Is it possible to display on a same graph the error of type I and type II error given n, alpha and beta?
PowerTest
applet.zip
Gracias
Hey,
I've got a nondifferentiable bounded multivariable function and I'd like to find a good approxiation of it's minumum and maximum.
Basicly, I'd like to automaticly be able to return the maximum and minimum of the height of the 3D-plot i have. That would just be perfect.
However, I can't find anything that does anything like this.....
 It is the mathematica code for bifurcation diagram of the model that i am working with now. is there anybody who can translate it into maple code? or does anyone can help me with making a bifurcation diagram for such a ODE system in maple??
Noticed that after simplify memory remains in some internal caches. How to free it after simplification done?
Could i manually reset status bar (i.e. memory and time values)? restart; doesn't help.
I was wondering if anyone knew of a procedure or patch for Newton's method with two variables. I checked maple help and there only seemed to be Newton's method for one variable.
It's for root finding when you have two functions, each with one or two variables; it involves a jacobian matrix.
I'm running Maple 13 btw.
In next procedure i calculated 1st derivative of H in y=0 via series approximation. And i see that some terms of series are missed. If i would raise second parameter to cnt+20 for FuncToSeries in GetLimitsArray it becomes better. But why it's not OK with even cnt+8? series_test.mw
I have the numerical solution of Phi(r,t) which is a numerical solution of a pde..
I want to find the following energy integral at fixed time say t=10 ,
Energy = int(a*r^2*Phi(r,10)^2 + 2*b*r*Phi(r,10)^3,r=0..infinity)... I could not find help in maple.. I guess I had to do the following
1. select the numerical solution dependent only on r at t=10 slice..
2.Use numerical methods to evaluate the integral..
Just try simplify :
to_zero.mw
with(Statistics):
Phiinverse := (x) -> Quantile(Normal(0, 1), x) :
evalf(Phiinverse(1-1/2^24));
and the result is 5.691523310-2.147372008*I
Now, I can get a real-valued solution to this by using the equivalent
functionality from stats instead of Statistics.
with(stats):
PhiinvClassic:= (x) -> statevalf[icdf, normald[0, 1]](x):
evalf(PhiinvClassic(1-1/2^24));
I have coded maple script and got that error. How can I fix it?
Here is my code error.mw. Please help.
raw_panel_cuttin.doc
 Given a large rectangular wooden panel, you want to cut specific quantities of smaller rectangles from it.
Hi.
I have two complex functions with 3 variables: z1,z2,t . I need the first derivative of one of these functions with respect to one variable onle. Here is what I did:
f1:=z1(t)+2*z2(t):
f2:=z1(t)-3*z2(t):
diff(f1,z1(t)) this gives me an error. I need to write the variable as z1(t) not z1 because I'm doing some calculations for different time.
Thanks for the help.
     I just purchased Maple and I am just learning calculus pretty much for fun.  I am reading "Calculus Made Easy" by Sylvanus Thompson.  On page 56 there is a set of equations for which I would like to know the steps.  I was wondering how to do this in Maple.  I played around with the Student and Tutor commands, but can't seem to get it to work.
     The equation is y+dy=(x+dx)^-2
hi,
how to change coordinate system?
for example :
diff(f(x, y), x)   =   (diff(f(r, theta), r))*cos(theta)-(diff(f(r, theta), theta))*sin(theta)/r
thx;
aryan.
First 1821 1822 1823 1824 1825 1826 1827 Last Page 1823 of 2458
