Consider the simple loop below:
> for q  from 1 by 1 to 12 do;
> if inter[q] <= B then xz[q] := inter[q] end if;
> end do;
inter[1] to inter[12] is defined previously
B is also calculated beforehand.
My problem is that Maple insists on looking for inter[13] and xz[13]. My range is between 1 and 12 so Maple shouldnt be doing this.
Hi all. This is porbably a very elementary question. Maple outputs something of the form  " X +  0. I" after a computation, where X is a number. I'm confused as to what 0. I is. My first thought is that it's 0.1 * I, but then squaring X +  0. I  gives back X^2 + 0. I instead of the expected X^2 - 0. 01 + 0.2 X I. Could someone explain to me what Maple means by that? Thanks!
X +  0. I
Dear Maple Users
I was looking forward to having the Units package improved in Maple 15. Units are indeed converted to SI Units when direct calculations are made. It is a disappointment though that this conversion doesn't occur when solving equations as the example below show:
Unfortunately Maplesoft mix up their announcements for news in version 15 of Maple with...
I want to save a plot into Array or other and re-plot it by pointplot.
restart:with(plots):
f:=x->cos(x)+cos(x)^2;
plot(f(x),x=0..2*Pi);
With Array, I want to determine dx (step) of the plot (Array) and the dimension of Array (number of line and column).
If Pk:=plot(f(x),x=0..2*Pi); is Array, I can reproduce the plot as:
ef := {seq([Pk[i,1], Pk[i,2]], i = 1 .. N)}: # Pk[i,1] is x and Pk[i,2] is f(x), N number of line of Array
I would like to do the following.
Ive got variables a(z) where z(tau). Now I would like to do something like:
>> t = z(tau);
>> a := a(z);
>> diff(a,tau);
  == (da/dz)*(dz/dtau)
How come that I don't have a commenter badge?
I'm pretty sure that I left more than 10 comments on this site.
Could comment 10 times to this question if necessary.
Alec,
Thank you very much for your explanation!
Do you known about any book or other texts that explain more about it ?
I would like to create some examples of maximum likelihood estimation using this symbolic approach.
Best regards,
Pedro
I am having trouble in defining multivariable functions. For instance, when I define the follow code:
assume(n>0)
 f:=(x_1,x_2,...,x_n) -> sum(x[i],i=1..n)
I get the error: Error, invalid operator parameter name.
How can I define this type of function when the number of variables is conditional on "n" ?
I have the function:
restart: with(plots): with(OrthogonalExpansions): with(DiscreteTransforms):
f:=t->piecewise(t<0,0,t<1,t,t<2,2-t,0);
The Fourier coefficients a[0], a[i] and b[i] can be calculated by:
T:=2: Trig:=FourierSeries(f(t),t=0..T,n,'Coefficients');
a[0]:= op(1, Coefficients);a[i]:= op(1, op(2, Coefficients))[1];b[i]:= op(1, op(2, Coefficients))[2];
I want to calculate those coefficients a[0...
Defined a demand function:
x:=(p,w)->w/(p[1]+p[2]+p[3])*Vector([p[2]/p[1],p[3]/p[2],p[1],p[3]])
The Slutsky Matrix is calculated as Dpx(p,w) + Dwx(p,w) x(p,w)^T with Dpx(p,w) = Jacobian for p1, p2, p3 and Dwx(p,w) is a column vector of the derivate of x1, x2, x3 in respect to w.
Step by step:
Dxp := Jacobian(x(p,w),[p[1],p[2],p[3]])
yields the correct Jacobian.
For Dwx I've tried several different methods, i.e.
Dwx := Jacobian(x(p,w),[w...
I am having a problem with variable assignment.
output 15 should be:
test :=[1]
[2]
[1 1]
At some point, the array test is being overwritten even though in my proceedure I use only local variables.
How does one go about defining a road surface that can be used with the tire library for doing road holding on hills and side slopes?
> I found this information and code quite useful. Now my set t1 changes slightly to include I and -I. I also set up conditionl statements to extract the right elements according to the criteria on the value of beta*Q as adviced previously. I then test this out using the values for (beta,Q) as (1,1), (-1,1),(0,1).
When beta*Q is positive (one in this case) I is not selected...
I'm looking for a quick way, preferrably without using any loops to 'map' a function using several vectors.
In the single vector case, this is quite easy, but with multiple vectors, I'm not sure if map is the correct command to use.
For example:
u:=<1,1,1>;
v:=<2,3,4>;
f:=(x,y)->ln(x-y);
What I'd like to do is create a new vector from the map of the function onto both vectors,...
I'm a beginner who is learning Finite Field under the help of Maple. I'm wondering is there a command to compute the minimal polynomials for the members of a finite field?
For instance, for GF(16) realized by the polynomial a^4 = a + 1,we know that for a's minimal polynomial is x^4 + x + 1, a^3's minimal polynomial is x^4 + x^3 + x^2 + x + 1. In Maple, how do I reproduce such result?
Thank you very much for your help,
Best,
Kelvin
First 1882 1883 1884 1885 1886 1887 1888 Last Page 1884 of 2457
