Hi, I am trying to make the solutions for a class that I am the TA for using Maple in Document Mode. Is there a way to show the steps for Gaussian Elimination easily? (I know I could copy the intermediate matrices from the Tutor, but I am trying to avoid doing that.) Thanks, Laura
Last week I asked about manipulating a Matrix into the form:
pts := [[x1,y1],[x2,y2]...[xn,yn]]
I was directed to use the zip function, which after some trial and error I have "successfully" done. The problem I am having (I think) is that I am using Maple9. Using the zip function as in the example:
I need to solve the heat diffusion equation in a system with two enclosed walls.  The first wall (made of a material called fr4) goes from x=0 o x=d1, and the second wall (made of copper, that is cu)from x=d1 to x=d2.
u(x,t) is my unknown (change of temperature with time and space) for the first wall, and v(x,t) the unknown for the second wall.
So the system of PDEs to solve is:
>PDE:=[ diff(u(x,t),t) = afr4*diff(diff(u(x,t),t) ,
I have a function in 2 variables - lets make it easy, the function is:
f(beta,c_0) = beta-6*beta*c_0+3*beta*c_0^2
I want to know in which regions this function has positive values and where it is negative. Tried it with the command contourplot, but this is not telling me anything :(.
Hope somebody can help
Thx
is there any way to solve a system like (d denotes the derivates):
f1(x1,x2,y1,y2)=0
f2(x1,x2,y1,y2)=0
dg1(x1,x2,y1,y2)/dy1=0
dg2(x1,x2,y1,y2)/dy2=0
Hi there, could someone help me plot zeta(0.5 + it) as seen here - en.wikipedia.org/wiki/File:Zeta_polar.svg
I assume I need to import some complex plot package?
This may have an annoyingly simple answer but I cannot seem to plot the prime counting function
with(numtheory):
plot(pi(x), x=0..100);
This just gives me an empty plot.  Any ideas?
I am very, very new to Maple and I know practically nothing. I have to create a number line, which I realize I use the plot command and x-axis, but that's about all I know. As an example, my professor gave "plot([[1,0],[5,0]],color=black,thickness=5);
Is it possible to export a Maple animation as a movie that can be inserted elsewhere like a PowerPoint presentation?  I know that I can export a "still frame" from an animation but I would like to export the entire movie.   Thanks.   David
f(x) = (a((ax+b)/(cx-a))+b)/(c((ax+b)/(cx-a))-a)
The homework assignment asked me to simplify this function. It turns out that I was able to simplify it all the way down to f(x) = x by hand. However, I cannot seem to get Maple to simplify it any further than the original problem. Any ideas? Thanks, Brandon
when a student or colleague attaches a .mw file to an e-mail....i have trouble opening it....when i try to i get this question "How do you want to open this text file?" with four options "Maple Text", "Plaintext," "Maple Input" and "Cancel".  it does not matter what I enter here....the worksheet appears empty.
i do not have any problem with .mws files as e-mail attachments.
pwh
I am trying to solve numerically the following equation :
Eq:={diff(u(x,t),t$2)-0.1*diff(u(x,t),x$2)+0.00001*diff(u(x,t),x$4)+0.1*diff(u(x,t),t$3)=0};
Here is my code :
restart;with(plots): with(PDEtools):
BC:={u(0,t)=0,u(1,t)=0,D[1](u)(0,t)=0,D[1](u)(1,t)=0};
I will really appreciate some help with assigning solutions of the solve command to names. For example, when I enter the command...
solve( [3x + 9y=10,8x-7y=20],[x,y])
I get the following output:
[[x=250/93, y=20/93]]
How can I extract the solutions and assign them to x and y which I want to use in subsequent calculations such as ...
sin(x) + sqrt (y)
I am solving a system of ODEs numerically, and then plotting the results over time. I would really like Maple to show me the equation behind the plotted graphs. Through my searches I have not been able to find the code for that. Any help would be greatly appreciated. For example, how do I see the equation for W(t)?
sol1a := dsolve([Eq1a, Eq2a, Eq3a, H(0) = 4879, W(0) = 105000, R(0) = 0], numeric, method = rosenbrock, output = listprocedure)
plots[odeplot](sol1a, [t, W(t)], t = 0 .. 40, color = blue, style = point);
I have a system of equations like this:
equation
and I wrote this equations into maple in this way:
eqns := [diff(x(t), t) = -x(t)-y(t), diff(y(t), t) = x(t)+.25*y(t)+r(t), diff(z(t), t) = 3+x(t)*z(t), diff(r(t), t) = .5*z(t)+0.5e-1*r]
using DEplot3d I tried to drawing attractor diagram:
First 2191 2192 2193 2194 2195 2196 2197 Last Page 2193 of 2457
