Consider the following DEQ:
x*y'+2y=1
Maple can solve this without problems with dsolve. But I want to use the Mellin Transformation for this, similar to the more common laplace transformation. The last step, the transformation back to the x-domain, does not work. Any idea why?
restart:with(inttrans);
mellin(x*diff(y(x),x)+2*y(x)=1,x,s);
solve(%,mellin(y(x),x,s));
invmellin(%,s,x);
Dear Maple Users
I have encountered some strange behavior when trying to copy a vector:
In the first section I define a vector a and try to copy that vector and assign it to an variable b. Then changing the first coordinate in the copied vector b actually change the original vector as...
main.mw
Please, start attach from beginning till that place where
Is this the best way to extract the argmin with "minimize"? Thanks for your suggestions.
minimum := minimize( x^2, x = -1 .. 1, 'location' = true );
y_min := minimum[1];
x_argmin := rhs(op(op(minimum[2])[][1]));
                       0, {[{x = 0}, 0]}
Code
L:={NULL}:
for q from 11 to 100
check:=0:
for p from 1 to 200
n:=length(p):
for i from 1 to n
a[i]:=p[i]:
s:=sum(a[i],i=2..n)
if p-a[1]-10*s*modq=0 then
check:=check+1:
if check=200 then
L:=L{op(L),q}:
print(L);
and the pseudocode:
1. L is the empty set
2. for q from 11 to 100
3. check=0
4. for p from 1 to 200
5. find n, the number of digits of p
6. for i from 1 to n
7. find a[i], the ith digit of p
Dear,
How could we know which command to use to do a specific task such as:  "convert boolean value to {1,0}" . I know we could use evalhf() but if we search with keyword "convert true false to 0 1 " in the Maple help then we may not find the right command
Using the Online Help is a solution but I want to know an offline solution since I am not always with the Internet. Did anyone wrote a summary sheet with the content such as : (i.e a list of all commands with keywords for searching)
Ok, this mut have been asked a million times, but for the heck I cannot find how to do it:
I have a data file with many columns of data, delimiited, and many rows. I can read this in with ImportMatrix no sweat. The generated matrix has (row,column) format, i.e. matrix[1] is row 1 etc.
Now I want to plot two arbitrary columns against each other, say matrix[][19] vs matrix[][13] (the 19th column vs the 13. column). The data are monotonic in each vector so I can...
Hi.
I have defined a function "norma" that calculates the normal vector in a point "r" in a given surface:
norma:=proc(l,r) local nu;
if r[1]>= l/2 then nu:=[r[1]-l/2,r[2]];
elif r[1]<=-l/2 then nu:=[r[1]+l/2,r[2]];
Now I need to calculate an integral using this function varyign the parameter "r" but I get this error message:
> int(norma(l,[cos(x), sin(x)]), x = -1.5768 .. -.5638);
Error, (in norma) cannot...
I'm using Maple 15 with Suse Linux 11.4
Export to latex produces a tex file which, when conveted by pdflatex contains all sorts of errors. The page margins are very large, parts are missing, the title appears alone on a page, lists of equations don't have line breaks so, for a long list you find just the central part going from edge to edge of the page.
I gave up using "Export to latex" on earlier versions. I had thought that Maple 15 might be better, but it seems worse.
Q1) Could you pls tell me how can I show in maple the curve (x^2+y^2)^2=x^2-y^2 in the form of
x(t)=cos(t)/1+sin^2*t and y(t)=sint*cost/1+sin^2*t.
Q2) how can I express sin^2(4x) in terms of powers of cosx.
a) cos^3(3x)cos(5x) as a linear combination of cosines of multiples of x.
how can i solve matrix ?
for example :
Matrix(4, 4, {(1, 1) = 18, (1, 2) = -45, (1, 3) = 36, (1, 4) = -9, (2, 1) = 9, (2, 2) = -18, (2, 3) = 9, (2, 4) = 0, (3, 1) = 0, (3, 2) = 9, (3, 3) = -18, (3, 4) = 9, (4, 1) = -9, (4, 2) = 36, (4, 3) = -45, (4, 4) = 18})
I have a module to overload the * operator for the function f such that:
a*f(b,c,d) = f(a*b,a*c,a*d)
FPackage :=  module()option package;    export `*`;    `*` :=    overload    (      [        proc(a::algebraic, b::specfunc(anything, f))          option overload;          map2(:-`*`, a, b...
Could uou pls tell me how to do a parametric representation of the curve in maple where curve is define as
(x^2+y^2)^2=x^2-y^2 . Secondly how to plot this curve.
m(x[i]) = product(x[i]-x[j], j = 1 .. N)              i <> j
ex:
for N=4
hey,i'm trying to divide the values i get using this
y := 23.45*sin((360*(x+284))/365):
seq(evalf(y), x = 1..365);
by some imported data....how do i do this?any good advice will be appreciated.Thank you in advance
Judith
First 1832 1833 1834 1835 1836 1837 1838 Last Page 1834 of 2457
