I want to show algebraically that the expected correlation is
decreasing in the tails of the distribution ie that the correlation coefficient
breaksdown when we have large moves. How can this be done?
Here is a standard example of how dcoeffs works:
> with(PDEtools);
> X := a*(diff(y(x), x, x))^2+b*(diff(y(x), x, x))+c*(diff(y(x), x));
                             2                     ...
for example:
i want to know how many numbers generated in this loops
[seq([seq(i, j = i .. 5)], i = 1 .. 5)]
[1, 1, 1, 1, 1], [2, 2, 2, 2], [3, 3, 3], [4, 4], [5];
as if there is no way that can make a "++" increment operator in maple 12
please give me advise how can i find some text fragment in Math 2D mode?
    I'm trying to get a component to perform a Fractional Derivative in MapleSim to use in a multibody simulation (as a spring-dash pot component). However, I'm stumped by trying to get the fracdiff function past the custom component code.
  • When set to series, the fractional derivative is only accurate near the estimated about point
  • When set to LaPlace, it's impossible to perform the transform...
Good morning. I know what is the function that I report the rank of the controllability matrix for time-invariant systems.?
help me please
I have a very simply equations
eqs := {2.32 = a+b, pa = .4310344828*a, pb = .4310344828*b, pa+pb = 1}
pa is the persnet of a in the whole a+b
maple auto simplify pa = a / 2.32 to that.
I call the solve(eqs) and get the NULL return. that mean there is no solution for this eqs
but that's not true
even I do this
solve(eqs union {a=1})
it also return NULL
My command:
odeplot(dsol1,[x(t), y(t), z(t)])
where dsol1 is the numeric RK45 solution of my system of differential equations, and x(t), y(t), z(t) are the solutions. This command works fine, but I am not able to animate it.
hi guys,
i need to solve s system pf three PDES numerically and ended up with "in pdsolve/numeric/process_PDEs) all dependent variables in PDE must have dependencies esplicitly delclared". Can anyone gives me a hint to fix it (worksheet is attached).
I have to make following substitutions in a ODE:
alpha = x - 2
y(alpha) =  y(x) - 1
[Maple code starts]
The ode is
ODE := diff(y(x), x) = (y(x)+1)/(x+2)-exp((y(x)+1)/(x+2));
I have used the following commands:
Rhsa := eval(rhs(ODE), {x = alpha-2, y(x) = y(alpha)-1});
lhsa:=subs({x = alpha, y(x) = y(alpha)}, lhs(ODE));
Sub_ODE:=lhsa = Rhsa;
Hi:
I am trying to save plots to files in the batch mode (or when running maple from the terminal). The simple code below works fine from the gui interface, but when executed from the terminal, the fonts are not adjusted. I have tried exporting to other formats as well (eps, jpeg). Any ideas how to get around it?? It is problematic for me because I need to produce density plots with large data sets. Ideally I would like to export in the eps format, but these large...
Hi there,
1) I have imported my excel file using Tools>assistant>import data.
2) My excel file contains close to 35 columns.
3) Now, within Maple, I want to plot say Column B (Time) against Column C (Temperature) of the imported excel file.
4) Also, in addition, once I can plot two columns against each other, How can I include other columns in the same plot.
Any nudge in the positive direction will be appreciated.
I use gnuplot to generate graphs in C++.Now we all know that in C++,we  just pass a text file to gnuplot,tell it to plot the text file.
Now,in Maple I want to do the similar thing,like this:
Suppose I have some single variable function/procedure,say of x
then I can write a loop say,
for 0 to 100 by 0.01 do
x,f(x)
od;
With this I can see the output.Now if I want the plot of f(x) vs x,then how can I say it to Maple?
I have a system of three differential equations with three unknowns, say f(t), g(t) and h(t).
My problem is that the system involves also f(invh(g(t))), g(invh(g(t))) and f(invg(h(t))), where invh is the inverse of h and invg is the inverse of g.
How can I instruct Maple to deal with these inverse functions?
I came across this problem while helping another user find the maxima of an expression for
various values of a parameter here:
http://www.mapleprimes.com/questions/124104-Maximum-Points--Of-Function-With-More
For various values of ga, it was required to find the maxima in a range of 0<delta<2.
Plots of the expression indicate that one such maxima exists for each value of the parameter.
My approach was to find the zeros of the first...
First 1867 1868 1869 1870 1871 1872 1873 Last Page 1869 of 2457
