u = -1/2*ln(-2*t*x+x^2+1)/x;
what is command to find x in terms of u of above formula? i.e. x = u^2+u+1
 Hi.
How can we use  the variation of constants formula to solve the IVP
Hi. I have a system of PDEs. How do I plot its solutions?
I want to calculae the value of "Z" shape strip resistor like below. One end is AB and the other is FG,the thickness is t.
I want to use the Schwarz-Christoffel Mapping for this problem,"Z" shape to rectangle.
I have already find the map from rectangle to half plane,exp function.
But I can't find the analytic form relation from half plane to the "Z" shape.
Can you help me,please?
Thank you in advance.
How can I tell Maple to compute the product of tow symbolic matrices
A:=Matrix(2, [[a,b],[c,d]]);
B:=Matrix(2, [[e,f],[g,h]]);
C:=multiply(A,B);
to have C:=([ae+bg, af+bh],[...])
I have a sample waveform of an air conditioner and want to see if any low frequencies (10 Hz which is harmful to human health) exist in the wave.  How can I do that?
Granted the frequencies picked up in the recorded file depend on the quality of the recording and the recorder and lower frequencies may not have been picked up.
I've looked at
Hi im somehow not able to export my worksheet into a word document, as the rtf format doesnt seem to be available on the maple 15 mac version. converting into html is possible but not satisfying. i really need help here.
thanks a lot !!!!
greetings
What is the distance between the trigonometrical polynomials of the form a0/2+a1*cos(Pi*x)+b1*sin(Pi*x) and the polynomials of  degree at most 1, ie c0+c1*x, in the Chebyshev metrics on the interval [-1,1] and in the L^2 metrics on the same interval?
i want '*' to keep doing exactly what it already does. for example, x*x*x*x is still x^4.
but furthermore, i want to be able to somehow redefine(define in addition) '*' as follows:
protect('a');protect('b');
redefine('*', a*b=1,b*a=-1);
basically, for protected letters a and b, maple...
How can I plot f(x,y)=(cos(x^2+y^2))^1/2 whithout knowing the domain?
And then having Maple to find the domain and plot it?
I have a package, a zip file, written by someone, it consists three files, as seen below
what this package, let's call it helloworld, offers is the following:
all i need to do is extract those three files shown (hdb, ind, lib) into C:\Program Files (x86)\Maple 12\lib
then once i type with(helloworld):
1, it modifies the...
I wish to view the complete internal workings of the code (specifically the SHA code created by Joe Riel)
I tried  ...
interface(verboseproc=2)
print(SHA)  #appears to show a limited amount of code
showstat(SHA)  #shows some code but it's not complete
march('list',"c:\\testlib\\SHA.mla")   # not exactly what I thought it would list
How do I view the code?
hi
i want to solve following equation
f(s)=a+b*s+c*s^2
with these condition
f(0)=0
f'(0)=0
f'(5)=1
please help me
thancks
hi,
please Help me in the following code :
> restart;
i:=0;
u[i](s):=A+B*s-C*exp(-s);
lambda(s,x):= -(1/2)*(s-x)^2;
tre(s,x):=lambda(s,x)*(diff(u[i...
I have a set of nonlinear and coupled PDEs for a cable actuated system. I want to transfer this set to a set of ODEs and write it down in Matrix form. I used Galerkin's method and derived the ODEs in discritized form. I have a problem in converting this set of equation into a matrix form like "Mq"+Cq'+Kq=F". The derived equations are very complicated and contains some nonlinear terms. One of the three equations looks like this:
First 1865 1866 1867 1868 1869 1870 1871 Last Page 1867 of 2457
