my problem is probably that maple assigns everywhere possible the whole expression (cause its analytical)
How do i get it to calculate a float and save it as such?
e.g.
interfaceenergy:=5.
sig:=200.*10^6
Temp:=fsolve(xi_M[Temp,sig,interfaceenergy)=0.5,T, T=100..400])
whattype(Temp) ---> function
...this is part of a nested loop (2) so after some time of calculating maple says
"Error unable to store.... and then...
I have two questions regarding truncated normal distribution.
1. Is there a convenient way in Maple to compute and plot the density function of a truncated normal distribution? I know that in Maple, after creating a random variable, I can use the function Statistics:-PDF to compute the density function, and use DensityPlot to draw the function. But for truncated distribution, I have to compute it manually by doing integration to compute the normalized...
I have a problem.
I solved a problem, but i like to get one solution for one variable.
i send my project.
help me please.21-07-2011_-ecuacion.mw
I am working with two multivariate functions A and B, with coefficients over a finite field. The x-degree of A is greater than or equal to B, which is greater than or equal to 1, and thus I want to find q and r such that:
A = q*B + r, where q, r are elements of K(y,z)[x], where K is my finite field. Obviously, I would like the x-degree of r to be less than that of B, and r not equal to 0.
My problem is this: the Rem and Quo commands, which will deal with my...
I have explored some multi-animation with maple, but I can not change the parameters one by one.
http://www.mapleprimes.com/questions/99833-Procedure-For-ANIMATE-Multiparametrique
Command Explore is analog to Mathematica's Manipulate but the problem in a new worksheet.
How to get Explore like Manipulate in the same worksheet ?
alex_01
hi, i cant solve the following ODE and Boundary conditions in maple. please help me. i use dsolve and ode analyser but i cant receive and conclusion. thanks.
#beta:=.01;
#lambda:=.3;
s:=f(x)^2*diff(f(x),x,x)+x*f(x)*(1-2*beta)+beta*diff(f(x),x)*(x^2-1);
bcs:=f(1)=0,D(f)(-lambda)*f(-lambda)=beta*(lambda^2-1);
Dear guys
In my program I have a loop and after some calculation I want to write the results. I use:
" writedata("D:\\arvin\\bao-cmb-h.txt", convert(T, array), float);"
but maple give me an error:
" Error, (in convert/list) object too large "
how can I write my data?
I have a strange error when i try to plot an ODE with "numeric,method=gear,parameters=[...]" as options activated. After this implementation I give the parameter a value: ODE(parameters=[123]); -> works. But when I type "odeplot(ODE, [x(t),y(t)],10..20,numpoints=100);" for example, i get the errormessage:
" Error, (in dsolve/numeric/gear) Array index out of range"
But when i remove the option "method=gear", so that the ODE is solved with default runge-kutta...
I'm developing an application that I'd like to use elements of an array as parameters in MapleSim components - is there a way to use Maple arrays/vectors in MapleSim?
Also is there a way to open a file and read its contents (data) as the starting point (parameter set) for a MapleSim simulation?
Why does the following derivative vanish?
f:=k->(y->y^k);
h:=z->f(2)(z);
D(h);
Note: I am aware that setting h:=f(2) would give the correct result. However, I would like to use the arrow -> notation in a more complicated problem. Also, it seems odd that the plot(h) displays the graph of z->z^2, while D(h) gives 0.
The quantity ω(x):= limsup_T->+infinity Pi/T*ν(x,T) is said to be the frequency of a function x:[0,infinity)->R,
where ν(x,T) equals the number of zeros (taking into account  the multiplicities) of the function x on the interval [0,T].
a) To estimate from above the frequency of any non-zero solution of the ODE diff(x(t),t$2011)+x(t)=0.
b) To find the frequency of the function x(t):=sin(t)+sin(Pi*t).
Edit.
I have a variable number of pointplots c[1] .. c[i] and i want to plot all in a single plot.
I tried display(c[k],k=1..i); or display(c[k]$k=1..i); but i got an error. Typing evey list like: display(c1,c2,c3,....); is not possible because i is variable. What can i do?
I used the folowing command to solve a system of equations:
fsolve(equations,variables);
then the results were on the following form:
{u1=.1,u4=1,u5=3,u2=4,u3=0}
but I want to rearrange as:
{u1=.1,u2=4,u3=0,u4=1,u5=3}
please help me and i will very grateful for you...
When i try to get all roots for an ODE, i try to use fsolve:
  fsolve((rhs(ODE_4))(t)=0,t=10..20);
where ODE_4 is an ODE (dsolve, numeric, output=listprocedure), where i want to find the root of the 4th variable in the ODE (4 should be an index).
Then i only get the fist root after t=10 and the computation stops. What can i do to get ALL roots in the given interval?
"Find the local maxima and minima in some noisy signal"
I have a data array which I want to determine the peaks in the measurements.
For this task I tried to translate the code found  from MatLab to Maple.
As you can see I get the values(peaks) on the x axis displaced.
By using GlobalSearch get the same peaks with the coordinates correctly.
As much as I seek and analyze command lines can not find the error or errors.
First 1869 1870 1871 1872 1873 1874 1875 Last Page 1871 of 2457
