How can one obtain the principal measurement of an angle (which belongs to the interval ]-π;π]?
QuestionMesPrincipale.mw
Equation:=int(y'(x)*w(x)) = [int([y(x)^(1/2)]*w(x))]^(-2/3) When plugging this Equation into dsolve, Maple provides the following implicit solution: Solution:= [3*y(x)^(4/3)]/4 + int[(2*y(x)^(5/6)/[3*int([(y(x)^(1/2))*w(x)]/[3*int[(y(x)^(1/2))*w(x)]^(5/3) When going to odeadvisor, the suggestion was to first convert to the form y = G(x,y'(x) and then utilize the method of 'patterns', which I could not apply to this equation. If anyone can fill in the steps between 'Equation' and 'Solution', it would be greatly, appreciated. P.S.Sadly, I am unable to attach the actual Maplesoft worksheet.
Can anyone assist with this error please?
#Clear memory and load package.
#Initialise variables,matrices and vectors.
b:=<<18>,<-2>>:
c:=<<1>,<1>>:
i:=0:
P:=<1.08,1.37,1.56,1.61>;
t:=<5,10,15,20>;
tol:=1e-6:
#Initialise Gauss-Newton matrices.
n:=Dimension(t):
f:=Matrix(n,1):
J:=Matrix(n,2):
#Display initial parameter values.
printf("Gauss-Newton Method\n");
printf("-------------------\n");
printf("Before iterations,A = %f and B = %f\n",b(1),b(2));
#Perform the Gauss-Newton method.
while max(abs(evalf(c)))>tol do
  i:=i+1;
  for r from 1 to n do
     f(r,1):=evalf((In(b(1)+t[r])+b(2))-P[r]);
     J(r,1):=evalf(1/b(1)+t[r]);
     J(r,2):=evalf(1);
c:=Multiply(MatrixInverse(Multiply(Transpose(J),J)),Multiply(Transpose(J),f));
b:=b-c;
printf("After iterations %d, A = %f and B = %f\n",i,b(1),b(2));
Vector(4, {(1) = 1.08, (2) = 1.37, (3) = 1.56, (4) = 1.61})
Vector[column](%id = 36893488152076174028)
Gauss-Newton Method
Before iterations,A = 18.000000 and B = -2.000000
After iterations 1, A =
Error, (in fprintf) number expected for floating point format
Download Asst_3_Q4b.mw
The x region is z<x<1 and y region is 0<y<pi//3, I think there is an error in the j values in the loop
Can anyone assist please?
#Clear memory.
#Initialise variables and arrays.
h:=0.1;
k:=Pi/30;
c:=1:
iter:=0:
tol:=1e-5;
w:=1.5;
u:=Array(0..10,0..10):
U:=Array(0..10,0..10):
#Calculate boundary u values.
for i from 0 to 10 do
   u[i,Pi/3]:=0;
   u[i,0]:=0;
for j from 0 to Pi/3 do
   u[0,j]:=0;
   u[10,j]:=sin(3*j*k)/2;
#Perform the Gauss-Seidel method.
while c>tol do
   iter:=iter+1;
   if iter>99 then
      printf("\nGauss-Seidel method did not converge,change w.\n");
   break;
end if:
for i from 1 to 9 do
     U[i,j]:=u[i,j];
     u[i,j]:=(10*Pi^2*u[i-1,j]+9*u[i,j-1]+9*u[i,j+1]+2*Pi^2*u[i+1,j])/20;
     u[i,j]:=w*u[i,j]+(1-w)*U[i,j];
c:=max(abs(u[1..9,1..9]-U[1..9,1..9]));
printf("After iteration %2d,the maximum change in u is %7.1e\n",iter,c);
#Display the final u values if method converged.
if iter<100 then
    printf("\nGauss-Seidel Method\n");
    for j from 10 by -1 to 0 do
        printf("%6.4f",u[i,j]);
    printf("\n");
end if:
.1
(1/30)*Pi
0.1e-4
1.5
Error, bad index into Array
Error, final value in for loop must be numeric or character
Gauss-Seidel Method
0.00000.00000.00000.00000.00000.00000.00000.00000.00000.00000.0000
Download Asst_3_Q3c.mw
Hello. I have a problem with the phaseportrait and I hope could help me with this:
can you do groupwork on a single documet
Can anyone assist with the error please?
#Clear memory.
h:=0.1;
n:=10;
k:=0.1;
m:=10;
t:=Array(0..m):
x:=Array(0..n):
u:=Array(0..n,0..m):
#Initialise the x array and the initial u(x,0) boundary.
for i from 0 to n do
    x[i]:=i*h;
    u[i,0]:=exp(x[i]);
#Initialise the t array and the u(x,t) side boundaries.
for j from 0 to m do
   t[j]:=j*k;
   u[0,j]:=0;
   u[n,j]:=t[j];
#Use the 2D CTCS explicit wave method.
for i from 1 to n-1 do
   u[i,1]:=(9*u[i-1,0]+14*u[i,0]+9*u[i+1,0])/32+[i]/10;
for j from 1 to m-1 do
  for i from 0 to n-1 do
   u[i,j+1]:=(9*u[i-1,j]+14**u[i,j]+9*u[i+1,j])/16-u[i,j-1];
#Display the u(x,t)values.
printf("2D CTCS Explicit Wave Method\n");
printf("----------------------------\n");
printf("x\t\t t\t\t u\n");
   printf("% f\t% f\t% f\n",x[i],t[m],u[i,m]);
.1
10
.1
10
Error, Array index out of range
x                 t                 u
 0.000000         1.000000         0.000000
 0.100000         1.000000         0.000000
 0.200000         1.000000         0.000000
 0.300000         1.000000         0.000000
 0.400000         1.000000         0.000000
 0.500000         1.000000         0.000000
 0.600000         1.000000         0.000000
 0.700000         1.000000         0.000000
 0.800000         1.000000         0.000000
 0.900000         1.000000         0.000000
 1.000000         1.000000         1.000000
Download Asst_3_Q2b.mw
HI,
I want to simplify an algebraic experssion. How do I do this with Maple?
A1.mw
In the code below I do not understand why f(3,1) cannot be computed : it returns the conjugate of D1[2,2] although I have defined it as a random number. Maybe you understand this ? Actually I first got an error message of the type "bad index into matrix". Thus I wrote ''D1''[t, t] instead of D1[t, t] to fix the issue in the product.
Many thanks in advance for your help
with(LinearAlgebra);
D1 := evalf(RandomMatrix(3));
f := (i, j) -> if i = j then D1[i, i]; elif i = j + 1 then (1 - abs(D1[i, i])^2)^(1/2)*(1 - abs(D1[j, j])^2)^(1/2); elif j + 1 < i then (1 - abs(D1[i, i])^2)^(1/2)*(1 - abs(D1[j, j])^2)^(1/2)*product(-conjugate(''D1''[t, t]), t = j + 1 .. i - 1); else 0; end if;
f(1, 1);
f(1, 2), f(1, 3);
f(2, 2);
f(2, 3);
f(3, 3);
f(2, 1);
f(3, 2);
f(3, 1);
Modu := evalf(Matrix(3, (i, j) -> f(i, j)));
f(3,1) is given by 3222.984487*conjugate(D1[2, 2]): I do not get why the value of D1[2,2] is ignored.
Dear Colleagues,
I wish to use plot3d to the attached code but always encoutered error. However, pointplot3d runs perfectly. Please I need your assistance in this regards.
Thank you all and best regards.K2_Problem_2_two_body_kepler_e=0.mw
I have been using 'MemoryInUse()' to try to track down a memory leak that is crashing my Maple-based simulation. The problematic proc seems to be ProbDStarLNu which calculates the probablity of decay as a function of the angles of the decay product. It gets called a lot in acceptance rejection decay generation.
'MemoryInUse()' slows it down a lot. It also seemed to give weird results to me. I calculate the mem used on entry and then after the 4 trig functions have been called. The amount of mem 'in use' goes down after the trig functions are called. I was suspecting they were the source of the leak, but they seem almost an anti-leak.
This weird behavior caused me to write my own mem counting proc ('memUsed') based on summing over the results of 'mem:= kernelopts(memusage)'.
It is much faster. It gives nearly but not quite the same numbers. It still goes "backward" when the trig functions are called. Most of the mem growth comes from the algebra that follows the trig.
Why would that be?
I have included code for 'ProbDStarLNu'. It's pretty simple.
I have been having problem in solving this question because of the 'Whittaker'.
Can anyone please asist me how to integrate below problem with the 'Whitaker?
f := exp(-1.5*t)*(GAMMA(2)*t^(2-alpha)/GAMMA(3-alpha)-t^(1-alpha)/GAMMA(2-alpha)+t^2-t);
               /   (2 - alpha)        (1 - alpha)           \
               |  t                  t                 2    |
   exp(-1.5 t) |---------------- - ---------------- + t  - t|
               \GAMMA(3 - alpha)   GAMMA(2 - alpha)         /
int(f, t);
2.^(3.-1.*alpha)*3.^(alpha-3.)*(t^(-.5000000000*alpha)*3.^(-.5000000000*alpha)*2.^(.5000000000*alpha)*(alpha-3.)*(-2.+alpha)*exp(-.7500000000*t)*WhittakerM(-.5000000000*alpha, -.5000000000*alpha+.5000000000, 1.500000000*t)/(3.-1.*alpha)+t^(-.5000000000*alpha)*3.^(-.5000000000*alpha)*2.^(.5000000000*alpha)*(1.500000000*t-1.*alpha+2.)*(alpha-3.)*exp(-.7500000000*t)*WhittakerM(-.5000000000*alpha+1., -.5000000000*alpha+.5000000000, 1.500000000*t)/(3.-1.*alpha))/GAMMA(3.-1.*alpha)-1.*2.^(2.-1.*alpha)*3.^(-2.+alpha)*(t^(-.5000000000*alpha)*3.^(-.5000000000*alpha)*2.^(.5000000000*alpha)*exp(-.7500000000*t)*WhittakerM(-.5000000000*alpha, -.5000000000*alpha+.5000000000, 1.500000000*t)+t^(-.5000000000*alpha)*3.^(-.5000000000*alpha)*2.^(.5000000000*alpha)*(-2.+alpha)*exp(-.7500000000*t)*WhittakerM(-.5000000000*alpha+1., -.5000000000*alpha+.5000000000, 1.500000000*t)/(2.-1.*alpha))/GAMMA(2.-1.*alpha)+.1481481481+(0.9876543210e-1*(-6.750000000*t^2-9.*t-6.))*exp(-1.500000000*t)-(.2222222222*(-2.-3.*t))*exp(-1.500000000*t)
I want infinite series expansion of incomplete upper gamma function.
I clicked on the author's page link and was redirected to front page instead. Does this link work? Why does it not work for me?
How to define constants - MaplePrimes
I'm trying to use CodeTools[Profile] to investigate my memory leak and the effect or lack there of of 'forget' to improve it.
I copied my code from an example:
with(CodeTools[Profiling]);
 [Allow, Build, Coverage, GetProfileTable, Ignore, IsProfiled,
   LoadProfiles, Merge, PrintProfiles, Profile, Remove,
   SaveProfiles, Select, SortBy, UnProfile]
Profile([PickAngles(1.0, 1.0, 1.0)]);
Error, (in CodeTools:-Profiling:-Profile) unexpected argument(s)
The 'unexpected argument' is the 'result' from 'PickAngles'. I've tried with and w/o the '[]' but it does the same thing failing to recognize that 'PickAngles' is a procedure.
The example I used is here:
https://www.maplesoft.com/support/help/maple/view.aspx?path=CodeTools%2FProfiling%2FProfile procedure.
I did what to make of the subscript Profiles in the example so I used '[Profiles]' and that worked or seemed to.
First 195 196 197 198 199 200 201 Last Page 197 of 2457
