In an erlier post, I referred to the foot date format, and that post didn't trigger a reply, so I imagine that there is no satisfactory answer..
Help states, for FormatTime, "The default format is the ISO 8601 standard default date format..." but the date in the footer is of the style "12/1/10" which has obvious faults. Is there a way to get a decent date format in the footer other than putting it in by hand?
Good morning,
I want to  to show the 2-simplex (in R^2) obtained from the inequality
x+ y+ z < = 12*a
 with a:=1;
x, y, z  >= 0.
(the angles of the triangle are (12,0,0), (0,12,0) and (0,0,12) )
The CORE of a cooperative game, is the set points that additionally satisfy the system
x+ y >= 6
x+ z >= 6
y + z >= 6
Is there a way of plotting the vertical axis in reverse order. i.e, zero at top of graph and numbers increasing downwards??
Hi Everyone,
I'm wondering if anyone here has had a similar experience.
I assign Maple projects to my students in table format.  They do their work in the first column and I write my comments in the second column.
I noticed that while I grade a worksheet (Maple 14 on a Windows 7 laptop), Maple becomes very sluggish.  I started monitoring  Maple's memory usage while editing.  When I open the file, the memory footprint is roughly 60,000K....
say i have an equation that represents the variation of some quanity with height. I naturally want to plot height on the vertical axis and the equation on the horizontal. Is there any way of doing this? E.g, the eqaution below, where z is a vertical coordinate...
> E := proc (z) options operator, arrow; 2000+5*z end proc;
I have the simplified version of what I want to do:
restart: with(LinearAlgebra):
d:=4:
product(MatrixExponential(I*Matrix(d,{(l,l)=1})*A[l,l]),l=1..d):
But I get the following error:
Error, (in Matrix) integer indices required for Matrix
Help appreciated.
Hello friends,
I would like to obtain the "n" for which the second column reaches its maximum and minimum (in the case of my example below, n= 5, 11 and 17 (for -10) and n = 8 and 14 (for 10))
interface(rtablesize=20):
Matrix([  seq([ n,round(10*sin(n)),round(10*cos(n))], n=1..20)]  );
How can I do that?
Thanks a lot for you attention,
Jean-Jacques
I use the following commands to generate some complex numbers:
equ := 2+(s+1)*exp(tau*s) = 0;
a := [0, .8, 2*Pi/(3*sqrt(3)), 4*Pi/(3*sqrt(3))];
for i to nops(a) do
   evalf(solve(subs(tau = a[i], equ), s));
end do
then maple output four complex numbers. I want to get a list which contains the four output complex numbers,how can I do that without retyping the output numbers manually?
By the...
I am trying to use Maple 14.01 for implementing the computation of some cooperative game solutions with transferable utility.
As a first step for computing the CORE, I need to be able to draw the 2-simplices ( a triangle in R^2 with vertices (1,0,0), (0,1,0), (0,0,1) and 3-simplices ( a tetrahedron  with vertices  (1,0,0,0), (0,1,0,0), (0,0,1,0), (0,0,0,1) ). Certainly, I would like to be able to rotate and to visualize from different angles the figure.
A small question:
When I send the following command, I can see the matrix of 10 x 2:
Matrix( [seq( [ n , sum( evalf(1/(n+1)), k=(1/3*n)..(2/3*n) )], n= 1..10)]);
However, when I want to evaluate for  n=1..50.. I cannot see any numbers but only a description of a matrix.
How may I can I see the matrix for n=1..50?
Thanks a lot for your attention,
Jean-Jacques
Hi; every body
i have a problem with fsolve using fours equestion. i use fsolve to slove four equestions and it doesnot give any soltion even if i determent the period of solution as follow,
x1=0..3, x2=0..2, x3=0..1/2, x4=0..5.
i have increased the digit to 100 but it still does not give solution where i am sure there is solution in this interval.
I am looking to create a list-of-lists with all the combinations of 1..7.
The order is not important so for example [1,7] [7,1] should only return [1,7]
ie
[[1],[2],[3],[4],[5],[6],[7],[1,2],[1,3],[1,4],[1,5],[1,6],[1,7],
[2,2], [3,3], [4,4] ......................
[3,2]...................
[7,2].............
[1,2,1]........
[1,2,2].......     ]
I am no sure I am explaining...
I just bought an HP 8500A 910A printer. So far every other application except Maple prints correctly and well. When I print, each (whole) page is printed in the upper left hand quarter of a letter size sheet of paper. This never happened with my old HP LaserJet 4L. After much search, there do not seem to be any setable preferences that could lead to this result.
On the HP forum, there is another user with the same problem except the application is different....
Hey folks I need some help with basic string manipulation.
Say I want to find the sum of the digits of 123
What I've been doing is the loooong way of converting 123 to a string, breaking it up into 3 seperate numbers, converting these back to their decimal value, then adding them up.
How could I make this more efficient? Is there some part of StringTools that would do this for me?
Then...
a. How to write a  proc(a,h,A,B,C) procedure which calculates the area of the projection of the pyramid OKLMS on the plane p:A*x+B*y+C*z+D=0,where O(0,0,0), K(a,0,0), L(a,a,0), M(0,a,0), and S(a/2,a/2,h)?
b.  How to write a  proc(r,h,A,B,C) procedure which calculates the area of the projection of the cone
with the base {(x,y,z): x^2+y^2<=r^2,z=0} and the vertex S(0,0,h) on the plane p:A*x+B*y+C*z+D=0?
First 1943 1944 1945 1946 1947 1948 1949 Last Page 1945 of 2457
