The Units package includes various units that are called ton/metric ton/tonne/short tons but not long tons (LT). A long ton is equal to 2240 pounds of weight and is part of the imperial system, so it is also know as the "imperial ton" or the "weight ton".
This unit (the long ton) is used extensively in naval architecture and ocean engineering. I would hope that you consider adding it into the next update of the Units package.
Or perhaps, it would...
I am using Windows 64 bit Maple 14.
I am trying to read a package (stochastic9) stored in a text file, stochastic9.txt in the directory:
C:\Program Files\Maple 14
I can't read this or ANY file from ANY directory. Nor can I save ANY object to ANY directory. Here are some sample entries and error messages:
> currentdir();
"C:\Program Files\Maple 14"...
I really need a result to the integration below but Maple 13 just won't return one. Could you please help me or advise me as to what might be wrong or what I might try ? I'm integrating on the real line in x but even when I alter the limits of integration maple just returns the integrand.
s1:= int((1/8)*sqrt(2)*exp((1/2)*k^2*cos(x)^2/sigma^2)*exp(-(1/2)*k^2/sigma^2...
I have a system equations like { a + b = 1, c = a + b +1, d = a + c}
and the sovle function which give me then answer like { a = -2+d, b = -d+3, c = 2, d = d}
I just care about the information in form (name = numeric) like { c = 2 }
and i want the "core" equations which give me that information like { a +b = 1, c = a +b +1 } => {c = 2}
how i can i get the "core" equations of that.
The integrals are
v1:=int((1/(2*Pi) + Q* cos(k*phi))^2/ (1+ beta^2*((1/(2*Pi)) + Q* cos(k*phi) )^2),phi=-Pi..Pi);
v2:=int((1/(2*Pi) + Q* cos(k*phi))^2*cos(k*phi)/ (1+ beta^2*((1/(2*Pi)) + Q* cos(k*phi) )^2),phi=-Pi..Pi);
v3:=int((1/(2*Pi) + Q* cos(k*phi))^3*cos(k*phi)/ ((1+ beta^2*((1/(2*Pi)) + Q* cos(k*phi) )^2))^2,phi=-Pi..Pi);
v4 := int(exp((-1/2)*((psi-theta-k*sin(theta-phi))/sigma)^2),phi = - Pi ..Pi);
setupdiagramMQ.
I am having a strange experience with the arrow command.   In the attached worksheet, one can see that plot structures h, i & j and l, m & n are both doing the essentially the same thing:   A vertical line is to be drawn and arrows pointing up and down from the two endpoints are to be added.  The arrows are all of the...
As title
I need help in finding the maximum point of each curve (please see maple file link attached), or if possible display each maximum point (under different "ga") on the 3Dplot
Your help is appreciated
Correction.mw
Hello, I'm new to Maple.
when I write:
solve({Wa=Ve,-4*Vd+4*Ve=-4*Wa+4*Wb,12*Vc-24*Vd+12*Ve=12*Wa-24*Wb+12*Wc},{Wc});
Maple gives me no output.
Can somebody help me, what I'm doing wrong? (Maple 9.5)
Thank you for your help!
Hi colleagues. I executed a problem on Maple 12 and the results were on a matrix form as:
A=[11X11 Matrix]
How can i display the full content of the matrix and how can i extract one row or one column from the matrix???
 Hello, everyone,
I have two problems in my worksheet.
First, when I specified the value of "s1" for a smaller number, for example 1e-5 or 1e-6, the imaginary part of "an" tends to infinity or -infinity, however, it should be finite.
Second, the value of "an" is instable when specific value of "s1" is choosen. For example, in the attached worksheet, s1=1.9e-4, the value of "an" will be changed when you click "!!!" button several times(that means execute the entire worksheet).
Maplesoft uses deprecated power pc compatibility not supportred by mac osx lion. lmutil crashes and forces me to quit the application.Unable to get host ID
My contour of integration is a semi circle whose diameter rests on the imaginary axis from -ri to ri.  The arc of radius r is on the positive real axis going from -ri to ri.  On the curve I want to have directional arrows indicating that I am traversing this contour in the positive direction.  How do I create this figure in MAPLE?
First 1868 1869 1870 1871 1872 1873 1874 Last Page 1870 of 2457
