I have FORTRAN namelist files, that have the form like
<space>&namelist_name
<space>varName1=0.600
<space>varName2=123
<space>varName3=345.0
<space>&end
In these files there are no blank lines as automatically put in above,
The goal is to read such files into Maple and have the same varNames created in Maple to be names/symbols with the values shown in the FORTRAN file assigned to those Maple names. In other words, Maple should then have
varName1 := 0.600:
varName2 := 123:
varName3 := 345.0:
This would enable the Maple to use these variables in the usual way to make calculations, etc.
I know how to read the FORTRAN files and get the varNames and values into two separate Maple tables, but I haven't found a way to then make the Maple assignments that are required. There must be a way to accomplish the goal.
Thank you for any suggestions.
      --- Mike
Write a Maple procedure called "matricediag" which takes as input a square matrix M of m rows and m columns and which returns The smallest element below the main diagonal and its position.
When I look for petrov type II vacuum solutions in the Metric search, one of the metrics i get is Stephani [33,8,3].
But when I load the metric and calculate the Ricci or the Einstein tensor, they are not identically zero.
Am I using the metric search wrong or is there a glitch in the program?
Download Temp.mw
Let  denote the factors of the "absolute factorization" of the following bivariate polynomial (i.e., ):
p := product(x^3*k^2 + (x*(y + 2) + 2)*k - x^3 + y^3 + y + 1, k = RootOf(_Z^3 + _Z + 1)):
f__0 := (evala@AFactors)(p)[2, .., 1]; # Assume that we do not know the extension field in advance.
It is unfortunate that the output is not easy to read, so I have to simplify it here. However, it appears that none of the results (i.e., , , and ) is eminently readable.
p := product(x^3*(k^2-1)+(x*(y+2)+2)*k+y^3+y+1, k = RootOf(_Z^3+_Z+1))
-3*x^9+8*x^6*y^3-5*x^3*y^6+y^9-4*x^7*y+3*x^4*y^4-8*x^7+8*x^6*y-x^5*y^2+6*x^4*y^3-10*x^3*y^4+x^2*y^5+3*y^7-4*x^5*y+3*x^4*y^2-5*x^3*y^3+4*x^2*y^4+3*y^6-4*x^5+5*x^4*y-11*x^3*y^2+5*x^2*y^3+4*x*y^4+3*y^5-2*x^4-16*x^3*y-x^2*y^2+8*x*y^3+6*y^4-11*x^3-16*x^2*y+4*x*y^2+8*y^3-20*x^2+3*y^2-16*x+7*y-3
f__0 := (`@`(evala, AFactors))(p)[2, () .. (), 1]
[x^3+((-(106/3267)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+1486/3267+(1/3267)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)^2)*y+2972/3267-(212/3267)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+(2/3267)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)^2)*x+(-(4/3267)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)^2-3040/3267+(61/3267)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2))*y^3+(-(4/3267)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)^2-3040/3267+(61/3267)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2))*y-68/3267-(151/3267)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)-(2/3267)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)^2, x^3+(((106/3267)*RootOf(10501+_Z^3+51*_Z)+(106/3267)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+1486/3267+(1/3267)*(-RootOf(10501+_Z^3+51*_Z)-RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2))^2)*y+2972/3267+(212/3267)*RootOf(10501+_Z^3+51*_Z)+(212/3267)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+(2/3267)*(-RootOf(10501+_Z^3+51*_Z)-RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2))^2)*x+(-(4/3267)*(-RootOf(10501+_Z^3+51*_Z)-RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2))^2-3040/3267-(61/3267)*RootOf(10501+_Z^3+51*_Z)-(61/3267)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2))*y^3+(-(4/3267)*(-RootOf(10501+_Z^3+51*_Z)-RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2))^2-3040/3267-(61/3267)*RootOf(10501+_Z^3+51*_Z)-(61/3267)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2))*y-68/3267+(151/3267)*RootOf(10501+_Z^3+51*_Z)+(151/3267)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)-(2/3267)*(-RootOf(10501+_Z^3+51*_Z)-RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2))^2, x^3+((-(106/3267)*RootOf(10501+_Z^3+51*_Z)+1486/3267+(1/3267)*RootOf(10501+_Z^3+51*_Z)^2)*y+2972/3267-(212/3267)*RootOf(10501+_Z^3+51*_Z)+(2/3267)*RootOf(10501+_Z^3+51*_Z)^2)*x+(-(4/3267)*RootOf(10501+_Z^3+51*_Z)^2-3040/3267+(61/3267)*RootOf(10501+_Z^3+51*_Z))*y^3+(-(4/3267)*RootOf(10501+_Z^3+51*_Z)^2-3040/3267+(61/3267)*RootOf(10501+_Z^3+51*_Z))*y-68/3267-(151/3267)*RootOf(10501+_Z^3+51*_Z)-(2/3267)*RootOf(10501+_Z^3+51*_Z)^2]
f__1 := evala(f__0)
[34/3267-(151/3267)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+(2/3267)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)*RootOf(10501+_Z^3+51*_Z)+(2/3267)*RootOf(10501+_Z^3+51*_Z)^2+(2870/3267)*x-(212/3267)*x*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)-(2/3267)*x*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)*RootOf(10501+_Z^3+51*_Z)-(2/3267)*x*RootOf(10501+_Z^3+51*_Z)^2-(2836/3267)*y+(61/3267)*y*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+(4/3267)*y*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)*RootOf(10501+_Z^3+51*_Z)+(4/3267)*y*RootOf(10501+_Z^3+51*_Z)^2+(1435/3267)*x*y-(106/3267)*x*y*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)-(1/3267)*x*y*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)*RootOf(10501+_Z^3+51*_Z)-(1/3267)*x*y*RootOf(10501+_Z^3+51*_Z)^2+x^3-(2836/3267)*y^3+(61/3267)*y^3*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+(4/3267)*y^3*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)*RootOf(10501+_Z^3+51*_Z)+(4/3267)*y^3*RootOf(10501+_Z^3+51*_Z)^2, x^3+(106/3267)*x*y*RootOf(10501+_Z^3+51*_Z)+(106/3267)*x*y*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+(1435/3267)*x*y+(1/3267)*x*y*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)*RootOf(10501+_Z^3+51*_Z)+(2870/3267)*x+(212/3267)*x*RootOf(10501+_Z^3+51*_Z)+(212/3267)*x*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+(2/3267)*x*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)*RootOf(10501+_Z^3+51*_Z)-(4/3267)*y^3*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)*RootOf(10501+_Z^3+51*_Z)-(2836/3267)*y^3-(61/3267)*y^3*RootOf(10501+_Z^3+51*_Z)-(61/3267)*y^3*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)-(4/3267)*y*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)*RootOf(10501+_Z^3+51*_Z)-(2836/3267)*y-(61/3267)*y*RootOf(10501+_Z^3+51*_Z)-(61/3267)*y*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+34/3267+(151/3267)*RootOf(10501+_Z^3+51*_Z)+(151/3267)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)-(2/3267)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)*RootOf(10501+_Z^3+51*_Z), x^3-(106/3267)*x*y*RootOf(10501+_Z^3+51*_Z)+(1486/3267)*x*y+(1/3267)*x*y*RootOf(10501+_Z^3+51*_Z)^2+(2972/3267)*x-(212/3267)*x*RootOf(10501+_Z^3+51*_Z)+(2/3267)*x*RootOf(10501+_Z^3+51*_Z)^2-(4/3267)*y^3*RootOf(10501+_Z^3+51*_Z)^2-(3040/3267)*y^3+(61/3267)*y^3*RootOf(10501+_Z^3+51*_Z)-(4/3267)*y*RootOf(10501+_Z^3+51*_Z)^2-(3040/3267)*y+(61/3267)*y*RootOf(10501+_Z^3+51*_Z)-68/3267-(151/3267)*RootOf(10501+_Z^3+51*_Z)-(2/3267)*RootOf(10501+_Z^3+51*_Z)^2]
f__2 := simplify(f__0, size)
[(1/3267)*(-4*y^3+(-4+x)*y-2+2*x)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)^2+(1/3267)*(61*y^3+(61-106*x)*y-151-212*x)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)-(3040/3267)*y^3+(1/3267)*(1486*x-3040)*y+x^3-68/3267+(2972/3267)*x, (1/3267)*(-4*y^3+(-4+x)*y-2+2*x)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)^2+(1/3267)*((-8*y^3+(-8+2*x)*y-4+4*x)*RootOf(10501+_Z^3+51*_Z)-61*y^3+(106*x-61)*y+212*x+151)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+(1/3267)*(-4*y^3+(-4+x)*y-2+2*x)*RootOf(10501+_Z^3+51*_Z)^2+(1/3267)*(-61*y^3+(106*x-61)*y+212*x+151)*RootOf(10501+_Z^3+51*_Z)-(3040/3267)*y^3+(1/3267)*(1486*x-3040)*y+x^3-68/3267+(2972/3267)*x, (1/3267)*(-4*y^3+(-4+x)*y-2+2*x)*RootOf(10501+_Z^3+51*_Z)^2+(1/3267)*(61*y^3+(61-106*x)*y-151-212*x)*RootOf(10501+_Z^3+51*_Z)-(3040/3267)*y^3+(1/3267)*(1486*x-3040)*y+x^3-68/3267+(2972/3267)*x]
f__3 := simplify(f__0, RootOf)
[34/3267-(2836/3267)*y^3+(61/3267)*y*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)-(151/3267)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+(2870/3267)*x-(106/3267)*x*y*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)-(2836/3267)*y+(61/3267)*y^3*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+(1435/3267)*x*y+x^3-(212/3267)*x*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+(1/3267)*(-x*y-2*x+4*y^3+4*y+2)*RootOf(10501+_Z^3+51*_Z)^2+(1/3267)*(-2*x*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)-x*y*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+2*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+4*y*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+4*y^3*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2))*RootOf(10501+_Z^3+51*_Z), x^3-(61/3267)*y^3*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+(151/3267)*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+(1435/3267)*x*y+34/3267+(2870/3267)*x-(2836/3267)*y^3-(2836/3267)*y+(106/3267)*x*y*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+(212/3267)*x*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)-(61/3267)*y*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+(1/3267)*(-61*y-61*y^3+151+2*x*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+106*x*y-4*y*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)-4*y^3*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+x*y*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2)+212*x-2*RootOf(_Z^2+_Z*RootOf(10501+_Z^3+51*_Z)+51+RootOf(10501+_Z^3+51*_Z)^2))*RootOf(10501+_Z^3+51*_Z), x^3+((-(106/3267)*RootOf(10501+_Z^3+51*_Z)+1486/3267+(1/3267)*RootOf(10501+_Z^3+51*_Z)^2)*y+2972/3267-(212/3267)*RootOf(10501+_Z^3+51*_Z)+(2/3267)*RootOf(10501+_Z^3+51*_Z)^2)*x+(-(4/3267)*RootOf(10501+_Z^3+51*_Z)^2-3040/3267+(61/3267)*RootOf(10501+_Z^3+51*_Z))*y^3+(-(4/3267)*RootOf(10501+_Z^3+51*_Z)^2-3040/3267+(61/3267)*RootOf(10501+_Z^3+51*_Z))*y-68/3267-(151/3267)*RootOf(10501+_Z^3+51*_Z)-(2/3267)*RootOf(10501+_Z^3+51*_Z)^2]
Unfortunately, none of f__0, f______1__, f__2, and f______3__ is very readable.
It can be proved that the following one is also the factors.
f__4 := [x^3 + RootOf(3*_Z^3 - 4*_Z^2 + _Z - 1, index = 3)*(x*(y + 2) + 2) + RootOf(3*_Z^3 + 8*_Z^2 + 5*_Z + 1, index = 3)*(y^3 + y + 1), x^3 + RootOf(3*_Z^3 - 4*_Z^2 + _Z - 1, index = 2)*(x*(y + 2) + 2) + RootOf(3*_Z^3 + 8*_Z^2 + 5*_Z + 1, index = 1)*(y^3 + y + 1), x^3 + RootOf(3*_Z^3 - 4*_Z^2 + _Z - 1, index = 1)*(x*(y + 2) + 2) + RootOf(3*_Z^3 + 8*_Z^2 + 5*_Z + 1, index = 2)*(y^3 + y + 1)];
evala(p+3*`?()`(`*`, f__4))NULL
[x^3+RootOf(3*_Z^3-4*_Z^2+_Z-1, index = 3)*(x*(y+2)+2)+RootOf(3*_Z^3+8*_Z^2+5*_Z+1, index = 3)*(y^3+y+1), x^3+RootOf(3*_Z^3-4*_Z^2+_Z-1, index = 2)*(x*(y+2)+2)+RootOf(3*_Z^3+8*_Z^2+5*_Z+1, index = 1)*(y^3+y+1), x^3+RootOf(3*_Z^3-4*_Z^2+_Z-1, index = 1)*(x*(y+2)+2)+RootOf(3*_Z^3+8*_Z^2+5*_Z+1, index = 2)*(y^3+y+1)]
`~`[length]([f__ || (0 .. 4)])
[3858, 4389, 1410, 3608, 513]
`~`[MmaTranslator:-Mma:-LeafCount]([f__ || (0 .. 4)])
[935, 1047, 391, 881, 166]
As you can see, f__4 is of lower mathematical complexity.
Download fully_simplify_f_0.mw
The  above (whose "size" is smaller) comes from manual simplification, but this is not a easy work. Is there a way to get the much simplified result programmatically?
I am not able to make a MWE for this error, as it only shows in the debugger. So it seems Maple internal memory changes or some other library is loaded to cause this. Inside the debugger, I get to a function which does this
DBG> simplify(JacobiDN(x,k)^2*n)
Error, invalid input: simplify/Jacobi/JacobiDN expects its 1st argument, k, to be of type posint, but received 0
Version 2023 on windows 10
In a worksheet, the above works just fine
Back to the debugger, if I write (2*n) instead of 2*n, then the error goes away
DBG> simplify(JacobiDN(x,k)^(2*n))
JacobiDN(x,k)^(2*n)
The values of x,k,n are all symbols and have no values in the code running:
I have no idea why this happend when I run the code only. It think x is zero in the above for some reason.
Sorry can't make MWE, I wish I can. Something strange happens when I run the code that does not show otherwise.
Any suggestions how to invetigate this more? Stepping into the simplify code it fails in
DBG> next
`simplify/check_constant`:
   3   return type(r,'And(constant,Or(Not(function),satisfies(f -> evalb(op(f)
         <> NULL))))')
DBG> r
JacobiDN(x,k)^2*n^2
DBG> type(r,'And(constant,Or(Not(function),satisfies(f -> evalb(op(f)          <> NULL))))')
DBG> step
`simplify/Jacobi`
`simplify/do`:
  84               userinfo(1,simplify,'applying',new_simp,
                     `function to expression`);
 85               new_r := new_simp(r,symb_mode);
Here it generate the error.
It has nothing to do with simplify. Here is a call to integrate which gives same error
DBG> lhs(ode)
diff(diff(xi(x),x),x)-k^2*JacobiSN(x,k)*JacobiCN(x,k)/JacobiDN(x,k)*diff(xi(x),x)+(-k^2*JacobiCN(x,k)^2+k^2*JacobiSN(x,k)^2-k^4*JacobiSN(x,k)^2*JacobiCN(x,k)^2/JacobiDN(x,k)^2-JacobiSN(x,k)^2*k^2*n^2+n^2)*xi(x)
DBG> int(lhs(ode),x)
DBG> x
x
DBG> k
k
DBG> xi(x)
xi(x)
alias(b = JacobiCN(sqrt(2)*sqrt(x), sqrt(2)*_Z/2)^2);
                          lessthan, b
I could not find an explanation on the help page.
I would have expected simply b as the return value.
Update:
A worksheet that generates the output
RootOf(JacobiCN(sqrt(2)*sqrt(x), (1/2)*sqrt(2)*_Z)^2*_Z^2+_Z^2-2)
RootOf(JacobiCN(2^(1/2)*x^(1/2), (1/2)*2^(1/2)*_Z)^2*_Z^2+_Z^2-2)
plot(RootOf(JacobiCN(2^(1/2)*x^(1/2), (1/2)*2^(1/2)*_Z)^2*_Z^2+_Z^2-2), x = 0 .. 5)
convert(JacobiCN(sqrt(2)*sqrt(x), (1/2)*sqrt(2)*_Z)^2, Elliptic_related)
1-JacobiSN(2^(1/2)*x^(1/2), (1/2)*2^(1/2)*_Z)^2
convert(RootOf(JacobiCN(2^(1/2)*x^(1/2), (1/2)*2^(1/2)*_Z)^2*_Z^2+_Z^2-2), Elliptic_related)
RootOf(JacobiSN(2^(1/2)*x^(1/2), (1/2)*2^(1/2)*_Z)^2*_Z^2-2*_Z^2+2)
alias(b = JacobiSN(sqrt(2)*sqrt(x), (1/2)*sqrt(2)*_Z))
lessthan, b
Download alias_with_lessthan_output.mw
Apparently functions working on lines do not work on segments.
I can't see any logical explanation why that should be so.
Please consider expanding functionality in future Maple versions.
segprojection.mw
Is there a way to determine the version of MapleSim used to create a model from the model file or within MapleSim when an older model was loaded?
Hei
Vet noen om Windows 11 støtter Maple 2020? Eller støttes det bare av Windows 10.
If I understand right, the form  is equivalent to  (where the optional index variable is omitted), which produces a sequence of n occurrences of y. But how to explain the following output (of p1())?
kernelopts(version)
`Maple 2023.0, X86 64 WINDOWS, Mar 06 2023, Build ID 1689885`
p0 := proc()
    local a := 1, b := 2;
    seq('assign(('a', 'b') = (a + 1, 2*b))', 1 .. 3);
    print(a, b)
end:
p1 := proc()
    seq('assign(('a', 'b') = (a + 1, 2*b))', 3);
    print(a, b)
end:
p2 := proc()
    'assign(('a', 'b') = (a + 1, 2*b))' $ 3;
    print(a, b)
end:
p3 := proc()
    to 3 do
    od;
    print(a, b)
end:
p0()
p1()
p2()
p3()
4, 16
5, 32
4, 16
4, 16
Download singular_behaviour_of_`seq`.mw
Main code:
p1 := proc()
    print(a, b)
end:
p1():
How can an equation containing a logarithmic function be converted into a polynomial?
Is there a way in the physics package to get my index to run from 0 to 3 instead of 1 to 4/0?
I have a data structure/plotting question. How do I plot the 3 lambdas (singleaxis) and the 6 betas (dualaxis) for 12 calibrations (1000 runs each)? All the details are in the script 230523_different-calibrations.mw. Thank you!
For the beta plots and subplots, please follow the dualaxis example output format at the bottom of my script for each of the 12 calibrations.
For the lambda plots, I'd like to combine a few of them as follows (each plot with lambda_1 subplot, lambda_2 subplot, and lambda_3 subplot - note that the lambda plot example at the bottom of the script is dualaxis but I just need singleaxis):
PLOT 1 (singleaxis): lambda_1, _2, _3 for ncal2 and ncal3 (superimposed, 2 data series for each subplot)
PLOT 2 (singleaxis):  lambda_1, _2, _3 for ncal7 and ncal8 (superimposed, 2 data series for each subplot)
PLOT 3 (singleaxis):  lambda_1, _2, _3 for ncal4, ncal5, ncal6 (superimposed, 3 data series for each subplot)
PLOT 4 (singleaxis):  lambda_1, _2, _3 for ncal9, ncal10, ncal11 (superimposed, 3 data series for each subplot)
First 196 197 198 199 200 201 202 Last Page 198 of 2427
