Hello, can anybody explain-me (or give-me a link about) the Maple default directory configuration. Specially the signification and difference between the terms: currentdir homedir (in kernelopts) UserDirectory (in maplesys.ini file) Thank-you
ok just trying to integrat something here
-[(tan(theta)) dtheta]/[sec(theta) (2cos(theta)-1)^(0.5) (1-cos(theta))] = (sqrt(Mgh/A)) t
and get to sec(theta) = 1 + sech (sqrt(Mgh/A)) t
any advice?
I have a simple acceleration/position problem that I can't figure out how to use piecewise to put into Maple --- can anyone assist?
Can we define dependencies of a variable after using the variable? For example, let us take,
f:=2*T+x^2;
Here, T has no dependencies. What should we do to make it dependent of x and y without redefining the whole thing as f:=2*T(x,y)+x^2;
and, can we do this for a whole matrix or vector?
Let us say that we have a code shown below:
with(DifferentialGeometry):
DGsetup([x,y],M):
e[1]:=A*ExteriorDerivative(x);
e[2]:=A*ExteriorDerivative(y);
simplify(e[1] &wedge e[1]+e[1] &wedge e[2]);
the output of this code is
How do I can generate eps figure from my maple calculation, in which expernal rectangular frame (solid lines) does not appear. I generate successfully the eps but I cannot remove the frame.
ok so i have the differnetial equation
[latex] \lambda^{2} (\frac{dx}{dt})^{2} = (cos{ \alpha} - x)(cos{ \beta} - x) [/latex]
where [latex] x = cos{ \theta} [/latex]
and the solution is
[latex] x = cos{ \alpha} sin^{2}{\frac{t}{2 \lambda}} + cos{ \beta} cos^{2}{\frac{t}{2 \lambda}} [/latex]
please show you're working cos that's where im getting lost
now i want to use maple to show this is the solution to the eqn.
how do i do this???
Hi to all,
I need to verify an multivariate equality in maple, here it goes:
Nr := 3 - cos(x - y) - cos( z - x) - cos(y - z);
Dr := (sin(x/2))^2 +  (sin(y/2))^2 + (sin(z/2))^2;
assume(x>0, x<Pi); assume(y>0,y<Pi); assume(z>0,z<Pi);
eqn := Nr/Dr;
I need to check whether eqn <= 6. I have tried
is(eqn > 6)  and is(eqn <=6) and both give FAIL as output. But if I change the denominator, Dr say Dr := Dr + 6;
Dear all:
hi!
I am trying to solve an ODE for w(x);
E - a parameter
MI - a parameter
w(x) - Transverse deflection
q(x) - Transverse force on the beam with respect to x
G - a parameter
A - a parameter
ap - a parameter
si - a parameter
mysol1 - differential equation to be solved with boundary conditions (bc1,bc2,bc3 and bc4) applied
Hi everybody,
I have a symbolic matrix (11x11) it is sparsely populated with components on the diagonal and 2 places either side.  When I have tried to calculate the [standar operations > nverse] (on a PC with Raid 0 and 4 Gb) Maple 12 stops running at 1883 Mb and complains about 'memory allocation?
Q1: how do I (inexperienced maple user) increase memory allocation?
Q2: when I tried to run a 5x5 matrix as a test a matrix wasn't returned, only a list of letters?
like (1+x)(1+2x)^2=(1+x)(1+4x+4x^2)
I think people can do that with Mathematica
How to make Maple simplify expression like
sqrt(  x^(2*a+2) )
to x^(a+1), where x is assumed positive?
The Maple's simplify works only if the constant 'a' is already assigned to a number, otherwise it refuses to simplify it, even if I tell it assume(x>0).
Ok,
I have read the previous questions/answers regarding exporting a matrix to excel.  It is not working.
I am running Maple 10 Standard, XP, and Excel 2003.  I have Maple as an Add-In on Excel.
When I select my Matrix, right click, my options for export are:  MatLab, Tab Delimited, Matrix Market.  I chose Tab Delimited, but I get the same response from any choice, and an error box appears saying, "Error Fetching RTable ID".  Any suggestions?
First 2241 2242 2243 2244 2245 2246 2247 Last Page 2243 of 2457
