp*l^2+mp*d*l*cos(alpha(t))]*diff(alpha(t),t$2)-mp*sin(alpha(t))*[-l*d*alpha(t)^2]+mp*[l*9.81*sin(alpha(t))]=0;
587*[10+.92*cos(alpha(t))]*(diff(diff(x(t), t), t))+[7796.8368+5400.40*cos(alpha(t))]*(diff(diff(alpha(t), t), t))-587*sin(alpha(t))*[-9.20*alpha(t)^2]+[5297.7924*sin(alpha(t))] = 0
eq4:=mp*l*cos(alpha(t))*diff(x(t),t$2)+(Ip+mp*l^2)*diff(alpha(t),t$2)-mp*9.81*l*sin(alpha(t))=0;
540.04*cos(alpha(t))*(diff(diff(x(t), t), t))+7796.8368*(diff(diff(alpha(t), t), t))-5297.7924*sin(alpha(t)) = 0
CI:= x(0)=0,alpha(0)=0,D(x)(0)=0,D(alpha)(0)=0;
x(0) = 0, alpha(0) = 0, (D(x))(0) = 0, (D(alpha))(0) = 0
sys := eq1, eq2, eq3, eq4:
solution:=dsolve([sys,CI],numeric);
Error, (in DEtools/convertsys) unable to convert to an explicit first-order system
thanks for your help
Download tangage.mw
Is it possible to numerically calculate  the integral
int((-12*y^2+1)*ln(abs(Zeta(x+I*y)))/(4*y^2+1)^3, [y = 0 .. infinity, x = 1/2 .. infinity])
in Maple?
The code
int((-12*y^2+1)*ln(abs(Zeta(x+I*y)))/(4*y^2+1)^3, [y = 0 .. infinity, x = 1/2 .. infinity],numeric,epsilon=0.1)
has been executed on my comp  without any output since this morning.
Hello everybody, i need to graphic a couple of functions just like this one:
 http://temasmatematicos.uniandes.edu.co/Casquetes_cilindricos/Pags/Anim_1.htm
i have been watching this:
 http://www.maplesoft.com/teachingconcepts/detail.aspx?cid=12 VISUALIZATION --> Animation 2
i've tried with (plots) (plottools) animate, etc. but i can't figure out how to do it.
It would be very helpful if someone explain me how to do this.
Thank you all!
First 1455 1456 1457 1458 1459 1460 1461 Last Page 1457 of 2462
