Hi everyone,
I am trying to use a numerical solution calculated by maple as input for another differential equation (to be solved numerically also)
What I have now:
dsysT := {diff(nT(t),t)=-(F/V)*nT(t),nT(0)=nD0}:
dsnT := dsolve(dsysT,numeric);
dsysD := {diff(nD(t),t)=(F/V)*(nDi-nD(t))-nD(t)*<here should be the function from above>*sigma,nD(0)=nD0}:
dsnD := dsolve(dsysD,numeric);
I have a Maple pointplot3d animation and I'm looking to take out two segments of that plot.  The segments are known and are the same throughout the animation but I want to erase them from the plots.  I tried colouring them white but when you rotate it you can tell they were there, so I was wondering if there is a way of earsing them, or colouring them clear, or something to that effect.
I have been staring at my screan for an hour and cannot do the following.  I am sure it's trivial but I just can see it.  Please!
I´m a maple rookie and I need help to read in data from a text file. I´ve tried sscanf, readdata, readline but nothing works in a proper way.
My text file looks like that:
1 2 3 4 5 6
2 4 6 8 10 12
3 6 9 12 15 18
In MAPLE the data must look like this:
The first 3 values of the first line should be a vector p[1] := <1, 2, 3> the other values shoud be a vector n[1] := <4,5,6>
2nd line p[2] := <2,4,6> and n[2] := <8,10,12> and so on.
Please send me an example!
Hello Friends;! What a joy to be able to connect again!
I need your collaboration and guidance;
I have the following file, binary data, I need a graph on maple as an oscilloscope and perform a series of Fourier analysis
Download 9494_salida2.txt
View file details
I tried solving a set of 7 nonlinear equations but maple evaluates for about an hour and then says that "warning : solutions may have been lost " i dont have any clue why it is saying so.there are atleast 3 variables in my equations that are highly nonlinear(the others dont have exp term) like for ex K3 =
i want Maple to calculate this for me (0 <= a <= 1):
int(cosh(a*x)/cosh(x),x=0..infinity);
I know that there is a "nice" solution, best way to do this by hand is using contour integration in the complex plane, i think. But can Maple be of help here ?
Hello :),
Here is some code, and it returns an error : "too many levels of recursion".
X := 0;
while A <> 1
do
S := solve({X = .15*p*(1/2), L-X = .15*q*(1/2)}, [p, q]);
p := S[1];
q := S[2];
if (frac(p) <= 0.1e-1 AND frac(q) <= 0.1e-1) then A := 1 else X := X+0.1e-2 fi;
od;
Maybe, we can't do that this way, but i don't see easier way for the machine...
Thank you for your help !
Hello, I am trying to trace a phaseportrait of this system: sys:=D(x)(t)=-a*x(t)+b*y(t), D(y)(t)=-c*(p1*x(t)+q1*(x(t))^3)+V0*d*cos(2*Pi*10^(-4)*f*t); where a:=0.1785714286, b:=1, c:=20000, d:=10, V0 varies and f:=1273. For instance, lets take V0=4.08. I did the following procedure: >with(DEtools): with(plots): >p1:=0.18*10^(-5): q1:=0.12*10^(-5): >sys:=D(x)(t)=-a*x(t)+b*y(t), D(y)(t)=-c*(p1*x(t)+q1*(x(t))^3)+V0*d*cos(2*Pi*10^(-4)*f*t); >ic:=[[x(0)=-0.09,y(0)=-0.09],[x(0)=-0.09,y(0)=0.09],[x(0)=0.09,y(0)=-0.09],[x(0)=0.09,y(0)=0.09]];
I was trying to extend these www.mapleprimes.com/forum/probfunctioneasytaskfailed ideas to compute the ratio distribution function of two r.v.'s, something along these mathworld.wolfram.com/RatioDistribution.html lines. So how do I do that with Maple, say for the ratio of two independent zero-trancated Geometrical r.v.'s? Or how do I obtain with Maple the distribution of the reciprocal of such a random variable?Thanks.
Hi all, thanks for all the help so far. I have this nonlinear differential equation with boundary conditions. I have tried quite few ways but nothing has worked so far. x := diff(y(r), r, r)+2*(diff(y(r), r))/r+1.5*(16*4300)*Pi^2*10^6*sqrt(Pi/(2*0.128e-2^3))*polylog(3/2, exp(0.128e-2*(1194.3-y(r)))) = 0; boundary conditions: bc:= D(y)(0) = 0, y(infinity) = 0 Thanks in advance MS
Hi there, I don't find the right command that let's me plot parametrized curves in 3D. So lets say i wanna plot a srew fether, that is parametrized as follows: g: [0,10π] -> R³ : t -> g(t) = [cos(t),sin(t),] How do i do this? -.^
I would like to get to the numeric values that are calculated by creating a plot using implicitplot.
Any help or pointers are greatly appreciated.
M.
Windows Vista Home Premium+Maple 13+Maple toolbox for MATLAB 13+Matlab R2009a
Error Message: MATLAB not found!
First 2166 2167 2168 2169 2170 2171 2172 Last Page 2168 of 2472
