Hi All,
I'm new here and to Maple and this is my first post.
How do I get maple to evalaute the following expression:
sum(exp(-1/2*(((psi-theta) + 2*pi*n) / (sigma))^2), n=1..infinity);
psi and theta are angles, sigma is a constant - basically psi, theta and sigma are numbers. In fact the summation is where n is a member of Z (set of integers) but I will be happy with a solution for n= 1..infinity.
when I eval an expression at one x value it works but why does eval fail to work when multiple values of x are passed on to eval as a list....
a:=x^2
eval(a,x=9) will result in 81.
But eval(a,x=[9,10]) does not produce   81,100 .
I was under the impression that multiple values of x can be passed on as a list. Please let me know where I am making mistake(s). Thanks in advance !!
I am thinking about using Maple for my math calculations and work. Is Maple going to be around and vibrant since its acquisition by a Japanese software group? Just wanted to make sure I am not investing time and resources in a technology that might be phased out. Thanks in advance!
I need help with unapply command in order to create functions out of solutions produced by the solve command. For example, I want to solve ax^2+bx+c=0 and create a function out of the first of the two results. Thanks in advance!!
How can I use the eval command to evaluate x^2 at  [5,7]. I know how to eval x^2 at just x=5 or just x=7 but I am not sure how to evaluate the entire list [5,7]. Thanks in advance !!
what is the purpose behind the command gc()  ? Thanks in advance !!
Some time after I start using Maple 13 I notice that the scroll bar on the right is choppy. I also notice similar issues when I plot a 2D graph with the plot and the scroll bar becoming choppy. Could this be a computer memory problem? I am using Maple 13 on Windows XP with 1.25GB RAM. Thanks in advance !!
Please help me with function mapping.
I want to map 1/x over the list [2,6,8].
Solving the system
 a1 := 2*x2-x3-x4-x5-x6-x7;
 a2 := -2*x1+2*x3-x4-x5-x6-x7;
 a3 := x1-2*x2+2*x4-x5-x6-x7;
 a4 := x1+x2-2*x3+2*x5-x6-x7;
 a5 := x1+x2+x3-2*x4+2*x6-x7;
 a6 := x1+x2+x3+x4-2*x5+2*x7;
 a7 := x1+x2+x3+x4+x5-2*x6; b := x1+x2+x3+x4+x5+x6+x7;
 solve({x1 >= 0, x2 >= 0, x3 >= 0, x4 >= 0, x5 >= 0, x6 >= 0, x7 >= 0,
 b = 1, a1 <= 0, a2 <= 0, a3 <= 0, a4 <= 0, a5 <= 0, a6 <= 0, a7 <= 0},...
Are there naming conventions or requirements for uploaded files?
I am used to using something like "name.rlm.xx.yy.Mvv.mw" with spaces as appropriate in the name. xx.yy is my version, because I save many versions as I go along. Mvv is the Maple version.
Are there some names that MaplePrimes will not handle correctly, aside from length?
Though I have been a casual Maple user since M12, I really don't know how to use it well, and am just learning it. I set myself a few tasks to help me discover its potential. I find that I learn better if I have some goal, even if it is just a sample goal.
In the accompanying file, I want to see how to use M14, and explore how to use Legendre polynomials.
Q: In (3.4), is there a cleaner way to declare the sequence?
Q: Am I using sequences correctly in this file?
I am trying to duplicate the material that is shown in the accompanying PDF file, where the plot actually comes from the calculations, much as I am trying to do with Maple 14.
Q: (3.9) gets the correct coefs, but not very pretty...is there a better way?
Q: I eventually stumbled upon (3.10), which looks correct, but when I dragged it to the plot and dropped it, I got only the first Legendre polynomial, not n of them. How do I get that?
Q: How do I show that I dropped L on the plot? The legend shows Curve 1 and 2.
Q: Is there a way to combine (3.8) and (3.9) into one stem, for example, by using array subscripts? I tried and failed.
Legendre_polynomial_.mw
Legendre_polynomial_.pdf
So Im doing a curve againist data plots for angular freq,
Ive reached the stage where im trying to evaluate the function,
ive put
>fit :=eval(f(x),R[2]);
where R[2] is the the values for the constants, in the function
F/sqrt(m^2*(omega^2-omega_0^2)^2+b^2*omega^2
which is also defined as f(x)
how can I find the average of numberrs in a list. For example, I want to find the average of [4,6,8]. Thanks!
12345123.msim
I use maplesim to simulate a very simple circuit, and want to obtain voltage of a resistor, so I check the voltage of  Probe block, but get nothing. I upload my document.
I'm a beginner in maplesim, can you give me some advices?
Hi:
I have a number of functions all enclosed inside the Sum functionin the  following form:
Test:=Sum(f1(n)+f2(n)),n=1..infinity);
Each of the functions f1, etc are fairly complicated, and there are more than two, but this example will do.
How do I get Maple to expand Test into the form:
Test:=Sum(f1(n),n=1..infinity) + Sum(f2(n),n=1..infinity);
I've tried every combination of expand, simplify, combine collect, that I can think of - nothing works.
First 1941 1942 1943 1944 1945 1946 1947 Last Page 1943 of 2457
