Dear mapleprimes ODE enthusiasts,
I am analyzing a stiff 3D system characterizes by fast-slow dynamics. I believe I can show analytically that, for some parameter values, in a neighborhood of some critical points (where the system is stationary), the dynamic system has a local center manifold that is center-stable. I have simulated the system for different parameter values.I am interested in one particular trajectory. With a random set of initial values, the system...
Hi:
I have a worksheet with a fairly complicated expression. Suppose it is of the form A:=B.
In red I have
>A:=B;
and just below it, in blue I have
A:=B
Now I highlight the blue "A:=B", press CTRL-C, move to another worksheet, postion the cursor next to a blank ">" and press CTRL-V. The blue statement appears in the new worksheet, BUT...
It only appears in red (i.e. executable) if the blue statement "A:=B"...
What would be the best way to compute the determinant of a very large (millions x millions) 0-1 matrix?
I have a multi-equation vehicle model that I can set up as
> sol3 := dsolve([eqB, eqC, eqD, eqE, eqF, speed(0) = 0, V(0) = 0.7047824398e-1], [Tm(t),
Tw(t), V(t), omega(t), speed(t)]);
or, following a MaplePrimes post
> sys := [eqB, eqC, eqD, eqE, eqF];
> ics := [speed(0) = 0, V(0) = 0.7047824398e-1, omega(0) = 0, Tw(0) = 0, Tm(0) = 0];
> vars := ...
Okay what am I doing wrong here?  It's an examination of the simple 1-d heat diffusion equation in a rod with homogenous boundary conditions.  I'm looking for the temperature distribution over a thin rod with unit length 1.  Both ends are held at 0.  And the initial temperature distribution across the rod I have set equal to x, with the diffusivity k=1/10.
So first set up the 1-d homogeneous heat equation
he:=diff(u(x,t),t)=k*diff(u(x,t),t,t):
I am looking for the equivalent command in Maple to the Mathematica command # which takes the first argument of a pure function. Is there any such equivalent, and if so what is it?
Hello friends,
I have tried to linearize three nonlinear equations which are coupled in the form of:
a1*xdot(1)+a2*xdot(2)+a3*xdot(3)=f1(x1,x2,x3)+u(1)
b1*xdot(1)+b2*xdot(2)+b3*xdot(3)=f2(x1,x2,x3)+u(2)
c1*xdot(1)+c2*xdot(2)+c3*xdot(3)=f3(x1,x2,x3)
the ai, bi, ci parameters are constant parameters and x1, x2, x3 are variables (states). also, u(1) and u(2) are inputs to the system. xdot(i) is the derivative form of xi.
I have a function written that takes a column vector and returns a column vector. I would like to apply this function to a matrix and have it run on the columns of the matrix. Is there a way to do this like in Mathematica? I have tried the Map and Map2 commands but they only apply a function entry by entry. I need a way to evaluate a vector function on the first through last columns of the matrix.
I want to fit Data with a model that calculates the values by solving an ODE numerically.
solL:=dsolve({Lpde,ICS}, numeric, method=rkf45, parameters=[lambda[0],T[m]]);
Next, I created a procedure.
ans:=proc(p1,p2) solL(parameters=[p1,p2]); rhs(solL(3600)[2]); end proc;
This is giving a length L(t) depending on parameters lambda[0] and T[m]. I would like to fit this model with my data. These data are given for a fixed time...
I would like to know how to convert solution from rsolve
rsolve({y(n+2)-2*y(n+1)+4*y(n), y(0)=C1, y(1)=C2}, y(n));
(1/6*I)*(C1*sqrt(3)-(3*I)*C1-C2*sqrt(3))*(1+I*sqrt(3))^n+(1/6*I)*(-C1*sqrt(3)-(3*I)*C1+C2*sqrt(3))*(1-I*sqrt(3))^n
to this form with sin and cos
ex1 := {
diff(x1(s),s$2) - 2/x2(s)*diff(x1(s),s)*diff(x2(s),s) = 0,
diff(x2(s),s$2) + 1/x2(s)*diff(x1(s),s)^2-1/x2(s)*diff(x2(s),s) = 0
sol := dsolve(ex1);
ic := {x1(0)=0.1, x2(0)=0.1};
dsol := dsolve(ex1 union ic, numeric, range=0..1);
odeplot(dsol);
Error, (in dsolve/numeric/SC/IVPsetup) initial conditions must be numeric
initial condition has already set 0.1 but still ask for must be numeric why?
I have a problem with radiobutton
i have 3 types of fricction, and each radio button has one type of it.
I have a problem when i select one type of friction don´t plot it
that is the code  RBFEstatica is a radiobutton of type static fricction
if GetProperty(RBFEstatica,value) = true then
DocumentTools[SetProperty](Label0,caption,estatica);
p1 := 0;
p2 := 0.1;
deltav1 := piecewise((abs(x2q1(t)) > 0 and abs(x2q1(t)) < 0), p1, p2);
Hello all,
Im trying to apply the working of the algorithm shown below to a more complex one(attached). The simple algorithm produces separate spreadsheets for different values of j. In the attached algorithm Im trying to produce different spreadsheets for different values of 'angle1'. I have applied the same structure but with no success.
Can someone please have a look at my code and point me to my mistake?
Any help is really appreciated
Hello everybody,
   I have to solve the following differential equation numerically
dsys1 := {0.27e-2*(diff(x(t), [`$`(t, 2)])) = -3*10^(-4)*sqrt((diff(x(t), t))^2+(diff(y(t), t))^2+(diff(z(t), t))^2)*(diff(x(t), t))-(2.25*10^(-4)*8)*(diff(y(t), t)), 0.27e-2*(diff(y(t), [`$`(t, 2)])) = -3*10^(-4)*sqrt((diff(x(t), t))^2+(diff(y(t), t))^2+(diff(z(t), t))^2)*(diff(y(t), t))+(2.25*10^(-4)*8)*(diff(x(t), t)), 0.27e-2*(diff(z(t), [`$`(t, 2)])) = -3*10^(-4...
I am not able to use the Maple 15, because after it starts up, I receive an error ""the kernel loader cannot find Maple engine..."
What does it means and how to solve it?
First 1881 1882 1883 1884 1885 1886 1887 Last Page 1883 of 2457
