with(OrthogonalExpansions) not working in Maple 15 (work in Maple 14). What is the equivalent package for FourierSeries calculations?
Kamel Boughrara
 I have the following equation that I want to plot for theta and t with other parameter values in the equation fixed as below. But when I try to animate the solution I get an 'unable to plot' error message. What can I do to plot the equation, U(theta, t) below.
 U(theta, t) := 1/2/Pi+Q*sin(k*theta)+P*sin(m*theta)+1/4*(-I*Q*exp(1/2*k*(-sigma^2*k+2*I*theta...
does anybody have any idea how to simplify
> t:=5^(-n)*2^n;
to
> s:=(2/5)^n;
Pavel
I have Maple 15. I am trying to calculate the limit of this function
((x^3-2x^2+sin(x))^(1/3))/(6x+2)
for x tend to +infinity. As you can get it with a rapid manual calculus, this limit is 1/6. But Maple returns undefined for this very simple limit. Why? How can i get Maple to calculate limits correctly? Derive 6 return the correct answer
How can i delete a row in a (2D) Matrix?
Thanks,   (Mohsen)
evolf := proc(f);
h1 := z + f(x);
h2 := z - f(x);
h3 := z*f(x);
h4 := f(x)/z;
h5 := z+diff(f(x),x);
h6 := z-diff(f(x),x);
h7 := z*diff(f(x),x);
h8 := diff(f(x),x)/z;
h9 := subs(x=z, f(x));
test := [h1, h2, h3, h4, h5, h6, h7, h8, h9];
F = 0;
for i from 1 to 9 do
    F = F + 1/(1+exp(subs(x=0,test[i])-subs(x=0,f(x))));
Hi there,
I am using plot3d in worksheet mode to create a bunge of complex 3d-geometries containing "patches" (style = wireframeopaque) and wireframes (style = wireframe) representing the deformed and undeformed geometry of a system. I would like to export them as vector graphics since only then the results look nice enough to be used in a report.
When using Maple 12 rightclick->export->EPS, works nearly. Unfortunately the patches are not really...
I have tried everything I can think of but cannot figure out how to phase a sine wave so that I see 3 plots of
f(x)=sin(x)
as a set of {0°, 120°, 240°} together on the same plot...
Hi there,
I have a system of seven equations and want to make a phase plane with field arrows for two independent variables (C vs I). When I use DEplot it doesn't give me field with arrows. I just wonder if anybody could please help me in this issue. Here is my system:
dp/dt = P kappa I-gamma[1] CE- delta[1] CH
dE/dt = lambda E(E[0]-E)-gamma[1] C E
dI/dt = gamma[1] CE + eta Ia/(epsilon+K) -kappa I -alpha K I-delta[2] I M
dIa/dt = alpha K I+delta[2] I M
I have a model which contains 3 variables and several parameters, the equtions are as following:
diff(i(t),t) = alpha*B(t)*S(t)/(K+B(t))-r*i(t)
diff(S(t),t) = -alpha*B(t)*S(t)/(K+B(t))+b*(N-S(t))
diff(B(t),t) = e*i(t)+g*B(t)
How can I solve them to get the solutions by using Maple, and plot them?
Sorry I'm just a new learner with little math background. Plz explain more specific if you want. Thanks for your help.
I just wondered if there was a similar rule for sine.
I have the system of two difference equations. I need to plot phase plane of (x(k), y(k)).
Hallo,
I would like to parse function name of parameters (type is function) in my procedure.
I expact for the one parameter this fun::Or(name, function(name). This is exactly the same type like the second parameter in procedure rsolve
For example:
The value of the parameter fun is y(n) and I would like to parse function name y and function variable
Dear Maple users
I have encountered a strange problem when trying to make inline evaluations in Document Mode. The shortcut Ctrl+= does work on my stationary Windows XP machine, but does not work on my notebook running Windows 7 (64 bit).
To make it clear: I change to Math Mode using the F5 key, type the expression and hold Ctrl and Shift key down and press the key with the = sign. And Yes, I am using Document Mode!
When I rightclick in order to use...
  We have two random points A(X1,Y1,Z1) and B(X2,Y2,Z2) in the unit cube, ie X1, X2, Y1, Y2, Z1, and Z2 are collectively independent random variables uniformly distributed on the interval [0,1].
  How to find  the mean of the distance between A and B with Maple? The same question in higher dimensions.
First 1879 1880 1881 1882 1883 1884 1885 Last Page 1881 of 2457
