I try to solve the following, but it have the error of singular. can any one help me solve it.
> restart;
> dsys1 := diff(y(x), `$`(x, 2))+(lambda*lambda)*y(x) = 0;
              / d  / d      \\         2
              |--- |--- y(x...
I have two expression like,
exp1:=A1*x*(k-p*x)+A2*x+A3*p+A4
exp2:=A5*x*(k-p*x)
where A1, A2, A3, A4 and A5 are some lengthy expressions.
I need to find the division of these two, namely exp3
exp3:=exp1/exp2
in the form
exp3:=(A1/A5)+the rest
In other words, I need to extract the part which could be normalized by x*(k-p*x).
I need to know how to use Maple to solve group permutaions and Cayley tables
I wanted that the same X-axe represents 1-10, 100-110 and 500-510. I do not know if it is possible to have a kind of X-values that in the same graph shows  the Y-values for the 32 following points: 1,2,..9,10,100,101,..110,500, 501,502,..., 510 . If I consider all interval 1-510, I could not be able to apreciate the graphic.
Thanks for your attention Kirnyk.
Jean-Jacques
I'm trying to understand shooting method using maple in solving BVP. especially to solve boundary layer flow. I don't have any idea about the step size used and convergence criteria specified in shoot lib in the maple. Can anybody help me with this? Where can I refer to. Thank you
Could you give examples of differentiate differential form or integrate differential form using maple?
A friend asked me if Maple can do the following integral, since Mathematica just spins for an indefinite time with it:
int (  (1/sqrt(2*Pi))*(1/(1+exp(x)))*exp(-(1/2)*((x-a)/b)^2) ) from -infinity to infinity
Interesting integral though!
Dear friends,
The commands below generates a graphic. Hower I would like two things:
1. That the Y values are from 0 to 0.7 (in the example before it goes --by default--only until 0.5).
2. To represent in the X-axe the values from from 1-10, 100-110 and 500-510. I do mean, axe-X excluding 11 to 99, 111 to 499.
Here the commands:
ww:= [seq( [n, add(1/(n+1), k=ceil(1/3*n)..floor(2/3*n))], n=1..10)]:
plot(ww, style=point):
I have 2 sets of nonlinear motion equation for double pendulum problem. I wonder how can I solve these second order nonlinear equations first and second how can I extract the state space model for this system.
I have a DLL which contains many function for the 1997 IASM steam tables.
As an example (in SI units)
> dllloc := "c:/Windows/system/astemdll.dll";
> psat := define_external(psat97mc, FORTRAN, arg1::(float[8]), RETURN::(float[8]), LIB = dllloc);
> b := psat(647.096);
Version: Maple 7
How can I acheive the following?
Pseudo-maple, this is what I want to happen.
> f:=modp(x,2);
> subs(x=3, f);
(output) 1
The problem is that the first line echoes "f:=x" and then subs(x=3,f); outputs 3.
In a similar way, I get the following unexpected result,
> f2 := 0.5 < floor( modp(floor(y/17)* 2^(-17*floor(x)-modp(floor(y),17)) ,2) );
(output) f2 := .5 < 0
For some reason the RHS of...
This is an equation:T*s^3+s^2+K=0,where T>0,K>0, s is complex variable. I have known that one of its roots has real part, and this real part is independent of T and K. I don't know how can I use maple to illustrate this conclusion, can you give me some advices? I try to use solve command, but the result is very chaotic.
Thank you in advance.
I want to produce a list with oder by total degree, of monomials in several variables
i.e. {1, x, y, x^2, y^2, xy} would be the list or all monomials in the variables x and y with total degree <=2,
currently i can produce a list using a loop command that gives me the set
U:=(seq(seq((x^n)*(y^m), n=0..2),m=0..2));
which returns the list
U=1, x, x^2, y, xy, x^2y, y^2, xy^2, x^2y^2
which has terms that i do not require i.e. ...
Here is my code , could you please tell me where i'm going wrong... isn't plotting anything
Fern :=proc(n);
local pick,n;
n := NULL;
for n from 1 to n do
pick := rand();
if pick < 0.01 then
x[n+1] := 0;
y[n+1] := 0.16*y[n];
else if pick < 0.01 + 0.85 then
x[n+1] := 0.85*x[n] + 0.04*y[n] + 0;
y[n+1] := -0.04*x[n] + 0.85*y[n] + 1.6;
else if pick < 0.01 + 0.85 + 0.07 then
x[n+1] := 0.2*x[n] - 0.26*y[n] + 0;
y[n+1] := 0.23*x[n] + 0.22*y[n] + 1.6;
In a particular calculation I kepp getting (erratically) the error message,
Error, (in sqrfree) argument must be a polynomial or a rational function in lam
I don't...
First 1933 1934 1935 1936 1937 1938 1939 Last Page 1935 of 2457
