The following simple procedure:
SubsColumn: = proc (A, V, k)
local B, m;
with (LinearAlgebra);
m: = ColumnDimension (A);
B: = <A[..,1..m]|V>;
B: = ColumnOperation (B, [k, m +1]);
B: = DeleteColumn (B, m +1);
B;
solve the problem of...
Could you please tell me, how can I model a varying stiffness spring using MapleSim 4?
I think, this can realized using a varying "c" parameter of a standard spring from the MapleSim library, but I don't know, how I can change the "c"-stiffness value during the modeling process.
Dear friends,
My following commands (MAPLE 14), generate the matrix zz1 (see below).
How could I get a plot with "n" (first column) in the "X-coordinate" and second/third and fouth columns in "Y-coordinate"?,
Thanks for your attention,
Jean-Jacques
interface(rtablesize=50):
f1 :=  (w1, w2,n) -> add(add(
 `if` (1/2 <= w1+j*w2+((1/n)*(1-w1-w2))*k and
why the results of two BessLk function is wrong? The results I got is negative,but it shouldn't be less than zero。For the same  integration expression, I use the mathematica, can get the right results.But when use maple,with the variable value's increasing,the results ranges from positive to negative.In fact, the result I got is outage probability,it should be positive.
What can be said about this divergent series:
 sum((cos(m)+I*sin(m))*(cosh(w)+sinh(w)),n=1 ..infinity) where m=Pi*n and w = ln(n)/n?
Calculate
int(cos(100*(x^4-x)), x = -infinity .. infinity)
with the relative error less than  10 percentages.
I use 'SystemConnect' command to connect two transfer function, as the following codes illustrated.
with(DynamicSystems);
sys1 := TransferFunction(10/(s*(s+10)));
sys2 := TransferFunction(k*s^2/(s+20));
Warning, improper transfer-function, degree(num) > degree(den)
sys3 := SystemConnect(sys1, sys2, connection = negativefeedback, outputtype = tf);
Error, (in unknown) cannot convert improper transfer function to state-space model
does anybody have experience with solving heat conduction for multi-layer domain?
the following command gives unrealistic results:
pdsolve(PDE,IBC, numerics)
Mo
I'm currently implementing the Poker test to determine whether a binary sequence possesses some specific characteristics that a truly random sequence would be likely to exhibit.
Maple can't solve the inequation `assuming`([solve(floor(160/m)>=5*2^m,[m])],[m::posint]);
However, `assuming`([solve((160/m)>=5*2^m,[m])],[m::posint]); works.
Is there a way to rewrite...
Hi friends,
I have this piecewise function:
restart:assume(n,integer):h := piecewise(n::odd, n^2, n^3);
I can not get explicitly the derivative:
diff(h,n);
But, with
restart:h1 := piecewise(And(n::integer, n::odd), n^2, n^3);
I can get the derivative explicitly:
diff(h1,n);
Why ?
k := 1:
alpha := vector([x*cos(theta), x*sin(theta), k*x]);
e1 := map(diff, alpha, theta);
e2 := map(diff, alpha, x);
G := matrix([[simplify(e1[1]^2 + e1[2]^2 + e1[3]^2), 0],[0, simplify(e2[1]^2 + e2[2]^2 + e2[3]^2)]]);
inv_e1 := evalm(1/G[1,1]*e1);
inv_e2 := evalm(1/G[2,2]*e2);
e11 := map(diff, e1, theta);
e12 := map(diff, e1, x);
e22 := map(diff, e2, x);
gamma_1_11 := simplify(evalm(e11&*inv_e1));
gamma_1_12 := simplify(evalm(e12&*inv_e1));
How to interpolate in terms of any form of algebra in maple?
For example, to interpolate a time series in terms of exponential or mixed with cos and sin?
Hi, all,
Is there a command to test whether two polynomials are equal to each other?
Or I have to write a procedure to do that?
Gepo
I guess I have an easy question here. How do you write stuff in Maple which you don't want displayed? For example, if I wanted to set alpha=1 but I didn't want that printed after pressing enter?
Cheers
Hi all forum people, I need use the maple for symbolic solutions, I am a beginner user.
I read about the isolate, solve, equations, expressions and functions in maple, I have a great confusion in my head.
My needs are, make a equations (with currents and voltages) and isolate any variable in a time, and combine them with another equations.
  ic=vin/L*Ton+im
if=(vin-vo)/L*Toff+im
dil/dt=(if-im)/T
another case:
First 1935 1936 1937 1938 1939 1940 1941 Last Page 1937 of 2457
