I'm using Maple 14 on 4-way and 6-way AMD 64 hardware running Windows Vista to numerically estimate inverses of a cumulative distribution function at hundreds of points, and am using the Task model to assign each point's inverse computation to a separate task. The cdf is a weighted sum of thousands of simpler functions, and so each task needs the weights. Initially I had set these up as a global variable, but after reading Darin Ohashi's MaplePrime's post ...
Hi all!
solve({q[R1] >= 0, q[S] >= 0, `dΠ`[R1] = 0}, q[R1])
This command gives me a piecewise solution, showing somewhat like:
[] q[S] < 0.13...
[{q[R1] = ...(q[S])   }] q[S] => 0.13...
Is there some way to define that part of this piecewise function for which q[S]=>0.13 as a seperate function? I need to do some more work on q[R1...
Hello there,
so i have a maple algorithms which produces about a thousand set of results. The algorithms produces about 7 values.. and this is iterated about 100 times.
Is there any way I could transfer all these values into a spreadsheet?
basically I want to end up with a speadsheet with the values from each iteration forming a row.
Thanks in advance!
How to flatten a list without ListTools? Thanks.
In the following code Maple simplifies the last expression different, based on whether assume(mu::real, sigma>0) is set or not.
The point is, that the assumptions got -to my mind- nothing to do with the displayed results.
Why does Maple do such weird things?
Here is the code. The last output is different based on whether the '#' before assume(mu::real,sigma>0): is set or not:
with(Statistics):
Y9 := RandomVariable(LogNormal(b, c)):
I discovered, that Maple did substitute every single parameter but c!
Anyway, when I isolate the problem and do not assume anything for mu and sigma, the problem does not occur.
Therefore I print here the complete relevant code.
Is there a way to "convince" Maple to do those trivial substitutions of c also, without seperating each problematical expression?
Here is the code:
with(Statistics):
#Definitions and assumptions
My problem is the following:
deq1:=2*[(y(x)*(diff(y(x), x, x))-1)/sqrt(1+(diff(y(x), x))^2)+(diff(y(x), x, x))/(1+(diff(y(x), x))^2)] = cos(x);
I do this way (error anyway):
deq := (y(x)*(diff(y(x), x, x))-1)*(1+(diff(y(x), x))^2)+(diff(y(x), x, x))*sqrt(1+(diff(y(x), x))^2)-cos(x)*sqrt(1+(diff(y(x), x))^2)*(1+(diff(y(x), x))^2) = 0
sol := dsolve([deq, y(0) = 0, (D(y))(0) = 0], y(x), numeric, range = 0 .. 3)
So, my question is, how can I determine the integral of the left side of deq1? ...
How do I keep Maple from changing the variable xi to the greek letter?
I have this differential equation:
deq := (diff(y(x), x, x))*y(x)-1+x*y(x)^2 = cos(x);
sol := dsolve({deq, y(0) = 1, (D(y))(0) = 1}, numeric);
After that I have a numerical solution for y, and for diff(y(x),x). But I would like to plot diff(y(x),x,x). (and then diff(y(x),x,x)+diff(y(x),x)*cos(x)). How can I do that?
Any help will be appreciated,
L
Hello there,  How can I compile this? I used   boundarycompiled := Compiler:-Compile(findboundary)    but this didnt work. Thanks in advance
> findboundary:=proc(a,b,c,d,e,f,g,h)  ;
> global A,B,lowerbound,upperbound;
> A, B := solve(a = b, x), solve(c = b, x);
> x1a, x1b := evalf(solve((x-e)^2+(a-f)^2-g^2)); if x1a < x1b then minx1, maxx1 := x1a, x1b else minx1, maxx1 := x1b, x1a end if;
> x2a, x2b := evalf(solve((x-e...
Hi. I have to solve the following differential equation numerically
f := [(diff(y(x), x))*(diff(y(x), x, x))/sqrt(y(x)^2+diff(y(x), x))+diff(y(x), x, x)] = x^6
dsolve({f, y(0) = 2, (D(y))(0) = 1.5, (D(D(y)))(0) = 1}, y(x), numeric, range = 0 .. 10)
Error, (in DEtools/convertsys) unable to convert to an explicit first-order system
I don't know what to do, I've read help and work on this for 3 days now.
Hey,
i am completely new in working with Maple. I spent the past 2 days to find a solution to my problem, but wasnt successfull.
Here is what i wanna do:
i have a function with 3 Variables and i wanna take the total derivative of this function.
Then i wanna know if the derivative is positiv or negative.
The only thing about the variables i know is that 2 of them are between 0 and 1, and the other variable...
I guess I should know this but what is the difference between a Matrix and an Array in Maple?
I've been given the relationship:
R*sqrt(sigma)-1-(1)/(4)*(l-(2*kappa*R^2)/(R*sqrt(sigma)))/(1+coth(R*sqrt(sigma)))-kappa*R^2/6+m/(2*R), for the particular case where m=l=0, and where
R=exp[(kappa*(R^2))/6]. On a sketch of R vs kappa, apparently sigma >0 on the lower branch, but there should be some sigma < 0 on the upper branch.
To attempt to solve this whole problem, I use the following commands:
restart;with(plots):
Please help plot solution of ODE in polar coords or tell how can i define a piecewise function that will make me able to plot the right and left side of singularities.
>sys1:=diff(r(t),t$2)=2*cos(teta(t))/r(t)^3,diff(teta(t),t$2)=sin(teta(t))/r(t)^3;funcs:=[r(t),teta(t)]:InC:=r(0)=1,teta(0)=15,D(r)(0)=0,D(teta)(0)=-2;
>FNUM:=dsolve({sys1,InC},numeric,funcs);
>odeplot(FNUM,funcs,t=0..230,numpoints=2000,coords=polar,view=[-20..20,-20..20]);
First 2005 2006 2007 2008 2009 2010 2011 Last Page 2007 of 2457
